the following patch was just integrated into master: commit b59e8505d841bafb9ffdaf2086f46d62a0e1689a Author: Julius Werner jwerner@chromium.org Date: Wed Sep 25 13:54:57 2013 -0700
libpayload: usbmsc: Remove DETACHED state from MSC device structure
The USB MSC device structure contains a "ready" state that can be either "ready", "not ready" or "detached". The last one can only be assigned when the device is completely unresponsive and gets forcefully logically detached via usb_detach_device(). This call (at least in the current version) also calls all destructors and frees the complete usbdev_t structure (including the MSC specific part), which unfortunately makes storing the "detached" state in that very structure a little pointless.
This patch reduces the "ready" value to a simple boolean and makes sure that all detachment cases immediately return from the MSC driver, carefully avoiding any use-after-free opportunities.
Change-Id: Iff1c0849f9ce7c95d399bb9a1a0a94469951194d Signed-off-by: Julius Werner jwerner@chromium.org Reviewed-on: https://chromium-review.googlesource.com/170667 (cherry picked from commit fd4529f37fdd1c93a8b902488ffeef7001b1a05a) Signed-off-by: Isaac Christensen isaac.christensen@se-eng.com Reviewed-on: http://review.coreboot.org/6654 Reviewed-by: Ronald G. Minnich rminnich@gmail.com Tested-by: build bot (Jenkins)
See http://review.coreboot.org/6654 for details.
