Angel Pons has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/46796 )
Change subject: soc/intel/broadwell: Split up acpi.c ......................................................................
Change-Id: Ie9c57b6f5c226cee8797027941fa03e69de52923 Signed-off-by: Angel Pons th3fanbus@gmail.com --- M src/soc/intel/broadwell/acpi.c M src/soc/intel/broadwell/cpu/Makefile.inc A src/soc/intel/broadwell/cpu/acpi.c M src/soc/intel/broadwell/pch/Makefile.inc A src/soc/intel/broadwell/pch/acpi.c 5 files changed, 452 insertions(+), 396 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/96/46796/1
diff --git a/src/soc/intel/broadwell/acpi.c b/src/soc/intel/broadwell/acpi.c index 7366642..9b5ac9e 100644 --- a/src/soc/intel/broadwell/acpi.c +++ b/src/soc/intel/broadwell/acpi.c @@ -26,128 +26,6 @@ #include <soc/systemagent.h> #include <soc/intel/broadwell/chip.h>
-/* - * List of supported C-states in this processor. Only the ULT parts support C8, - * C9, and C10. - */ -enum { - C_STATE_C0, /* 0 */ - C_STATE_C1, /* 1 */ - C_STATE_C1E, /* 2 */ - C_STATE_C3, /* 3 */ - C_STATE_C6_SHORT_LAT, /* 4 */ - C_STATE_C6_LONG_LAT, /* 5 */ - C_STATE_C7_SHORT_LAT, /* 6 */ - C_STATE_C7_LONG_LAT, /* 7 */ - C_STATE_C7S_SHORT_LAT, /* 8 */ - C_STATE_C7S_LONG_LAT, /* 9 */ - C_STATE_C8, /* 10 */ - C_STATE_C9, /* 11 */ - C_STATE_C10, /* 12 */ - NUM_C_STATES -}; - -#define MWAIT_RES(state, sub_state) \ - { \ - .addrl = (((state) << 4) | (sub_state)), \ - .space_id = ACPI_ADDRESS_SPACE_FIXED, \ - .bit_width = ACPI_FFIXEDHW_VENDOR_INTEL, \ - .bit_offset = ACPI_FFIXEDHW_CLASS_MWAIT, \ - .access_size = ACPI_FFIXEDHW_FLAG_HW_COORD, \ - } - -static acpi_cstate_t cstate_map[NUM_C_STATES] = { - [C_STATE_C0] = { }, - [C_STATE_C1] = { - .latency = 0, - .power = 1000, - .resource = MWAIT_RES(0, 0), - }, - [C_STATE_C1E] = { - .latency = 0, - .power = 1000, - .resource = MWAIT_RES(0, 1), - }, - [C_STATE_C3] = { - .latency = C_STATE_LATENCY_FROM_LAT_REG(0), - .power = 900, - .resource = MWAIT_RES(1, 0), - }, - [C_STATE_C6_SHORT_LAT] = { - .latency = C_STATE_LATENCY_FROM_LAT_REG(1), - .power = 800, - .resource = MWAIT_RES(2, 0), - }, - [C_STATE_C6_LONG_LAT] = { - .latency = C_STATE_LATENCY_FROM_LAT_REG(2), - .power = 800, - .resource = MWAIT_RES(2, 1), - }, - [C_STATE_C7_SHORT_LAT] = { - .latency = C_STATE_LATENCY_FROM_LAT_REG(1), - .power = 700, - .resource = MWAIT_RES(3, 0), - }, - [C_STATE_C7_LONG_LAT] = { - .latency = C_STATE_LATENCY_FROM_LAT_REG(2), - .power = 700, - .resource = MWAIT_RES(3, 1), - }, - [C_STATE_C7S_SHORT_LAT] = { - .latency = C_STATE_LATENCY_FROM_LAT_REG(1), - .power = 700, - .resource = MWAIT_RES(3, 2), - }, - [C_STATE_C7S_LONG_LAT] = { - .latency = C_STATE_LATENCY_FROM_LAT_REG(2), - .power = 700, - .resource = MWAIT_RES(3, 3), - }, - [C_STATE_C8] = { - .latency = C_STATE_LATENCY_FROM_LAT_REG(3), - .power = 600, - .resource = MWAIT_RES(4, 0), - }, - [C_STATE_C9] = { - .latency = C_STATE_LATENCY_FROM_LAT_REG(4), - .power = 500, - .resource = MWAIT_RES(5, 0), - }, - [C_STATE_C10] = { - .latency = C_STATE_LATENCY_FROM_LAT_REG(5), - .power = 400, - .resource = MWAIT_RES(6, 0), - }, -}; - -static int cstate_set_s0ix[3] = { - C_STATE_C1E, - C_STATE_C7S_LONG_LAT, - C_STATE_C10 -}; - -static int cstate_set_non_s0ix[3] = { - C_STATE_C1E, - C_STATE_C3, - C_STATE_C7S_LONG_LAT -}; - -static int get_cores_per_package(void) -{ - struct cpuinfo_x86 c; - struct cpuid_result result; - int cores = 1; - - get_fms(&c, cpuid_eax(1)); - if (c.x86 != 6) - return 1; - - result = cpuid_ext(0xb, 1); - cores = result.ebx & 0xff; - - return cores; -} - unsigned long acpi_fill_mcfg(unsigned long current) { current += acpi_create_mcfg_mmconfig((acpi_mcfg_mmconfig_t *)current, @@ -155,252 +33,6 @@ return current; }
-static acpi_tstate_t tss_table_fine[] = { - { 100, 1000, 0, 0x00, 0 }, - { 94, 940, 0, 0x1f, 0 }, - { 88, 880, 0, 0x1e, 0 }, - { 82, 820, 0, 0x1d, 0 }, - { 75, 760, 0, 0x1c, 0 }, - { 69, 700, 0, 0x1b, 0 }, - { 63, 640, 0, 0x1a, 0 }, - { 57, 580, 0, 0x19, 0 }, - { 50, 520, 0, 0x18, 0 }, - { 44, 460, 0, 0x17, 0 }, - { 38, 400, 0, 0x16, 0 }, - { 32, 340, 0, 0x15, 0 }, - { 25, 280, 0, 0x14, 0 }, - { 19, 220, 0, 0x13, 0 }, - { 13, 160, 0, 0x12, 0 }, -}; - -static acpi_tstate_t tss_table_coarse[] = { - { 100, 1000, 0, 0x00, 0 }, - { 88, 875, 0, 0x1f, 0 }, - { 75, 750, 0, 0x1e, 0 }, - { 63, 625, 0, 0x1d, 0 }, - { 50, 500, 0, 0x1c, 0 }, - { 38, 375, 0, 0x1b, 0 }, - { 25, 250, 0, 0x1a, 0 }, - { 13, 125, 0, 0x19, 0 }, -}; - -static void generate_T_state_entries(int core, int cores_per_package) -{ - /* Indicate SW_ALL coordination for T-states */ - acpigen_write_TSD_package(core, cores_per_package, SW_ALL); - - /* Indicate FFixedHW so OS will use MSR */ - acpigen_write_empty_PTC(); - - /* Set a T-state limit that can be modified in NVS */ - acpigen_write_TPC("\TLVL"); - - /* - * CPUID.(EAX=6):EAX[5] indicates support - * for extended throttle levels. - */ - if (cpuid_eax(6) & (1 << 5)) - acpigen_write_TSS_package( - ARRAY_SIZE(tss_table_fine), tss_table_fine); - else - acpigen_write_TSS_package( - ARRAY_SIZE(tss_table_coarse), tss_table_coarse); -} - -static void generate_C_state_entries(void) -{ - acpi_cstate_t map[3]; - int *set; - int i; - - config_t *config = config_of_soc(); - - if (config->s0ix_enable) - set = cstate_set_s0ix; - else - set = cstate_set_non_s0ix; - - for (i = 0; i < 3; i++) { - memcpy(&map[i], &cstate_map[set[i]], sizeof(acpi_cstate_t)); - map[i].ctype = i + 1; - } - - /* Generate C-state tables */ - acpigen_write_CST_package(map, ARRAY_SIZE(map)); -} - -static int calculate_power(int tdp, int p1_ratio, int ratio) -{ - u32 m; - u32 power; - - /* - * M = ((1.1 - ((p1_ratio - ratio) * 0.00625)) / 1.1) ^ 2 - * - * Power = (ratio / p1_ratio) * m * tdp - */ - - m = (110000 - ((p1_ratio - ratio) * 625)) / 11; - m = (m * m) / 1000; - - power = ((ratio * 100000 / p1_ratio) / 100); - power *= (m / 100) * (tdp / 1000); - power /= 1000; - - return (int)power; -} - -static void generate_P_state_entries(int core, int cores_per_package) -{ - int ratio_min, ratio_max, ratio_turbo, ratio_step; - int coord_type, power_max, power_unit, num_entries; - int ratio, power, clock, clock_max; - msr_t msr; - - /* Determine P-state coordination type from MISC_PWR_MGMT[0] */ - msr = rdmsr(MSR_MISC_PWR_MGMT); - if (msr.lo & MISC_PWR_MGMT_EIST_HW_DIS) - coord_type = SW_ANY; - else - coord_type = HW_ALL; - - /* Get bus ratio limits and calculate clock speeds */ - msr = rdmsr(MSR_PLATFORM_INFO); - ratio_min = (msr.hi >> (40-32)) & 0xff; /* Max Efficiency Ratio */ - - /* Determine if this CPU has configurable TDP */ - if (cpu_config_tdp_levels()) { - /* Set max ratio to nominal TDP ratio */ - msr = rdmsr(MSR_CONFIG_TDP_NOMINAL); - ratio_max = msr.lo & 0xff; - } else { - /* Max Non-Turbo Ratio */ - ratio_max = (msr.lo >> 8) & 0xff; - } - clock_max = ratio_max * CPU_BCLK; - - /* Calculate CPU TDP in mW */ - msr = rdmsr(MSR_PKG_POWER_SKU_UNIT); - power_unit = 2 << ((msr.lo & 0xf) - 1); - msr = rdmsr(MSR_PKG_POWER_SKU); - power_max = ((msr.lo & 0x7fff) / power_unit) * 1000; - - /* Write _PCT indicating use of FFixedHW */ - acpigen_write_empty_PCT(); - - /* Write _PPC with no limit on supported P-state */ - acpigen_write_PPC_NVS(); - - /* Write PSD indicating configured coordination type */ - acpigen_write_PSD_package(core, 1, coord_type); - - /* Add P-state entries in _PSS table */ - acpigen_write_name("_PSS"); - - /* Determine ratio points */ - ratio_step = PSS_RATIO_STEP; - num_entries = (ratio_max - ratio_min) / ratio_step; - while (num_entries > PSS_MAX_ENTRIES-1) { - ratio_step <<= 1; - num_entries >>= 1; - } - - /* P[T] is Turbo state if enabled */ - if (get_turbo_state() == TURBO_ENABLED) { - /* _PSS package count including Turbo */ - acpigen_write_package(num_entries + 2); - - msr = rdmsr(MSR_TURBO_RATIO_LIMIT); - ratio_turbo = msr.lo & 0xff; - - /* Add entry for Turbo ratio */ - acpigen_write_PSS_package( - clock_max + 1, /*MHz*/ - power_max, /*mW*/ - PSS_LATENCY_TRANSITION, /*lat1*/ - PSS_LATENCY_BUSMASTER, /*lat2*/ - ratio_turbo << 8, /*control*/ - ratio_turbo << 8); /*status*/ - } else { - /* _PSS package count without Turbo */ - acpigen_write_package(num_entries + 1); - } - - /* First regular entry is max non-turbo ratio */ - acpigen_write_PSS_package( - clock_max, /*MHz*/ - power_max, /*mW*/ - PSS_LATENCY_TRANSITION, /*lat1*/ - PSS_LATENCY_BUSMASTER, /*lat2*/ - ratio_max << 8, /*control*/ - ratio_max << 8); /*status*/ - - /* Generate the remaining entries */ - for (ratio = ratio_min + ((num_entries - 1) * ratio_step); - ratio >= ratio_min; ratio -= ratio_step) { - - /* Calculate power at this ratio */ - power = calculate_power(power_max, ratio_max, ratio); - clock = ratio * CPU_BCLK; - - acpigen_write_PSS_package( - clock, /*MHz*/ - power, /*mW*/ - PSS_LATENCY_TRANSITION, /*lat1*/ - PSS_LATENCY_BUSMASTER, /*lat2*/ - ratio << 8, /*control*/ - ratio << 8); /*status*/ - } - - /* Fix package length */ - acpigen_pop_len(); -} - -void generate_cpu_entries(const struct device *device) -{ - int coreID, cpuID, pcontrol_blk = ACPI_BASE_ADDRESS, plen = 6; - int totalcores = dev_count_cpu(); - int cores_per_package = get_cores_per_package(); - int numcpus = totalcores/cores_per_package; - - printk(BIOS_DEBUG, "Found %d CPU(s) with %d core(s) each.\n", - numcpus, cores_per_package); - - for (cpuID = 1; cpuID <= numcpus; cpuID++) { - for (coreID = 1; coreID <= cores_per_package; coreID++) { - if (coreID > 1) { - pcontrol_blk = 0; - plen = 0; - } - - /* Generate processor _SB.CPUx */ - acpigen_write_processor( - (cpuID - 1) * cores_per_package+coreID - 1, - pcontrol_blk, plen); - - /* Generate P-state tables */ - generate_P_state_entries( - coreID - 1, cores_per_package); - - /* Generate C-state tables */ - generate_C_state_entries(); - - /* Generate T-state tables */ - generate_T_state_entries( - cpuID - 1, cores_per_package); - - acpigen_pop_len(); - } - } - - /* PPKG is usually used for thermal management - of the first and only package. */ - acpigen_write_processor_package("PPKG", 0, cores_per_package); - - /* Add a method to notify processor nodes */ - acpigen_write_processor_cnot(cores_per_package); -} - static unsigned long acpi_fill_dmar(unsigned long current) { struct device *const igfx_dev = pcidev_path_on_root(SA_DEVFN_IGD); @@ -471,31 +103,3 @@
return current; } - -unsigned long acpi_fill_madt(unsigned long current) -{ - int sci = acpi_sci_irq(); - acpi_madt_irqoverride_t *irqovr; - uint16_t flags = MP_IRQ_TRIGGER_LEVEL; - - /* Local APICs */ - current = acpi_create_madt_lapics(current); - - /* IOAPIC */ - current += acpi_create_madt_ioapic((acpi_madt_ioapic_t *)current, 2, IO_APIC_ADDR, 0); - - /* INT_SRC_OVR */ - irqovr = (void *)current; - current += acpi_create_madt_irqoverride(irqovr, 0, 0, 2, 0); - - if (sci >= 20) - flags |= MP_IRQ_POLARITY_LOW; - else - flags |= MP_IRQ_POLARITY_HIGH; - - /* SCI */ - irqovr = (void *)current; - current += acpi_create_madt_irqoverride(irqovr, 0, sci, sci, flags); - - return current; -} diff --git a/src/soc/intel/broadwell/cpu/Makefile.inc b/src/soc/intel/broadwell/cpu/Makefile.inc index e9f4637..803696a 100644 --- a/src/soc/intel/broadwell/cpu/Makefile.inc +++ b/src/soc/intel/broadwell/cpu/Makefile.inc @@ -16,6 +16,7 @@
postcar-y += ../../../../cpu/intel/car/non-evict/exit_car.S
+ramstage-y += acpi.c ramstage-y += cpu.c ramstage-y += smmrelocate.c
diff --git a/src/soc/intel/broadwell/cpu/acpi.c b/src/soc/intel/broadwell/cpu/acpi.c new file mode 100644 index 0000000..ec3d588 --- /dev/null +++ b/src/soc/intel/broadwell/cpu/acpi.c @@ -0,0 +1,395 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#include <acpi/acpi.h> +#include <acpi/acpi_gnvs.h> +#include <acpi/acpigen.h> +#include <arch/ioapic.h> +#include <arch/smp/mpspec.h> +#include <cbmem.h> +#include <device/pci_ops.h> +#include <cpu/x86/smm.h> +#include <console/console.h> +#include <types.h> +#include <string.h> +#include <arch/cpu.h> +#include <cpu/x86/msr.h> +#include <cpu/intel/turbo.h> +#include <ec/google/chromeec/ec.h> +#include <vendorcode/google/chromeos/gnvs.h> +#include <soc/acpi.h> +#include <soc/cpu.h> +#include <soc/iomap.h> +#include <soc/lpc.h> +#include <soc/msr.h> +#include <soc/pci_devs.h> +#include <soc/pm.h> +#include <soc/systemagent.h> +#include <soc/intel/broadwell/chip.h> + +/* + * List of supported C-states in this processor. Only the ULT parts support C8, + * C9, and C10. + */ +enum { + C_STATE_C0, /* 0 */ + C_STATE_C1, /* 1 */ + C_STATE_C1E, /* 2 */ + C_STATE_C3, /* 3 */ + C_STATE_C6_SHORT_LAT, /* 4 */ + C_STATE_C6_LONG_LAT, /* 5 */ + C_STATE_C7_SHORT_LAT, /* 6 */ + C_STATE_C7_LONG_LAT, /* 7 */ + C_STATE_C7S_SHORT_LAT, /* 8 */ + C_STATE_C7S_LONG_LAT, /* 9 */ + C_STATE_C8, /* 10 */ + C_STATE_C9, /* 11 */ + C_STATE_C10, /* 12 */ + NUM_C_STATES +}; + +#define MWAIT_RES(state, sub_state) \ + { \ + .addrl = (((state) << 4) | (sub_state)), \ + .space_id = ACPI_ADDRESS_SPACE_FIXED, \ + .bit_width = ACPI_FFIXEDHW_VENDOR_INTEL, \ + .bit_offset = ACPI_FFIXEDHW_CLASS_MWAIT, \ + .access_size = ACPI_FFIXEDHW_FLAG_HW_COORD, \ + } + +static acpi_cstate_t cstate_map[NUM_C_STATES] = { + [C_STATE_C0] = { }, + [C_STATE_C1] = { + .latency = 0, + .power = 1000, + .resource = MWAIT_RES(0, 0), + }, + [C_STATE_C1E] = { + .latency = 0, + .power = 1000, + .resource = MWAIT_RES(0, 1), + }, + [C_STATE_C3] = { + .latency = C_STATE_LATENCY_FROM_LAT_REG(0), + .power = 900, + .resource = MWAIT_RES(1, 0), + }, + [C_STATE_C6_SHORT_LAT] = { + .latency = C_STATE_LATENCY_FROM_LAT_REG(1), + .power = 800, + .resource = MWAIT_RES(2, 0), + }, + [C_STATE_C6_LONG_LAT] = { + .latency = C_STATE_LATENCY_FROM_LAT_REG(2), + .power = 800, + .resource = MWAIT_RES(2, 1), + }, + [C_STATE_C7_SHORT_LAT] = { + .latency = C_STATE_LATENCY_FROM_LAT_REG(1), + .power = 700, + .resource = MWAIT_RES(3, 0), + }, + [C_STATE_C7_LONG_LAT] = { + .latency = C_STATE_LATENCY_FROM_LAT_REG(2), + .power = 700, + .resource = MWAIT_RES(3, 1), + }, + [C_STATE_C7S_SHORT_LAT] = { + .latency = C_STATE_LATENCY_FROM_LAT_REG(1), + .power = 700, + .resource = MWAIT_RES(3, 2), + }, + [C_STATE_C7S_LONG_LAT] = { + .latency = C_STATE_LATENCY_FROM_LAT_REG(2), + .power = 700, + .resource = MWAIT_RES(3, 3), + }, + [C_STATE_C8] = { + .latency = C_STATE_LATENCY_FROM_LAT_REG(3), + .power = 600, + .resource = MWAIT_RES(4, 0), + }, + [C_STATE_C9] = { + .latency = C_STATE_LATENCY_FROM_LAT_REG(4), + .power = 500, + .resource = MWAIT_RES(5, 0), + }, + [C_STATE_C10] = { + .latency = C_STATE_LATENCY_FROM_LAT_REG(5), + .power = 400, + .resource = MWAIT_RES(6, 0), + }, +}; + +static int cstate_set_s0ix[3] = { + C_STATE_C1E, + C_STATE_C7S_LONG_LAT, + C_STATE_C10 +}; + +static int cstate_set_non_s0ix[3] = { + C_STATE_C1E, + C_STATE_C3, + C_STATE_C7S_LONG_LAT +}; + +static int get_cores_per_package(void) +{ + struct cpuinfo_x86 c; + struct cpuid_result result; + int cores = 1; + + get_fms(&c, cpuid_eax(1)); + if (c.x86 != 6) + return 1; + + result = cpuid_ext(0xb, 1); + cores = result.ebx & 0xff; + + return cores; +} + +static acpi_tstate_t tss_table_fine[] = { + { 100, 1000, 0, 0x00, 0 }, + { 94, 940, 0, 0x1f, 0 }, + { 88, 880, 0, 0x1e, 0 }, + { 82, 820, 0, 0x1d, 0 }, + { 75, 760, 0, 0x1c, 0 }, + { 69, 700, 0, 0x1b, 0 }, + { 63, 640, 0, 0x1a, 0 }, + { 57, 580, 0, 0x19, 0 }, + { 50, 520, 0, 0x18, 0 }, + { 44, 460, 0, 0x17, 0 }, + { 38, 400, 0, 0x16, 0 }, + { 32, 340, 0, 0x15, 0 }, + { 25, 280, 0, 0x14, 0 }, + { 19, 220, 0, 0x13, 0 }, + { 13, 160, 0, 0x12, 0 }, +}; + +static acpi_tstate_t tss_table_coarse[] = { + { 100, 1000, 0, 0x00, 0 }, + { 88, 875, 0, 0x1f, 0 }, + { 75, 750, 0, 0x1e, 0 }, + { 63, 625, 0, 0x1d, 0 }, + { 50, 500, 0, 0x1c, 0 }, + { 38, 375, 0, 0x1b, 0 }, + { 25, 250, 0, 0x1a, 0 }, + { 13, 125, 0, 0x19, 0 }, +}; + +static void generate_T_state_entries(int core, int cores_per_package) +{ + /* Indicate SW_ALL coordination for T-states */ + acpigen_write_TSD_package(core, cores_per_package, SW_ALL); + + /* Indicate FFixedHW so OS will use MSR */ + acpigen_write_empty_PTC(); + + /* Set a T-state limit that can be modified in NVS */ + acpigen_write_TPC("\TLVL"); + + /* + * CPUID.(EAX=6):EAX[5] indicates support + * for extended throttle levels. + */ + if (cpuid_eax(6) & (1 << 5)) + acpigen_write_TSS_package( + ARRAY_SIZE(tss_table_fine), tss_table_fine); + else + acpigen_write_TSS_package( + ARRAY_SIZE(tss_table_coarse), tss_table_coarse); +} + +static void generate_C_state_entries(void) +{ + acpi_cstate_t map[3]; + int *set; + int i; + + config_t *config = config_of_soc(); + + if (config->s0ix_enable) + set = cstate_set_s0ix; + else + set = cstate_set_non_s0ix; + + for (i = 0; i < 3; i++) { + memcpy(&map[i], &cstate_map[set[i]], sizeof(acpi_cstate_t)); + map[i].ctype = i + 1; + } + + /* Generate C-state tables */ + acpigen_write_CST_package(map, ARRAY_SIZE(map)); +} + +static int calculate_power(int tdp, int p1_ratio, int ratio) +{ + u32 m; + u32 power; + + /* + * M = ((1.1 - ((p1_ratio - ratio) * 0.00625)) / 1.1) ^ 2 + * + * Power = (ratio / p1_ratio) * m * tdp + */ + + m = (110000 - ((p1_ratio - ratio) * 625)) / 11; + m = (m * m) / 1000; + + power = ((ratio * 100000 / p1_ratio) / 100); + power *= (m / 100) * (tdp / 1000); + power /= 1000; + + return (int)power; +} + +static void generate_P_state_entries(int core, int cores_per_package) +{ + int ratio_min, ratio_max, ratio_turbo, ratio_step; + int coord_type, power_max, power_unit, num_entries; + int ratio, power, clock, clock_max; + msr_t msr; + + /* Determine P-state coordination type from MISC_PWR_MGMT[0] */ + msr = rdmsr(MSR_MISC_PWR_MGMT); + if (msr.lo & MISC_PWR_MGMT_EIST_HW_DIS) + coord_type = SW_ANY; + else + coord_type = HW_ALL; + + /* Get bus ratio limits and calculate clock speeds */ + msr = rdmsr(MSR_PLATFORM_INFO); + ratio_min = (msr.hi >> (40-32)) & 0xff; /* Max Efficiency Ratio */ + + /* Determine if this CPU has configurable TDP */ + if (cpu_config_tdp_levels()) { + /* Set max ratio to nominal TDP ratio */ + msr = rdmsr(MSR_CONFIG_TDP_NOMINAL); + ratio_max = msr.lo & 0xff; + } else { + /* Max Non-Turbo Ratio */ + ratio_max = (msr.lo >> 8) & 0xff; + } + clock_max = ratio_max * CPU_BCLK; + + /* Calculate CPU TDP in mW */ + msr = rdmsr(MSR_PKG_POWER_SKU_UNIT); + power_unit = 2 << ((msr.lo & 0xf) - 1); + msr = rdmsr(MSR_PKG_POWER_SKU); + power_max = ((msr.lo & 0x7fff) / power_unit) * 1000; + + /* Write _PCT indicating use of FFixedHW */ + acpigen_write_empty_PCT(); + + /* Write _PPC with no limit on supported P-state */ + acpigen_write_PPC_NVS(); + + /* Write PSD indicating configured coordination type */ + acpigen_write_PSD_package(core, 1, coord_type); + + /* Add P-state entries in _PSS table */ + acpigen_write_name("_PSS"); + + /* Determine ratio points */ + ratio_step = PSS_RATIO_STEP; + num_entries = (ratio_max - ratio_min) / ratio_step; + while (num_entries > PSS_MAX_ENTRIES-1) { + ratio_step <<= 1; + num_entries >>= 1; + } + + /* P[T] is Turbo state if enabled */ + if (get_turbo_state() == TURBO_ENABLED) { + /* _PSS package count including Turbo */ + acpigen_write_package(num_entries + 2); + + msr = rdmsr(MSR_TURBO_RATIO_LIMIT); + ratio_turbo = msr.lo & 0xff; + + /* Add entry for Turbo ratio */ + acpigen_write_PSS_package( + clock_max + 1, /*MHz*/ + power_max, /*mW*/ + PSS_LATENCY_TRANSITION, /*lat1*/ + PSS_LATENCY_BUSMASTER, /*lat2*/ + ratio_turbo << 8, /*control*/ + ratio_turbo << 8); /*status*/ + } else { + /* _PSS package count without Turbo */ + acpigen_write_package(num_entries + 1); + } + + /* First regular entry is max non-turbo ratio */ + acpigen_write_PSS_package( + clock_max, /*MHz*/ + power_max, /*mW*/ + PSS_LATENCY_TRANSITION, /*lat1*/ + PSS_LATENCY_BUSMASTER, /*lat2*/ + ratio_max << 8, /*control*/ + ratio_max << 8); /*status*/ + + /* Generate the remaining entries */ + for (ratio = ratio_min + ((num_entries - 1) * ratio_step); + ratio >= ratio_min; ratio -= ratio_step) { + + /* Calculate power at this ratio */ + power = calculate_power(power_max, ratio_max, ratio); + clock = ratio * CPU_BCLK; + + acpigen_write_PSS_package( + clock, /*MHz*/ + power, /*mW*/ + PSS_LATENCY_TRANSITION, /*lat1*/ + PSS_LATENCY_BUSMASTER, /*lat2*/ + ratio << 8, /*control*/ + ratio << 8); /*status*/ + } + + /* Fix package length */ + acpigen_pop_len(); +} + +void generate_cpu_entries(const struct device *device) +{ + int coreID, cpuID, pcontrol_blk = ACPI_BASE_ADDRESS, plen = 6; + int totalcores = dev_count_cpu(); + int cores_per_package = get_cores_per_package(); + int numcpus = totalcores/cores_per_package; + + printk(BIOS_DEBUG, "Found %d CPU(s) with %d core(s) each.\n", + numcpus, cores_per_package); + + for (cpuID = 1; cpuID <= numcpus; cpuID++) { + for (coreID = 1; coreID <= cores_per_package; coreID++) { + if (coreID > 1) { + pcontrol_blk = 0; + plen = 0; + } + + /* Generate processor _SB.CPUx */ + acpigen_write_processor( + (cpuID - 1) * cores_per_package+coreID - 1, + pcontrol_blk, plen); + + /* Generate P-state tables */ + generate_P_state_entries( + coreID - 1, cores_per_package); + + /* Generate C-state tables */ + generate_C_state_entries(); + + /* Generate T-state tables */ + generate_T_state_entries( + cpuID - 1, cores_per_package); + + acpigen_pop_len(); + } + } + + /* PPKG is usually used for thermal management + of the first and only package. */ + acpigen_write_processor_package("PPKG", 0, cores_per_package); + + /* Add a method to notify processor nodes */ + acpigen_write_processor_cnot(cores_per_package); +} diff --git a/src/soc/intel/broadwell/pch/Makefile.inc b/src/soc/intel/broadwell/pch/Makefile.inc index 1c19613..119534f 100644 --- a/src/soc/intel/broadwell/pch/Makefile.inc +++ b/src/soc/intel/broadwell/pch/Makefile.inc @@ -1,5 +1,6 @@ bootblock-y += bootblock.c
+ramstage-y += acpi.c ramstage-y += adsp.c romstage-y += early_pch.c ramstage-$(CONFIG_ELOG) += elog.c diff --git a/src/soc/intel/broadwell/pch/acpi.c b/src/soc/intel/broadwell/pch/acpi.c new file mode 100644 index 0000000..712bb46 --- /dev/null +++ b/src/soc/intel/broadwell/pch/acpi.c @@ -0,0 +1,55 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#include <acpi/acpi.h> +#include <acpi/acpi_gnvs.h> +#include <acpi/acpigen.h> +#include <arch/ioapic.h> +#include <arch/smp/mpspec.h> +#include <cbmem.h> +#include <device/pci_ops.h> +#include <cpu/x86/smm.h> +#include <console/console.h> +#include <types.h> +#include <string.h> +#include <arch/cpu.h> +#include <cpu/x86/msr.h> +#include <cpu/intel/turbo.h> +#include <ec/google/chromeec/ec.h> +#include <vendorcode/google/chromeos/gnvs.h> +#include <soc/acpi.h> +#include <soc/cpu.h> +#include <soc/iomap.h> +#include <soc/lpc.h> +#include <soc/msr.h> +#include <soc/pci_devs.h> +#include <soc/pm.h> +#include <soc/systemagent.h> +#include <soc/intel/broadwell/chip.h> + +unsigned long acpi_fill_madt(unsigned long current) +{ + int sci = acpi_sci_irq(); + acpi_madt_irqoverride_t *irqovr; + uint16_t flags = MP_IRQ_TRIGGER_LEVEL; + + /* Local APICs */ + current = acpi_create_madt_lapics(current); + + /* IOAPIC */ + current += acpi_create_madt_ioapic((acpi_madt_ioapic_t *)current, 2, IO_APIC_ADDR, 0); + + /* INT_SRC_OVR */ + irqovr = (void *)current; + current += acpi_create_madt_irqoverride(irqovr, 0, 0, 2, 0); + + if (sci >= 20) + flags |= MP_IRQ_POLARITY_LOW; + else + flags |= MP_IRQ_POLARITY_HIGH; + + /* SCI */ + irqovr = (void *)current; + current += acpi_create_madt_irqoverride(irqovr, 0, sci, sci, flags); + + return current; +}
Michael Niewöhner has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/46796 )
Patch Set 6: Code-Review+2
Michael Niewöhner has submitted this change. ( https://review.coreboot.org/c/coreboot/+/46796 )
Change-Id: Ie9c57b6f5c226cee8797027941fa03e69de52923 Signed-off-by: Angel Pons th3fanbus@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/46796 Reviewed-by: Michael Niewöhner foss@mniewoehner.de Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/soc/intel/broadwell/acpi.c M src/soc/intel/broadwell/cpu/Makefile.inc A src/soc/intel/broadwell/cpu/acpi.c M src/soc/intel/broadwell/pch/Makefile.inc A src/soc/intel/broadwell/pch/acpi.c 5 files changed, 452 insertions(+), 396 deletions(-)
Approvals: build bot (Jenkins): Verified Michael Niewöhner: Looks good to me, approved
