Felix Singer has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/49186 )
Change subject: vc/intel/fsp1_1/skylake: Remove unused header file ......................................................................
Change-Id: I329a1484cbd16296a2aa047876c2506c74d4452d Signed-off-by: Felix Singer felixsinger@posteo.net --- D src/vendorcode/intel/fsp/fsp1_1/skylake/FspUpdVpd.h 1 file changed, 0 insertions(+), 1,075 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/86/49186/1
diff --git a/src/vendorcode/intel/fsp/fsp1_1/skylake/FspUpdVpd.h b/src/vendorcode/intel/fsp/fsp1_1/skylake/FspUpdVpd.h deleted file mode 100644 index fddc168..0000000 --- a/src/vendorcode/intel/fsp/fsp1_1/skylake/FspUpdVpd.h +++ /dev/null @@ -1,1075 +0,0 @@ -/** @file - -Copyright (c) 2017, Intel Corporation. All rights reserved.<BR> - -Redistribution and use in source and binary forms, with or without modification, -are permitted provided that the following conditions are met: - -* Redistributions of source code must retain the above copyright notice, this - list of conditions and the following disclaimer. -* Redistributions in binary form must reproduce the above copyright notice, this - list of conditions and the following disclaimer in the documentation and/or - other materials provided with the distribution. -* Neither the name of Intel Corporation nor the names of its contributors may - be used to endorse or promote products derived from this software without - specific prior written permission. - - THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" - AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE - IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE - ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE - LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR - CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF - SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS - INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN - CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) - ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF - THE POSSIBILITY OF SUCH DAMAGE. - - This file is automatically generated. Please do NOT modify !!! - -**/ - -#ifndef __FSPUPDVPD_H__ -#define __FSPUPDVPD_H__ - -#pragma pack(push, 1) - - -#define MRC_MAX_RCOMP 3 -#define MRC_MAX_RCOMP_TARGETS 5 -#define MAX_CHANNELS_NUM 2 -#define MAX_DIMMS_NUM 2 - -typedef struct { - UINT16 RcompResistor[MRC_MAX_RCOMP]; ///< Offset 0: Reference RCOMP resistors on motherboard - UINT16 RcompTarget[MRC_MAX_RCOMP_TARGETS]; ///< Offset 6: RCOMP target values for DqOdt, DqDrv, CmdDrv, CtlDrv, ClkDrv -} MEMORY_RCOMP; - - -typedef struct { - UINT32 VendorDeviceId; /* Vendor ID/Device ID */ - UINT16 SubSystemId; /* SubSystem ID */ - UINT8 RevisionId; /* Revision ID. 0xFF applies to all steppings */ - UINT8 FrontPanelSupport; /* Front panel support (1=yes, 2=no) */ - UINT16 NumberOfRearJacks; /* Number of Rear Jacks */ - UINT16 NumberOfFrontJacks; /* Number of Front Jacks */ -} SA_HDA_HEADER; - -typedef struct { - UINT16 VendorId; /* Codec Vendor ID */ - UINT16 DeviceId; /* Codec Device ID */ - UINT8 RevisionId; /* Revision ID of the codec. 0xFF matches any revision. */ - UINT8 SdiNo; /* SDI number, 0xFF matches any SDI. */ - UINT16 DataDwords; /* Number of data DWORDs pointed by the codec data buffer. */ - UINT32 Reserved; /* Reserved for future use. Must be set to 0. */ -} AZALIA_HEADER; - -typedef struct { - AZALIA_HEADER Header; /* AZALIA PCH header */ - UINT32 *Data; /* Pointer to the data buffer. Its length is specified in the header */ -} AUDIO_AZALIA_VERB_TABLE; - -/// -/// Refer to the definition of PCH_INT_PIN -/// -typedef enum { - SiPchNoInt, ///< No Interrupt Pin - SiPchIntA, - SiPchIntB, - SiPchIntC, - SiPchIntD -} SI_PCH_INT_PIN; -/// -/// The PCH_DEVICE_INTERRUPT_CONFIG block describes interrupt pin, IRQ and interrupt mode for PCH device. -/// -typedef struct { - UINT8 Device; ///< Device number - UINT8 Function; ///< Device function - UINT8 IntX; ///< Interrupt pin: INTA-INTD (see SI_PCH_INT_PIN) - UINT8 Irq; ///< IRQ to be set for device. -} SI_PCH_DEVICE_INTERRUPT_CONFIG; - -#define SI_PCH_MAX_DEVICE_INTERRUPT_CONFIG 64 ///< Number of all PCH devices - -/// -/// USB Overcurrent pins definition, the values match the setting of PCH EDS, please refer to PCH EDS for more details -/// -typedef enum { - UsbOverCurrentPin0 = 0, - UsbOverCurrentPin1, - UsbOverCurrentPin2, - UsbOverCurrentPin3, - UsbOverCurrentPin4, - UsbOverCurrentPin5, - UsbOverCurrentPin6, - UsbOverCurrentPin7, - UsbOverCurrentPinSkip, - UsbOverCurrentPinMax -} USB_OVERCURRENT_PIN; - - -/// -/// The ChipsetInit Info structure provides the information of ME ChipsetInit CRC and BIOS ChipsetInit CRC. -/// -typedef struct { - UINT8 Revision; - UINT8 Rsvd[3]; - UINT16 MeChipInitCrc; - UINT16 BiosChipInitCrc; -} CHIPSET_INIT_INFO; - - -typedef struct { - UINT8 DimmId; - UINT32 SizeInMb; - UINT16 MfgId; - UINT8 ModulePartNum[20];/* Module part number for DDR3 is 18 bytes however for DRR4 20 bytes as per JEDEC Spec, so reserving 20 bytes */ -} DIMM_INFO; - -typedef struct { - UINT8 ChannelId; - UINT8 DimmCount; - DIMM_INFO DimmInfo[MAX_DIMMS_NUM]; -} CHANNEL_INFO; - -typedef struct { - UINT8 Revision; - UINT16 DataWidth; - /** As defined in SMBIOS 3.0 spec - Section 7.18.2 and Table 75 - **/ - UINT8 MemoryType; - UINT16 MemoryFrequencyInMHz; - /** As defined in SMBIOS 3.0 spec - Section 7.17.3 and Table 72 - **/ - UINT8 ErrorCorrectionType; - UINT8 ChannelCount; - CHANNEL_INFO ChannelInfo[MAX_CHANNELS_NUM]; -} FSP_SMBIOS_MEMORY_INFO; - - - -/** UPD data structure for FspMemoryInitApi -**/ -typedef struct { - -/** Offset 0x0020 -**/ - UINT64 Signature; - -/** Offset 0x0028 - Revision - Revision version of the MemoryInitUpd Region -**/ - UINT8 Revision; - -/** Offset 0x0029 -**/ - UINT8 UnusedUpdSpace0[7]; - -/** Offset 0x0030 - Platform Reserved Memory Size - The minimum platform memory size required to pass control into DXE - 0x400000 : 0x400000 -**/ - UINT64 PlatformMemorySize; - -/** Offset 0x0038 - Memory SPD Pointer Channel 0 Dimm 0 - Pointer to SPD data in Memory. Default: 0 for empty channel -**/ - UINT32 MemorySpdPtr00; - -/** Offset 0x003C - Memory SPD Pointer Channel 0 Dimm 1 - Pointer to SPD data in Memory. Default: 0 for empty channel -**/ - UINT32 MemorySpdPtr01; - -/** Offset 0x0040 - Memory SPD Pointer Channel 1 Dimm 0 - Pointer to SPD data in Memory. Default: 0 for empty channel -**/ - UINT32 MemorySpdPtr10; - -/** Offset 0x0044 - Memory SPD Pointer Channel 1 Dimm 1 - Pointer to SPD data in Memory. Default: 0 for empty channel -**/ - UINT32 MemorySpdPtr11; - -/** Offset 0x0048 - SPD Data Length - Length of SPD Data - 0x100:256 Bytes, 0x200:512 Bytes -**/ - UINT16 MemorySpdDataLen; - -/** Offset 0x004A - Dq Byte Map CH0 - Dq byte mapping between CPU and DRAM, Channel 0: board-dependent -**/ - UINT8 DqByteMapCh0[12]; - -/** Offset 0x0056 - Dq Byte Map CH1 - Dq byte mapping between CPU and DRAM, Channel 1: board-dependent -**/ - UINT8 DqByteMapCh1[12]; - -/** Offset 0x0062 - Dqs Map CPU to DRAM CH 0 - Set Dqs mapping relationship between CPU and DRAM, Channel 0: board-dependent -**/ - UINT8 DqsMapCpu2DramCh0[8]; - -/** Offset 0x006A - Dqs Map CPU to DRAM CH 1 - Set Dqs mapping relationship between CPU and DRAM, Channel 1: board-dependent -**/ - UINT8 DqsMapCpu2DramCh1[8]; - -/** Offset 0x0072 - RcompResister settings - Indicates RcompReister settings: Board-dependent -**/ - UINT16 RcompResistor[3]; - -/** Offset 0x0078 - RcompTarget settings - RcompTarget settings: board-dependent -**/ - UINT16 RcompTarget[5]; - -/** Offset 0x0082 - Dqs Pins Interleaved Setting - Indicates DqPinsInterleaved setting: board-dependent - $EN_DIS -**/ - UINT8 DqPinsInterleaved; - -/** Offset 0x0083 - VREF_CA - CA Vref routing: board-dependent - 0:VREF_CA goes to both CH_A and CH_B, 1: VREF_CA to CH_A and VREF_DQ_A to CH_B, 2:VREF_CA to CH_A and VREF_DQ_B to CH_B -**/ - UINT8 CaVrefConfig; - -/** Offset 0x0084 - Smram Mask - The SMM Regions AB-SEG and/or H-SEG reserved - 0: Neither, 1:AB-SEG, 2:H-SEG, 3: Both -**/ - UINT8 SmramMask; - -/** Offset 0x0085 - MRC Fast Boot - Enables/Disable the MRC fast path thru the MRC - $EN_DIS -**/ - UINT8 MrcFastBoot; - -/** Offset 0x0086 -**/ - UINT16 UnusedUpdSpace1; - -/** Offset 0x0088 - Intel Enhanced Debug - Intel Enhanced Debug (IED): 0=Disabled, 0x400000=Enabled and 4MB SMRAM occupied - 0 : Disable, 0x400000 : Enable -**/ - UINT32 IedSize; - -/** Offset 0x008C - Tseg Size - Size of SMRAM memory reserved. 0x400000 for Release build and 0x1000000 for Debug build - 0x0400000:4MB, 0x01000000:16MB -**/ - UINT32 TsegSize; - -/** Offset 0x0090 - MMIO Size - Size of memory address space reserved for MMIO (Memory Mapped I/O) in MB. - 0x0600 : 0x0600 -**/ - UINT16 MmioSize; - -/** Offset 0x0092 - Probeless Trace - Probeless Trace: 0=Disabled, 1=Enable. Enabling Probeless Trace will reserve 128MB. This also requires IED to be enabled. - $EN_DIS -**/ - UINT8 ProbelessTrace; - -/** Offset 0x0093 -**/ - UINT8 UnusedUpdSpace2[3]; - -/** Offset 0x0096 - Enable Trace Hub - Enable/disable Trace Hub function. - $EN_DIS -**/ - UINT8 EnableTraceHub; - -/** Offset 0x0097 -**/ - UINT8 UnusedUpdSpace3[60]; - -/** Offset 0x00D3 - Internal Graphics Pre-allocated Memory - Size of memory preallocated for internal graphics. - 0x00:0 MB, 0x01:32 MB, 0x02:64 MB, 0x03:128 MB, 0x04:256 MB, 0x05:512 MB -**/ - UINT8 IgdDvmt50PreAlloc; - -/** Offset 0x00D4 - Internal Graphics - Enable/disable internal graphics. - $EN_DIS -**/ - UINT8 InternalGfx; - -/** Offset 0x00D5 - Aperture Size - Select the Aperture Size. - 0:128 MB, 1:256 MB, 2:512 MB -**/ - UINT8 ApertureSize; - -/** Offset 0x00D6 - SA GV - System Agent dynamic frequency support and when enabled memory will be training at two different frequencies. Only effects ULX/ULT CPUs. 0=Disabled, 1=FixedLow, 2=FixedHigh, and 3=Enabled. - 0:Disabled, 1:FixedLow, 2:FixedHigh, 3:Enabled -**/ - UINT8 SaGv; - -/** Offset 0x00D7 - Rank Margin Tool - Enable/disable Rank Margin Tool. - $EN_DIS -**/ - UINT8 RMT; - -/** Offset 0x00D8 - DDR Frequency Limit - Maximum Memory Frequency Selections in Mhz. Options are 1067, 1333, 1600, 1867, 2133, 2400 and 0 for Auto. - 1067:1067, 1333:1333, 1600:1600, 1867:1867, 2133:2133, 2400:2400, 0:Auto -**/ - UINT16 DdrFreqLimit; - -/** Offset 0x00DA - Board Type - MrcBoardType, Options are 0=Mobile/Mobile Halo, 1=Desktop/DT Halo, 5=ULT/ULX/Mobile Halo, 7=UP Server - 0:Mobile/Mobile Halo, 1:Desktop/DT Halo, 5:ULT/ULX/Mobile Halo, 7:UP Server -**/ - UINT8 UserBd; - -/** Offset 0x00DB -**/ - UINT8 UnusedUpdSpace4[105]; - -/** Offset 0x0144 - MMA Test Content Pointer - Pointer to MMA Test Content in Memory -**/ - UINT32 MmaTestContentPtr; - -/** Offset 0x0148 - MMA Test Content Size - Size of MMA Test Content in Memory -**/ - UINT32 MmaTestContentSize; - -/** Offset 0x014C - MMA Test Config Pointer - Pointer to MMA Test Config in Memory -**/ - UINT32 MmaTestConfigPtr; - -/** Offset 0x0150 - MMA Test Config Size - Size of MMA Test Config in Memory -**/ - UINT32 MmaTestConfigSize; - -/** Offset 0x0154 -**/ - UINT32 FspCarBase; - -/** Offset 0x0158 -**/ - UINT32 FspCarSize; - -/** Offset 0x015C - SMBUS SPD Write Disable - Set/Clear Smbus SPD Write Disable. 0: leave SPD Write Disable bit; 1: set SPD Write Disable bit. For security recommendations, SPD write disable bit must be set. - $EN_DIS -**/ - UINT8 SmbusSpdWriteDisable; - -/** Offset 0x015D -**/ - UINT8 ReservedMemoryInitUpd[163]; -} MEMORY_INIT_UPD; - -/** UPD data structure for FspSiliconInitApi -**/ -typedef struct { - -/** Offset 0x0200 -**/ - UINT64 Signature; - -/** Offset 0x0208 - Revision - Revision version of the SiliconInitUpd Region -**/ - UINT8 Revision; - -/** Offset 0x0209 -**/ - UINT8 UnusedUpdSpace5[7]; - -/** Offset 0x0210 - Logo Pointer - Points to PEI Display Logo Image - 0 : 0 -**/ - UINT32 LogoPtr; - -/** Offset 0x0214 - Logo Size - Size of PEI Display Logo Image - 0 : 0 -**/ - UINT32 LogoSize; - -/** Offset 0x0218 - Graphics Configuration Ptr - Points to VBT - 0 : 0 -**/ - UINT32 GraphicsConfigPtr; - -/** Offset 0x021C - Enable Device 4 - Enable/disable Device 4 - $EN_DIS -**/ - UINT8 Device4Enable; - -/** Offset 0x021D - Enable Azalia - Enable/disable Azalia controller. - $EN_DIS -**/ - UINT8 EnableAzalia; - -/** Offset 0x021E - Enable HD Audio DSP - Enable/disable HD Audio DSP feature. - $EN_DIS -**/ - UINT8 DspEnable; - -/** Offset 0x021F - Select HDAudio IoBuffer Ownership - Indicates the ownership of the I/O buffer between Intel HD Audio link vs I2S0 / I2S port. 0: Intel HD-Audio link owns all the I/O buffers. 1: Intel HD-Audio link owns 4 of the I/O buffers for 1 HD-Audio codec connection, and I2S1 port owns 4 of the I/O buffers for 1 I2S codec connection. 2: Reserved. 3: I2S0 and I2S1 ports own all the I/O buffers. - 0:HD-A Link, 1:Shared HD-A Link and I2S Port, 3:I2S Ports -**/ - UINT8 IoBufferOwnership; - -/** Offset 0x0220 - Enable CIO2 Controller - Enable/disable SKYCAM CIO2 Controller. - $EN_DIS -**/ - UINT8 Cio2Enable; - -/** Offset 0x0221 - Enable eMMC Controller - Enable/disable eMMC Controller. - $EN_DIS -**/ - UINT8 ScsEmmcEnabled; - -/** Offset 0x0222 - Enable eMMC HS400 Mode - Enable eMMC HS400 Mode. - $EN_DIS -**/ - UINT8 ScsEmmcHs400Enabled; - -/** Offset 0x0223 - Enable SdCard Controller - Enable/disable SD Card Controller. - $EN_DIS -**/ - UINT8 ScsSdCardEnabled; - -/** Offset 0x0224 - Enable ISH Controller - Enable/disable ISH Controller. - $EN_DIS -**/ - UINT8 IshEnable; - -/** Offset 0x0225 - Show SPI controller - Enable/disable to show SPI controller. - $EN_DIS -**/ - UINT8 ShowSpiController; - -/** Offset 0x0226 - HSIO HECI Messaging - Enable/Disable. 0: Disable, prevent the HSIO version check and HSIO init messages from being sent, 1: enable - $EN_DIS -**/ - UINT8 HsioMessaging; - -/** Offset 0x0227 - HECI3 state - The HECI3 state from Mbp for reference in S3 path or when MbpHob is not installed. This must be enabled if Integrated Touch (iTouch) is supported. 0: disable, 1: enable - $EN_DIS -**/ - UINT8 Heci3Enabled; - -/** Offset 0x0228 - MicrocodeRegionBase - Memory Base of Microcode Updates -**/ - UINT32 MicrocodeRegionBase; - -/** Offset 0x022C - MicrocodeRegionSize - Size of Microcode Updates -**/ - UINT32 MicrocodeRegionSize; - -/** Offset 0x0230 - Turbo Mode - Enable/Disable Turbo mode. 0: disable, 1: enable - $EN_DIS -**/ - UINT8 TurboMode; - -/** Offset 0x0231 - Enable SATA SALP Support - Enable/disable SATA Aggressive Link Power Management. - $EN_DIS -**/ - UINT8 SataSalpSupport; - -/** Offset 0x0232 - Enable SATA ports - Enable/disable SATA ports. One byte for each port, byte0 for port0, byte1 for port1, and so on. -**/ - UINT8 SataPortsEnable[8]; - -/** Offset 0x023A - Enable SATA DEVSLP Feature - Enable/disable SATA DEVSLP per port. 0 is disable, 1 is enable. One byte for each port, byte0 for port0, byte1 for port1, and so on. -**/ - UINT8 SataPortsDevSlp[8]; - -/** Offset 0x0242 - Enable USB2 ports - Enable/disable per USB2 ports. One byte for each port, byte0 for port0, byte1 for port1, and so on. -**/ - UINT8 PortUsb20Enable[16]; - -/** Offset 0x0252 - Enable USB3 ports - Enable/disable per USB3 ports. One byte for each port, byte0 for port0, byte1 for port1, and so on. -**/ - UINT8 PortUsb30Enable[10]; - -/** Offset 0x025C - Enable xDCI controller - Enable/disable to xDCI controller. - $EN_DIS -**/ - UINT8 XdciEnable; - -/** Offset 0x025D - Enable XHCI SSIC Eanble - Enable/disable XHCI SSIC port. - $EN_DIS -**/ - UINT8 SsicPortEnable; - -/** Offset 0x025E - Enable SMBus - Enable/disable SMBus controller. - $EN_DIS -**/ - UINT8 SmbusEnable; - -/** Offset 0x025F - Enable SerialIo Device Mode - 0:Disabled, 1:ACPI Mode, 2:PCI Mode, 3:Hidden mode, 4:Legacy UART mode - Enable/disable SerialIo I2C0,I2C1,I2C2,I2C3,I2C4,I2C5,SPI0,SPI1,UART0,UART1,UART2 device mode respectively. One byte for each controller, byte0 for I2C0, byte1 for I2C1, and so on. -**/ - UINT8 SerialIoDevMode[11]; - -/** Offset 0x026A - Address of PCH_DEVICE_INTERRUPT_CONFIG table. - The address of the table of PCH_DEVICE_INTERRUPT_CONFIG. -**/ - UINT32 DevIntConfigPtr; - -/** Offset 0x026E - Number of DevIntConfig Entry - Number of Device Interrupt Configuration Entry. If this is not zero, the DevIntConfigPtr must not be NULL. -**/ - UINT8 NumOfDevIntConfig; - -/** Offset 0x026F - PIRQx to IRQx Map Config - PIRQx to IRQx mapping. The valid value is 0x00 to 0x0F for each. First byte is for PIRQA, second byte is for PIRQB, and so on. The setting is only available in Legacy 8259 PCI mode. -**/ - UINT8 PxRcConfig[8]; - -/** Offset 0x0277 - Select GPIO IRQ Route - GPIO IRQ Select. The valid value is 14 or 15. - 0 : 0xFF -**/ - UINT8 GpioIrqRoute; - -/** Offset 0x0278 - Select SciIrqSelect - SCI IRQ Select. The valid value is 9, 10, 11, and 20, 21, 22, 23 for APIC only. - 0 : 0xFF -**/ - UINT8 SciIrqSelect; - -/** Offset 0x0279 - Select TcoIrqSelect - TCO IRQ Select. The valid value is 9, 10, 11, 20, 21, 22, 23. - 0 : 0xFF -**/ - UINT8 TcoIrqSelect; - -/** Offset 0x027A - Enable/Disable Tco IRQ - Enable/disable TCO IRQ - $EN_DIS -**/ - UINT8 TcoIrqEnable; - -/** Offset 0x027B - AzaliaVerbTableNumEntries - Number of Entries in Azalia Verb Table -**/ - UINT8 AzaliaVerbTableNumEntries; - -/** Offset 0x027C - AzaliaVerbTablePtr - Pointer to Array of pointers to Codec Table. -**/ - UINT32 AzaliaVerbTablePtr; - -/** Offset 0x0280 - RTC CMOS RAM LOCK - Enable RTC lower and upper 128 byte Lock bits to lock Bytes 38h-3Fh in the upper and and lower 128-byte bank of RTC RAM. - $EN_DIS -**/ - UINT8 LockDownConfigRtcLock; - -/** Offset 0x0281 - Enable SATA - Enable/disable SATA controller. - $EN_DIS -**/ - UINT8 EnableSata; - -/** Offset 0x0282 - SATA Mode - Select SATA controller working mode. - 0:AHCI, 1:RAID -**/ - UINT8 SataMode; - -/** Offset 0x0283 - USB Per Port HS Preemphasis Bias - USB Per Port HS Preemphasis Bias. 000b-0mV, 001b-11.25mV, 010b-16.9mV, 011b-28.15mV, 100b-28.15mV, 101b-39.35mV, 110b-45mV, 111b-56.3mV. One byte for each port. -**/ - UINT8 Usb2AfePetxiset[16]; - -/** Offset 0x0293 - USB Per Port HS Transmitter Bias - USB Per Port HS Transmitter Bias. 000b-0mV, 001b-11.25mV, 010b-16.9mV, 011b-28.15mV, 100b-28.15mV, 101b-39.35mV, 110b-45mV, 111b-56.3mV, One byte for each port. -**/ - UINT8 Usb2AfeTxiset[16]; - -/** Offset 0x02A3 - USB Per Port HS Transmitter Emphasis - USB Per Port HS Transmitter Emphasis. 00b - Emphasis OFF, 01b - De-emphasis ON, 10b - Pre-emphasis ON, 11b - Pre-emphasis & De-emphasis ON. One byte for each port. -**/ - UINT8 Usb2AfePredeemp[16]; - -/** Offset 0x02B3 - USB Per Port Half Bit Pre-emphasis - USB Per Port Half Bit Pre-emphasis. 1b - half-bit pre-emphasis, 0b - full-bit pre-emphasis. One byte for each port. -**/ - UINT8 Usb2AfePehalfbit[16]; - -/** Offset 0x02C3 - Enable the write to USB 3.0 TX Output -3.5dB De-Emphasis Adjustment - Enable the write to USB 3.0 TX Output -3.5dB De-Emphasis Adjustment. Each value in arrary can be between 0-1. One byte for each port. -**/ - UINT8 Usb3HsioTxDeEmphEnable[10]; - -/** Offset 0x02CD - USB 3.0 TX Output -3.5dB De-Emphasis Adjustment Setting - USB 3.0 TX Output -3.5dB De-Emphasis Adjustment Setting, HSIO_TX_DWORD5[21:16], <b>Default = 29h</b> (approximately -3.5dB De-Emphasis). One byte for each port. -**/ - UINT8 Usb3HsioTxDeEmph[10]; - -/** Offset 0x02D7 - Enable the write to USB 3.0 TX Output Downscale Amplitude Adjustment - Enable the write to USB 3.0 TX Output Downscale Amplitude Adjustment, Each value in arrary can be between 0-1. One byte for each port. -**/ - UINT8 Usb3HsioTxDownscaleAmpEnable[10]; - -/** Offset 0x02E1 - USB 3.0 TX Output Downscale Amplitude Adjustment - USB 3.0 TX Output Downscale Amplitude Adjustment, HSIO_TX_DWORD8[21:16], <b>Default = 00h</b>. One byte for each port. -**/ - UINT8 Usb3HsioTxDownscaleAmp[10]; - -/** Offset 0x02EB - Enable PCIE RP - Enable/disable PCIE Root Ports. 0: disable, 1: enable. One byte for each port, byte0 for port1, byte1 for port2, and so on. -**/ - UINT8 PcieRpEnable[20]; - -/** Offset 0x02FF - Enable PCIE RP PMSCI - Indicate whether the root port power manager SCI is enabled - 0: disable, 1: enable. One byte for each port, byte0 for port1, byte1 for port2, and so on. -**/ - UINT8 PcieRpPmSci[20]; - -/** Offset 0x0313 - Enable PCIE RP CLKREQ Support - Enable/disable PCIE Root Port CLKREQ support. 0: disable, 1: enable. One byte for each port, byte0 for port1, byte1 for port2, and so on. -**/ - UINT8 PcieRpClkReqSupport[20]; - -/** Offset 0x0327 - Configure CLKREQ Number - Configure Root Port CLKREQ Number if CLKREQ is supported. Each value in arrary can be between 0-6. One byte for each port, byte0 for port1, byte1 for port2, and so on. -**/ - UINT8 PcieRpClkReqNumber[20]; - -/** Offset 0x033B - Enable LAN - Enable/Disable LAN controller. - $EN_DIS -**/ - UINT8 EnableLan; - -/** Offset 0x033C - LAN LTR Programming - Enable/Disable LTR capabilty of PCH internal LAN. - $EN_DIS -**/ - UINT8 LanLtrEnable; - -/** Offset 0x033D - SATA eSATASpeedLimit - When enabled, BIOS will configure the PxSCTL.SPD to 2 to limit the eSATA port speed. 0: disable, 1: enable. - $EN_DIS -**/ - UINT8 eSATASpeedLimit; - -/** Offset 0x033E - SATA RST RAID0 - Enable/Disable RAID0. - $EN_DIS -**/ - UINT8 SataRstRaid0; - -/** Offset 0x033F - SATA RST RAID1 - Enable/Disable RAID1. - $EN_DIS -**/ - UINT8 SataRstRaid1; - -/** Offset 0x0340 - SATA RST RAID10 - Enable/Disable RAID10. - $EN_DIS -**/ - UINT8 SataRstRaid10; - -/** Offset 0x0341 - SATA RST RAID5 - Enable/Disable RAID5. - $EN_DIS -**/ - UINT8 SataRstRaid5; - -/** Offset 0x0342 - Skip Multi-Processor Initialization - When this is skipped, boot loader must initialize processors before SilicionInit API. 0: Initialize, 1: Skip - $EN_DIS -**/ - UINT8 SkipMpInit; - -/** Offset 0x0343 - Enable PCIE RP HotPlug - Enable/disable PCIE Root Ports HogPlug. 0: disable, 1: enable. One byte for each port, byte0 for port1, byte1 for port2, and so on. -**/ - UINT8 PcieRpHotPlug[20]; - -/** Offset 0x0357 - Enable PCIE RP Function Swap - Enable/disable PCIE RP function swap. 0: disable, 1: enable. It allows BIOS to use root port function number swapping when root port of function 0 is disabled. NOTE: This option will not work if ports 1, 9, 17 are fused or configured for RST PCIe storage. Disabling function swap may have adverse impact on power management. - $EN_DIS -**/ - UINT8 RpFunctionSwap; - -/** Offset 0x0358 - USB2 Port Over Current Configuration - Configure over current pin assignment per USB2 ports. Refer to USB_OVERCURRENT_PIN. 0x08 means "skip over current pin". One byte for each port, byte0 for port0, byte1 for port1, and so on. -**/ - UINT8 Usb2OverCurrentPin[16]; - -/** Offset 0x0368 - USB3 Port Over Current Configuration - Configure over current pin assignment per USB3 ports. Refer to USB_OVERCURRENT_PIN. 0x08 means "skip over current pin". One byte for each port, byte0 for port0, byte1 for port1, and so on. -**/ - UINT8 Usb3OverCurrentPin[10]; - -/** Offset 0x0372 - Psi1Threshold - Power State 1 current cuttof in 1/4 Amp increments. Range is 0-128A. Array index maps to VR 0 = System Agent, 1 = IA Core, 2 = Ring, 3 = GT unsliced, 4 = GT sliced -**/ - UINT16 Psi1Threshold[5]; - -/** Offset 0x037C - Psi2Threshold - Power State 2 current cuttof in 1/4 Amp increments. Range is 0-128A. Array index maps to VR 0 = System Agent, 1 = IA Core, 2 = Ring, 3 = GT unsliced, 4 = GT sliced -**/ - UINT16 Psi2Threshold[5]; - -/** Offset 0x0386 - Psi3Threshold - State 3 current cuttof in 1/4 Amp increments. Range is 0-128A. Array index maps to VR 0 = System Agent, 1 = IA Core, 2 = Ring, 3 = GT unsliced, 4 = GT sliced -**/ - UINT16 Psi3Threshold[5]; - -/** Offset 0x0390 - Psi3Enable - Power State 3 0: Disable 1: Enable. Array index maps to VR 0 = System Agent, 1 = IA Core, 2 = Ring, 3 = GT unsliced, 4 = GT sliced -**/ - UINT8 Psi3Enable[5]; - -/** Offset 0x0395 - Psi4Enable - Power State 4 0: Disable 1: Enable. Array index maps to VR 0 = System Agent, 1 = IA Core, 2 = Ring, 3 = GT unsliced, 4 = GT sliced -**/ - UINT8 Psi4Enable[5]; - -/** Offset 0x039A - ImonSlope - Imon slope correction. Specified in 1/100 increment values. Range is 0-200. 125 = 1.25. 0: Auto Array index maps to VR 0 = System Agent, 1 = IA Core, 2 = Ring, 3 = GT unsliced, 4 = GT sliced -**/ - UINT8 ImonSlope[5]; - -/** Offset 0x039F - ImonOffset - Imon offset correction. Units 1/4, Range 0-255. Value of 100 = 100/4 = 25 offset. 0: Auto Array index maps to VR 0 = System Agent, 1 = IA Core, 2 = Ring, 3 = GT unsliced, 4 = GT sliced -**/ - UINT8 ImonOffset[5]; - -/** Offset 0x03A4 - IccMax - VR Icc Max limit. 0-255A in 1/4 A units. 400 = 100A Array index maps to VR 0 = System Agent, 1 = IA Core, 2 = Ring, 3 = GT unsliced, 4 = GT sliced -**/ - UINT16 IccMax[5]; - -/** Offset 0x03AE - VrVoltageLimit - VR Voltage Limit. Range is 0-7999mV. Array index maps to VR 0 = System Agent, 1 = IA Core, 2 = Ring, 3 = GT unsliced, 4 = GT sliced -**/ - UINT16 VrVoltageLimit[5]; - -/** Offset 0x03B8 - VrConfigEnable - BIOS configuration of VR 0: Disable 1: Enable. Array index maps to VR 0 = System Agent, 1 = IA Core, 2 = Ring, 3 = GT unsliced, 4 = GT sliced -**/ - UINT8 VrConfigEnable[5]; - -/** Offset 0x03BD - CPU S3 Resume Data - CPU S3 Resume Data passed from the FSP CPU S3 Resume HOB during normal boot. -**/ - UINT32 CpuS3ResumeHobData; - -/** Offset 0x03C1 - CpuS3ResumeMtrrData - Pointer CPU S3 Resume MTRR Data -**/ - UINT32 CpuS3ResumeMtrrData; - -/** Offset 0x03C5 - CpuS3ResumeMtrrDataSize - Size of S3 resume MTRR data. -**/ - UINT16 CpuS3ResumeMtrrDataSize; - -/** Offset 0x03C7 - Lock Down Config Global Smi - Enable SMI_LOCK bit to prevent writes to the Global SMI Enable bit. Value 0: Disable, 1: Enable. - $EN_DIS -**/ - UINT8 LockDownConfigGlobalSmi; - -/** Offset 0x03C8 - Lock Down Config Bios Interface - Enable BIOS Interface Lock Down bit to prevent writes to the Backup Control Register. Top Swap bit and the General Control and Status Registers Boot BIOS Straps. Value 0: Disable, 1: Enable. - $EN_DIS -**/ - UINT8 LockDownConfigBiosInterface; - -/** Offset 0x03C9 - Lock Down Config Bios Lock - When enabled, the BIOS Region can only be modified from SMM after EndOfDxe protocol is installed. Value 0: Disable, 1: Enable. - $EN_DIS -**/ - UINT8 LockDownConfigBiosLock; - -/** Offset 0x03CA - Lock Down Config Spi Eiss - Enable InSMM.STS (EISS) in SPI If this bit is set, then WPD must be a '1' and InSMM.STS must be '1' also in order to write to BIOS regions of SPI Flash. If this bit is clear, then the InSMM.STS is a don't care. The BIOS must set the EISS bit while BIOS Guard support is enabled. Value 0: Clear EISS bit, 1: Set EISS bit. - $EN_DIS -**/ - UINT8 LockDownConfigSpiEiss; - -/** Offset 0x03CB - Subsystem Vendor ID - Subsystem Vendor ID of the PCH devices. -**/ - UINT16 PchConfigSubSystemVendorId; - -/** Offset 0x03CD - Subsystem ID - Subsystem ID of the PCH devices. -**/ - UINT16 PchConfigSubSystemId; - -/** Offset 0x03CF - Wol Enable Override - Corresponds to the "WOL Enable Override" bit in the General PM Configuration B (GEN_PMCON_B) register. Value 0: Disable, 1: Enable. - $EN_DIS -**/ - UINT8 WakeConfigWolEnableOverride; - -/** Offset 0x03D0 - Pcie Wake From DeepSx - Determine if enable PCIe to wake from deep Sx. Value 0: Disable, 1: Enable. - $EN_DIS -**/ - UINT8 WakeConfigPcieWakeFromDeepSx; - -/** Offset 0x03D1 - Power Management DeepSxPolicy - Deep Sx Policy. Values 0: PchDeepSxPolDisable, 1: PchDpS5BatteryEn, 2: PchDpS5AlwaysEn, 3: PchDpS4S5BatteryEn, 4: PchDpS4S5AlwaysEn, 5: PchDpS3S4S5BatteryEn, 6: PchDpS3S4S5AlwaysEn. - 0 : 0x06 -**/ - UINT8 PmConfigDeepSxPol; - -/** Offset 0x03D2 - Power Management SlpS3MinAssert - SLP_S3 Minimum Assertion Width Policy. Values 0: PchSlpS360us, 1: PchSlpS31ms, 2: PchSlpS350ms, 3: PchSlpS32s. - 0 : 0x03 -**/ - UINT8 PmConfigSlpS3MinAssert; - -/** Offset 0x03D3 - Power Management SlpS4MinAssert - SLP_S4 Minimum Assertion Width Policy. Values 0: PchSlpS4PchTime, 1: PchSlpS41s, 2: PchSlpS42s, 3: PchSlpS43s, 4: PchSlpS44s. - 0 : 0x04 -**/ - UINT8 PmConfigSlpS4MinAssert; - -/** Offset 0x03D4 - Power Management SlpSusMinAssert - SLP_SUS Minimum Assertion Width Policy. Values 0: PchSlpSus0ms, 1: PchSlpSus500ms, 2: PchSlpSus1s, 3: PchSlpSus4s. - 0 : 0x03 -**/ - UINT8 PmConfigSlpSusMinAssert; - -/** Offset 0x03D5 - Power Management SlpAMinAssert - SLP_A Minimum Assertion Width Policy. Values 0: PchSlpA0ms, 1: PchSlpA4s, 2: PchSlpA98ms, 3: PchSlpA2s. - 0 : 0x03 -**/ - UINT8 PmConfigSlpAMinAssert; - -/** Offset 0x03D6 - Power Management Pci Clock Run - This member describes whether or not the PCI ClockRun feature of PCH should be enabled. Values 0: Disabled, 1: Enabled - $EN_DIS -**/ - UINT8 PmConfigPciClockRun; - -/** Offset 0x03D7 - Power Management SLP_X Stretching After SUS Well - SLP_X Stretching After SUS Well Power Up. Values 0: Disabled, 1: Enabled - $EN_DIS -**/ - UINT8 PmConfigSlpStrchSusUp; - -/** Offset 0x03D8 - Power Management Power Button Override Period - PCH power button override period. Values: 0x0 - 4s, 0x1 - 6s, 0x2 - 8s, 0x3 - 10s, 0x4 - 12s, 0x5 - 14s. - 0 : 0x05 -**/ - UINT8 PmConfigPwrBtnOverridePeriod; - -/** Offset 0x03D9 - Power Management Power Reset Power Cycle Duration - Reset Power Cycle Duration could be customized in the unit of second. PCH HW default is 4 seconds, and range is 1~4 seconds. Values: 0x0 - 0s, 0x1 - 1s, 0x2 - 2s, 0x3 - 3s, 0x4 - 4s. - 0 : 0x04 -**/ - UINT8 PmConfigPwrCycDur; - -/** Offset 0x03DA - PCH Serial IRQ Configuration - Determines if enable Serial IRQ. Values 0: Disabled, 1: Enabled - $EN_DIS -**/ - UINT8 SerialIrqConfigSirqEnable; - -/** Offset 0x03DB - PCH Serial IRQ Mode Select - Serial IRQ Mode Select. Values: 0: PchQuietMode, 1: PchContinuousMode. - 0 : 0x01 -**/ - UINT8 SerialIrqConfigSirqMode; - -/** Offset 0x03DC - PCH Serial IRQ Start Frame Pulse Width - Start Frame Pulse Width. Values: 0: PchSfpw4Clk, 1: PchSfpw6Clk, 2: PchSfpw8Clk. - 0 : 0x02 -**/ - UINT8 SerialIrqConfigStartFramePulse; - -/** Offset 0x03DD - PSF Unlock - The PSF registers will be locked before 3rd party code execution. This policy unlock the PSF space. NOTE: Do not set this policy "PsfUnlock" unless necessary. - $EN_DIS -**/ - UINT8 PsfUnlock; - -/** Offset 0x03DE - IO voltage for I2C controllers - Selects the IO voltage for I2C controllers, 0: PchSerialIoIs33V, 1: PchSerialIoIs18V. -**/ - UINT8 SerialIoI2cVoltage[6]; - -/** Offset 0x03E4 - Enable 8254 Static Clock Gating in early POST time - Set 8254CGE=1 is required for C11 support. However, set 8254CGE=1 in POST time might fail to boot legacy OS which using 8254 timer. Make sure it won't break legacy OS boot before enabling this. - $EN_DIS -**/ - UINT8 Early8254ClockGatingEnable; - -/** Offset 0x03E5 - Enable VR specific mailbox command - VR specific mailbox commands, 000b: no VR specific command sent, 001b: A VR mailbox command specifically for the MPS IMPV8 VR will be sent, 010b: VR specific command sent for PS4 exit issue, 011b: VR specific command sent for both MPS IMPV8 & PS4 exit issue. - $EN_DIS -**/ - UINT8 SendVrMbxCmd; - -/** Offset 0x03E6 -**/ - UINT8 AcousticNoiseMitigation; - -/** Offset 0x03E7 -**/ - UINT8 SlowSlewRateForIa; - -/** Offset 0x03E8 -**/ - UINT8 SlowSlewRateForGt; - -/** Offset 0x03E9 -**/ - UINT8 SlowSlewRateForSa; - -/** Offset 0x03EA -**/ - UINT8 FastPkgCRampDisable; - -/** Offset 0x03EB -**/ - UINT8 ReservedSiliconInitUpd[15]; -} SILICON_INIT_UPD; - -#define FSP_UPD_SIGNATURE 0x244450554C4B5324 /* '$SKLUPD$' */ -#define FSP_MEMORY_INIT_UPD_SIGNATURE 0x244450554D454D24 /* '$MEMUPD$' */ -#define FSP_SILICON_INIT_UPD_SIGNATURE 0x244450555F495324 /* '$SI_UPD$' */ - -/** UPD data structure. The UPD_DATA_REGION may contain some reserved or unused fields in the data structure. These fields are required to use the default values provided in the FSP binary. Intel always recommends copying the whole UPD_DATA_REGION from the flash to a local structure in the stack before overriding any field. -**/ -typedef struct { - -/** Offset 0x0000 -**/ - UINT64 Signature; - -/** Offset 0x0008 - This field is not an option and is a Revision of the UPD_DATA_REGION. It can be used by the boot loader to validate the UPD region. If the value in this field is changed for an FSP release, the boot loader should not assume the same layout for the UPD_DATA_REGION data structure. Instead it should use the new FspUpdVpd.h from the FSP release package. - Size of SMRAM memory reserved. 0x400000 for Release build and 0x1000000 for Debug build -**/ - UINT8 Revision; - -/** Offset 0x0009 -**/ - UINT8 ReservedUpd0[7]; - -/** Offset 0x0010 - MemoryInitUpdOffset - This field contains the offset of the MemoryInitUpd structure relative to UPD_DATA_REGION -**/ - UINT32 MemoryInitUpdOffset; - -/** Offset 0x0014 - SiliconInitUpdOffset - This field contains the offset of the SiliconInitUpd structure relative to UPD_DATA_REGION -**/ - UINT32 SiliconInitUpdOffset; - -/** Offset 0x0018 -**/ - UINT64 ReservedUpd1; - -/** Offset 0x0020 -**/ - MEMORY_INIT_UPD MemoryInitUpd; - -/** Offset 0x0200 -**/ - SILICON_INIT_UPD SiliconInitUpd; - -/** Offset 0x03FA - RegionTerminator - This field is not an option and is a termination field at the end of the data structure. This field is will have a value 0x55AA indicating the end of UPD data.The boot loader should never override this field. -**/ - UINT16 RegionTerminator; -} UPD_DATA_REGION; - -#define FSP_IMAGE_ID 0x245053464C4B5324 /* '$SKLFSP$' */ -#define FSP_IMAGE_REV 0x01090000 - -/** VPD data structure -**/ -typedef struct { - -/** Offset 0x0000 -**/ - UINT64 PcdVpdRegionSign; - -/** Offset 0x0008 - PcdImageRevision - This field is not an option and is a revision ID for the FSP release. It can be used by the boot loader to validate the VPD/UPD region. If the value in this field is changed for an FSP release, the boot loader should not assume the same layout for the UPD_DATA_REGION/VPD_DATA_REGION data structure. Instead it should use the new FspUpdVpd.h from the FSP release package. This should match the ImageRevision in FSP_INFO_HEADER. -**/ - UINT32 PcdImageRevision; - -/** Offset 0x000C -**/ - UINT32 PcdUpdRegionOffset; - -/** Offset 0x0010 -**/ - UINT8 UnusedVpdSpace0[32]; - -/** Offset 0x0030 - PcdSerialIoUartDebugEnable - Enable SerialIo Uart debug library with/without initializing SerialIo Uart device in FSP. - 0:Disable, 1:Enable and Initialize, 2:Enable without Initializing -**/ - UINT8 PcdSerialIoUartDebugEnable; - -/** Offset 0x0031 - PcdSerialIoUartNumber - Select SerialIo Uart Controller for debug. - 0:SerialIoUart0, 1:SerialIoUart1, 2:SerialIoUart2 -**/ - UINT8 PcdSerialIoUartNumber; - -/** Offset 0x0032 -**/ - UINT32 PcdSerialIoUartInputClock; -} VPD_DATA_REGION; - -#pragma pack(pop) - -#endif
Hello Patrick Rudolph,
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/86/49186/2
Angel Pons has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/49186 )
Patch Set 3: Code-Review+2
Michael Niewöhner has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/49186 )
Hello build bot (Jenkins), Angel Pons, Michael Niewöhner, Patrick Rudolph,
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/86/49186/5
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/86/49186/6
Nico Huber has submitted this change. ( https://review.coreboot.org/c/coreboot/+/49186 )
Change-Id: I329a1484cbd16296a2aa047876c2506c74d4452d Signed-off-by: Felix Singer felixsinger@posteo.net Reviewed-on: https://review.coreboot.org/c/coreboot/+/49186 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Angel Pons th3fanbus@gmail.com Reviewed-by: Michael Niewöhner foss@mniewoehner.de --- D src/vendorcode/intel/fsp/fsp1_1/skylake/FspUpdVpd.h 1 file changed, 0 insertions(+), 1,075 deletions(-)
Approvals: build bot (Jenkins): Verified Angel Pons: Looks good to me, approved Michael Niewöhner: Looks good to me, approved
