Arthur Heymans has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/35758 )
Change subject: [TESTME]sb/intel/nm10: Fix enabling HPET ......................................................................
RCBA_HPTC needs to be read back to consistently enable HPET. This ought to fix raminit failing sometimes and SeaBIOS endlessly waiting for user input.
TODO untested
Change-Id: I20a25fd97cd09fedb70469262c64d8d3828bb684 Signed-off-by: Arthur Heymans arthur@aheymans.xyz --- M src/northbridge/intel/pineview/raminit.c M src/southbridge/intel/i82801gx/lpc.c 2 files changed, 8 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/58/35758/1
diff --git a/src/northbridge/intel/pineview/raminit.c b/src/northbridge/intel/pineview/raminit.c index 5cece41..7f59d91 100644 --- a/src/northbridge/intel/pineview/raminit.c +++ b/src/northbridge/intel/pineview/raminit.c @@ -552,10 +552,12 @@ static void enable_hpet(void) { u32 reg32; - reg32 = RCBA32(0x3404); + reg32 = RCBA32(HPTC); reg32 &= ~0x3; reg32 |= (1 << 7); - RCBA32(0x3404) = reg32; + RCBA32(HPTC) = reg32; + /* On NM10 this only works if read back */ + RCBA32(HPTC); HPET32(0x10) = HPET32(0x10) | 1; }
diff --git a/src/southbridge/intel/i82801gx/lpc.c b/src/southbridge/intel/i82801gx/lpc.c index 4e2f9f9..62576c1 100644 --- a/src/southbridge/intel/i82801gx/lpc.c +++ b/src/southbridge/intel/i82801gx/lpc.c @@ -310,6 +310,10 @@ reg32 |= (1 << 7); // HPET Address Enable reg32 &= ~(3 << 0); RCBA32(HPTC) = reg32; + /* On NM10 this only works if read back */ + RCBA32(HPTC); + + write32((u32 *)0xfed00010, read32((u32 *)0xfed00010) | 1); }
static void enable_clock_gating(void)
Angel Pons has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/35758 )
Patch Set 1: Code-Review+1
Was just tested, as reported on IRC. Waiting for commit message updating to +2
Name of user not set #1002601 has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/35758 )
Patch works, no user input required for boot process to continue. Tested: Intel D510MO https://lewd.pics/p/40Cw.jpg
Hello Patrick Rudolph, Angel Pons, Name of user not set #1002601, build bot (Jenkins), Damien Zammit,
Change subject: sb/intel/nm10: Fix enabling HPET ......................................................................
TESTED on Intel D510MO, Fixes SeaBIOS waiting for input, without a timeout.
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/58/35758/2
Patrick Rudolph has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/35758 )
Patch Set 2: Code-Review+2
Arthur Heymans has submitted this change. ( https://review.coreboot.org/c/coreboot/+/35758 )
Change-Id: I20a25fd97cd09fedb70469262c64d8d3828bb684 Signed-off-by: Arthur Heymans arthur@aheymans.xyz Reviewed-on: https://review.coreboot.org/c/coreboot/+/35758 Reviewed-by: Patrick Rudolph siro@das-labor.org Reviewed-by: Angel Pons th3fanbus@gmail.com Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/northbridge/intel/pineview/raminit.c M src/southbridge/intel/i82801gx/lpc.c 2 files changed, 8 insertions(+), 2 deletions(-)
Approvals: build bot (Jenkins): Verified Patrick Rudolph: Looks good to me, approved Angel Pons: Looks good to me, but someone else must approve Name of user not set #1002601: Looks good to me, but someone else must approve
