Hello Matt DeVillier,
https://review.coreboot.org/c/coreboot/+/35923
Change subject: mb/intel/saddlebrook: migrate to FSP 2.0 ......................................................................
This patch is part of the patch series to drop support for FSP 1.1 in soc/intel/skylake.
The following modifications have been done to migrate the board(s) from FSP 1.1 to FSP 2.0:
- remove deprecated devicetree VR_RING domain (only 4 domains in FSP 2.0) - add AC/DC loadline values to devicetree (see TODO) - add FSP parameter DmiVc1 (see TODO) - set FSP board type to "mobile"
TODO: - check loadline values again - loadline values in devicetree maybe can dropped again, as Maxim is working on adding missing loadline values in CB:35167 - find out why some boards set DmiVc1 - testing
Change-Id: I7481f3413de6780df01d9b769bd4f16d439f087c Signed-off-by: Michael Niewöhner foss@mniewoehner.de Signed-off-by: Matt DeVillier matt.devillier@gmail.com --- M src/mainboard/intel/saddlebrook/Kconfig M src/mainboard/intel/saddlebrook/devicetree.cb M src/mainboard/intel/saddlebrook/ramstage.c M src/mainboard/intel/saddlebrook/romstage.c 4 files changed, 73 insertions(+), 70 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/23/35923/1
diff --git a/src/mainboard/intel/saddlebrook/Kconfig b/src/mainboard/intel/saddlebrook/Kconfig index 934c15a..3fb694a 100644 --- a/src/mainboard/intel/saddlebrook/Kconfig +++ b/src/mainboard/intel/saddlebrook/Kconfig @@ -32,6 +32,7 @@ select HAVE_CMOS_DEFAULT select MAINBOARD_USES_IFD_GBE_REGION select USE_INTEL_FSP_MP_INIT + select MAINBOARD_USES_FSP2_0
config IRQ_SLOT_COUNT int diff --git a/src/mainboard/intel/saddlebrook/devicetree.cb b/src/mainboard/intel/saddlebrook/devicetree.cb index 3322bf8..1d9a71b 100644 --- a/src/mainboard/intel/saddlebrook/devicetree.cb +++ b/src/mainboard/intel/saddlebrook/devicetree.cb @@ -61,82 +61,80 @@
register "serirq_mode" = "SERIRQ_CONTINUOUS"
- # VR Settings Configuration for 5 Domains - #+----------------+-------+-------+-------------+-------------+-------+ - #| Domain/Setting | SA | IA | Ring Sliced | GT Unsliced | GT | - #+----------------+-------+-------+-------------+-------------+-------+ - #| Psi1Threshold | 20A | 20A | 20A | 20A | 20A | - #| Psi2Threshold | 4A | 5A | 5A | 5A | 5A | - #| Psi3Threshold | 1A | 1A | 1A | 1A | 1A | - #| Psi3Enable | 1 | 1 | 1 | 1 | 1 | - #| Psi4Enable | 1 | 1 | 1 | 1 | 1 | - #| ImonSlope | 0 | 0 | 0 | 0 | 0 | - #| ImonOffset | 0 | 0 | 0 | 0 | 0 | - #| IccMax | 7A | 34A | 34A | 35A | 35A | - #| VrVoltageLimit | 1.52V | 1.52V | 1.52V | 1.52V | 1.52V | - #+----------------+-------+-------+-------------+-------------+-------+ + # VR Settings Configuration for 4 Domains + #+----------------+-----------+-----------+-------------+----------+ + #| Domain/Setting | SA | IA | GT Unsliced | GT | + #+----------------+-----------+-----------+-------------+----------+ + #| Psi1Threshold | 20A | 20A | 20A | 20A | + #| Psi2Threshold | 4A | 5A | 5A | 5A | + #| Psi3Threshold | 1A | 1A | 1A | 1A | + #| Psi3Enable | 1 | 1 | 1 | 1 | + #| Psi4Enable | 1 | 1 | 1 | 1 | + #| ImonSlope | 0 | 0 | 0 | 0 | + #| ImonOffset | 0 | 0 | 0 | 0 | + #| IccMax | 7A | 34A | 35A | 35A | + #| VrVoltageLimit | 1.52V | 1.52V | 1.52V | 1.52V | + #| AC LoadLine | 15 mOhm | 5.7 mOhm | 5.2 mOhm | 5.2 mOhm | + #| DC LoadLine | 14.3 mOhm | 4.83 mOhm | 4.2 mOhm | 4.2 mOhm | + #+----------------+-----------+-----------+-------------+----------+ register "domain_vr_config[VR_SYSTEM_AGENT]" = "{ - .vr_config_enable = 1, \ - .psi1threshold = 0x50, \ - .psi2threshold = 0x10, \ - .psi3threshold = 0x4, \ - .psi3enable = 1, \ - .psi4enable = 1, \ - .imon_slope = 0x0, \ - .imon_offset = 0x0, \ - .icc_max = 0x1C, \ - .voltage_limit = 0x5F0 \ + .vr_config_enable = 1, + .psi1threshold = VR_CFG_AMP(20), + .psi2threshold = VR_CFG_AMP(4), + .psi3threshold = VR_CFG_AMP(1), + .psi3enable = 1, + .psi4enable = 1, + .imon_slope = 0x0, + .imon_offset = 0x0, + .icc_max = VR_CFG_AMP(7), + .voltage_limit = 1520, + .ac_loadline = 1500, + .dc_loadline = 1430, }"
register "domain_vr_config[VR_IA_CORE]" = "{ - .vr_config_enable = 1, \ - .psi1threshold = 0x50, \ - .psi2threshold = 0x14, \ - .psi3threshold = 0x4, \ - .psi3enable = 1, \ - .psi4enable = 1, \ - .imon_slope = 0x0, \ - .imon_offset = 0x0, \ - .icc_max = 0x88, \ - .voltage_limit = 0x5F0 \ - }" - register "domain_vr_config[VR_RING]" = "{ - .vr_config_enable = 1, \ - .psi1threshold = 0x50, \ - .psi2threshold = 0x14, \ - .psi3threshold = 0x4, \ - .psi3enable = 1, \ - .psi4enable = 1, \ - .imon_slope = 0x0, \ - .imon_offset = 0x0, \ - .icc_max = 0x88, \ - .voltage_limit = 0x5F0, \ + .vr_config_enable = 1, + .psi1threshold = VR_CFG_AMP(20), + .psi2threshold = VR_CFG_AMP(5), + .psi3threshold = VR_CFG_AMP(1), + .psi3enable = 1, + .psi4enable = 1, + .imon_slope = 0x0, + .imon_offset = 0x0, + .icc_max = VR_CFG_AMP(34), + .voltage_limit = 1520, + .ac_loadline = 570, + .dc_loadline = 483, }"
register "domain_vr_config[VR_GT_UNSLICED]" = "{ - .vr_config_enable = 1, \ - .psi1threshold = 0x50, \ - .psi2threshold = 0x14, \ - .psi3threshold = 0x4, \ - .psi3enable = 1, \ - .psi4enable = 1, \ - .imon_slope = 0x0, \ - .imon_offset = 0x0, \ - .icc_max = 0x8C ,\ - .voltage_limit = 0x5F0 \ + .vr_config_enable = 1, + .psi1threshold = VR_CFG_AMP(20), + .psi2threshold = VR_CFG_AMP(5), + .psi3threshold = VR_CFG_AMP(1), + .psi3enable = 1, + .psi4enable = 1, + .imon_slope = 0x0, + .imon_offset = 0x0, + .icc_max = VR_CFG_AMP(35), + .voltage_limit = 1520, + .ac_loadline = 520, + .dc_loadline = 420, }"
register "domain_vr_config[VR_GT_SLICED]" = "{ - .vr_config_enable = 1, \ - .psi1threshold = 0x50, \ - .psi2threshold = 0x14, \ - .psi3threshold = 0x4, \ - .psi3enable = 1, \ - .psi4enable = 1, \ - .imon_slope = 0x0, \ - .imon_offset = 0x0, \ - .icc_max = 0x8C, \ - .voltage_limit = 0x5F0 \ + .vr_config_enable = 1, + .psi1threshold = VR_CFG_AMP(20), + .psi2threshold = VR_CFG_AMP(5), + .psi3threshold = VR_CFG_AMP(1), + .psi3enable = 1, + .psi4enable = 1, + .imon_slope = 0x0, + .imon_offset = 0x0, + .icc_max = VR_CFG_AMP(35), + .voltage_limit = 1520, + .ac_loadline = 520, + .dc_loadline = 420, }"
# Enable x1 slot diff --git a/src/mainboard/intel/saddlebrook/ramstage.c b/src/mainboard/intel/saddlebrook/ramstage.c index 42477e6..ed37681 100644 --- a/src/mainboard/intel/saddlebrook/ramstage.c +++ b/src/mainboard/intel/saddlebrook/ramstage.c @@ -16,7 +16,7 @@ #include <soc/ramstage.h> #include "gpio.h"
-void mainboard_silicon_init_params(SILICON_INIT_UPD *params) +void mainboard_silicon_init_params(FSP_SIL_UPD *params) { /* Configure pads prior to SiliconInit() in case there's any * dependencies during hardware initialization. */ diff --git a/src/mainboard/intel/saddlebrook/romstage.c b/src/mainboard/intel/saddlebrook/romstage.c index 46c2cdd..aa218fd 100644 --- a/src/mainboard/intel/saddlebrook/romstage.c +++ b/src/mainboard/intel/saddlebrook/romstage.c @@ -25,10 +25,10 @@ #include <spd_bin.h>
-void mainboard_memory_init_params( - struct romstage_params *params, - MEMORY_INIT_UPD *memory_params) +void mainboard_memory_init_params(FSPM_UPD *mupd) { + FSP_M_CONFIG *mem_cfg = &mupd->FspmConfig; + struct spd_block blk = { .addr_map = { 0x50, 0x52, }, }; @@ -59,4 +59,8 @@ /* update spd length*/ memory_params->MemorySpdDataLen = blk.len; memory_params->DqPinsInterleaved = TRUE; + + mem_cfg->UserBd = BOARD_TYPE_MOBILE; + + mupd->FspmTestConfig.DmiVc1 = 1; }
Michael Niewöhner has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/35923 )
Uploaded patch set 2: Patch Set 1 was rebased.
Aaron Durbin has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/35923 )
Patch Set 3:
https://review.coreboot.org/c/coreboot/+/35923/3/src/mainboard/intel/saddleb... File src/mainboard/intel/saddlebrook/romstage.c:
https://review.coreboot.org/c/coreboot/+/35923/3/src/mainboard/intel/saddleb... PS3, Line 40: memory_params- This breaking everything.
Matt DeVillier has uploaded a new patch set (#4) to the change originally created by Michael Niewöhner. ( https://review.coreboot.org/c/coreboot/+/35923 )
Change-Id: I7481f3413de6780df01d9b769bd4f16d439f087c Signed-off-by: Michael Niewöhner foss@mniewoehner.de Signed-off-by: Matt DeVillier matt.devillier@gmail.com --- M src/mainboard/intel/saddlebrook/Kconfig M src/mainboard/intel/saddlebrook/devicetree.cb M src/mainboard/intel/saddlebrook/ramstage.c M src/mainboard/intel/saddlebrook/romstage.c 4 files changed, 85 insertions(+), 82 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/23/35923/4
Matt DeVillier has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/35923 )
Patch Set 4:
Done
Patch Set 5: Code-Review+2
Uploaded patch set 7: Patch Set 6 was rebased.
Patrick Georgi has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/35923 )
Patch Set 7:
https://review.coreboot.org/c/coreboot/+/35923/7//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/35923/7//COMMIT_MSG@17 PS7, Line 17: TODO: : - testing what about testing?
Patch Set 7:
what about testing?
well, shouldn't this be tested before merging? I don't have the board, so someone else needs to test it
Michael Niewöhner has restored this change. ( https://review.coreboot.org/c/coreboot/+/35923 )
Restored
Patch Set 7:
@PraveenX would you mind testing this?
Uploaded patch set 8: Patch Set 7 was rebased.
Wim Vervoorn has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/35923 )
Patch Set 8: Code-Review+1
Uploaded patch set 9: Patch Set 8 was rebased.
PraveenX Hodagatta Pranesh has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/35923 )
Patch Set 9:
Patch Set 7:
what is the expectation for test ? Boot test ?
Patch Set 9:
Patch Set 9:
Patch Set 7:
Well, in the best case the device boots and works just like before :-)
Patch Set 9:
Patch Set 9:
Patch Set 9:
Patch Set 7:
Able to build with this patch,initially not able to boot & cannot see serial logs. later changing to 16MB ROM SIZE(adding decriptor.bin + Me.bin ) and UART fix ( https://review.coreboot.org/c/coreboot/+/36319) board can boot till UEFI payload shell.
not yet working : cannot boot to Linux and MRC is not working.
Patch Set 9:
Patch Set 9:
Patch Set 9:
Patch Set 9:
Patch Set 7:
did it work before the transition to fsp2.0?
Patch Set 9:
Patch Set 9:
Patch Set 9:
Patch Set 9:
Patch Set 9:
Patch Set 7:
iow. test what the current state is without this cb applied, please
Patch Set 9: Code-Review+1
well, shouldn't this be tested before merging? I don't have the board, so someone else needs to test […]
Done
Nico Huber has submitted this change. ( https://review.coreboot.org/c/coreboot/+/35923 )
TODO: - testing
Change-Id: I7481f3413de6780df01d9b769bd4f16d439f087c Signed-off-by: Michael Niewöhner foss@mniewoehner.de Signed-off-by: Matt DeVillier matt.devillier@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/35923 Reviewed-by: Michael Niewöhner Reviewed-by: Wim Vervoorn Reviewed-by: Aaron Durbin adurbin@chromium.org Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/mainboard/intel/saddlebrook/Kconfig M src/mainboard/intel/saddlebrook/devicetree.cb M src/mainboard/intel/saddlebrook/ramstage.c M src/mainboard/intel/saddlebrook/romstage.c 4 files changed, 69 insertions(+), 84 deletions(-)
Approvals: build bot (Jenkins): Verified Aaron Durbin: Looks good to me, approved Matt DeVillier: Looks good to me, approved Wim Vervoorn: Looks good to me, but someone else must approve Michael Niewöhner: Looks good to me, but someone else must approve
config IRQ_SLOT_COUNT int diff --git a/src/mainboard/intel/saddlebrook/devicetree.cb b/src/mainboard/intel/saddlebrook/devicetree.cb index 3322bf8..385a4be 100644 --- a/src/mainboard/intel/saddlebrook/devicetree.cb +++ b/src/mainboard/intel/saddlebrook/devicetree.cb @@ -61,82 +61,70 @@
- # VR Settings Configuration for 5 Domains - #+----------------+-------+-------+-------------+-------------+-------+ - #| Domain/Setting | SA | IA | Ring Sliced | GT Unsliced | GT | - #+----------------+-------+-------+-------------+-------------+-------+ - #| Psi1Threshold | 20A | 20A | 20A | 20A | 20A | - #| Psi2Threshold | 4A | 5A | 5A | 5A | 5A | - #| Psi3Threshold | 1A | 1A | 1A | 1A | 1A | - #| Psi3Enable | 1 | 1 | 1 | 1 | 1 | - #| Psi4Enable | 1 | 1 | 1 | 1 | 1 | - #| ImonSlope | 0 | 0 | 0 | 0 | 0 | - #| ImonOffset | 0 | 0 | 0 | 0 | 0 | - #| IccMax | 7A | 34A | 34A | 35A | 35A | - #| VrVoltageLimit | 1.52V | 1.52V | 1.52V | 1.52V | 1.52V | - #+----------------+-------+-------+-------------+-------------+-------+ + # VR Settings Configuration for 4 Domains + #+----------------+-----------+-----------+-------------+----------+ + #| Domain/Setting | SA | IA | GT Unsliced | GT | + #+----------------+-----------+-----------+-------------+----------+ + #| Psi1Threshold | 20A | 20A | 20A | 20A | + #| Psi2Threshold | 4A | 5A | 5A | 5A | + #| Psi3Threshold | 1A | 1A | 1A | 1A | + #| Psi3Enable | 1 | 1 | 1 | 1 | + #| Psi4Enable | 1 | 1 | 1 | 1 | + #| ImonSlope | 0 | 0 | 0 | 0 | + #| ImonOffset | 0 | 0 | 0 | 0 | + #| IccMax | 7A | 34A | 35A | 35A | + #| VrVoltageLimit | 1.52V | 1.52V | 1.52V | 1.52V | + #+----------------+-----------+-----------+-------------+----------+ register "domain_vr_config[VR_SYSTEM_AGENT]" = "{ - .vr_config_enable = 1, \ - .psi1threshold = 0x50, \ - .psi2threshold = 0x10, \ - .psi3threshold = 0x4, \ - .psi3enable = 1, \ - .psi4enable = 1, \ - .imon_slope = 0x0, \ - .imon_offset = 0x0, \ - .icc_max = 0x1C, \ - .voltage_limit = 0x5F0 \ + .vr_config_enable = 1, + .psi1threshold = VR_CFG_AMP(20), + .psi2threshold = VR_CFG_AMP(4), + .psi3threshold = VR_CFG_AMP(1), + .psi3enable = 1, + .psi4enable = 1, + .imon_slope = 0x0, + .imon_offset = 0x0, + .icc_max = VR_CFG_AMP(7), + .voltage_limit = 1520, }"
register "domain_vr_config[VR_IA_CORE]" = "{ - .vr_config_enable = 1, \ - .psi1threshold = 0x50, \ - .psi2threshold = 0x14, \ - .psi3threshold = 0x4, \ - .psi3enable = 1, \ - .psi4enable = 1, \ - .imon_slope = 0x0, \ - .imon_offset = 0x0, \ - .icc_max = 0x88, \ - .voltage_limit = 0x5F0 \ - }" - register "domain_vr_config[VR_RING]" = "{ - .vr_config_enable = 1, \ - .psi1threshold = 0x50, \ - .psi2threshold = 0x14, \ - .psi3threshold = 0x4, \ - .psi3enable = 1, \ - .psi4enable = 1, \ - .imon_slope = 0x0, \ - .imon_offset = 0x0, \ - .icc_max = 0x88, \ - .voltage_limit = 0x5F0, \ + .vr_config_enable = 1, + .psi1threshold = VR_CFG_AMP(20), + .psi2threshold = VR_CFG_AMP(5), + .psi3threshold = VR_CFG_AMP(1), + .psi3enable = 1, + .psi4enable = 1, + .imon_slope = 0x0, + .imon_offset = 0x0, + .icc_max = VR_CFG_AMP(34), + .voltage_limit = 1520, }"
register "domain_vr_config[VR_GT_UNSLICED]" = "{ - .vr_config_enable = 1, \ - .psi1threshold = 0x50, \ - .psi2threshold = 0x14, \ - .psi3threshold = 0x4, \ - .psi3enable = 1, \ - .psi4enable = 1, \ - .imon_slope = 0x0, \ - .imon_offset = 0x0, \ - .icc_max = 0x8C ,\ - .voltage_limit = 0x5F0 \ + .vr_config_enable = 1, + .psi1threshold = VR_CFG_AMP(20), + .psi2threshold = VR_CFG_AMP(5), + .psi3threshold = VR_CFG_AMP(1), + .psi3enable = 1, + .psi4enable = 1, + .imon_slope = 0x0, + .imon_offset = 0x0, + .icc_max = VR_CFG_AMP(35), + .voltage_limit = 1520, }"
register "domain_vr_config[VR_GT_SLICED]" = "{ - .vr_config_enable = 1, \ - .psi1threshold = 0x50, \ - .psi2threshold = 0x14, \ - .psi3threshold = 0x4, \ - .psi3enable = 1, \ - .psi4enable = 1, \ - .imon_slope = 0x0, \ - .imon_offset = 0x0, \ - .icc_max = 0x8C, \ - .voltage_limit = 0x5F0 \ + .vr_config_enable = 1, + .psi1threshold = VR_CFG_AMP(20), + .psi2threshold = VR_CFG_AMP(5), + .psi3threshold = VR_CFG_AMP(1), + .psi3enable = 1, + .psi4enable = 1, + .imon_slope = 0x0, + .imon_offset = 0x0, + .icc_max = VR_CFG_AMP(35), + .voltage_limit = 1520, }"
-void mainboard_silicon_init_params(SILICON_INIT_UPD *params) +void mainboard_silicon_init_params(FSP_SIL_UPD *params) { /* Configure pads prior to SiliconInit() in case there's any * dependencies during hardware initialization. */ diff --git a/src/mainboard/intel/saddlebrook/romstage.c b/src/mainboard/intel/saddlebrook/romstage.c index 0ed6730..8e280de 100644 --- a/src/mainboard/intel/saddlebrook/romstage.c +++ b/src/mainboard/intel/saddlebrook/romstage.c @@ -24,10 +24,10 @@ #include <spd_bin.h>
-void mainboard_memory_init_params( - struct romstage_params *params, - MEMORY_INIT_UPD *memory_params) +void mainboard_memory_init_params(FSPM_UPD *mupd) { + FSP_M_CONFIG *mem_cfg = &mupd->FspmConfig; + struct spd_block blk = { .addr_map = { 0x50, 0x52, }, }; @@ -36,26 +36,22 @@ dump_spd_info(&blk); printk(BIOS_SPEW, "spd block length: 0x%08x\n", blk.len);
- memory_params->MemorySpdPtr00 = (UINT32) blk.spd_array[0]; - memory_params->MemorySpdPtr10 = (UINT32) blk.spd_array[1]; - printk(BIOS_SPEW, "0x%08x: SpdDataBuffer_0_0\n", - memory_params->MemorySpdPtr00); - printk(BIOS_SPEW, "0x%08x: SpdDataBuffer_1_0\n", - memory_params->MemorySpdPtr10); + mem_cfg->MemorySpdPtr00 = (UINT32) blk.spd_array[0]; + mem_cfg->MemorySpdPtr10 = (UINT32) blk.spd_array[1]; + printk(BIOS_SPEW, "0x%08x: SpdDataBuffer_0_0\n", mem_cfg->MemorySpdPtr00); + printk(BIOS_SPEW, "0x%08x: SpdDataBuffer_1_0\n", mem_cfg->MemorySpdPtr10);
/* * Configure the DQ/DQS settings if required. In general the settings * should be set in the FSP flash image and should not need to be * changed. */ - mainboard_fill_dq_map_data(&memory_params->DqByteMapCh0, - &memory_params->DqByteMapCh1); - mainboard_fill_dqs_map_data(&memory_params->DqsMapCpu2DramCh0, - &memory_params->DqsMapCpu2DramCh1); - mainboard_fill_rcomp_res_data(&memory_params->RcompResistor); - mainboard_fill_rcomp_strength_data(&memory_params->RcompTarget); + mainboard_fill_dq_map_data(&mem_cfg->DqByteMapCh0, &mem_cfg->DqByteMapCh1); + mainboard_fill_dqs_map_data(&mem_cfg->DqsMapCpu2DramCh0, &mem_cfg->DqsMapCpu2DramCh1); + mainboard_fill_rcomp_res_data(&mem_cfg->RcompResistor); + mainboard_fill_rcomp_strength_data(&mem_cfg->RcompTarget);
/* update spd length*/ - memory_params->MemorySpdDataLen = blk.len; - memory_params->DqPinsInterleaved = TRUE; + mem_cfg->MemorySpdDataLen = blk.len; + mem_cfg->DqPinsInterleaved = TRUE; }
