the following patch was just integrated into master: commit 05a8472900ab2a57218b5f3affdaad1df10ed44e Author: Vadim Bendebury vbendeb@chromium.org Date: Sat Apr 25 13:05:10 2015 -0700
xcompile: improve mips toolchain handling
The mips toolchain used by coreboot so far comes from Chrome OS chroot and is built explicitly for little endian code generation.
Other flavors of MIPS toolchain usually generate big endian code by default and require command line options to switch to little endian mode.
This patch adds another variable to the set of compiler flags examined to determine compiler compatibility. This results in adding another nested for loop in test_architecture(). To avoid the need to break from different levels of nesting, processing of the successful case is taken out from test_architecture().
With this change the Mentor Graphics provided mips GCC toolchain is accepted by xcompile, resulting in the following output:
ARCH_SUPPORTED+=mips SUBARCH_SUPPORTED+=mips mipsel CC_mips:=mips-linux-gnu-gcc CFLAGS_mips:= -Wno-unused-but-set-variable -fno-stack-protector -Wl,--build-id=none -mno-abicalls -fno-pic -EL CPP_mips:=mips-linux-gnu-cpp AS_mips:=mips-linux-gnu-as LD_mips:=mips-linux-gnu-ld NM_mips:=mips-linux-gnu-nm OBJCOPY_mips:=mips-linux-gnu-objcopy OBJDUMP_mips:=mips-linux-gnu-objdump READELF_mips:=mips-linux-gnu-readelf STRIP_mips:=mips-linux-gnu-strip AR_mips:=mips-linux-gnu-ar
Change-Id: I4da384b366880929693c59dc0e1c522b35c41bea Signed-off-by: Vadim Bendebury vbendeb@chromium.org Reviewed-on: http://review.coreboot.org/9997 Tested-by: build bot (Jenkins) Reviewed-by: Patrick Georgi pgeorgi@google.com Reviewed-by: Paul Menzel paulepanter@users.sourceforge.net
See http://review.coreboot.org/9997 for details.
