Stefan Reinauer (stefan.reinauer@coreboot.org) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/10012
commit 92d6d7ec297a164632c01b8debd868f1916ecaba Author: Stefan Reinauer reinauer@chromium.org Date: Mon Apr 27 13:40:16 2015 -0700
cpu/x86: Kconfig cleanups
Sort some Kconfig options
Change-Id: I25ea327ed151e18ccb5d13626d44925d2a253d08 Signed-off-by: Stefan Reinauer stefan.reinauer@coreboot.org --- src/cpu/x86/Kconfig | 23 ++++++++++++++--------- 1 file changed, 14 insertions(+), 9 deletions(-)
diff --git a/src/cpu/x86/Kconfig b/src/cpu/x86/Kconfig index 94225a3..d8f338d 100644 --- a/src/cpu/x86/Kconfig +++ b/src/cpu/x86/Kconfig @@ -1,7 +1,16 @@ +# TODO These two options look too similar config PARALLEL_CPU_INIT bool default n
+config PARALLEL_MP + def_bool n + help + This option uses common MP infrastructure for bringing up APs + in parallel. It additionally provides a more flexible mechanism + for sequencing the steps of bringing up the APs. + + config UDELAY_IO bool default y if !UDELAY_LAPIC && !UDELAY_TSC && !UDELAY_TIMER2 @@ -39,11 +48,14 @@ config TSC_MONOTONIC_TIMER help Expose monotonic time using the TSC.
-config UDELAY_TIMER2 +# This option is used in code but never selected. +config TSC_CALIBRATE_WITH_IO bool + depends on UDELAY_TSC default n
-config TSC_CALIBRATE_WITH_IO +# This option is used in code but never selected. +config UDELAY_TIMER2 bool default n
@@ -121,13 +133,6 @@ config PLATFORM_USES_FSP1_0 Selected for Intel processors/platform combinations that use the Intel Firmware Support Package (FSP) 1.0 for initialization.
-config PARALLEL_MP - def_bool n - help - This option uses common MP infrastructure for bringing up APs - in parallel. It additionally provides a more flexible mechanism - for sequencing the steps of bringing up the APs. - config BACKUP_DEFAULT_SMM_REGION def_bool n help
