Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/60024 )
Change subject: soc/amd/{cezanne,common}: Add PSP_S0I3_RESUME_VERSTAGE Kconfig option ......................................................................
Add PSP_S0I3_RESUME_VERSTAGE Kconfig option. When enabled, verstage will be run in PSP during S0i3 resume. Setting softfuse bit 40 enables this in PSP.
BUG=b:200578885, b:202397678 BRANCH=None TEST=Verstage runs during s0i3 resume on Nipperkin
Change-Id: I2c185f787c1e77bd09f6cbbb1f47deb665ed0c79 Signed-off-by: Rob Barnes robbarnes@google.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/60024 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Karthik Ramasubramanian kramasub@google.com Reviewed-by: Raul Rangel rrangel@chromium.org --- M src/soc/amd/cezanne/Makefile.inc M src/soc/amd/common/psp_verstage/Kconfig 2 files changed, 13 insertions(+), 2 deletions(-)
Approvals: build bot (Jenkins): Verified Raul Rangel: Looks good to me, approved Karthik Ramasubramanian: Looks good to me, approved
diff --git a/src/soc/amd/cezanne/Makefile.inc b/src/soc/amd/cezanne/Makefile.inc index 58df740..a05da8d 100644 --- a/src/soc/amd/cezanne/Makefile.inc +++ b/src/soc/amd/cezanne/Makefile.inc @@ -110,6 +110,10 @@ PSP_SOFTFUSE_BITS += 29 endif
+ifeq ($(CONFIG_PSP_S0I3_RESUME_VERSTAGE),y) +PSP_SOFTFUSE_BITS += 40 +endif + # Use additional Soft Fuse bits specified in Kconfig PSP_SOFTFUSE_BITS += $(call strip_quotes, $(CONFIG_PSP_SOFTFUSE_BITS))
diff --git a/src/soc/amd/common/psp_verstage/Kconfig b/src/soc/amd/common/psp_verstage/Kconfig index 6cac8b7..45a5d22 100644 --- a/src/soc/amd/common/psp_verstage/Kconfig +++ b/src/soc/amd/common/psp_verstage/Kconfig @@ -6,10 +6,17 @@ accessing the boot device. Select it on platforms which supports using CCP DMA to access the boot device.
+config PSP_S0I3_RESUME_VERSTAGE + bool "S0i3 resume verstage" + depends on VBOOT_STARTS_BEFORE_BOOTBLOCK + default n + help + Select this item to enable running verstage during S0i3 resume. + config PSP_INIT_TPM_ON_S0I3_RESUME bool - depends on TPM2 && VBOOT_STARTS_BEFORE_BOOTBLOCK - default VBOOT_STARTS_BEFORE_BOOTBLOCK + depends on TPM2 && PSP_S0I3_RESUME_VERSTAGE + default PSP_S0I3_RESUME_VERSTAGE help If the TPM is reset while in S0i3, it must be reinitialized during s0i3 resume. This must be performed in PSP verstage since
