Edward O'Callaghan (eocallaghan@alterapraxis.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/5400
commit 2e00b6ab7c42cd5526b627ad49d1cd9fd4881037 Author: Edward O'Callaghan eocallaghan@alterapraxis.com Date: Sun Mar 23 20:37:09 2014 +1100
superio/fintek/f71869ad: Setup SMBus correctly.
Fintek Super I/O has "mutli-function selection registers" that need tweaking before the Super I/O will talk to SB.
Change-Id: I28489c183d9d2c379a0488ec5709bbf184ba6853 Signed-off-by: Edward O'Callaghan eocallaghan@alterapraxis.com --- src/superio/fintek/f71869ad/superio.c | 57 ++++++++++++++++++++++++++++++++++- 1 file changed, 56 insertions(+), 1 deletion(-)
diff --git a/src/superio/fintek/f71869ad/superio.c b/src/superio/fintek/f71869ad/superio.c index 9325bac..2c1b9b2 100644 --- a/src/superio/fintek/f71869ad/superio.c +++ b/src/superio/fintek/f71869ad/superio.c @@ -28,6 +28,61 @@ #include "chip.h" #include "f71869ad.h"
+static void toggle_clk_tune_en(device_t dev, int state) +{ + u8 reg8; + + reg8 = pnp_read_config(dev, 0x26); + + switch(state) { + case 1: + reg8 ^= 0x08; /* CLK_TUNE_EN=1 */ + break; + case 0: + reg8 &= 0xF7; /* CLK_TUNE_EN=0 */ + break; + } + + pnp_write_config(dev, 0x26, reg8); +} + +static void enable_hwm_smbus(device_t dev) +{ + pnp_write_config(dev, 0x25, 0x09); // powerdown FDC & PP + pnp_write_config(dev, 0x27, 0xa1); // debug+timing_gpio + pnp_write_config(dev, 0x28, 0x01); // multi-func select reg1 + + /* CLK_TUNE_EN switch index 0x29 ~ 0x2C to WDT fine tune registers */ + toggle_clk_tune_en(dev, 1); /* CLK_TUNE_EN=1 */ + pnp_write_config(dev, 0x29, 0x6f); // WDT clock divisor high byte (CLK_TUNE_EN=1) + pnp_write_config(dev, 0x2a, 0x24); // WDT clock divisor low byte (CLK_TUNE_EN=1) + pnp_write_config(dev, 0x2b, 0x00); // WDT clock fine tune count (CLK_TUNE_EN=1) + pnp_write_config(dev, 0x2b, 0x60); // WDT clock fine tune count (CLK_TUNE_EN=1) + /* CLK_TUNE_EN switch index 0x29 ~ 0x2C from WDT fine tune registers */ + toggle_clk_tune_en(dev, 0); /* CLK_TUNE_EN=0 */ + + pnp_write_config(dev, 0x29, 0x6f); // multi-func select reg2 (CLK_TUNE_EN=0) + pnp_write_config(dev, 0x2a, 0x24); // multi-func select reg3 (CLK_TUNE_EN=0) + pnp_write_config(dev, 0x2b, 0x00); // multi-func select reg4 (CLK_TUNE_EN=0) + /* multi-func sel reg5 - Configure pins 57/58 as SCL/SDA (AMD TSI bus). */ + pnp_write_config(dev, 0x2c, 0x60); // multi-func select reg5 (CLK_TUNE_EN=0) + pnp_write_config(dev, 0x2f, 0x2f); // wakeup control register +} + +static void f71869ad_pnp_enable_resources(device_t dev) +{ + pnp_enable_resources(dev); + + pnp_enter_conf_mode(dev); + switch(dev->path.pnp.device) { + case F71869AD_HWM: + printk(BIOS_DEBUG, "F71869AD HWM SMBus enabled\n"); + enable_hwm_smbus(dev); + break; + } + pnp_exit_conf_mode(dev); +} + static void f71869ad_init(device_t dev) { struct superio_fintek_f71869ad_config *conf = dev->chip_info; @@ -46,7 +101,7 @@ static void f71869ad_init(device_t dev) static struct device_operations ops = { .read_resources = pnp_read_resources, .set_resources = pnp_set_resources, - .enable_resources = pnp_enable_resources, + .enable_resources = f71869ad_pnp_enable_resources, .enable = pnp_alt_enable, .init = f71869ad_init, .ops_pnp_mode = &pnp_conf_mode_8787_aa,
