Stefan Reinauer (stefan.reinauer@coreboot.org) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/9565
commit 707e20e1d9f16910923f1bb042fdb252212fdc20 Author: Julius Werner jwerner@chromium.org Date: Thu Jan 29 17:50:58 2015 -0800
vboot2: Fill vboot1 handoff with correct TPM firmware version
sd->fw_version represents the version of the *current* firmware, which is not necessarily the same as the one stored in the TPM (and may be 0 in recovery mode). Use the newly added sd->fw_version_secdata instead which contains a more correct value.
CQ-DEPEND=CL:244601 BRANCH=veyron BUG=chrome-os-partner:35941 TEST=Booted Jerry in recovery mode, confirmed crossystem tpm_fwver was corrent (and not 0).
Change-Id: I30f5998da5ac518d6fcb7a651eba4e1fabc14478 Signed-off-by: Stefan Reinauer reinauer@chromium.org Original-Commit-Id: eb8142f69cea34e11f9081caafcaae7a15cc3801 Original-Change-Id: Id95bd8c6412f2e8b2ae643c3b5a3dee13d0d47be Original-Signed-off-by: Julius Werner jwerner@chromium.org Original-Reviewed-on: https://chromium-review.googlesource.com/244591 Original-Reviewed-by: Randall Spangler rspangler@chromium.org --- src/vendorcode/google/chromeos/vboot2/vboot_handoff.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/src/vendorcode/google/chromeos/vboot2/vboot_handoff.c b/src/vendorcode/google/chromeos/vboot2/vboot_handoff.c index 33ff79a..87ea289 100644 --- a/src/vendorcode/google/chromeos/vboot2/vboot_handoff.c +++ b/src/vendorcode/google/chromeos/vboot2/vboot_handoff.c @@ -79,7 +79,7 @@ static void fill_vboot_handoff(struct vboot_handoff *vboot_handoff, vb_sd->struct_size = sizeof(VbSharedDataHeader); vb_sd->data_size = VB_SHARED_DATA_MIN_SIZE; vb_sd->data_used = sizeof(VbSharedDataHeader); - vb_sd->fw_version_tpm = vb2_sd->fw_version; + vb_sd->fw_version_tpm = vb2_sd->fw_version_secdata;
if (get_write_protect_state()) vb_sd->flags |= VBSD_BOOT_FIRMWARE_WP_ENABLED;
