Isaac Christensen (isaac.christensen@se-eng.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/4552
commit f8779247beb69a8e6c6519074c866ca69f6c8e00 Author: Patrick Georgi patrick@georgi-clan.de Date: Sat Dec 21 21:39:37 2013 +0100
libpayload: Add ARM defconfig
make junit.xml tries to build it, but fails (ARM port doesn't seem to be ready?) Useful test case to demonstrate a failing libpayload build.
Change-Id: Iba4fe551b48f631e6a3bd90eb07930fc70761332 Signed-off-by: Patrick Georgi patrick@georgi-clan.de --- payloads/libpayload/configs/defconfig-arm | 72 +++++++++++++++++++++++++++++++ 1 file changed, 72 insertions(+)
diff --git a/payloads/libpayload/configs/defconfig-arm b/payloads/libpayload/configs/defconfig-arm new file mode 100644 index 0000000..55552b0 --- /dev/null +++ b/payloads/libpayload/configs/defconfig-arm @@ -0,0 +1,72 @@ +# +# Automatically generated make config: don't edit +# libpayload version: 0.2.0 +# Thu Aug 14 20:38:59 2014 +# + +# +# Generic Options +# +# CONFIG_LP_EXPERIMENTAL is not set +# CONFIG_LP_OBSOLETE is not set +# CONFIG_LP_DEVELOPER is not set +# CONFIG_LP_CHROMEOS is not set + +# +# Architecture Options +# +CONFIG_LP_ARCH_ARMV7=y +# CONFIG_LP_ARCH_X86 is not set +# CONFIG_LP_MEMMAP_RAM_ONLY is not set + +# +# Standard Libraries +# +CONFIG_LP_LIBC=y +CONFIG_LP_CURSES=y +CONFIG_LP_TINYCURSES=y +# CONFIG_LP_PDCURSES is not set +CONFIG_LP_CBFS=y +CONFIG_LP_LZMA=y + +# +# Console Options +# +# CONFIG_LP_SKIP_CONSOLE_INIT is not set +CONFIG_LP_CBMEM_CONSOLE=y +CONFIG_LP_SERIAL_CONSOLE=y +# CONFIG_LP_SERIAL_SET_SPEED is not set +# CONFIG_LP_SERIAL_ACS_FALLBACK is not set +CONFIG_LP_VIDEO_CONSOLE=y +# CONFIG_LP_COREBOOT_VIDEO_CONSOLE is not set +CONFIG_LP_PC_KEYBOARD=y +CONFIG_LP_PC_KEYBOARD_LAYOUT_US=y +# CONFIG_LP_PC_KEYBOARD_LAYOUT_DE is not set + +# +# Drivers +# +# CONFIG_LP_RTC_PORT_EXTENDED_VIA is not set +CONFIG_LP_STORAGE=y +# CONFIG_LP_STORAGE_64BIT_LBA is not set +CONFIG_LP_STORAGE_ATA=y +CONFIG_LP_STORAGE_ATAPI=y +CONFIG_LP_USB=y +CONFIG_LP_USB_OHCI=y +CONFIG_LP_USB_EHCI=y +CONFIG_LP_USB_XHCI=y +CONFIG_LP_USB_HID=y +CONFIG_LP_USB_HUB=y +CONFIG_LP_USB_MSC=y +CONFIG_LP_USB_GEN_HUB=y +# CONFIG_LP_USB_PCI is not set +CONFIG_LP_USB_MEMORY=y +CONFIG_LP_USB_OHCI_BASE_ADDRESS=0x12120000 +CONFIG_LP_USB_EHCI_BASE_ADDRESS=0x12110000 +CONFIG_LP_USB_XHCI_BASE_ADDRESS=0x12000000 +# CONFIG_LP_BIG_ENDIAN is not set +CONFIG_LP_LITTLE_ENDIAN=y +# CONFIG_LP_IO_ADDRESS_SPACE is not set +CONFIG_LP_ARCH_SPECIFIC_OPTIONS=y +CONFIG_LP_COREBOOT_INFO_RANGE_BASE=0x10 +CONFIG_LP_COREBOOT_INFO_RANGE_SIZE=0x4000000
