Felix Held has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/51242 )
Change subject: [RFC] soc/amd/cezanne/chipset.cb: clean up and change some aliases ......................................................................
With the aliases some of the comments are redundant. I'm still not sure if the Ethernet controller on the embedded SKUs supports 10G or only 1G.
Signed-off-by: Felix Held felix-coreboot@felixheld.de Change-Id: I1e432c12f92a622f8ee05be19acb2c304dd74afb --- M src/soc/amd/cezanne/chipset.cb 1 file changed, 24 insertions(+), 24 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/42/51242/1
diff --git a/src/soc/amd/cezanne/chipset.cb b/src/soc/amd/cezanne/chipset.cb index 5e3d269..cb05750 100644 --- a/src/soc/amd/cezanne/chipset.cb +++ b/src/soc/amd/cezanne/chipset.cb @@ -4,48 +4,48 @@ end device domain 0 on device pci 00.0 alias gnb on end - device pci 0.2 alias iommu off end # IOMMU + device pci 00.2 alias iommu off end
- device pci 1.0 on end # Dummy Host Bridge, do not disable - device pci 1.1 alias gpp_bridge_1_1 off end # GPP Bridge 0 - device pci 1.2 alias gpp_bridge_1_2 off end # GPP Bridge 1 - device pci 1.3 alias gpp_bridge_1_3 off end # GPP Bridge 2 + device pci 01.0 on end # Dummy Host Bridge, do not disable + device pci 01.1 alias gpp_gfx_bridge_0 off end + device pci 01.2 alias gpp_gfx_bridge_1 off end + device pci 01.3 alias gpp_gfx_bridge_2 off end
- device pci 2.0 on end # Dummy Host Bridge, do not disable - device pci 2.1 alias gpp_bridge_2_1 off end # GPP Bridge 0 - device pci 2.2 alias gpp_bridge_2_2 off end # GPP Bridge 1 - device pci 2.3 alias gpp_bridge_2_3 off end # GPP Bridge 2 - device pci 2.4 alias gpp_bridge_2_4 off end # GPP Bridge 3 - device pci 2.5 alias gpp_bridge_2_5 off end # GPP Bridge 4 - device pci 2.6 alias gpp_bridge_2_6 off end # GPP Bridge 5 - device pci 2.7 alias gpp_bridge_2_7 off end # GPP Bridge 6 + device pci 02.0 on end # Dummy Host Bridge, do not disable + device pci 02.1 alias gpp_bridge_0 off end + device pci 02.2 alias gpp_bridge_1 off end + device pci 02.3 alias gpp_bridge_2 off end + device pci 02.4 alias gpp_bridge_3 off end + device pci 02.5 alias gpp_bridge_4 off end + device pci 02.6 alias gpp_bridge_5 off end + device pci 02.7 alias gpp_bridge_6 off end
- device pci 8.0 on end # Dummy Host Bridge, do not disable - device pci 8.1 alias gpp_bridge_a off # Internal GPP Bridge 0 to Bus A + device pci 08.0 on end # Dummy Host Bridge, do not disable + device pci 08.1 alias gpp_bridge_a off # Internal GPP Bridge 0 to Bus A device pci 0.0 alias gfx off end # Internal GPU (GFX) - device pci 0.1 alias gfx_az off end # Display HD Audio Controller (GFXAZ) + device pci 0.1 alias gfx_hda off end # Display HD Audio Controller (GFXAZ) device pci 0.2 alias crypto off end # Crypto Coprocessor - device pci 0.3 alias xhci_0 off end # USB 3.1 (USB0) - device pci 0.4 alias xhci_1 off end # USB 3.1 (USB1) + device pci 0.3 alias xhci_0 off end + device pci 0.4 alias xhci_1 off end device pci 0.5 alias acp off end # Audio Processor (ACP) - device pci 0.6 alias standalone_az off end # Audio Processor HD Audio Controller (Standalone AZ) + device pci 0.6 alias hda off end # Audio Processor HD Audio Controller (main AZ) device pci 0.7 alias mp2 off end # Sensor Fusion Hub (MP2) end - device pci 8.2 alias gpp_bridge_b off # Internal GPP Bridge 1 to Bus B + device pci 08.2 alias gpp_bridge_b off # Internal GPP Bridge 1 to Bus B device pci 0.0 alias sata_0 off end # first SATA controller; AHCI Mode device pci 0.1 alias sata_1 off end # second SATA Controller; SATA Raid/AHCI Mode device pci 0.2 alias xgbe_0 off end # 10 GbE Controller Port 0 (XGBE0) device pci 0.3 alias xgbe_1 off end # 10 GbE Controller Port 1 (XGBE1) end - device pci 8.3 alias gpp_bridge_c off # Internal GPP Bridge 2 to Bus C + device pci 08.3 alias gpp_bridge_c off # Internal GPP Bridge 2 to Bus C device pci 0.0 alias dummy_function_c off end # PCIe Dummy Function device pci 0.2 alias i2s_ac97 off end # I2S/AC'97 Audio end
- device pci 14.0 alias smbus on end # SMBus, primary FCH function - device pci 14.3 alias lpc_bridge on end # LPC Bridge + device pci 14.0 alias smbus on end # primary FCH function + device pci 14.3 alias lpc_bridge on end
- device pci 18.0 alias data_fabric_0 on end # Data fabric [0-7] + device pci 18.0 alias data_fabric_0 on end device pci 18.1 alias data_fabric_1 on end device pci 18.2 alias data_fabric_2 on end device pci 18.3 alias data_fabric_3 on end
