Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/72739 )
Change subject: soc/amd/common/data_fabric_helper: normalize addresses in debug print ......................................................................
Instead of just printing the register contents, normalize the contents of the base and limit registers to actual MMIO addresses and then print those. This will hopefully avoid some confusion caused by the shifted addresses.
Output on Mandolin before the patch:
=== Data Fabric MMIO configuration registers === Addresses are shifted to the right by 16 bits. idx control base limit 0 93 fc00 febf 1 93 1000000 ffffffff 2 93 d000 f7ff 3 1093 fed0 fedf 4 90 0 0 5 90 0 0 6 90 0 0 7 90 0 0
Output on Mandolin after the patch:
=== Data Fabric MMIO configuration registers === idx control base limit 0 93 fc000000 febfffff 1 93 10000000000 ffffffffffff 2 93 d0000000 f7ffffff 3 1093 fed00000 fedfffff 4 90 0 ffff 5 90 0 ffff 6 90 0 ffff 7 90 0 ffff
Signed-off-by: Felix Held felix-coreboot@felixheld.de Change-Id: I62eeb88ddac6a7a421fccc8e433523459117976a Reviewed-on: https://review.coreboot.org/c/coreboot/+/72739 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Fred Reitberger reitbergerfred@gmail.com --- M src/soc/amd/common/block/data_fabric/data_fabric_helper.c 1 file changed, 59 insertions(+), 7 deletions(-)
Approvals: build bot (Jenkins): Verified Fred Reitberger: Looks good to me, approved
diff --git a/src/soc/amd/common/block/data_fabric/data_fabric_helper.c b/src/soc/amd/common/block/data_fabric/data_fabric_helper.c index 412daae..b64edcd 100644 --- a/src/soc/amd/common/block/data_fabric/data_fabric_helper.c +++ b/src/soc/amd/common/block/data_fabric/data_fabric_helper.c @@ -47,16 +47,23 @@
void data_fabric_print_mmio_conf(void) { + uint32_t control; + uint64_t base, limit; printk(BIOS_SPEW, "=== Data Fabric MMIO configuration registers ===\n" - "Addresses are shifted to the right by 16 bits.\n" - "idx control base limit\n"); + "idx control base limit\n"); for (unsigned int i = 0; i < NUM_NB_MMIO_REGS; i++) { - printk(BIOS_SPEW, " %2u %8x %8x %8x\n", - i, - data_fabric_broadcast_read32(0, NB_MMIO_CONTROL(i)), - data_fabric_broadcast_read32(0, NB_MMIO_BASE(i)), - data_fabric_broadcast_read32(0, NB_MMIO_LIMIT(i))); + control = data_fabric_broadcast_read32(0, NB_MMIO_CONTROL(i)); + /* Base and limit address registers don't contain the lower address bits, but + are shifted by D18F0_MMIO_SHIFT bits */ + base = (uint64_t)data_fabric_broadcast_read32(0, NB_MMIO_BASE(i)) + << D18F0_MMIO_SHIFT; + limit = (uint64_t)data_fabric_broadcast_read32(0, NB_MMIO_LIMIT(i)) + << D18F0_MMIO_SHIFT; + /* Lower D18F0_MMIO_SHIFT address limit bits are all 1 */ + limit += (1 << D18F0_MMIO_SHIFT) - 1; + printk(BIOS_SPEW, " %2u %8x %16llx %16llx\n", + i, control, base, limit); } }
