Subrata Banik has submitted this change. ( https://review.coreboot.org/c/coreboot/+/84919?usp=email )
Change subject: mb/google/fatcat: Adjust EC host command range for microchip EC ......................................................................
This commit adjusts the EC host command range for the Fatcat board to 0x800-0x807 & 0x200-0x20f.
This change is necessary because the microchip EC used on the Fatcat board has a smaller host command range than the ITE/Nuvoton ECs used on other Fatcat variants.
The `gen1_dec` register in the devicetree is updated to reflect this change.
As per boot log, the `gen1_dec` aka offset 0x84, base address is 800 and size is 8 bytes.
AP FW Boot log:
[SPEW] PCI: 00:00:1f.0 resource base 800 size 8 align 0 gran 0 limit 0 flags c0000100 index 84
BUG=b:376207365 TEST=Able to build and boot google/fatcat w/o any error.
without this patch:
[SPEW ] LPC: Trying to open IO window from 800 size 8 [ERROR] LPC: Cannot open IO window: 800 size 8 [ERROR] No more IO windows
with this patch:
Change-Id: Ifcee533341fa583d841a4b564f25831c6d04e951 Signed-off-by: Subrata Banik subratabanik@google.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/84919 Reviewed-by: Anil Kumar K anil.kumar.k@intel.com Reviewed-by: Paul Menzel paulepanter@mailbox.org Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Pranava Y N pranavayn@google.com Reviewed-by: Vijay P Hiremath vijay.p.hiremath@intel.com --- M src/mainboard/google/fatcat/variants/baseboard/fatcat/devicetree.cb 1 file changed, 5 insertions(+), 2 deletions(-)
Approvals: Anil Kumar K: Looks good to me, but someone else must approve Vijay P Hiremath: Looks good to me, but someone else must approve Pranava Y N: Looks good to me, approved build bot (Jenkins): Verified Paul Menzel: Looks good to me, but someone else must approve
diff --git a/src/mainboard/google/fatcat/variants/baseboard/fatcat/devicetree.cb b/src/mainboard/google/fatcat/variants/baseboard/fatcat/devicetree.cb index d794925..1b1fc73 100644 --- a/src/mainboard/google/fatcat/variants/baseboard/fatcat/devicetree.cb +++ b/src/mainboard/google/fatcat/variants/baseboard/fatcat/devicetree.cb @@ -4,8 +4,11 @@ register "pmc_gpe0_dw1" = "GPP_D" register "pmc_gpe0_dw2" = "GPP_E"
- # EC host command ranges are in 0x800-0x8ff & 0x200-0x20f - register "gen1_dec" = "0x00fc0801" + # For Fatcat (with microchip EC): + # EC host command ranges are in 0x800-0x807 & 0x200-0x20f + # For other Fatcat variants (with ITE/Nuvoton EC): + # EC host command ranges are in 0x800-0x8ff & 0x200-0x20f + register "gen1_dec" = "CONFIG(BOARD_GOOGLE_FATCAT) ? 0x00040801 : 0x00fc0801" register "gen2_dec" = "0x000c0201" # EC memory map range is 0x900-0x9ff register "gen3_dec" = "0x00fc0901"
