Zhi7 Li has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/58196 )
Change subject: mb/google/dedede/var/sasukette: Generate SPD ID for supported memory parts ......................................................................
Add supported memory parts in the mem_parts_used.txt and generate the SPD ID for the memory parts. The memory parts being added are: 1. Samsung K4U6E3S4AB-MGCL
Signed-off-by: Zhi Li lizhi7@huaqin.corp-partner.google.com Change-Id: I811f32defd50a940a09f238d38c962d2caf42855 --- M src/mainboard/google/dedede/variants/sasukette/memory/Makefile.inc M src/mainboard/google/dedede/variants/sasukette/memory/dram_id.generated.txt M src/mainboard/google/dedede/variants/sasukette/memory/mem_parts_used.txt 3 files changed, 3 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/96/58196/1
diff --git a/src/mainboard/google/dedede/variants/sasukette/memory/Makefile.inc b/src/mainboard/google/dedede/variants/sasukette/memory/Makefile.inc index 490e591..05ff304 100644 --- a/src/mainboard/google/dedede/variants/sasukette/memory/Makefile.inc +++ b/src/mainboard/google/dedede/variants/sasukette/memory/Makefile.inc @@ -4,4 +4,4 @@ # util/spd_tools/bin/part_id_gen JSL lp4x src/mainboard/google/dedede/variants/sasukette/memory src/mainboard/google/dedede/variants/sasukette/memory/mem_parts_used.txt
SPD_SOURCES = -SPD_SOURCES += spd/lp4x/set-1/spd-1.hex # ID = 0(0b0000) Parts = K4U6E3S4AA-MGCR +SPD_SOURCES += spd/lp4x/set-1/spd-1.hex # ID = 0(0b0000) Parts = K4U6E3S4AA-MGCR, K4U6E3S4AB-MGCL diff --git a/src/mainboard/google/dedede/variants/sasukette/memory/dram_id.generated.txt b/src/mainboard/google/dedede/variants/sasukette/memory/dram_id.generated.txt index b02dcd7..cb4801e 100644 --- a/src/mainboard/google/dedede/variants/sasukette/memory/dram_id.generated.txt +++ b/src/mainboard/google/dedede/variants/sasukette/memory/dram_id.generated.txt @@ -5,3 +5,4 @@
DRAM Part Name ID to assign K4U6E3S4AA-MGCR 0 (0000) +K4U6E3S4AB-MGCL 0 (0000) diff --git a/src/mainboard/google/dedede/variants/sasukette/memory/mem_parts_used.txt b/src/mainboard/google/dedede/variants/sasukette/memory/mem_parts_used.txt index be1daed..476f0f5 100644 --- a/src/mainboard/google/dedede/variants/sasukette/memory/mem_parts_used.txt +++ b/src/mainboard/google/dedede/variants/sasukette/memory/mem_parts_used.txt @@ -10,3 +10,4 @@
# Part Name K4U6E3S4AA-MGCR +K4U6E3S4AB-MGCL
