Lijian Zhao has uploaded this change for review. ( https://review.coreboot.org/25704
Change subject: soc/intel/cannonlake: Set DISB after Dram init ......................................................................
DRAM Initialization Scratchpad Bit need to be set after Dram Initialization finished.
BUG=None
Change-Id: I16dd3787cb743bc5b7492042f3c3757534e1a51c Signed-off-by: Lijian Zhao lijian.zhao@intel.com --- M src/soc/intel/cannonlake/pmutil.c M src/soc/intel/cannonlake/romstage/romstage.c 2 files changed, 14 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/04/25704/1
diff --git a/src/soc/intel/cannonlake/pmutil.c b/src/soc/intel/cannonlake/pmutil.c index a5d1833..3749b1c 100644 --- a/src/soc/intel/cannonlake/pmutil.c +++ b/src/soc/intel/cannonlake/pmutil.c @@ -128,6 +128,19 @@ return gpe_sts_bits; }
+void pmc_set_disb(void) +{ + /* Set the DISB after DRAM init */ + uint8_t disb_val; + + disb_val = read8(pmc_mmio_regs() + GEN_PMCON_A + 2); + disb_val |= DISB; + + /* Don't clear bits that are write-1-to-clear */ + disb_val &= ~(MS4V | SUS_PWR_FLR); + write8((pmc_mmio_regs() + GEN_PMCON_A + 2), disb_val); +} + /* * PMC controller gets hidden from PCI bus * during FSP-Silicon init call. Hence PWRMBASE diff --git a/src/soc/intel/cannonlake/romstage/romstage.c b/src/soc/intel/cannonlake/romstage/romstage.c index dc96526..c8cb927 100644 --- a/src/soc/intel/cannonlake/romstage/romstage.c +++ b/src/soc/intel/cannonlake/romstage/romstage.c @@ -123,6 +123,7 @@ timestamp_add_now(TS_START_ROMSTAGE); s3wake = pmc_fill_power_state(ps) == ACPI_S3; fsp_memory_init(s3wake); + pmc_set_disb(); if (!s3wake) save_dimm_info(); if (postcar_frame_init(&pcf, 1 * KiB))
