Stefan Reinauer (stefan.reinauer@coreboot.org) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/9477
commit b82450c6d01dd14b41eb5a3af0290e9ca8fff9b4 Author: Harry Pan harry.pan@intel.com Date: Thu Nov 27 18:33:02 2014 +0800
wtm2: fix coreboot compilation error since tpmp removed
Since CL:226662, all TPMP accessing should be removed as well, else it will cause fox_wtm2 coreboot failed on build.
BUG=none BRANCH=none TEST=./setup_board --board=fox_wtm2 && emerge-fox_wtm2 coreboot CQ-DEPEND=CL:226662
Change-Id: Ib25f2d32997ef82b0ebf049803f2c5002a0a3abf Signed-off-by: Stefan Reinauer reinauer@chromium.org Original-Commit-Id: c99456bf42544518e2a36b6e0bbfe7f4ee1b4aff Original-Change-Id: Ia0eebb1924bbb23979c880f7d05600a0cf1e4ca3 Original-Signed-off-by: Harry Pan harry.pan@intel.com Original-Reviewed-on: https://chromium-review.googlesource.com/232165 Original-Reviewed-by: Wei Shun Chang wei.shun.chang@intel.com Original-Reviewed-by: Duncan Laurie dlaurie@chromium.org --- src/mainboard/intel/wtm2/acpi_tables.c | 3 --- 1 file changed, 3 deletions(-)
diff --git a/src/mainboard/intel/wtm2/acpi_tables.c b/src/mainboard/intel/wtm2/acpi_tables.c index 2df32a9..a89d30c 100644 --- a/src/mainboard/intel/wtm2/acpi_tables.c +++ b/src/mainboard/intel/wtm2/acpi_tables.c @@ -43,9 +43,6 @@ void acpi_create_gnvs(global_nvs_t *gnvs) /* Disable USB ports in S5 */ gnvs->s5u0 = 0;
- /* TPM Present */ - gnvs->tpmp = 1; - gnvs->tcrt = CRITICAL_TEMPERATURE; gnvs->tpsv = PASSIVE_TEMPERATURE; gnvs->tmax = MAX_TEMPERATURE;
