Angel Pons has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/43237 )
Change subject: mb/gizmosphere/gizmo2: Drop dead code ......................................................................
This code is not even being build-tested. Drop it before it grows moss.
Change-Id: Icc3f9a4f71001547ef3d1efe6fc7551b5c690f92 Signed-off-by: Angel Pons th3fanbus@gmail.com --- M src/mainboard/gizmosphere/gizmo2/acpi/ide.asl M src/mainboard/gizmosphere/gizmo2/acpi/sata.asl M src/mainboard/gizmosphere/gizmo2/acpi/usb_oc.asl M src/mainboard/gizmosphere/gizmo2/bootblock.c 4 files changed, 0 insertions(+), 474 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/37/43237/1
diff --git a/src/mainboard/gizmosphere/gizmo2/acpi/ide.asl b/src/mainboard/gizmosphere/gizmo2/acpi/ide.asl index a1db5e9..c8d7172 100644 --- a/src/mainboard/gizmosphere/gizmo2/acpi/ide.asl +++ b/src/mainboard/gizmosphere/gizmo2/acpi/ide.asl @@ -1,233 +1,3 @@ /* SPDX-License-Identifier: GPL-2.0-only */
/* No IDE functionality */ - -#if 0 -/* -Scope (_SB) { - Device(PCI0) { - Device(IDEC) { - Name(_ADR, 0x00140001) - #include "ide.asl" - } - } -} -*/ - -/* Some timing tables */ -Name(UDTT, Package(){ /* Udma timing table */ - 120, 90, 60, 45, 30, 20, 15, 0 /* UDMA modes 0 -> 6 */ -}) - -Name(MDTT, Package(){ /* MWDma timing table */ - 480, 150, 120, 0 /* Legacy DMA modes 0 -> 2 */ -}) - -Name(POTT, Package(){ /* Pio timing table */ - 600, 390, 270, 180, 120, 0 /* PIO modes 0 -> 4 */ -}) - -/* Some timing register value tables */ -Name(MDRT, Package(){ /* MWDma timing register table */ - 0x77, 0x21, 0x20, 0xFF /* Legacy DMA modes 0 -> 2 */ -}) - -Name(PORT, Package(){ - 0x99, 0x47, 0x34, 0x22, 0x20, 0x99 /* PIO modes 0 -> 4 */ -}) - -OperationRegion(ICRG, PCI_Config, 0x40, 0x20) /* ide control registers */ - Field(ICRG, AnyAcc, NoLock, Preserve) -{ - PPTS, 8, /* Primary PIO Slave Timing */ - PPTM, 8, /* Primary PIO Master Timing */ - OFFSET(0x04), PMTS, 8, /* Primary MWDMA Slave Timing */ - PMTM, 8, /* Primary MWDMA Master Timing */ - OFFSET(0x08), PPCR, 8, /* Primary PIO Control */ - OFFSET(0x0A), PPMM, 4, /* Primary PIO master Mode */ - PPSM, 4, /* Primary PIO slave Mode */ - OFFSET(0x14), PDCR, 2, /* Primary UDMA Control */ - OFFSET(0x16), PDMM, 4, /* Primary UltraDMA Mode */ - PDSM, 4, /* Primary UltraDMA Mode */ -} - -Method(GTTM, 1) /* get total time*/ -{ - Store(And(Arg0, 0x0F), Local0) /* Recovery Width */ - Increment(Local0) - Store(ShiftRight(Arg0, 4), Local1) /* Command Width */ - Increment(Local1) - Return(Multiply(30, Add(Local0, Local1))) -} - -Device(PRID) -{ - Name (_ADR, Zero) - Method(_GTM, 0) - { - NAME(OTBF, Buffer(20) { /* out buffer */ - 0xFF, 0xFF, 0xFF, 0xFF, - 0xFF, 0xFF, 0xFF, 0xFF, - 0xFF, 0xFF, 0xFF, 0xFF, - 0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00 - }) - - CreateDwordField(OTBF, 0, PSD0) /* PIO spd0 */ - CreateDwordField(OTBF, 4, DSD0) /* DMA spd0 */ - CreateDwordField(OTBF, 8, PSD1) /* PIO spd1 */ - CreateDwordField(OTBF, 12, DSD1) /* DMA spd1 */ - CreateDwordField(OTBF, 16, BFFG) /* buffer flags */ - - /* Just return if the channel is disabled */ - If(And(PPCR, 0x01)) { /* primary PIO control */ - Return(OTBF) - } - - /* Always tell them independent timing available and IOChannelReady used on both drives */ - Or(BFFG, 0x1A, BFFG) - - /* save total time of primary PIO master timing to PIO spd0 */ - Store(GTTM(PPTM), PSD0) - /* save total time of primary PIO slave Timing to PIO spd1 */ - Store(GTTM(PPTS), PSD1) - - If(And(PDCR, 0x01)) { /* It's under UDMA mode */ - Or(BFFG, 0x01, BFFG) - Store(DerefOf(Index(UDTT, PDMM)), DSD0) - } - Else { - Store(GTTM(PMTM), DSD0) /* Primary MWDMA Master Timing, DmaSpd0 */ - } - - If(And(PDCR, 0x02)) { /* It's under UDMA mode */ - Or(BFFG, 0x04, BFFG) - Store(DerefOf(Index(UDTT, PDSM)), DSD1) - } - Else { - Store(GTTM(PMTS), DSD1) /* Primary MWDMA Slave Timing, DmaSpd0 */ - } - - Return(OTBF) /* out buffer */ - } /* End Method(_GTM) */ - - Method(_STM, 3, NotSerialized) - { - NAME(INBF, Buffer(20) { /* in buffer */ - 0xFF, 0xFF, 0xFF, 0xFF, - 0xFF, 0xFF, 0xFF, 0xFF, - 0xFF, 0xFF, 0xFF, 0xFF, - 0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00 - }) - - CreateDwordField(INBF, 0, PSD0) /* PIO spd0 */ - CreateDwordField(INBF, 4, DSD0) /* PIO spd0 */ - CreateDwordField(INBF, 8, PSD1) /* PIO spd1 */ - CreateDwordField(INBF, 12, DSD1) /* DMA spd1 */ - CreateDwordField(INBF, 16, BFFG) /*buffer flag */ - - Store(Match(POTT, MLE, PSD0, MTR, 0, 0), Local0) - Divide(Local0, 5, PPMM,) /* Primary PIO master Mode */ - Store(Match(POTT, MLE, PSD1, MTR, 0, 0), Local1) - Divide(Local1, 5, PPSM,) /* Primary PIO slave Mode */ - - Store(DerefOf(Index(PORT, Local0)), PPTM) /* Primary PIO Master Timing */ - Store(DerefOf(Index(PORT, Local1)), PPTS) /* Primary PIO Slave Timing */ - - If(And(BFFG, 0x01)) { /* Drive 0 is under UDMA mode */ - Store(Match(UDTT, MLE, DSD0, MTR, 0, 0), Local0) - Divide(Local0, 7, PDMM,) - Or(PDCR, 0x01, PDCR) - } - Else { - If(LNotEqual(DSD0, 0xFFFFFFFF)) { - Store(Match(MDTT, MLE, DSD0, MTR, 0, 0), Local0) - Store(DerefOf(Index(MDRT, Local0)), PMTM) - } - } - - If(And(BFFG, 0x04)) { /* Drive 1 is under UDMA mode */ - Store(Match(UDTT, MLE, DSD1, MTR, 0, 0), Local0) - Divide(Local0, 7, PDSM,) - Or(PDCR, 0x02, PDCR) - } - Else { - If(LNotEqual(DSD1, 0xFFFFFFFF)) { - Store(Match(MDTT, MLE, DSD1, MTR, 0, 0), Local0) - Store(DerefOf(Index(MDRT, Local0)), PMTS) - } - } - /* Return(INBF) */ - } /*End Method(_STM) */ - Device(MST) - { - Name(_ADR, 0) - Method(_GTF) { - Name(CMBF, Buffer(21) { - 0x03, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xEF, - 0x03, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xEF, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF5 - }) - CreateByteField(CMBF, 1, POMD) - CreateByteField(CMBF, 8, DMMD) - CreateByteField(CMBF, 5, CMDA) - CreateByteField(CMBF, 12, CMDB) - CreateByteField(CMBF, 19, CMDC) - - Store(0xA0, CMDA) - Store(0xA0, CMDB) - Store(0xA0, CMDC) - - Or(PPMM, 0x08, POMD) - - If(And(PDCR, 0x01)) { - Or(PDMM, 0x40, DMMD) - } - Else { - Store(Match - (MDTT, MLE, GTTM(PMTM), - MTR, 0, 0), Local0) - If(LLess(Local0, 3)) { - Or(0x20, Local0, DMMD) - } - } - Return(CMBF) - } - } /* End Device(MST) */ - - Device(SLAV) - { - Name(_ADR, 1) - Method(_GTF) { - Name(CMBF, Buffer(21) { - 0x03, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xEF, - 0x03, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xEF, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF5 - }) - CreateByteField(CMBF, 1, POMD) - CreateByteField(CMBF, 8, DMMD) - CreateByteField(CMBF, 5, CMDA) - CreateByteField(CMBF, 12, CMDB) - CreateByteField(CMBF, 19, CMDC) - - Store(0xB0, CMDA) - Store(0xB0, CMDB) - Store(0xB0, CMDC) - - Or(PPSM, 0x08, POMD) - - If(And(PDCR, 0x02)) { - Or(PDSM, 0x40, DMMD) - } - Else { - Store(Match - (MDTT, MLE, GTTM(PMTS), - MTR, 0, 0), Local0) - If(LLess(Local0, 3)) { - Or(0x20, Local0, DMMD) - } - } - Return(CMBF) - } - } /* End Device(SLAV) */ -} -#endif diff --git a/src/mainboard/gizmosphere/gizmo2/acpi/sata.asl b/src/mainboard/gizmosphere/gizmo2/acpi/sata.asl index f22d3df..659a076 100644 --- a/src/mainboard/gizmosphere/gizmo2/acpi/sata.asl +++ b/src/mainboard/gizmosphere/gizmo2/acpi/sata.asl @@ -1,133 +1,3 @@ /* SPDX-License-Identifier: GPL-2.0-only */
/* No SATA functionality */ - -#if 0 -/* -Scope (_SB) { - Device(PCI0) { - Device(SATA) { - Name(_ADR, 0x00110000) - #include "sata.asl" - } - } -} -*/ - -Name(STTM, Buffer(20) { - 0x78, 0x00, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x00, - 0x78, 0x00, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x00, - 0x1f, 0x00, 0x00, 0x00 -}) - -/* Start by clearing the PhyRdyChg bits */ -Method(_INI) { - _GPE._L1F() -} - -Device(PMRY) -{ - Name(_ADR, 0) - Method(_GTM, 0x0, NotSerialized) { - Return(STTM) - } - Method(_STM, 0x3, NotSerialized) {} - - Device(PMST) { - Name(_ADR, 0) - Method(_STA,0) { - if (LGreater(P0IS,0)) { - return (0x0F) /* sata is visible */ - } - else { - return (0x00) /* sata is missing */ - } - } - }/* end of PMST */ - - Device(PSLA) - { - Name(_ADR, 1) - Method(_STA,0) { - if (LGreater(P1IS,0)) { - return (0x0F) /* sata is visible */ - } - else { - return (0x00) /* sata is missing */ - } - } - } /* end of PSLA */ -} /* end of PMRY */ - -Device(SEDY) -{ - Name(_ADR, 1) /* IDE Scondary Channel */ - Method(_GTM, 0x0, NotSerialized) { - Return(STTM) - } - Method(_STM, 0x3, NotSerialized) {} - - Device(SMST) - { - Name(_ADR, 0) - Method(_STA,0) { - if (LGreater(P2IS,0)) { - return (0x0F) /* sata is visible */ - } - else { - return (0x00) /* sata is missing */ - } - } - } /* end of SMST */ - - Device(SSLA) - { - Name(_ADR, 1) - Method(_STA,0) { - if (LGreater(P3IS,0)) { - return (0x0F) /* sata is visible */ - } - else { - return (0x00) /* sata is missing */ - } - } - } /* end of SSLA */ -} /* end of SEDY */ - -/* SATA Hot Plug Support */ -Scope(_GPE) { - Method(_L1F,0x0,NotSerialized) { - if (_SB.P0PR) { - if (LGreater(_SB.P0IS,0)) { - sleep(32) - } - Notify(_SB.PCI0.STCR.PMRY.PMST, 0x01) /* NOTIFY_DEVICE_CHECK */ - store(one, _SB.P0PR) - } - - if (_SB.P1PR) { - if (LGreater(_SB.P1IS,0)) { - sleep(32) - } - Notify(_SB.PCI0.STCR.PMRY.PSLA, 0x01) /* NOTIFY_DEVICE_CHECK */ - store(one, _SB.P1PR) - } - - if (_SB.P2PR) { - if (LGreater(_SB.P2IS,0)) { - sleep(32) - } - Notify(_SB.PCI0.STCR.SEDY.SMST, 0x01) /* NOTIFY_DEVICE_CHECK */ - store(one, _SB.P2PR) - } - - if (_SB.P3PR) { - if (LGreater(_SB.P3IS,0)) { - sleep(32) - } - Notify(_SB.PCI0.STCR.SEDY.SSLA, 0x01) /* NOTIFY_DEVICE_CHECK */ - store(one, _SB.P3PR) - } - } -} -#endif diff --git a/src/mainboard/gizmosphere/gizmo2/acpi/usb_oc.asl b/src/mainboard/gizmosphere/gizmo2/acpi/usb_oc.asl index 168efff..a5846fe 100644 --- a/src/mainboard/gizmosphere/gizmo2/acpi/usb_oc.asl +++ b/src/mainboard/gizmosphere/gizmo2/acpi/usb_oc.asl @@ -1,15 +1,5 @@ /* SPDX-License-Identifier: GPL-2.0-only */
-/* simple name description */ -/* -#include <acpi/acpi.h> -DefinitionBlock ("DSDT.AML", "DSDT", 0x01, OEM_ID, ACPI_TABLE_CREATOR, 0x00010001 - ) - { - #include "usb.asl" - } -*/ - /* USB overcurrent mapping pins. */ Name(UOM0, 0) Name(UOM1, 2) @@ -21,95 +11,3 @@ Name(UOM7, 2) Name(UOM8, 6) Name(UOM9, 6) - -/* USB Overcurrent GPEs */ - -#if 0 /* TODO: Update */ -Method(UCOC, 0) { - Sleep(20) - Store(0x13,CMTI) - Store(0,GPSL) -} - -/* USB Port 0 overcurrent uses Gpm 0 */ -If(LLessEqual(UOM0,9)) { - Scope (_GPE) { - Method (_L13) { - } - } -} - -/* USB Port 1 overcurrent uses Gpm 1 */ -If (LLessEqual(UOM1,9)) { - Scope (_GPE) { - Method (_L14) { - } - } -} - -/* USB Port 2 overcurrent uses Gpm 2 */ -If (LLessEqual(UOM2,9)) { - Scope (_GPE) { - Method (_L15) { - } - } -} - -/* USB Port 3 overcurrent uses Gpm 3 */ -If (LLessEqual(UOM3,9)) { - Scope (_GPE) { - Method (_L16) { - } - } -} - -/* USB Port 4 overcurrent uses Gpm 4 */ -If (LLessEqual(UOM4,9)) { - Scope (_GPE) { - Method (_L19) { - } - } -} - -/* USB Port 5 overcurrent uses Gpm 5 */ -If (LLessEqual(UOM5,9)) { - Scope (_GPE) { - Method (_L1A) { - } - } -} - -/* USB Port 6 overcurrent uses Gpm 6 */ -If (LLessEqual(UOM6,9)) { - Scope (_GPE) { - /* Method (_L1C) { */ - Method (_L06) { - } - } -} - -/* USB Port 7 overcurrent uses Gpm 7 */ -If (LLessEqual(UOM7,9)) { - Scope (_GPE) { - /* Method (_L1D) { */ - Method (_L07) { - } - } -} - -/* USB Port 8 overcurrent uses Gpm 8 */ -If (LLessEqual(UOM8,9)) { - Scope (_GPE) { - Method (_L17) { - } - } -} - -/* USB Port 9 overcurrent uses Gpm 9 */ -If (LLessEqual(UOM9,9)) { - Scope (_GPE) { - Method (_L0E) { - } - } -} -#endif diff --git a/src/mainboard/gizmosphere/gizmo2/bootblock.c b/src/mainboard/gizmosphere/gizmo2/bootblock.c index bbc1d94..3fe9351 100644 --- a/src/mainboard/gizmosphere/gizmo2/bootblock.c +++ b/src/mainboard/gizmosphere/gizmo2/bootblock.c @@ -5,16 +5,4 @@
void bootblock_mainboard_early_init(void) { -#if 0 - volatile u32 i, val; - - /* LPC clock? Should happen before enable_serial. */ - - /* - * On Larne, after LpcClkDrvSth is set, it needs some time to be stable, - * because of the buffer ICS551M - */ - for (i = 0; i < 200000; i++) - val = inb(0xcd6); -#endif }
Michael Niewöhner has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43237 )
Patch Set 2: Code-Review+1
(2 comments)
https://review.coreboot.org/c/coreboot/+/43237/2/src/mainboard/gizmosphere/g... File src/mainboard/gizmosphere/gizmo2/acpi/ide.asl:
https://review.coreboot.org/c/coreboot/+/43237/2/src/mainboard/gizmosphere/g... PS2, Line 2: drop the whole file
https://review.coreboot.org/c/coreboot/+/43237/2/src/mainboard/gizmosphere/g... File src/mainboard/gizmosphere/gizmo2/acpi/sata.asl:
https://review.coreboot.org/c/coreboot/+/43237/2/src/mainboard/gizmosphere/g... PS2, Line 3: /* No SATA functionality */ drop the whole file
Hello build bot (Jenkins), Michael Niewöhner,
Change-Id: Icc3f9a4f71001547ef3d1efe6fc7551b5c690f92 Signed-off-by: Angel Pons th3fanbus@gmail.com --- D src/mainboard/gizmosphere/gizmo2/acpi/ide.asl M src/mainboard/gizmosphere/gizmo2/acpi/sata.asl M src/mainboard/gizmosphere/gizmo2/acpi/usb_oc.asl M src/mainboard/gizmosphere/gizmo2/bootblock.c 4 files changed, 0 insertions(+), 477 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/37/43237/3
Angel Pons has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43237 )
Patch Set 3:
(2 comments)
drop the whole file
Done
drop the whole file
src/southbridge/amd/agesa/hudson/acpi/fch.asl:26:11: fatal error: acpi/sata.asl: No such file or directory #include "acpi/sata.asl"
Patch Set 3: Code-Review+2
Angel Pons has submitted this change. ( https://review.coreboot.org/c/coreboot/+/43237 )
Change-Id: Icc3f9a4f71001547ef3d1efe6fc7551b5c690f92 Signed-off-by: Angel Pons th3fanbus@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/43237 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Michael Niewöhner --- D src/mainboard/gizmosphere/gizmo2/acpi/ide.asl M src/mainboard/gizmosphere/gizmo2/acpi/sata.asl M src/mainboard/gizmosphere/gizmo2/acpi/usb_oc.asl M src/mainboard/gizmosphere/gizmo2/bootblock.c 4 files changed, 0 insertions(+), 477 deletions(-)
Approvals: build bot (Jenkins): Verified Michael Niewöhner: Looks good to me, approved
diff --git a/src/mainboard/gizmosphere/gizmo2/acpi/ide.asl b/src/mainboard/gizmosphere/gizmo2/acpi/ide.asl deleted file mode 100644 index a1db5e9..0000000 --- a/src/mainboard/gizmosphere/gizmo2/acpi/ide.asl +++ /dev/null @@ -1,233 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only */ - -/* No IDE functionality */ - -#if 0 -/* -Scope (_SB) { - Device(PCI0) { - Device(IDEC) { - Name(_ADR, 0x00140001) - #include "ide.asl" - } - } -} -*/ - -/* Some timing tables */ -Name(UDTT, Package(){ /* Udma timing table */ - 120, 90, 60, 45, 30, 20, 15, 0 /* UDMA modes 0 -> 6 */ -}) - -Name(MDTT, Package(){ /* MWDma timing table */ - 480, 150, 120, 0 /* Legacy DMA modes 0 -> 2 */ -}) - -Name(POTT, Package(){ /* Pio timing table */ - 600, 390, 270, 180, 120, 0 /* PIO modes 0 -> 4 */ -}) - -/* Some timing register value tables */ -Name(MDRT, Package(){ /* MWDma timing register table */ - 0x77, 0x21, 0x20, 0xFF /* Legacy DMA modes 0 -> 2 */ -}) - -Name(PORT, Package(){ - 0x99, 0x47, 0x34, 0x22, 0x20, 0x99 /* PIO modes 0 -> 4 */ -}) - -OperationRegion(ICRG, PCI_Config, 0x40, 0x20) /* ide control registers */ - Field(ICRG, AnyAcc, NoLock, Preserve) -{ - PPTS, 8, /* Primary PIO Slave Timing */ - PPTM, 8, /* Primary PIO Master Timing */ - OFFSET(0x04), PMTS, 8, /* Primary MWDMA Slave Timing */ - PMTM, 8, /* Primary MWDMA Master Timing */ - OFFSET(0x08), PPCR, 8, /* Primary PIO Control */ - OFFSET(0x0A), PPMM, 4, /* Primary PIO master Mode */ - PPSM, 4, /* Primary PIO slave Mode */ - OFFSET(0x14), PDCR, 2, /* Primary UDMA Control */ - OFFSET(0x16), PDMM, 4, /* Primary UltraDMA Mode */ - PDSM, 4, /* Primary UltraDMA Mode */ -} - -Method(GTTM, 1) /* get total time*/ -{ - Store(And(Arg0, 0x0F), Local0) /* Recovery Width */ - Increment(Local0) - Store(ShiftRight(Arg0, 4), Local1) /* Command Width */ - Increment(Local1) - Return(Multiply(30, Add(Local0, Local1))) -} - -Device(PRID) -{ - Name (_ADR, Zero) - Method(_GTM, 0) - { - NAME(OTBF, Buffer(20) { /* out buffer */ - 0xFF, 0xFF, 0xFF, 0xFF, - 0xFF, 0xFF, 0xFF, 0xFF, - 0xFF, 0xFF, 0xFF, 0xFF, - 0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00 - }) - - CreateDwordField(OTBF, 0, PSD0) /* PIO spd0 */ - CreateDwordField(OTBF, 4, DSD0) /* DMA spd0 */ - CreateDwordField(OTBF, 8, PSD1) /* PIO spd1 */ - CreateDwordField(OTBF, 12, DSD1) /* DMA spd1 */ - CreateDwordField(OTBF, 16, BFFG) /* buffer flags */ - - /* Just return if the channel is disabled */ - If(And(PPCR, 0x01)) { /* primary PIO control */ - Return(OTBF) - } - - /* Always tell them independent timing available and IOChannelReady used on both drives */ - Or(BFFG, 0x1A, BFFG) - - /* save total time of primary PIO master timing to PIO spd0 */ - Store(GTTM(PPTM), PSD0) - /* save total time of primary PIO slave Timing to PIO spd1 */ - Store(GTTM(PPTS), PSD1) - - If(And(PDCR, 0x01)) { /* It's under UDMA mode */ - Or(BFFG, 0x01, BFFG) - Store(DerefOf(Index(UDTT, PDMM)), DSD0) - } - Else { - Store(GTTM(PMTM), DSD0) /* Primary MWDMA Master Timing, DmaSpd0 */ - } - - If(And(PDCR, 0x02)) { /* It's under UDMA mode */ - Or(BFFG, 0x04, BFFG) - Store(DerefOf(Index(UDTT, PDSM)), DSD1) - } - Else { - Store(GTTM(PMTS), DSD1) /* Primary MWDMA Slave Timing, DmaSpd0 */ - } - - Return(OTBF) /* out buffer */ - } /* End Method(_GTM) */ - - Method(_STM, 3, NotSerialized) - { - NAME(INBF, Buffer(20) { /* in buffer */ - 0xFF, 0xFF, 0xFF, 0xFF, - 0xFF, 0xFF, 0xFF, 0xFF, - 0xFF, 0xFF, 0xFF, 0xFF, - 0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00 - }) - - CreateDwordField(INBF, 0, PSD0) /* PIO spd0 */ - CreateDwordField(INBF, 4, DSD0) /* PIO spd0 */ - CreateDwordField(INBF, 8, PSD1) /* PIO spd1 */ - CreateDwordField(INBF, 12, DSD1) /* DMA spd1 */ - CreateDwordField(INBF, 16, BFFG) /*buffer flag */ - - Store(Match(POTT, MLE, PSD0, MTR, 0, 0), Local0) - Divide(Local0, 5, PPMM,) /* Primary PIO master Mode */ - Store(Match(POTT, MLE, PSD1, MTR, 0, 0), Local1) - Divide(Local1, 5, PPSM,) /* Primary PIO slave Mode */ - - Store(DerefOf(Index(PORT, Local0)), PPTM) /* Primary PIO Master Timing */ - Store(DerefOf(Index(PORT, Local1)), PPTS) /* Primary PIO Slave Timing */ - - If(And(BFFG, 0x01)) { /* Drive 0 is under UDMA mode */ - Store(Match(UDTT, MLE, DSD0, MTR, 0, 0), Local0) - Divide(Local0, 7, PDMM,) - Or(PDCR, 0x01, PDCR) - } - Else { - If(LNotEqual(DSD0, 0xFFFFFFFF)) { - Store(Match(MDTT, MLE, DSD0, MTR, 0, 0), Local0) - Store(DerefOf(Index(MDRT, Local0)), PMTM) - } - } - - If(And(BFFG, 0x04)) { /* Drive 1 is under UDMA mode */ - Store(Match(UDTT, MLE, DSD1, MTR, 0, 0), Local0) - Divide(Local0, 7, PDSM,) - Or(PDCR, 0x02, PDCR) - } - Else { - If(LNotEqual(DSD1, 0xFFFFFFFF)) { - Store(Match(MDTT, MLE, DSD1, MTR, 0, 0), Local0) - Store(DerefOf(Index(MDRT, Local0)), PMTS) - } - } - /* Return(INBF) */ - } /*End Method(_STM) */ - Device(MST) - { - Name(_ADR, 0) - Method(_GTF) { - Name(CMBF, Buffer(21) { - 0x03, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xEF, - 0x03, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xEF, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF5 - }) - CreateByteField(CMBF, 1, POMD) - CreateByteField(CMBF, 8, DMMD) - CreateByteField(CMBF, 5, CMDA) - CreateByteField(CMBF, 12, CMDB) - CreateByteField(CMBF, 19, CMDC) - - Store(0xA0, CMDA) - Store(0xA0, CMDB) - Store(0xA0, CMDC) - - Or(PPMM, 0x08, POMD) - - If(And(PDCR, 0x01)) { - Or(PDMM, 0x40, DMMD) - } - Else { - Store(Match - (MDTT, MLE, GTTM(PMTM), - MTR, 0, 0), Local0) - If(LLess(Local0, 3)) { - Or(0x20, Local0, DMMD) - } - } - Return(CMBF) - } - } /* End Device(MST) */ - - Device(SLAV) - { - Name(_ADR, 1) - Method(_GTF) { - Name(CMBF, Buffer(21) { - 0x03, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xEF, - 0x03, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xEF, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF5 - }) - CreateByteField(CMBF, 1, POMD) - CreateByteField(CMBF, 8, DMMD) - CreateByteField(CMBF, 5, CMDA) - CreateByteField(CMBF, 12, CMDB) - CreateByteField(CMBF, 19, CMDC) - - Store(0xB0, CMDA) - Store(0xB0, CMDB) - Store(0xB0, CMDC) - - Or(PPSM, 0x08, POMD) - - If(And(PDCR, 0x02)) { - Or(PDSM, 0x40, DMMD) - } - Else { - Store(Match - (MDTT, MLE, GTTM(PMTS), - MTR, 0, 0), Local0) - If(LLess(Local0, 3)) { - Or(0x20, Local0, DMMD) - } - } - Return(CMBF) - } - } /* End Device(SLAV) */ -} -#endif diff --git a/src/mainboard/gizmosphere/gizmo2/acpi/sata.asl b/src/mainboard/gizmosphere/gizmo2/acpi/sata.asl index f22d3df..659a076 100644 --- a/src/mainboard/gizmosphere/gizmo2/acpi/sata.asl +++ b/src/mainboard/gizmosphere/gizmo2/acpi/sata.asl @@ -1,133 +1,3 @@ /* SPDX-License-Identifier: GPL-2.0-only */
