Rizwan Qureshi has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/57295 )
Change subject: soc/intel/common/cse: Add argument to send message to appropriate fixed client ......................................................................
There are multiple HECI clents in the CSE. Currently coreboot is sending HECI messages to only the MKHI client. Add an argument to heci_send_receive() funtion to provide flexibility to the caller to select the client for which the message is intended for.
In the follow-up patches there will be messages sent to one other client.
BUG=None BRANCH=None TEST=Build and boot brya. HECI message send and receive to MKHI client is working.
Signed-off-by: Rizwan Qureshi rizwan.qureshi@intel.com Change-Id: Icde6d0155b62472b6a7caadc5fc8ea2e2ba6eb0c --- M src/soc/intel/common/block/cse/cse.c M src/soc/intel/common/block/cse/cse_eop.c M src/soc/intel/common/block/cse/cse_lite.c M src/soc/intel/common/block/include/intelblocks/cse.h 4 files changed, 17 insertions(+), 11 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/95/57295/1
diff --git a/src/soc/intel/common/block/cse/cse.c b/src/soc/intel/common/block/cse/cse.c index 7708c1b..f4a1ead 100644 --- a/src/soc/intel/common/block/cse/cse.c +++ b/src/soc/intel/common/block/cse/cse.c @@ -533,9 +533,10 @@ return 0; }
-int heci_send_receive(const void *snd_msg, size_t snd_sz, void *rcv_msg, size_t *rcv_sz) +int heci_send_receive(const void *snd_msg, size_t snd_sz, void *rcv_msg, size_t *rcv_sz, + uint8_t client) { - if (!heci_send(snd_msg, snd_sz, BIOS_HOST_ADDR, HECI_MKHI_ADDR)) { + if (!heci_send(snd_msg, snd_sz, BIOS_HOST_ADDR, client)) { printk(BIOS_ERR, "HECI: send Failed\n"); return 0; } @@ -663,7 +664,8 @@ if (rst_type == CSE_RESET_ONLY) status = heci_send(&msg, sizeof(msg), BIOS_HOST_ADDR, HECI_MKHI_ADDR); else - status = heci_send_receive(&msg, sizeof(msg), &reply, &reply_size); + status = heci_send_receive(&msg, sizeof(msg), &reply, &reply_size, + HECI_MKHI_ADDR);
printk(BIOS_DEBUG, "HECI: Global Reset %s!\n", status ? "success" : "failure"); return status; @@ -733,7 +735,7 @@ }
if (!heci_send_receive(&msg, sizeof(struct hmrfpo_enable_msg), - &resp, &resp_size)) + &resp, &resp_size, HECI_MKHI_ADDR)) return 0;
if (resp.hdr.result) { @@ -782,7 +784,7 @@ }
if (!heci_send_receive(&msg, sizeof(struct hmrfpo_get_status_msg), - &resp, &resp_size)) { + &resp, &resp_size, HECI_MKHI_ADDR)) { printk(BIOS_ERR, "HECI: HMRFPO send/receive fail\n"); return -1; } @@ -847,7 +849,8 @@
heci_reset();
- if (!heci_send_receive(&fw_ver_msg, sizeof(fw_ver_msg), &resp, &resp_size)) + if (!heci_send_receive(&fw_ver_msg, sizeof(fw_ver_msg), &resp, &resp_size, + HECI_MKHI_ADDR)) goto fail;
if (resp.hdr.result) diff --git a/src/soc/intel/common/block/cse/cse_eop.c b/src/soc/intel/common/block/cse/cse_eop.c index 6e57439..aac8c06 100644 --- a/src/soc/intel/common/block/cse/cse_eop.c +++ b/src/soc/intel/common/block/cse/cse_eop.c @@ -112,7 +112,7 @@
printk(BIOS_INFO, "HECI: Sending End-of-Post\n");
- if (!heci_send_receive(&msg, sizeof(msg), &resp, &resp_size)) { + if (!heci_send_receive(&msg, sizeof(msg), &resp, &resp_size, HECI_MKHI_ADDR)) { printk(BIOS_ERR, "HECI: EOP send/receive fail\n"); return CSE_EOP_RESULT_ERROR; } diff --git a/src/soc/intel/common/block/cse/cse_lite.c b/src/soc/intel/common/block/cse/cse_lite.c index 15d585d..762de2a 100644 --- a/src/soc/intel/common/block/cse/cse_lite.c +++ b/src/soc/intel/common/block/cse/cse_lite.c @@ -202,7 +202,8 @@
size_t resp_size = sizeof(struct get_bp_info_rsp);
- if (!heci_send_receive(&info_req, sizeof(info_req), bp_info_rsp, &resp_size)) { + if (!heci_send_receive(&info_req, sizeof(info_req), bp_info_rsp, &resp_size, + HECI_MKHI_ADDR)) { printk(BIOS_ERR, "cse_lite: Could not get partition info\n"); return false; } @@ -254,7 +255,8 @@ struct mkhi_hdr switch_resp; size_t sw_resp_sz = sizeof(struct mkhi_hdr);
- if (!heci_send_receive(&switch_req, sizeof(switch_req), &switch_resp, &sw_resp_sz)) + if (!heci_send_receive(&switch_req, sizeof(switch_req), &switch_resp, &sw_resp_sz, + HECI_MKHI_ADDR)) return false;
if (switch_resp.result) { @@ -291,7 +293,7 @@ size_t data_clr_rsp_sz = sizeof(data_clr_rsp);
if (!heci_send_receive(&data_clr_rq, sizeof(data_clr_rq), &data_clr_rsp, - &data_clr_rsp_sz)) { + &data_clr_rsp_sz, HECI_MKHI_ADDR)) { return false; }
diff --git a/src/soc/intel/common/block/include/intelblocks/cse.h b/src/soc/intel/common/block/include/intelblocks/cse.h index 153cb22..ff2d6f2 100644 --- a/src/soc/intel/common/block/include/intelblocks/cse.h +++ b/src/soc/intel/common/block/include/intelblocks/cse.h @@ -152,7 +152,8 @@ * rcv_msg of size rcv_sz * Returns 0 on failure and 1 on success. */ -int heci_send_receive(const void *snd_msg, size_t snd_sz, void *rcv_msg, size_t *rcv_sz); +int heci_send_receive(const void *snd_msg, size_t snd_sz, void *rcv_msg, size_t *rcv_sz, + uint8_t client);
/* * Attempt device reset. This is useful and perhaps only thing left to do when
