Wonkyu Kim has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/84228?usp=email )
Change subject: src/device: Add more condition to check valid PCI device id ......................................................................
Checking more conditions to check valid PCI device id to avoid device stuck issue.
Below are invalid PCI device id cases VID: 0x0 or 0xffff DID: 0x0 or 0xffff
Signed-off-by: Wonkyu Kim wonkyu.kim@intel.com Change-Id: Iffabc9037a8af1b2a4ffebdf30199c4f6eae9540 --- M src/device/pci_device.c 1 file changed, 18 insertions(+), 17 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/28/84228/1
diff --git a/src/device/pci_device.c b/src/device/pci_device.c index a2ad2b3..1b76b2f 100644 --- a/src/device/pci_device.c +++ b/src/device/pci_device.c @@ -1220,20 +1220,20 @@ dummy.path.pci.devfn = devfn;
id = pci_read_config32(&dummy, PCI_VENDOR_ID); - /* - * Have we found something? Some broken boards return 0 if a - * slot is empty, but the expected answer is 0xffffffff. - */ - if (id == 0xffffffff) - return NULL;
- if ((id == 0x00000000) || (id == 0x0000ffff) || - (id == 0xffff0000)) { - printk(BIOS_SPEW, "%s, bad id 0x%x\n", - dev_path(&dummy), id); + /* Checking bad VID and DID */ + dummy.vendor = id & 0xffff; + dummy.device = (id >> 16) & 0xffff; + if ((dummy.vendor == 0x0000) || (dummy.vendor == 0xffff) || + (dummy.device == 0xffff) || (dummy.device == 0x0000)) { + printk(BIOS_SPEW, "device %s [0x%04x/0x%04x] is not found.\n", + dev_path(&dummy), dummy.vendor, dummy.device); return NULL; } + dev = alloc_dev(bus, &dummy.path); + dev->vendor = dummy.vendor; + dev->device = dummy.device; } else { /* * Enable/disable the device. Once we have found the device- @@ -1259,13 +1259,16 @@ * this also handles optional devices that may not always * show up. */ - /* If the chain is fully enumerated quit */ - if ((id == 0xffffffff) || (id == 0x00000000) || - (id == 0x0000ffff) || (id == 0xffff0000)) { + + /* Checking bad VID and DID */ + dev->vendor = id & 0xffff; + dev->device = (id >> 16) & 0xffff; + if ((dev->vendor == 0x0000) || (dev->vendor == 0xffff) || + (dev->device == 0xffff) || (dev->device == 0x0000)) { if (dev->enabled) { printk(BIOS_INFO, - "PCI: Static device %s not found, disabling it.\n", - dev_path(dev)); + "PCI: Static device %s [0x%04x/0x%04x] not found, disabling it.\n", + dev_path(dev), dev->vendor, dev->device); dev->enabled = 0; } return dev; @@ -1277,8 +1280,6 @@ class = pci_read_config32(dev, PCI_CLASS_REVISION);
/* Store the interesting information in the device structure. */ - dev->vendor = id & 0xffff; - dev->device = (id >> 16) & 0xffff; dev->hdr_type = hdr_type;
/* Class code, the upper 3 bytes of PCI_CLASS_REVISION. */
