Attention is currently required from: Reka Norman, Kangheui Won, Tim Wawrzynczak. Hello build bot (Jenkins), Reka Norman, Kangheui Won, Tim Wawrzynczak,
https://review.coreboot.org/c/coreboot/+/61496
Change subject: mb/google/brya: Override memory ID to 0 for nivviks and nereid P0 ......................................................................
In the nivviks and nereid pre-proto builds, the memory straps used don't match those generated by spd_tools. Each pre-proto build only supports a single memory part, and each of these parts should have ID 0 (see CB:61443). Therefore, for nivviks and nereid board ID 0, hard code the memory IDs to 0 instead of reading them from the memory strap pins. From P1 onwards, the memory straps will be assigned based on the IDs generated by spd_tools.
BUG=b:197479026 TEST=Build test nivviks and nereid
Signed-off-by: Reka Norman rekanorman@google.com Change-Id: Ic0c6f3f22d7a94f9eed44e736308e5ac4157163d --- M src/mainboard/google/brya/variants/nereid/Makefile.inc A src/mainboard/google/brya/variants/nereid/memory.c M src/mainboard/google/brya/variants/nivviks/Makefile.inc A src/mainboard/google/brya/variants/nivviks/memory.c 4 files changed, 64 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/96/61496/3
