Patrick Georgi has submitted this change. ( https://review.coreboot.org/c/coreboot/+/57828 )
Change subject: mb/google/dedede/var/kracko: refactor DPTF section for overrides ......................................................................
Refactor DPTF section of code under the kracko overridetree. This makes kracko override dptf section of dedede/baseboard, because the DPTF tool's CRT, PSV and TSR3 settings are different than expected.
BUG=b:187482019 BRANCH=dedede TEST=Built and tested on dedede system
Change-Id: Iacc543f961a7f4652ee8583920b1794f916c7ec9 Signed-off-by: Robert Chen robert.chen@quanta.corp-partner.google.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/57828 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Tim Wawrzynczak twawrzynczak@chromium.org --- M src/mainboard/google/dedede/variants/kracko/overridetree.cb 1 file changed, 56 insertions(+), 0 deletions(-)
diff --git a/src/mainboard/google/dedede/variants/kracko/overridetree.cb b/src/mainboard/google/dedede/variants/kracko/overridetree.cb index 36226de..2124103 100644 --- a/src/mainboard/google/dedede/variants/kracko/overridetree.cb +++ b/src/mainboard/google/dedede/variants/kracko/overridetree.cb @@ -58,7 +58,63 @@ }, }"
+ register "power_limits_config" = "{ + .tdp_pl1_override = 6, + .tdp_pl2_override = 20, + }" + + register "tcc_offset" = "20" # TCC of 85C + device domain 0 on + device pci 04.0 on + chip drivers/intel/dptf + # Default DPTF Policy for all drawcia boards if not overridden + register "options.tsr[0].desc" = ""Memory"" + register "options.tsr[1].desc" = ""Ambient"" + register "options.tsr[2].desc" = ""Charger"" + register "options.tsr[3].desc" = ""5V regulator"" + ## Passive Policy + register "policies.passive" = "{ + [0] = DPTF_PASSIVE(CPU, CPU, 80, 1000), + [1] = DPTF_PASSIVE(CPU, TEMP_SENSOR_0, 70, 4000), + [2] = DPTF_PASSIVE(CPU, TEMP_SENSOR_1, 51, 1000), + [3] = DPTF_PASSIVE(CHARGER, TEMP_SENSOR_2, 75, 5000), + [4] = DPTF_PASSIVE(CPU, TEMP_SENSOR_3, 60, 1000) + }" + ## Critical Policy + register "policies.critical" = "{ + [0] = DPTF_CRITICAL(CPU, 119, SHUTDOWN), + [1] = DPTF_CRITICAL(TEMP_SENSOR_0, 115, SHUTDOWN), + [2] = DPTF_CRITICAL(TEMP_SENSOR_1, 115, SHUTDOWN), + [3] = DPTF_CRITICAL(TEMP_SENSOR_2, 115, SHUTDOWN), + [4] = DPTF_CRITICAL(TEMP_SENSOR_3, 115, SHUTDOWN) + }" + register "controls.power_limits" = "{ + .pl1 = { + .min_power = 3800, + .max_power = 5800, + .time_window_min = 1 * MSECS_PER_SEC, + .time_window_max = 1 * MSECS_PER_SEC, + .granularity = 200, + }, + .pl2 = { + .min_power = 20000, + .max_power = 20000, + .time_window_min = 1 * MSECS_PER_SEC, + .time_window_max = 1 * MSECS_PER_SEC, + .granularity = 1000, + } + }" + ## Charger Performance Control (Control, mA) + register "controls.charger_perf" = "{ + [0] = { 255, 3000 }, + [1] = { 24, 1500 }, + [2] = { 16, 1000 }, + [3] = { 8, 500 } + }" + device generic 0 alias dptf_policy on end + end + end # SA Thermal device device pci 14.0 on chip drivers/usb/acpi device usb 0.0 on
