Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/50658 )
Change subject: mb/lippert/frontrunner-af: Use common cpu/ and nb/ ASL files ......................................................................
There are no quad-core CPU models with fam14, _SB.C002 and .C003 get removed from ASL.
Change-Id: I96df5b3f93c2dd6a05d5693069b991ca01f71d73 Signed-off-by: Kyösti Mälkki kyosti.malkki@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/50658 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Angel Pons th3fanbus@gmail.com --- M src/mainboard/lippert/frontrunner-af/dsdt.asl 1 file changed, 4 insertions(+), 112 deletions(-)
diff --git a/src/mainboard/lippert/frontrunner-af/dsdt.asl b/src/mainboard/lippert/frontrunner-af/dsdt.asl index 1839b64..5f834fc 100644 --- a/src/mainboard/lippert/frontrunner-af/dsdt.asl +++ b/src/mainboard/lippert/frontrunner-af/dsdt.asl @@ -13,29 +13,7 @@ { /* Start of ASL file */ #include <acpi/dsdt_top.asl>
- - /* - * Processor Object - * - */ - Scope (_SB) { /* define processor scope */ - Device (C000) { - Name (_HID, "ACPI0007") - Name (_UID, 0) - } - Device (C001) { - Name (_HID, "ACPI0007") - Name (_UID, 1) - } - Device (C002) { - Name (_HID, "ACPI0007") - Name (_UID, 2) - } - Device (C003) { - Name (_HID, "ACPI0007") - Name (_UID, 3) - } - } /* End _SB scope */ + #include <cpu/amd/agesa/family14/acpi/cpu.asl>
#include <southbridge/amd/cimx/sb800/acpi/misc_io.asl>
@@ -58,10 +36,9 @@ /* _SB.PCI0 */ /* Note: Only need HID on Primary Bus */ Device(PCI0) { - External (TOM1) - External (TOM2) - Name(_HID, EISAID("PNP0A08")) /* PCI Express Root Bridge */ - Name(_CID, EISAID("PNP0A03")) /* PCI Root Bridge */ + + /* Describe the AMD Northbridge */ + #include <northbridge/amd/agesa/family14/acpi/northbridge.asl>
/* Operating System Capabilities Method */ Method (_OSC, 4) @@ -93,91 +70,6 @@ Return (PR0) /* PIC Mode */ } /* end _PRT */
- /* Describe the Northbridge devices */ - Device(AMRT) { - Name(_ADR, 0x00000000) - } /* end AMRT */ - - /* The internal GFX bridge */ - Device(AGPB) { - Name(_ADR, 0x00010000) - Name(_PRW, Package() {0x18, 4}) - Method(_PRT,0) { - Return (APR1) - } - } /* end AGPB */ - - /* Dev 2 & 3 are external GFX bridges, not used in Family14 */ - - Device(PBR4) { - Name(_ADR, 0x00040000) - Name(_PRW, Package() {0x18, 4}) - Method(_PRT,0) { - If(PICM){ Return(APS4) } /* APIC mode */ - Return (PS4) /* PIC Mode */ - } /* end _PRT */ - } /* end PBR4 */ - - Device(PBR5) { - Name(_ADR, 0x00050000) - Name(_PRW, Package() {0x18, 4}) - Method(_PRT,0) { - If(PICM){ Return(APS5) } /* APIC mode */ - Return (PS5) /* PIC Mode */ - } /* end _PRT */ - } /* end PBR5 */ - - Device(PBR6) { - Name(_ADR, 0x00060000) - Name(_PRW, Package() {0x18, 4}) - Method(_PRT,0) { - If(PICM){ Return(APS6) } /* APIC mode */ - Return (PS6) /* PIC Mode */ - } /* end _PRT */ - } /* end PBR6 */ - - /* The onboard EtherNet chip */ - Device(PBR7) { - Name(_ADR, 0x00070000) - Name(_PRW, Package() {0x18, 4}) - Method(_PRT,0) { - If(PICM){ Return(APS7) } /* APIC mode */ - Return (PS7) /* PIC Mode */ - } /* end _PRT */ - } /* end PBR7 */ - - Device(PE20) { - Name(_ADR, 0x00150000) - Name(_PRW, Package() {0x18, 4}) - Method(_PRT,0) { - If(PICM){ Return(APE0) } /* APIC mode */ - Return (PE0) /* PIC Mode */ - } /* end _PRT */ - } /* end PE20 */ - Device(PE21) { - Name(_ADR, 0x00150001) - Name(_PRW, Package() {0x18, 4}) - Method(_PRT,0) { - If(PICM){ Return(APE1) } /* APIC mode */ - Return (PE1) /* PIC Mode */ - } /* end _PRT */ - } /* end PE21 */ - Device(PE22) { - Name(_ADR, 0x00150002) - Name(_PRW, Package() {0x18, 4}) - Method(_PRT,0) { - If(PICM){ Return(APE2) } /* APIC mode */ - Return (APE2) /* PIC Mode */ - } /* end _PRT */ - } /* end PE22 */ - Device(PE23) { - Name(_ADR, 0x00150003) - Name(_PRW, Package() {0x18, 4}) - Method(_PRT,0) { - If(PICM){ Return(APE3) } /* APIC mode */ - Return (PE3) /* PIC Mode */ - } /* end _PRT */ - } /* end PE23 */
/* Describe the Southbridge devices */
4 is the latest approved patch-set. No files were changed between the latest approved patch-set and the submitted one.
