Kyösti Mälkki has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/34003
Change subject: pcengines/apuX: Replace use of dev_find_slot() ......................................................................
Find the NIC device based on the PCIe root port function.
Change-Id: Ia8c6e115c9b836ee60862427dfc9d46ca3dd1b69 Signed-off-by: Kyösti Mälkki kyosti.malkki@gmail.com --- M src/mainboard/pcengines/apu1/mainboard.c M src/mainboard/pcengines/apu2/mainboard.c 2 files changed, 16 insertions(+), 10 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/03/34003/1
diff --git a/src/mainboard/pcengines/apu1/mainboard.c b/src/mainboard/pcengines/apu1/mainboard.c index e5e30e0..088c839 100644 --- a/src/mainboard/pcengines/apu1/mainboard.c +++ b/src/mainboard/pcengines/apu1/mainboard.c @@ -206,17 +206,23 @@ const char *smbios_mainboard_serial_number(void) { static char serial[10]; - struct device *nic_dev; + struct device *dev; uintptr_t bar18; u32 mac_addr = 0; int i;
- nic_dev = dev_find_slot(1, PCI_DEVFN(0, 0)); - if ((serial[0] != 0) || !nic_dev) + /* Already initialized. */ + if (serial[0] != 0) + return serial; + + dev = pcidev_on_root(4, 0); + if (dev) + dev = pcidev_path_behind(dev->link_list, PCI_DEVFN(0, 0)); + if (!dev) return serial;
/* Read in the last 3 bytes of NIC's MAC address. */ - bar18 = pci_read_config32(nic_dev, 0x18); + bar18 = pci_read_config32(dev, 0x18); bar18 &= 0xFFFFFC00; for (i = 3; i < 6; i++) { mac_addr <<= 8; diff --git a/src/mainboard/pcengines/apu2/mainboard.c b/src/mainboard/pcengines/apu2/mainboard.c index 5a19d20..7dff6b9 100644 --- a/src/mainboard/pcengines/apu2/mainboard.c +++ b/src/mainboard/pcengines/apu2/mainboard.c @@ -197,9 +197,12 @@ struct device *dev; uintptr_t bar10; u32 mac_addr = 0; - u32 bus_no; int i;
+ /* Already initialized. */ + if (serial[0] != 0) + return serial; + /* * In case we have PCIe module connected to mPCIe2 slot, BDF 1:0.0 may * not be a NIC, because mPCIe2 slot is routed to the very first PCIe @@ -208,11 +211,8 @@ * connected. */ dev = pcidev_on_root(2, 2); - if ((serial[0] != 0) || !dev) - return serial; - - bus_no = dev->link_list->secondary; - dev = dev_find_slot(bus_no, PCI_DEVFN(0, 0)); + if (dev) + dev = pcidev_path_behind(dev->link_list, PCI_DEVFN(0, 0)); if (!dev) return serial;
Arthur Heymans has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/34003 )
Patch Set 1: Code-Review+1
https://review.coreboot.org/#/c/34003/1/src/mainboard/pcengines/apu2/mainboa... File src/mainboard/pcengines/apu2/mainboard.c:
https://review.coreboot.org/#/c/34003/1/src/mainboard/pcengines/apu2/mainboa... PS1, Line 203: : : : : : : Is this comment useful?
Kyösti Mälkki has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/34003 )
Patch Set 1:
Right.. comment needs a bit of adjustment.
Michał Żygowski has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/34003 )
Patch Set 1:
The commit message in the change that introduced this comment explains well enough what is going on here. IMO we can drop this comment in the patch.
https://review.coreboot.org/c/coreboot/+/29842
Hello Arthur Heymans, build bot (Jenkins), Michał Żygowski,
Change-Id: Ia8c6e115c9b836ee60862427dfc9d46ca3dd1b69 Signed-off-by: Kyösti Mälkki kyosti.malkki@gmail.com --- M src/mainboard/pcengines/apu1/mainboard.c M src/mainboard/pcengines/apu2/mainboard.c 2 files changed, 15 insertions(+), 16 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/03/34003/2
Patch Set 2: Code-Review+2
Kyösti Mälkki has submitted this change and it was merged. ( https://review.coreboot.org/c/coreboot/+/34003 )
Change-Id: Ia8c6e115c9b836ee60862427dfc9d46ca3dd1b69 Signed-off-by: Kyösti Mälkki kyosti.malkki@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/34003 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Michał Żygowski michal.zygowski@3mdeb.com --- M src/mainboard/pcengines/apu1/mainboard.c M src/mainboard/pcengines/apu2/mainboard.c 2 files changed, 15 insertions(+), 16 deletions(-)
Approvals: build bot (Jenkins): Verified Michał Żygowski: Looks good to me, approved
/* Read in the last 3 bytes of NIC's MAC address. */ - bar18 = pci_read_config32(nic_dev, 0x18); + bar18 = pci_read_config32(dev, 0x18); bar18 &= 0xFFFFFC00; for (i = 3; i < 6; i++) { mac_addr <<= 8; diff --git a/src/mainboard/pcengines/apu2/mainboard.c b/src/mainboard/pcengines/apu2/mainboard.c index 5a19d20..682120b 100644 --- a/src/mainboard/pcengines/apu2/mainboard.c +++ b/src/mainboard/pcengines/apu2/mainboard.c @@ -197,22 +197,15 @@ struct device *dev; uintptr_t bar10; u32 mac_addr = 0; - u32 bus_no; int i;
- /* - * In case we have PCIe module connected to mPCIe2 slot, BDF 1:0.0 may - * not be a NIC, because mPCIe2 slot is routed to the very first PCIe - * bridge and the first NIC is connected to the second PCIe bridge. - * Read secondary bus number from the PCIe bridge where the first NIC is - * connected. - */ - dev = pcidev_on_root(2, 2); - if ((serial[0] != 0) || !dev) + /* Already initialized. */ + if (serial[0] != 0) return serial;
- bus_no = dev->link_list->secondary; - dev = dev_find_slot(bus_no, PCI_DEVFN(0, 0)); + dev = pcidev_on_root(2, 2); + if (dev) + dev = pcidev_path_behind(dev->link_list, PCI_DEVFN(0, 0)); if (!dev) return serial;
