Duncan Laurie (dlaurie@chromium.org) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/16416
commit c1ce9ecbd2ec190ae246f87ac8f6fa4105f6ae4d Author: Duncan Laurie dlaurie@chromium.org Date: Fri Sep 2 14:45:53 2016 -0700
drivers/i2c/tpm: Fix error handling for tis structure not initialized
If the TPM completely fails to respond then the vendor structure may not have assigned handlers yet, so catch that case and return error so the boot can continue to recovery mode instead of asserting over and over.
Change-Id: If3a11567df89bc73b4d4878bf89d877974044f34 Signed-off-by: Duncan Laurie dlaurie@chromium.org --- src/drivers/i2c/tpm/tis.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/src/drivers/i2c/tpm/tis.c b/src/drivers/i2c/tpm/tis.c index c6173b4..ce0de89 100644 --- a/src/drivers/i2c/tpm/tis.c +++ b/src/drivers/i2c/tpm/tis.c @@ -114,6 +114,9 @@ static ssize_t tpm_transmit(const uint8_t *buf, size_t bufsiz) memcpy(&ordinal, buf + TPM_CMD_ORDINAL_BYTE, sizeof(ordinal)); ordinal = be32_to_cpu(ordinal);
+ if (!chip->vendor.send || !chip->vendor.status || !chip->vendor.cancel) + return -1; + if (count == 0) { printk(BIOS_DEBUG, "tpm_transmit: no data\n"); return -1;
