Stefan Reinauer (stefan.reinauer@coreboot.org) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/4254
commit 50319097fc5df130a5060cf1cd5bbaa0eb71eac0 Author: Gabe Black gabeblack@google.com Date: Wed Jun 19 04:54:38 2013 -0700
libpayload: Make the region to scan for the cb tables configurable.
The address range to scan for the coreboot tables varies from machine to machine based on the range memory occupies on the SOC being booted and on the amount of memory installed on the machine. To make libpayload work on different ARM systems with different needs, this change makes the region to scan configurable. In the future, we might want to come up with a more automatic mechanism like on x86, although there's less consistency on ARM as far as what ranges are even memory in the first place.
Change-Id: Ib50efe25a6152171b0fbd0e324dbc5e89c527d6e Signed-off-by: Gabe Black gabeblack@google.com Reviewed-on: https://gerrit.chromium.org/gerrit/59242 Reviewed-by: Gabe Black gabeblack@chromium.org Tested-by: Gabe Black gabeblack@chromium.org Commit-Queue: Gabe Black gabeblack@chromium.org --- payloads/libpayload/arch/armv7/Config.in | 8 ++++++++ payloads/libpayload/arch/armv7/coreboot.c | 3 ++- 2 files changed, 10 insertions(+), 1 deletion(-)
diff --git a/payloads/libpayload/arch/armv7/Config.in b/payloads/libpayload/arch/armv7/Config.in index 6c1bf44..79cd676 100644 --- a/payloads/libpayload/arch/armv7/Config.in +++ b/payloads/libpayload/arch/armv7/Config.in @@ -33,4 +33,12 @@ config ARCH_SPECIFIC_OPTIONS # dummy def_bool y select LITTLE_ENDIAN
+config COREBOOT_INFO_RANGE_BASE + hex "Base of the range to search for the coreboot tables" + +config COREBOOT_INFO_RANGE_SIZE + hex "Size of the range to search for the coreboot tables" + default 0x4000000 + + endif diff --git a/payloads/libpayload/arch/armv7/coreboot.c b/payloads/libpayload/arch/armv7/coreboot.c index b6178f7..bc9b47e 100644 --- a/payloads/libpayload/arch/armv7/coreboot.c +++ b/payloads/libpayload/arch/armv7/coreboot.c @@ -284,7 +284,8 @@ static int cb_parse_header(void *addr, int len, struct sysinfo_t *info)
int get_coreboot_info(struct sysinfo_t *info) { - int ret = cb_parse_header(phys_to_virt(0xbc000000), 0x4000000, info); + int ret = cb_parse_header(phys_to_virt(CONFIG_COREBOOT_INFO_RANGE_BASE), + CONFIG_COREBOOT_INFO_RANGE_SIZE, info);
return (ret == 1) ? 0 : -1; }
