Attention is currently required from: Hung-Te Lin, Liju-Clr Chen, Yidi Lin, Yu-Ping Wu.
Hello Hung-Te Lin, Rex-BC Chen, Yidi Lin, Yu-Ping Wu,
https://review.coreboot.org/c/coreboot/+/69432
Change subject: mb/google/geralt: Fix incorrect timestamps in the eventlog ......................................................................
Timestamp '2000-00-00 00:00:00' is considered as the invalid format. Enable RTC to fix incorrect timestamp format in the eventlog.
localhost ~ # head /var/log/eventlog.txt 0 | 2022-10-15 22:59:38 | Log area cleared | 4088 1 | 2022-10-15 22:59:38 | Memory Cache Update | Normal | Success 2 | 2022-10-15 22:59:45 | System boot | 0 3 | 2022-10-15 22:59:46 | Firmware vboot info | boot_mode=Developer | fw_tried=A | fw_try_count=0 | fw_prev_tried=A | fw_prev_result=Unknown localhost ~ # localhost ~ # date Sun Oct 16 01:42:59 PDT 2022 localhost ~ #
BUG=b:233720142 TEST=check the timestamp field in /var/log/eventlog.txt
Change-Id: Iddad102dc8d60de01a691d330deb8247e99c616a Signed-off-by: Liju-Clr Chen liju-clr.chen@mediatek.com --- M src/mainboard/google/geralt/Kconfig M src/soc/mediatek/mt8188/Makefile.inc 2 files changed, 29 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/32/69432/3
