Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/76662?usp=email )
Change subject: mb/google/nissa/var/craaskov: Add overridetree ......................................................................
Add override devicetree based on schematics(ver. 20230714).
BUG=b:290248526 BRANCH=firmware-nissa-15217.B TEST=emerge-nissa coreboot
Change-Id: Id002282d91dc94b00f5d133203b62ca39d6cae6d Signed-off-by: Rex Chou rex_chou@compal.corp-partner.google.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/76662 Reviewed-by: Sumeet R Pawnikar sumeet.r.pawnikar@intel.com Reviewed-by: Derek Huang derekhuang@google.com Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/mainboard/google/brya/variants/craaskov/overridetree.cb 1 file changed, 226 insertions(+), 1 deletion(-)
Approvals: Sumeet R Pawnikar: Looks good to me, approved Derek Huang: Looks good to me, approved build bot (Jenkins): Verified
diff --git a/src/mainboard/google/brya/variants/craaskov/overridetree.cb b/src/mainboard/google/brya/variants/craaskov/overridetree.cb index 4f2c04a..cd020a5 100644 --- a/src/mainboard/google/brya/variants/craaskov/overridetree.cb +++ b/src/mainboard/google/brya/variants/craaskov/overridetree.cb @@ -1,6 +1,231 @@ chip soc/intel/alderlake + register "sagv" = "SaGv_Enabled"
- device domain 0 on + # Bit 0 - C0 has no redriver, so enable SBU muxing in the SoC. + # Bit 2 - C1 has a redriver which does SBU muxing. + # Bit 1,3 - AUX lines are not swapped on the motherboard for either C0 or C1. + register "tcss_aux_ori" = "1" + + register "typec_aux_bias_pads[0]" = "{.pad_auxp_dc = GPP_E22, .pad_auxn_dc = GPP_E23}" + + # Intel Common SoC Config + #+-------------------+---------------------------+ + #| Field | Value | + #+-------------------+---------------------------+ + #| I2C0 | TPM. Early init is | + #| | required to set up a BAR | + #| | for TPM communication | + #| I2C1 | Touchscreen | + #| I2C2 | TOF/ALS | + #| I2C3 | Audio | + #| I2C5 | Trackpad | + #+-------------------+---------------------------+ + register "common_soc_config" = "{ + .i2c[0] = { + .early_init = 1, + .speed = I2C_SPEED_FAST_PLUS, + .speed_config[0] = { + .speed = I2C_SPEED_FAST_PLUS, + .scl_lcnt = 55, + .scl_hcnt = 30, + .sda_hold = 7, + } + }, + .i2c[1] = { + .speed = I2C_SPEED_FAST, + .speed_config[0] = { + .speed = I2C_SPEED_FAST, + .scl_lcnt = 158, + .scl_hcnt = 79, + .sda_hold = 7, + } + }, + .i2c[2] = { + .speed = I2C_SPEED_FAST, + .speed_config[0] = { + .speed = I2C_SPEED_FAST, + .scl_lcnt = 158, + .scl_hcnt = 79, + .sda_hold = 7, + } + }, + .i2c[3] = { + .speed = I2C_SPEED_FAST, + .speed_config[0] = { + .speed = I2C_SPEED_FAST, + .scl_lcnt = 158, + .scl_hcnt = 79, + .sda_hold = 7, + } + }, + .i2c[5] = { + .speed = I2C_SPEED_FAST, + .speed_config[0] = { + .speed = I2C_SPEED_FAST, + .scl_lcnt = 158, + .scl_hcnt = 79, + .sda_hold = 7, + } + }, + }" + + register "usb2_ports[1]" = "USB2_PORT_EMPTY" # Disable USB2 Port 2 + register "usb2_ports[4]" = "USB2_PORT_EMPTY" # Disable USB2 Port 5 + register "usb2_ports[6]" = "USB2_PORT_EMPTY" # Disable USB2 Port 7 + register "usb2_ports[7]" = "USB2_PORT_MID(OC_SKIP)" # Bluetooth port for CNVi WLAN + register "usb2_ports[9]" = "USB2_PORT_MID(OC_SKIP)" # Bluetooth port for CNVi WLAN + + device domain 0 on + device ref i2c1 on + chip drivers/i2c/hid + register "generic.hid" = ""ELAN9004"" + register "generic.desc" = ""ELAN Touchscreen"" + register "generic.irq" = "ACPI_IRQ_LEVEL_LOW(GPP_C7_IRQ)" + register "generic.probed" = "1" + register "generic.reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_C1)" + register "generic.reset_delay_ms" = "20" + register "generic.reset_off_delay_ms" = "2" + register "generic.enable_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_C0)" + register "generic.enable_delay_ms" = "1" + register "generic.stop_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_C6)" + register "generic.stop_delay_ms" = "150" + register "generic.stop_off_delay_ms" = "2" + register "generic.has_power_resource" = "1" + register "hid_desc_reg_offset" = "0x01" + device i2c 10 on end + end + end #I2C1 + device ref i2c3 on + chip drivers/i2c/generic + register "hid" = ""10EC5650"" + register "name" = ""RT58"" + register "desc" = ""Realtek RT5650"" + register "irq_gpio" = "ACPI_GPIO_IRQ_EDGE_BOTH(GPP_A23)" + register "property_count" = "1" + register "property_list[0].type" = "ACPI_DP_TYPE_INTEGER" + register "property_list[0].name" = ""realtek,jd-mode"" + register "property_list[0].integer" = "2" + device i2c 1a on end + end + end #I2C3 + device ref i2c5 on + chip drivers/i2c/generic + register "hid" = ""ELAN0000"" + register "desc" = ""ELAN Touchpad"" + register "irq" = "ACPI_IRQ_WAKE_LEVEL_LOW(GPP_F14_IRQ)" + register "wake" = "GPE0_DW2_14" + register "detect" = "1" + device i2c 15 on end + end + chip drivers/i2c/hid + register "generic.hid" = ""SYNA0000"" + register "generic.cid" = ""ACPI0C50"" + register "generic.desc" = ""Synaptics Touchpad"" + register "generic.irq" = "ACPI_IRQ_WAKE_LEVEL_LOW(GPP_F14_IRQ)" + register "generic.wake" = "GPE0_DW2_14" + register "generic.detect" = "1" + register "hid_desc_reg_offset" = "0x20" + device i2c 2c on end + end + end + device ref pcie_rp7 off end + device ref cnvi_wifi on + chip drivers/wifi/generic + register "wake" = "GPE0_PME_B0" + register "enable_cnvi_ddr_rfim" = "true" + register "add_acpi_dma_property" = "true" + device generic 0 on end + end + end + device ref pch_espi on + chip ec/google/chromeec + use conn0 as mux_conn[0] + device pnp 0c09.0 on end + end + end + device ref pmc hidden + chip drivers/intel/pmc_mux + device generic 0 on + chip drivers/intel/pmc_mux/conn + use usb2_port1 as usb2_port + use tcss_usb3_port1 as usb3_port + device generic 0 alias conn0 on end + end + end + end + end + device ref tcss_xhci on + chip drivers/usb/acpi + device ref tcss_root_hub on + chip drivers/usb/acpi + register "desc" = ""USB3 Type-C Port C0 (MLB)"" + register "type" = "UPC_TYPE_C_USB2_SS_SWITCH" + register "use_custom_pld" = "true" + register "custom_pld" = "ACPI_PLD_TYPE_C(LEFT, LEFT, ACPI_PLD_GROUP(1, 1))" + device ref tcss_usb3_port1 on end + end + end + end + end + device ref xhci on + chip drivers/usb/acpi + device ref xhci_root_hub on + chip drivers/usb/acpi + register "desc" = ""USB2 Type-C Port C0 (MLB)"" + register "type" = "UPC_TYPE_C_USB2_SS_SWITCH" + register "use_custom_pld" = "true" + register "custom_pld" = "ACPI_PLD_TYPE_C(LEFT, LEFT, ACPI_PLD_GROUP(1, 1))" + device ref usb2_port1 on end + end + chip drivers/usb/acpi + register "desc" = ""USB2 Type-A Port A0 (DB)"" + register "type" = "UPC_TYPE_A" + register "use_custom_pld" = "true" + register "custom_pld" = "ACPI_PLD_TYPE_A(LEFT, RIGHT, ACPI_PLD_GROUP(3, 1))" + device ref usb2_port3 on end + end + chip drivers/usb/acpi + register "desc" = ""USB2 Type-A Port A1 (DB)"" + register "type" = "UPC_TYPE_A" + register "use_custom_pld" = "true" + register "custom_pld" = "ACPI_PLD_TYPE_A(RIGHT, LEFT, ACPI_PLD_GROUP(4, 1))" + device ref usb2_port4 on end + end + chip drivers/usb/acpi + register "desc" = ""USB2 Camera"" + register "type" = "UPC_TYPE_INTERNAL" + device ref usb2_port6 on end + end + chip drivers/usb/acpi + register "desc" = ""USB2 Bluetooth"" + register "type" = "UPC_TYPE_INTERNAL" + register "reset_gpio" = + "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_D4)" + device ref usb2_port8 on end + end + chip drivers/usb/acpi + register "desc" = ""USB2 Bluetooth"" + register "type" = "UPC_TYPE_INTERNAL" + register "reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_D4)" + device ref usb2_port10 on end + end + chip drivers/usb/acpi + register "desc" = ""USB3 Type-A Port A0 (MLB)"" + register "type" = "UPC_TYPE_USB3_A" + register "use_custom_pld" = "true" + register "custom_pld" = "ACPI_PLD_TYPE_A(LEFT, RIGHT, ACPI_PLD_GROUP(3, 1))" + device ref usb3_port1 on end + end + chip drivers/usb/acpi + register "desc" = ""USB3 Type-A Port A1 (DB)"" + register "type" = "UPC_TYPE_USB3_A" + register "use_custom_pld" = "true" + register "custom_pld" = "ACPI_PLD_TYPE_A(RIGHT, LEFT, ACPI_PLD_GROUP(4, 1))" + device ref usb3_port2 on end + end + end + end + end end
end
