Patrick Georgi (pgeorgi@google.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/9550
commit 29ba83b04af951b6c3f276156d07e14388d2f654 Author: Julius Werner jwerner@chromium.org Date: Mon Nov 10 19:53:45 2014 -0800
veyron_jerry: Port CPU overshoot prevention
This patch ports commit 567f616f (rk3288: slowly raise to max cpu voltage to prevent overshoot) to Veyron_Jerry. It also fixes include ordering and some comment grammar in the affected code.
BRANCH=None BUG=chrome-os-partner:32716 TEST=None
Change-Id: I4ac14a38e4b3acc4926d4f51f409ff12d9c841cf Signed-off-by: Patrick Georgi pgeorgi@chromium.org Original-Commit-Id: 679014bc843788e8d4d5f5c7470ae76f8be5e942 Original-Change-Id: I9c0aba40ddd8a0852391df184034baa740d063df Original-Signed-off-by: Julius Werner jwerner@chromium.org Original-Reviewed-on: https://chromium-review.googlesource.com/228938 Original-Reviewed-by: David Hendricks dhendrix@chromium.org --- src/mainboard/google/veyron_jerry/bootblock.c | 10 ++++++++-- src/mainboard/google/veyron_pinky/bootblock.c | 7 ++----- 2 files changed, 10 insertions(+), 7 deletions(-)
diff --git a/src/mainboard/google/veyron_jerry/bootblock.c b/src/mainboard/google/veyron_jerry/bootblock.c index b34199d..30b00e1 100644 --- a/src/mainboard/google/veyron_jerry/bootblock.c +++ b/src/mainboard/google/veyron_jerry/bootblock.c @@ -20,6 +20,7 @@
#include <arch/io.h> #include <bootblock_common.h> +#include <delay.h> #include <soc/clock.h> #include <soc/i2c.h> #include <soc/grf.h> @@ -32,11 +33,16 @@
void bootblock_mainboard_init(void) { - /* cpu frequency will up to 1.8GHz, so the buck1 must up to 1.3v */ + /* Up VDD_CPU (BUCK1) to 1.4V to support max CPU frequency (1.8GHz). */ setbits_le32(&rk3288_pmu->iomux_i2c0scl, IOMUX_I2C0SCL); setbits_le32(&rk3288_pmu->iomux_i2c0sda, IOMUX_I2C0SDA); i2c_init(PMIC_BUS, 400*KHz); - rk808_configure_buck(PMIC_BUS, 1, 1300); + + /* Slowly raise to max CPU voltage to prevent overshoot */ + rk808_configure_buck(PMIC_BUS, 1, 1200); + udelay(175);/* Must wait for voltage to stabilize,2mV/us */ + rk808_configure_buck(PMIC_BUS, 1, 1400); + udelay(100);/* Must wait for voltage to stabilize,2mV/us */ rkclk_configure_cpu();
/* i2c1 for tpm */ diff --git a/src/mainboard/google/veyron_pinky/bootblock.c b/src/mainboard/google/veyron_pinky/bootblock.c index 99719c4..30b00e1 100644 --- a/src/mainboard/google/veyron_pinky/bootblock.c +++ b/src/mainboard/google/veyron_pinky/bootblock.c @@ -20,6 +20,7 @@
#include <arch/io.h> #include <bootblock_common.h> +#include <delay.h> #include <soc/clock.h> #include <soc/i2c.h> #include <soc/grf.h> @@ -27,16 +28,12 @@ #include <soc/rk808.h> #include <soc/spi.h> #include <vendorcode/google/chromeos/chromeos.h> -#include <delay.h>
#include "board.h"
void bootblock_mainboard_init(void) { - /* cpu frequency will up to 1.8GHz, - * in our experience the buck1 - * must up to 1.4v - */ + /* Up VDD_CPU (BUCK1) to 1.4V to support max CPU frequency (1.8GHz). */ setbits_le32(&rk3288_pmu->iomux_i2c0scl, IOMUX_I2C0SCL); setbits_le32(&rk3288_pmu->iomux_i2c0sda, IOMUX_I2C0SDA); i2c_init(PMIC_BUS, 400*KHz);
