Arthur Heymans has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/31600
Change subject: [UNTESTED]cpu/intel/model_1067x/mp_init: Implement get_microcode_info ......................................................................
Fixes microcode not being updated.
Change-Id: Iee7a3897362b63bc6d7b9827da47c1cb24135278 Signed-off-by: Arthur Heymans arthur@aheymans.xyz --- M src/cpu/intel/model_1067x/mp_init.c 1 file changed, 8 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/00/31600/1
diff --git a/src/cpu/intel/model_1067x/mp_init.c b/src/cpu/intel/model_1067x/mp_init.c index acd56c8..1a6110b 100644 --- a/src/cpu/intel/model_1067x/mp_init.c +++ b/src/cpu/intel/model_1067x/mp_init.c @@ -49,6 +49,13 @@ smm_initialize(); }
+static void get_microcode_info(const void **microcode, int *parallel) +{ + microcode_patch = intel_microcode_find(); + *microcode = microcode_patch; + *parallel = 1; +} + #define SMRR_SUPPORTED (1 << 11)
static void per_cpu_smm_trigger(void) @@ -98,6 +105,7 @@ .pre_mp_init = pre_mp_init, .get_cpu_count = get_cpu_count, .get_smm_info = smm_info, + .get_microcode_info = get_microcode_info, .pre_mp_smm_init = pre_mp_smm_init, .per_cpu_smm_trigger = per_cpu_smm_trigger, .relocation_handler = smm_relocation_handler,
Angel Pons has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/31600 )
Patch Set 1:
Will test on G41M-S3 with a Pentium E5200 or something model_1067x
Arthur Heymans has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/31600 )
Patch Set 1:
Patch Set 1:
This code is used for model_fxx, model_6ex and model_6fx too.
Nico Huber has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/31600 )
Patch Set 1:
The former have the update already applied early on the BSP, right?
Patch Set 1:
Also, just noticed, f3x seems to have some `!IS_ENABLED( CONFIG_PARALLEL_MP)` left, that is unreachable now? Or is it still used?
It's only selected by LGA775 and that only together with X4X/I945, AFAICS.
Patch Set 1:
Patch Set 1:
There is some code to update the BSP microcode in the CAR setup, https://review.coreboot.org/c/coreboot/+/30775 but currently it is not done.
Patch Set 1:
Patch Set 1:
I must have missed that... That CPU is not used by non-LGA775 anymore so that code can indeed be removed.
Paul Menzel has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/31600 )
Patch Set 1:
Is that a regression, or were microcode updates never applied by coreboot with these processors?
Patch Set 1:
Patch Set 1:
This fixes a regression indeed.
Masanori Ogino has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/31600 )
Patch Set 1: Code-Review+1
Tested on X60s (Core Solo U1300) with SeaBIOS, Linux 4.19.0 (Debian Buster) boots successfully and the microcode is loaded without OS's microcode package installed.
Patch Set 1:
Patch Set 1:
Could you please update the commit message accordingly?
Patch Set 1:
Complete fix and confirmed working: CB:31664
Patch Set 1: -Code-Review
Arthur Heymans has abandoned this change. ( https://review.coreboot.org/c/coreboot/+/31600 )
Abandoned
