Marshall Dawson has uploaded this change for review. ( https://review.coreboot.org/22884
Change subject: soc/amd/common: Make reading AGESA event log static ......................................................................
The function agesawrapper_amdreadeventlog() is only called from within agesawrapper.c. Make it a static function and: * shorten the name to help keep lines within 80 columns * convert initializers to C99 * break the call from the callers' if() statements * streamline the printk formatting
BUG=b:70671442 TEST=Build and run Kahlee, check console log
Change-Id: I402c75e4d65a592b9d1557c5852df03e48e206b9 Signed-off-by: Marshall Dawson marshalldawson3rd@gmail.com --- M src/soc/amd/common/block/include/amdblocks/agesawrapper.h M src/soc/amd/common/block/pi/agesawrapper.c 2 files changed, 40 insertions(+), 31 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/84/22884/1
diff --git a/src/soc/amd/common/block/include/amdblocks/agesawrapper.h b/src/soc/amd/common/block/include/amdblocks/agesawrapper.h index 08ac596..d16e9ff 100644 --- a/src/soc/amd/common/block/include/amdblocks/agesawrapper.h +++ b/src/soc/amd/common/block/include/amdblocks/agesawrapper.h @@ -40,7 +40,6 @@ AGESA_STATUS agesawrapper_amdinitlate(void); AGESA_STATUS agesawrapper_amdinitpost(void); AGESA_STATUS agesawrapper_amdinitmid(void); -AGESA_STATUS agesawrapper_amdreadeventlog(UINT8 HeapStatus); void *agesawrapper_getlateinitptr(int pick); AGESA_STATUS agesawrapper_amdlaterunaptask(UINT32 Func, UINTN Data, void *ConfigPtr); diff --git a/src/soc/amd/common/block/pi/agesawrapper.c b/src/soc/amd/common/block/pi/agesawrapper.c index cc57207..b9931d2 100644 --- a/src/soc/amd/common/block/pi/agesawrapper.c +++ b/src/soc/amd/common/block/pi/agesawrapper.c @@ -40,6 +40,34 @@ static void *AcpiCrat; #endif /* #ifndef __PRE_RAM__ */
+static AGESA_STATUS agesawrapper_readeventlog(UINT8 HeapStatus) +{ + AGESA_STATUS Status; + EVENT_PARAMS AmdEventParams = { + .StdHeader.CalloutPtr = &GetBiosCallout, + .StdHeader.HeapStatus = HeapStatus, + }; + + Status = AmdReadEventLog(&AmdEventParams); + if (AmdEventParams.EventClass) + printk(BIOS_DEBUG, "AGESA Event Log:\n"); + + while (AmdEventParams.EventClass != 0) { + printk(BIOS_DEBUG, " Class = %x, Info = %x," + " Param1 = 0x%x, Param2 = 0x%x" + " Param3 = 0x%x, Param4 = 0x%x\n", + (u32)AmdEventParams.EventClass, + (u32)AmdEventParams.EventInfo, + (u32)AmdEventParams.DataParam1, + (u32)AmdEventParams.DataParam2, + (u32)AmdEventParams.DataParam3, + (u32)AmdEventParams.DataParam4); + Status = AmdReadEventLog(&AmdEventParams); + } + + return Status; +} + AGESA_STATUS agesawrapper_amdinitreset(void) { AGESA_STATUS status; @@ -68,7 +96,8 @@ status = AmdInitReset(&AmdResetParams); timestamp_add_now(TS_AGESA_INIT_RESET_DONE);
- if (status != AGESA_SUCCESS) agesawrapper_amdreadeventlog(AmdParamStruct.StdHeader.HeapStatus); + if (status != AGESA_SUCCESS) + agesawrapper_readeventlog(AmdParamStruct.StdHeader.HeapStatus); AmdReleaseStruct (&AmdParamStruct); return status; } @@ -98,7 +127,8 @@ status = AmdInitEarly ((AMD_EARLY_PARAMS *)AmdParamStruct.NewStructPtr); timestamp_add_now(TS_AGESA_INIT_EARLY_DONE);
return status; @@ -169,7 +199,8 @@ (unsigned long)(PostParams->MemConfig.UmaBase) << 16 );
- if (status != AGESA_SUCCESS) agesawrapper_amdreadeventlog(PostParams->StdHeader.HeapStatus); + if (status != AGESA_SUCCESS) + agesawrapper_readeventlog(PostParams->StdHeader.HeapStatus); AmdReleaseStruct (&AmdParamStruct);
return status; @@ -203,7 +234,8 @@ status = AmdInitEnv (EnvParam); timestamp_add_now(TS_AGESA_INIT_ENV_DONE);
- if (status != AGESA_SUCCESS) agesawrapper_amdreadeventlog(EnvParam->StdHeader.HeapStatus); + if (status != AGESA_SUCCESS) + agesawrapper_readeventlog(EnvParam->StdHeader.HeapStatus); /* Initialize Subordinate Bus Number and Secondary Bus Number * In platform BIOS this address is allocated by PCI enumeration code Modify D1F0x18 @@ -274,7 +306,8 @@ status = AmdInitMid ((AMD_MID_PARAMS *)AmdParamStruct.NewStructPtr); timestamp_add_now(TS_AGESA_INIT_MID_DONE);
return status; @@ -306,7 +339,7 @@ timestamp_add_now(TS_AGESA_INIT_LATE_DONE);
if (Status != AGESA_SUCCESS) { - agesawrapper_amdreadeventlog(AmdLateParams->StdHeader.HeapStatus); + agesawrapper_readeventlog(AmdLateParams->StdHeader.HeapStatus); ASSERT(Status == AGESA_SUCCESS); }
@@ -351,31 +384,8 @@
Status = AmdLateRunApTask (&ApExeParams); if (Status != AGESA_SUCCESS) { - /* agesawrapper_amdreadeventlog(); */ + /* agesawrapper_readeventlog(); */ ASSERT(Status == AGESA_SUCCESS); - } - - return Status; -} - -AGESA_STATUS agesawrapper_amdreadeventlog (UINT8 HeapStatus) -{ - AGESA_STATUS Status; - EVENT_PARAMS AmdEventParams; - - memset(&AmdEventParams, 0, sizeof(AmdEventParams)); - - AmdEventParams.StdHeader.AltImageBasePtr = 0; - AmdEventParams.StdHeader.CalloutPtr = &GetBiosCallout; - AmdEventParams.StdHeader.Func = 0; - AmdEventParams.StdHeader.ImageBasePtr = 0; - AmdEventParams.StdHeader.HeapStatus = HeapStatus; - Status = AmdReadEventLog (&AmdEventParams); - while (AmdEventParams.EventClass != 0) { - printk(BIOS_DEBUG,"\nEventLog: EventClass = %x, EventInfo = %x.\n", (unsigned int)AmdEventParams.EventClass,(unsigned int)AmdEventParams.EventInfo); - printk(BIOS_DEBUG," Param1 = %x, Param2 = %x.\n",(unsigned int)AmdEventParams.DataParam1, (unsigned int)AmdEventParams.DataParam2); - printk(BIOS_DEBUG," Param3 = %x, Param4 = %x.\n",(unsigned int)AmdEventParams.DataParam3, (unsigned int)AmdEventParams.DataParam4); - Status = AmdReadEventLog (&AmdEventParams); }
return Status;
