Karthik Ramasubramanian has submitted this change. ( https://review.coreboot.org/c/coreboot/+/56798 )
Change subject: mb/google/dedede: Create driblee variant ......................................................................
Create the driblee variant of the waddledee reference board by copying the template files to a new directory named for the variant.
(Auto-generated by create_coreboot_variant.sh version 4.5.0.)
BUG=b:191732473 BRANCH=None TEST=util/abuild/abuild -p none -t google/dedede -x -a make sure the build includes GOOGLE_DRIBLEE
Signed-off-by: Frank Wu frank_wu@compal.corp-partner.google.com Change-Id: I1ad9a4e0cf7999337b55d62d5cc94e4f6c2e98f3 Reviewed-on: https://review.coreboot.org/c/coreboot/+/56798 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Karthik Ramasubramanian kramasub@google.com --- M src/mainboard/google/dedede/Kconfig M src/mainboard/google/dedede/Kconfig.name A src/mainboard/google/dedede/variants/driblee/include/variant/ec.h A src/mainboard/google/dedede/variants/driblee/include/variant/gpio.h A src/mainboard/google/dedede/variants/driblee/memory/Makefile.inc A src/mainboard/google/dedede/variants/driblee/memory/dram_id.generated.txt A src/mainboard/google/dedede/variants/driblee/memory/mem_parts_used.txt A src/mainboard/google/dedede/variants/driblee/overridetree.cb 8 files changed, 83 insertions(+), 0 deletions(-)
Approvals: build bot (Jenkins): Verified Karthik Ramasubramanian: Looks good to me, approved
diff --git a/src/mainboard/google/dedede/Kconfig b/src/mainboard/google/dedede/Kconfig index c2c0f5c..5c0b0df 100644 --- a/src/mainboard/google/dedede/Kconfig +++ b/src/mainboard/google/dedede/Kconfig @@ -114,6 +114,7 @@ default "Cappy2" if BOARD_GOOGLE_CAPPY2 default "Bugzzy" if BOARD_GOOGLE_BUGZZY default "Corori" if BOARD_GOOGLE_CORORI + default "Driblee" if BOARD_GOOGLE_DRIBLEE
config MAX_CPUS int @@ -153,6 +154,7 @@ default "cappy2" if BOARD_GOOGLE_CAPPY2 default "bugzzy" if BOARD_GOOGLE_BUGZZY default "corori" if BOARD_GOOGLE_CORORI + default "driblee" if BOARD_GOOGLE_DRIBLEE
endif #BOARD_GOOGLE_BASEBOARD_DEDEDE
diff --git a/src/mainboard/google/dedede/Kconfig.name b/src/mainboard/google/dedede/Kconfig.name index 98a656b..4dc0d0d 100644 --- a/src/mainboard/google/dedede/Kconfig.name +++ b/src/mainboard/google/dedede/Kconfig.name @@ -171,3 +171,8 @@ bool "-> Corori" select BOARD_GOOGLE_BASEBOARD_DEDEDE_TPM2 select BASEBOARD_DEDEDE_LAPTOP + +config BOARD_GOOGLE_DRIBLEE + bool "-> Driblee" + select BOARD_GOOGLE_BASEBOARD_DEDEDE_TPM2 + select BASEBOARD_DEDEDE_LAPTOP diff --git a/src/mainboard/google/dedede/variants/driblee/include/variant/ec.h b/src/mainboard/google/dedede/variants/driblee/include/variant/ec.h new file mode 100644 index 0000000..08870e0 --- /dev/null +++ b/src/mainboard/google/dedede/variants/driblee/include/variant/ec.h @@ -0,0 +1,8 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ + +#ifndef MAINBOARD_EC_H +#define MAINBOARD_EC_H + +#include <baseboard/ec.h> + +#endif diff --git a/src/mainboard/google/dedede/variants/driblee/include/variant/gpio.h b/src/mainboard/google/dedede/variants/driblee/include/variant/gpio.h new file mode 100644 index 0000000..9078664 --- /dev/null +++ b/src/mainboard/google/dedede/variants/driblee/include/variant/gpio.h @@ -0,0 +1,8 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ + +#ifndef MAINBOARD_GPIO_H +#define MAINBOARD_GPIO_H + +#include <baseboard/gpio.h> + +#endif /* MAINBOARD_GPIO_H */ diff --git a/src/mainboard/google/dedede/variants/driblee/memory/Makefile.inc b/src/mainboard/google/dedede/variants/driblee/memory/Makefile.inc new file mode 100644 index 0000000..b0ca222 --- /dev/null +++ b/src/mainboard/google/dedede/variants/driblee/memory/Makefile.inc @@ -0,0 +1,5 @@ +## SPDX-License-Identifier: GPL-2.0-or-later +## This is an auto-generated file. Do not edit!! +## Add memory parts in mem_parts_used.txt and run spd_tools to regenerate. + +SPD_SOURCES = placeholder.spd.hex diff --git a/src/mainboard/google/dedede/variants/driblee/memory/dram_id.generated.txt b/src/mainboard/google/dedede/variants/driblee/memory/dram_id.generated.txt new file mode 100644 index 0000000..fa24790 --- /dev/null +++ b/src/mainboard/google/dedede/variants/driblee/memory/dram_id.generated.txt @@ -0,0 +1 @@ +DRAM Part Name ID to assign diff --git a/src/mainboard/google/dedede/variants/driblee/memory/mem_parts_used.txt b/src/mainboard/google/dedede/variants/driblee/memory/mem_parts_used.txt new file mode 100644 index 0000000..e4258b5 --- /dev/null +++ b/src/mainboard/google/dedede/variants/driblee/memory/mem_parts_used.txt @@ -0,0 +1,11 @@ +# This is a CSV file containing a list of memory parts used by this variant. +# One part per line with an optional fixed ID in column 2. +# Only include a fixed ID if it is required for legacy reasons! +# Generated IDs are dependent on the order of parts in this file, +# so new parts must always be added at the end of the file! +# +# Generate an updated Makefile.inc and dram_id.generated.txt by running the +# gen_part_id tool from util/spd_tools/{ddr4,lp4x}. +# See util/spd_tools/{ddr4,lp4x}/README.md for more details and instructions. + +# Part Name diff --git a/src/mainboard/google/dedede/variants/driblee/overridetree.cb b/src/mainboard/google/dedede/variants/driblee/overridetree.cb new file mode 100644 index 0000000..cbad0d2 --- /dev/null +++ b/src/mainboard/google/dedede/variants/driblee/overridetree.cb @@ -0,0 +1,43 @@ +chip soc/intel/jasperlake + + # Intel Common SoC Config + #+-------------------+---------------------------+ + #| Field | Value | + #+-------------------+---------------------------+ + #| I2C0 | Trackpad | + #| I2C1 | Digitizer | + #| I2C2 | Touchscreen | + #| I2C3 | Camera | + #| I2C4 | Audio | + #+-------------------+---------------------------+ + register "common_soc_config" = "{ + .i2c[0] = { + .speed = I2C_SPEED_FAST, + }, + .i2c[1] = { + .speed = I2C_SPEED_FAST, + }, + .i2c[2] = { + .speed = I2C_SPEED_FAST, + }, + .i2c[3] = { + .speed = I2C_SPEED_FAST, + }, + .i2c[4] = { + .speed = I2C_SPEED_FAST, + }, + }" + + register "SerialIoGSpiMode[PchSerialIoIndexGSPI0]" = "PchSerialIoDisabled" # Disable GSPI0 + register "SerialIoGSpiCsMode[PchSerialIoIndexGSPI0]" = "0" + + device domain 0 on + device pci 15.0 on end + device pci 1e.2 off end # GSPI 0 + device pci 1f.0 on + chip drivers/pc80/tpm + device pnp 0c31.0 on end # Discrete TPM + end # chip drivers/pc80/tpm + end # PCH eSPI + end +end
