Patrick Georgi (pgeorgi@google.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/13690
commit 37279c1b8268517c25bb04c606af777cfb4a6b69 Author: Duncan Laurie dlaurie@chromium.org Date: Wed Feb 10 17:10:05 2016 -0800
skylake: Enable DDI-A 4-lane support if GOP does not execute
This change will allow the kernel to use 4-lane eDP connections if the GOP driver does not execute and set this bit. If GOP has executed (everyone but Chrome OS verified mode) the link will already be up and this will do nothing.
BUG=chrome-os-partner:50197 BRANCH=glados TEST=boot on chell and ensure 4
Change-Id: I9e2328b00db84f26b9bd03220b8ac0bd5f64cfbf Signed-off-by: Patrick Georgi pgeorgi@chromium.org Original-Commit-Id: cff83e18ce9936c8d507f93c8443b7056c62e844 Original-Change-Id: I3f1e5d78b91eb0e4a23fcc196aff0edadc252a0c Original-Signed-off-by: Duncan Laurie dlaurie@chromium.org Original-Reviewed-on: https://chromium-review.googlesource.com/327251 Original-Reviewed-by: Aaron Durbin adurbin@chromium.org --- src/soc/intel/skylake/igd.c | 21 +++++++++++++++++---- 1 file changed, 17 insertions(+), 4 deletions(-)
diff --git a/src/soc/intel/skylake/igd.c b/src/soc/intel/skylake/igd.c index b87467f..4bb597c 100644 --- a/src/soc/intel/skylake/igd.c +++ b/src/soc/intel/skylake/igd.c @@ -62,6 +62,23 @@ static inline void gtt_rmw(u32 reg, u32 andmask, u32 ormask)
static void igd_init(struct device *dev) { + u32 ddi_buf_ctl; + + gtt_res = find_resource(dev, PCI_BASE_ADDRESS_0); + if (!gtt_res || !gtt_res->base) + return; + + /* + * Enable DDI-A (eDP) 4-lane operation if the link is not up yet. + * This will allow the kernel to use 4-lane eDP links properly + * if the VBIOS or GOP driver does not execute. + */ + ddi_buf_ctl = gtt_read(DDI_BUF_CTL_A); + if (!acpi_is_wakeup_s3() && !(ddi_buf_ctl & DDI_BUF_CTL_ENABLE)) { + ddi_buf_ctl |= DDI_A_4_LANES; + gtt_write(DDI_BUF_CTL_A, ddi_buf_ctl); + } + if (IS_ENABLED(CONFIG_GOP_SUPPORT)) return;
@@ -70,10 +87,6 @@ static void igd_init(struct device *dev) reg32 |= PCI_COMMAND_MASTER | PCI_COMMAND_MEMORY | PCI_COMMAND_IO; pci_write_config32(dev, PCI_COMMAND, reg32);
- gtt_res = find_resource(dev, PCI_BASE_ADDRESS_0); - if (!gtt_res || !gtt_res->base) - return; - /* Wait for any configured pre-graphics delay */ if (!acpi_is_wakeup_s3()) { #if IS_ENABLED(CONFIG_CHROMEOS)
