Felix Singer has submitted this change. ( https://review.coreboot.org/c/coreboot/+/80056?usp=email )
Change subject: mb/purism/librem_cnl: Use chipset dt reference names ......................................................................
Use the references from the chipset devicetree as this makes the comments superfluous.
Change-Id: I87cec9026bcb621ceb7eae51f65ae35bc31d584a Signed-off-by: Felix Singer felixsinger@posteo.net Reviewed-on: https://review.coreboot.org/c/coreboot/+/80056 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Jonathon Hall jonathon.hall@puri.sm --- M src/mainboard/purism/librem_cnl/devicetree.cb M src/mainboard/purism/librem_cnl/variants/librem_14/overridetree.cb M src/mainboard/purism/librem_cnl/variants/librem_mini/overridetree.cb 3 files changed, 65 insertions(+), 65 deletions(-)
Approvals: Jonathon Hall: Looks good to me, approved build bot (Jenkins): Verified
diff --git a/src/mainboard/purism/librem_cnl/devicetree.cb b/src/mainboard/purism/librem_cnl/devicetree.cb index ff21977..3d26b09 100644 --- a/src/mainboard/purism/librem_cnl/devicetree.cb +++ b/src/mainboard/purism/librem_cnl/devicetree.cb @@ -44,58 +44,58 @@ device cpu_cluster 0 on end
device domain 0 on - device pci 00.0 on end # Host Bridge - device pci 02.0 on end # Integrated Graphics Device - device pci 04.0 on # SA Thermal device + device ref system_agent on end + device ref igpu on end + device ref dptf on register "Device4Enable" = "1" end - device pci 12.0 on end # Thermal Subsystem - device pci 13.0 off end # Integrated Sensor Hub - device pci 14.0 on end # USB xHC - device pci 14.1 off end # USB xDCI (OTG) - device pci 15.0 off end # I2C #0 - device pci 15.1 off end # I2C #1 - device pci 15.2 off end # I2C #2 - device pci 15.3 off end # I2C #3 - device pci 16.0 off end # Management Engine Interface 1 - device pci 16.1 off end # Management Engine Interface 2 - device pci 16.2 off end # Management Engine IDE-R - device pci 16.3 off end # Management Engine KT Redirection - device pci 16.4 off end # Management Engine Interface 3 - device pci 16.5 off end # Management Engine Interface 4 - device pci 17.0 on end # SATA - device pci 19.0 off end # I2C #4 - device pci 19.1 off end # I2C #5 - device pci 19.2 off end # UART #2 - device pci 1a.0 off end # eMMC - device pci 1c.0 off end # PCI Express Port 1 - device pci 1c.1 off end # PCI Express Port 2 - device pci 1c.2 off end # PCI Express Port 3 - device pci 1c.3 off end # PCI Express Port 4 - device pci 1c.4 off end # PCI Express Port 5 - device pci 1c.5 off end # PCI Express Port 6 - device pci 1c.6 off end # PCI Express Port 7 - device pci 1c.7 off end # PCI Express Port 8 - device pci 1d.0 off end # PCI Express Port 9 - device pci 1d.1 off end # PCI Express Port 10 - device pci 1d.2 off end # PCI Express Port 11 - device pci 1d.3 off end # PCI Express Port 12 - device pci 1d.4 off end # PCI Express Port 13 - device pci 1d.5 off end # PCI Express Port 14 - device pci 1d.6 off end # PCI Express Port 15 - device pci 1d.7 off end # PCI Express Port 16 - device pci 1e.0 off end # UART #0 - device pci 1e.1 off end # UART #1 - device pci 1e.2 off end # GSPI #0 - device pci 1e.3 off end # GSPI #1 - device pci 1f.0 on end # LPC Bridge - device pci 1f.1 off end # P2SB - device pci 1f.2 hidden end # Power Management Controller - device pci 1f.3 on # Intel HDA + device ref thermal on end + device ref ish off end + device ref xhci on end + device ref xdci off end + device ref i2c0 off end + device ref i2c1 off end + device ref i2c2 off end + device ref i2c3 off end + device ref heci1 off end + device ref heci2 off end + device ref csme_ider off end + device ref csme_ktr off end + device ref heci3 off end + device ref heci4 off end + device ref sata on end + device ref i2c4 off end + device ref i2c5 off end + device ref uart2 off end + device ref emmc off end + device ref pcie_rp1 off end + device ref pcie_rp2 off end + device ref pcie_rp3 off end + device ref pcie_rp4 off end + device ref pcie_rp5 off end + device ref pcie_rp6 off end + device ref pcie_rp7 off end + device ref pcie_rp8 off end + device ref pcie_rp9 off end + device ref pcie_rp10 off end + device ref pcie_rp11 off end + device ref pcie_rp12 off end + device ref pcie_rp13 off end + device ref pcie_rp14 off end + device ref pcie_rp15 off end + device ref pcie_rp16 off end + device ref uart0 off end + device ref uart1 off end + device ref gspi0 off end + device ref gspi1 off end + device ref lpc_espi on end + device ref p2sb off end + device ref pmc hidden end + device ref hda on register "PchHdaAudioLinkHda" = "1" end - device pci 1f.4 on end # SMBus - device pci 1f.5 on end # PCH SPI - device pci 1f.6 off end # GbE + device ref smbus on end + device ref fast_spi on end + device ref gbe off end end end diff --git a/src/mainboard/purism/librem_cnl/variants/librem_14/overridetree.cb b/src/mainboard/purism/librem_cnl/variants/librem_14/overridetree.cb index ef35ac0..b3fd862 100644 --- a/src/mainboard/purism/librem_cnl/variants/librem_14/overridetree.cb +++ b/src/mainboard/purism/librem_cnl/variants/librem_14/overridetree.cb @@ -24,7 +24,7 @@
# Actual device tree device domain 0 on - device pci 02.0 on # Integrated Graphics Device + device ref igpu on register "gfx" = "GMA_DEFAULT_PANEL(0)" register "panel_cfg" = "{ .up_delay_ms = 200, @@ -35,7 +35,7 @@ .backlight_off_delay_ms = 1, }" end - device pci 14.0 on # USB xHCI + device ref xhci on chip drivers/usb/acpi device usb 0.0 on chip drivers/usb/acpi @@ -131,8 +131,8 @@ register "usb3_ports[4]" = "USB3_PORT_DEFAULT(OC2)" # Type-C left register "usb3_ports[5]" = "USB3_PORT_DEFAULT(OC_SKIP)" # Card Reader end - device pci 14.1 off end # USB xDCI (OTG) - device pci 15.0 on # I2C #0 + device ref xdci off end + device ref i2c0 on chip drivers/i2c/hid register "generic.hid" = ""HTIX5288"" register "generic.name" = ""TPD0"" @@ -142,7 +142,7 @@ device i2c 2c on end end end - device pci 17.0 on # SATA + device ref sata on register "satapwroptimize" = "1" register "SataSalpSupport" = "1" # Port 2 (M.2 / inner) @@ -152,7 +152,7 @@ register "SataPortsEnable[2]" = "1" register "SataPortsDevSlp[2]" = "1" end - device pci 1c.6 on # PCI Express Port 7 -- x1 M.2/E 2230 (WLAN) + device ref pcie_rp7 on # x1 M.2/E 2230 (WLAN) register "PcieRpEnable[6]" = "1" register "PcieRpSlotImplemented[6]" = "1" register "PcieRpLtrEnable[6]" = "1" @@ -161,13 +161,13 @@ register "PcieClkSrcClkReq[2]" = "2" smbios_slot_desc "SlotTypeM2Socket1_SD" "SlotLengthOther" "M.2/E 2230" "SlotDataBusWidth1X" end - device pci 1c.7 on # PCI Express Port 8 + device ref pcie_rp8 on device pci 00.0 on end # x1 (LAN) register "PcieRpEnable[7]" = "1" register "PcieClkSrcUsage[3]" = "7" register "PcieClkSrcClkReq[3]" = "3" end - device pci 1d.0 on # PCI Express Port 9 -- x4 M.2/M 2280 (NVMe) + device ref pcie_rp9 on # x4 M.2/M 2280 (NVMe) register "PcieRpEnable[8]" = "1" register "PcieRpSlotImplemented[8]" = "1" register "PcieRpLtrEnable[8]" = "1" @@ -175,7 +175,7 @@ register "PcieClkSrcClkReq[0]" = "0" smbios_slot_desc "SlotTypeM2Socket3" "SlotLengthOther" "M.2/M 2280" "SlotDataBusWidth4X" end - device pci 1d.4 on # PCI Express Port 13 -- x4 M.2/M 2280 (NVMe) + device ref pcie_rp13 on # x4 M.2/M 2280 (NVMe) register "PcieRpEnable[12]" = "1" register "PcieRpSlotImplemented[12]" = "1" register "PcieRpLtrEnable[12]" = "1" @@ -183,7 +183,7 @@ register "PcieClkSrcClkReq[1]" = "1" smbios_slot_desc "SlotTypeM2Socket3" "SlotLengthOther" "M.2/M 2280" "SlotDataBusWidth4X" end - device pci 1f.0 on # LPC Bridge + device ref lpc_espi on # LPC configuration from lspci -s 1f.0 -xxx # Address 0x88: Decode 0x68 - 0x6F (EC PM channel) register "gen1_dec" = "0x00040069" diff --git a/src/mainboard/purism/librem_cnl/variants/librem_mini/overridetree.cb b/src/mainboard/purism/librem_cnl/variants/librem_mini/overridetree.cb index cab254a..f9baef2 100644 --- a/src/mainboard/purism/librem_cnl/variants/librem_mini/overridetree.cb +++ b/src/mainboard/purism/librem_cnl/variants/librem_mini/overridetree.cb @@ -20,7 +20,7 @@
# Actual device tree device domain 0 on - device pci 14.0 on # USB xHCI + device ref xhci on chip drivers/usb/acpi device usb 0.0 on chip drivers/usb/acpi @@ -123,12 +123,12 @@ register "usb3_ports[4]" = "USB3_PORT_DEFAULT(OC2)" # Type-A rear lower register "usb3_ports[5]" = "USB3_PORT_DEFAULT(OC2)" # Type-A rear upper end - device pci 17.0 on # SATA + device ref sata on register "SataPortsEnable[0]" = "1" # 2.5" register "SataPortsEnable[2]" = "1" # m.2 register "satapwroptimize" = "1" end - device pci 1c.7 on # PCI Express Port 8 -- x1 M.2/E 2230 (WLAN) + device ref pcie_rp8 on # x1 M.2/E 2230 (WLAN) register "PcieRpSlotImplemented[7]" = "1" register "PcieRpEnable[7]" = "1" register "PcieRpLtrEnable[7]" = "1" @@ -136,13 +136,13 @@ register "PcieClkSrcUsage[2]" = "0x80" smbios_slot_desc "SlotTypeM2Socket1_SD" "SlotLengthOther" "M.2/E 2230" "SlotDataBusWidth1X" end - device pci 1d.1 on # PCI Express Port 10 + device ref pcie_rp10 on device pci 00.0 on end # x1 (LAN) register "PcieRpEnable[9]" = "1" register "PcieClkSrcUsage[3]" = "9" register "PcieClkSrcClkReq[3]" = "3" end - device pci 1d.4 on # PCI Express Port 13 -- x4 M.2/M 2280 (NVMe) + device ref pcie_rp13 on # x4 M.2/M 2280 (NVMe) register "PcieRpSlotImplemented[12]" = "1" register "PcieRpEnable[12]" = "1" register "PcieRpLtrEnable[12]" = "1" @@ -150,7 +150,7 @@ register "PcieClkSrcClkReq[1]" = "1" smbios_slot_desc "SlotTypeM2Socket3" "SlotLengthOther" "M.2/M 2280" "SlotDataBusWidth4X" end - device pci 1f.0 on # LPC Bridge + device ref lpc_espi on chip superio/ite/it8528e device pnp 2e.1 on # UART1 io 0x60 = 0x3F8
