Hello Aaron Durbin,
https://review.coreboot.org/c/coreboot/+/42724
Change subject: mb/google/zork: Update ramstage GPIOs for v3 schematics for trembyle reference ......................................................................
This change updates the baseboard GPIO table in ramstage to match v3 version of trembyle reference schematics. All variants using this reference are accordingly updated to configure the GPIOs that changed as part of v3 schematics.
BUG=b:157088093, b:154676993, b:157098434 TEST=Compiles
Signed-off-by: Martin Roth martinroth@chromium.org Signed-off-by: Furquan Shaikh furquan@google.com Change-Id: Ib1d6ee2e995c1fca229c20ea63da9a45fb89f64a Reviewed-on: https://chromium-review.googlesource.com/c/chromiumos/third_party/coreboot/+... Reviewed-by: Aaron Durbin adurbin@google.com Commit-Queue: Furquan Shaikh furquan@chromium.org Tested-by: Furquan Shaikh furquan@chromium.org --- M src/mainboard/google/zork/variants/baseboard/gpio_baseboard_trembyle.c M src/mainboard/google/zork/variants/berknip/gpio.c M src/mainboard/google/zork/variants/ezkinil/gpio.c M src/mainboard/google/zork/variants/morphius/gpio.c M src/mainboard/google/zork/variants/trembyle/gpio.c 5 files changed, 105 insertions(+), 30 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/24/42724/1
diff --git a/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_trembyle.c b/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_trembyle.c index fad8a53..d3f7ae3 100644 --- a/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_trembyle.c +++ b/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_trembyle.c @@ -115,8 +115,8 @@ PAD_GPO(GPIO_11, HIGH), /* USI_INT_ODL */ PAD_GPI(GPIO_12, PULL_UP), - /* DMIC_SEL */ - PAD_GPO(GPIO_13, LOW), // Select Camera 1 Dmic + /* EN_PWR_TOUCHPAD_PS2 */ + PAD_GPO(GPIO_13, HIGH), /* BT_DISABLE */ PAD_GPO(GPIO_14, LOW), /* USB_OC0_L - USB C0 + USB A0 */ @@ -135,12 +135,12 @@ PAD_GPI(GPIO_31, PULL_UP), /* EN_PWR_FP */ PAD_GPO(GPIO_32, HIGH), - /* EN_PWR_TOUCHPAD_PS2 */ + /* DMIC SEL */ /* - * EN_PWR_TOUCHPAD_PS2 - Make sure Ext ROM Sharing is disabled before - * using this GPIO. Otherwise SPI flash access will be very slow. + * Make sure Ext ROM Sharing is disabled before using this GPIO. Otherwise SPI flash + * access will be very slow. */ - PAD_GPO(GPIO_67, HIGH), + PAD_GPO(GPIO_67, LOW), // Select Camera 1 Dmic /* EMMC_RESET */ PAD_GPO(GPIO_68, LOW), /* FPMCU_BOOT0 - TODO: Check this */ @@ -155,16 +155,14 @@ PAD_GPO(GPIO_76, HIGH), /* APU_EDP_BL_DISABLE TODP: Set low in depthcharge */ PAD_GPO(GPIO_85, HIGH), - /* MST_GPIO_2 (Fw Update HDMI hub) */ - PAD_GPI(GPIO_86, PULL_NONE), /* EMMC_DATA7 */ PAD_NF(GPIO_87, EMMC_DATA7, PULL_NONE), /* EMMC_DATA5 */ PAD_NF(GPIO_88, EMMC_DATA5, PULL_NONE), /* EN_DEV_BEEP_L */ PAD_GPO(GPIO_89, HIGH), - /* MST_GPIO_3 (Fw Update HDMI hub) */ - PAD_GPI(GPIO_90, PULL_NONE), + /* Testpoint */ + PAD_GPI(GPIO_90, PULL_UP), /* EN_SPKR TODO: Verify driver enables this (add to ACPI) */ PAD_GPO(GPIO_91, LOW), /* EMMC_DATA0 */ diff --git a/src/mainboard/google/zork/variants/berknip/gpio.c b/src/mainboard/google/zork/variants/berknip/gpio.c index f7a1e37..2a50d74 100644 --- a/src/mainboard/google/zork/variants/berknip/gpio.c +++ b/src/mainboard/google/zork/variants/berknip/gpio.c @@ -6,12 +6,22 @@ #include <gpio.h> #include <soc/gpio.h> #include <ec/google/chromeec/ec.h> -static const struct soc_amd_gpio berknip_v1_gpio_set_stage_ram[] = { + +static const struct soc_amd_gpio berknip_bid1_gpio_set_stage_ram[] = { + /* DMIC_SEL */ + PAD_GPO(GPIO_13, LOW), // Select Camera 1 Dmic /* USB_OC4_L - USB_A1 */ PAD_NF(GPIO_14, USB_OC4_L, PULL_UP), /* USB_OC2_L - USB A0 */ PAD_NF(GPIO_18, USB_OC2_L, PULL_UP), + /* EN_PWR_TOUCHPAD_PS2 */ + PAD_GPO(GPIO_67, HIGH), + /* MST_GPIO_2 (Fw Update HDMI hub) */ + PAD_GPI(GPIO_86, PULL_NONE), + /* MST_GPIO_3 (Fw Update HDMI hub) */ + PAD_GPI(GPIO_90, PULL_NONE), }; + const struct soc_amd_gpio *variant_override_gpio_table(size_t *size) { uint32_t board_version; @@ -25,8 +35,8 @@ board_version = 1;
if (board_version <= 1) { - *size = ARRAY_SIZE(berknip_v1_gpio_set_stage_ram); - return berknip_v1_gpio_set_stage_ram; + *size = ARRAY_SIZE(berknip_bid1_gpio_set_stage_ram); + return berknip_bid1_gpio_set_stage_ram; }
*size = 0; diff --git a/src/mainboard/google/zork/variants/ezkinil/gpio.c b/src/mainboard/google/zork/variants/ezkinil/gpio.c index 1b1ed54..2d6ebe7 100644 --- a/src/mainboard/google/zork/variants/ezkinil/gpio.c +++ b/src/mainboard/google/zork/variants/ezkinil/gpio.c @@ -6,12 +6,44 @@ #include <gpio.h> #include <soc/gpio.h> #include <ec/google/chromeec/ec.h> -static const struct soc_amd_gpio ezkinil_v1_gpio_set_stage_ram[] = { + +static const struct soc_amd_gpio ezkinil_bid1_gpio_set_stage_ram[] = { + /* DMIC_SEL */ + PAD_GPO(GPIO_13, LOW), // Select Camera 1 Dmic /* USB_OC4_L - USB_A1 */ PAD_NF(GPIO_14, USB_OC4_L, PULL_UP), /* USB_OC2_L - USB A0 */ PAD_NF(GPIO_18, USB_OC2_L, PULL_UP), + /* EN_PWR_TOUCHPAD_PS2 */ + PAD_GPO(GPIO_67, HIGH), + /* MST_GPIO_2 (Fw Update HDMI hub) */ + PAD_GPI(GPIO_86, PULL_NONE), + /* MST_GPIO_3 (Fw Update HDMI hub) */ + PAD_GPI(GPIO_90, PULL_NONE), }; + +static const struct soc_amd_gpio ezkinil_bid2_gpio_set_stage_ram[] = { + /* FPMCU_RST_L Change NC */ + PAD_GPI(GPIO_11, PULL_UP), + /* DMIC_SEL */ + PAD_GPO(GPIO_13, LOW), // Select Camera 1 Dmic + /* EN_PWR_TOUCHPAD_PS2 */ + PAD_GPO(GPIO_67, HIGH), + /* FPMCU_BOOT0 Change NC */ + PAD_GPI(GPIO_69, PULL_UP), + /* MST_GPIO_2 (Fw Update HDMI hub) Change NC */ + PAD_GPI(GPIO_86, PULL_UP), +}; + +static const struct soc_amd_gpio ezkinil_bid3_gpio_set_stage_ram[] = { + /* FPMCU_RST_L Change NC */ + PAD_GPI(GPIO_11, PULL_UP), + /* FPMCU_BOOT0 Change NC */ + PAD_GPI(GPIO_69, PULL_UP), + /* MST_GPIO_2 (Fw Update HDMI hub) Change NC */ + PAD_GPI(GPIO_86, PULL_UP), +}; + const struct soc_amd_gpio *variant_override_gpio_table(size_t *size) { uint32_t board_version; @@ -25,10 +57,13 @@ board_version = 1;
if (board_version <= 1) { - *size = ARRAY_SIZE(ezkinil_v1_gpio_set_stage_ram); - return ezkinil_v1_gpio_set_stage_ram; + *size = ARRAY_SIZE(ezkinil_bid1_gpio_set_stage_ram); + return ezkinil_bid1_gpio_set_stage_ram; + } else if (board_version == 2) { + *size = ARRAY_SIZE(ezkinil_bid2_gpio_set_stage_ram); + return ezkinil_bid2_gpio_set_stage_ram; }
- *size = 0; - return NULL; + *size = ARRAY_SIZE(ezkinil_bid3_gpio_set_stage_ram); + return ezkinil_bid3_gpio_set_stage_ram; } diff --git a/src/mainboard/google/zork/variants/morphius/gpio.c b/src/mainboard/google/zork/variants/morphius/gpio.c index ff8fa20..4cb98a3 100644 --- a/src/mainboard/google/zork/variants/morphius/gpio.c +++ b/src/mainboard/google/zork/variants/morphius/gpio.c @@ -7,20 +7,36 @@ #include <soc/gpio.h> #include <ec/google/chromeec/ec.h>
-static const struct soc_amd_gpio morphius_v1_gpio_set_stage_ram[] = { +static const struct soc_amd_gpio morphius_bid1_gpio_set_stage_ram[] = { + /* DMIC_SEL */ + PAD_GPO(GPIO_13, LOW), // Select Camera 1 Dmic /* USB_OC4_L - USB_A1 */ PAD_NF(GPIO_14, USB_OC4_L, PULL_UP), /* USB_OC2_L - USB A0 */ PAD_NF(GPIO_18, USB_OC2_L, PULL_UP), + /* EN_PWR_TOUCHPAD_PS2 */ + PAD_GPO(GPIO_67, HIGH), /* DMIC_AD_EN */ PAD_GPO(GPIO_84, HIGH), + /* MST_GPIO_2 (Fw Update HDMI hub) */ + PAD_GPI(GPIO_86, PULL_NONE), + /* MST_GPIO_3 (Fw Update HDMI hub) */ + PAD_GPI(GPIO_90, PULL_NONE), };
-static const struct soc_amd_gpio morphius_v2_gpio_set_stage_ram[] = { +static const struct soc_amd_gpio morphius_bid2_gpio_set_stage_ram[] = { + /* DMIC_SEL */ + PAD_GPO(GPIO_13, LOW), // Select Camera 1 Dmic /* USB_OC4_L - USB_A1 */ PAD_NF(GPIO_14, USB_OC4_L, PULL_UP), /* USB_OC2_L - USB A0 */ PAD_NF(GPIO_18, USB_OC2_L, PULL_UP), + /* EN_PWR_TOUCHPAD_PS2 */ + PAD_GPO(GPIO_67, HIGH), + /* MST_GPIO_2 (Fw Update HDMI hub) */ + PAD_GPI(GPIO_86, PULL_NONE), + /* MST_GPIO_3 (Fw Update HDMI hub) */ + PAD_GPI(GPIO_90, PULL_NONE), };
const struct soc_amd_gpio *variant_override_gpio_table(size_t *size) @@ -36,11 +52,11 @@ board_version = 1;
if (board_version <= 1) { - *size = ARRAY_SIZE(morphius_v1_gpio_set_stage_ram); - return morphius_v1_gpio_set_stage_ram; + *size = ARRAY_SIZE(morphius_bid1_gpio_set_stage_ram); + return morphius_bid1_gpio_set_stage_ram; } else if (board_version <= 2) { - *size = ARRAY_SIZE(morphius_v2_gpio_set_stage_ram); - return morphius_v2_gpio_set_stage_ram; + *size = ARRAY_SIZE(morphius_bid2_gpio_set_stage_ram); + return morphius_bid2_gpio_set_stage_ram; }
*size = 0; diff --git a/src/mainboard/google/zork/variants/trembyle/gpio.c b/src/mainboard/google/zork/variants/trembyle/gpio.c index 7973858..ce7e5dd 100644 --- a/src/mainboard/google/zork/variants/trembyle/gpio.c +++ b/src/mainboard/google/zork/variants/trembyle/gpio.c @@ -7,20 +7,36 @@ #include <soc/gpio.h> #include <ec/google/chromeec/ec.h>
-static const struct soc_amd_gpio trembyle_v1_v2_gpio_set_stage_ram[] = { +static const struct soc_amd_gpio trembyle_bid1_bid2_gpio_set_stage_ram[] = { + /* DMIC_SEL */ + PAD_GPO(GPIO_13, LOW), // Select Camera 1 Dmic /* USB_OC4_L - USB_A1 */ PAD_NF(GPIO_14, USB_OC4_L, PULL_UP), /* USB_OC2_L - USB A0 */ PAD_NF(GPIO_18, USB_OC2_L, PULL_UP), + /* EN_PWR_TOUCHPAD_PS2 */ + PAD_GPO(GPIO_67, HIGH), /* DMIC_AD_EN */ PAD_GPO(GPIO_84, HIGH), + /* MST_GPIO_2 (Fw Update HDMI hub) */ + PAD_GPI(GPIO_86, PULL_NONE), + /* MST_GPIO_3 (Fw Update HDMI hub) */ + PAD_GPI(GPIO_90, PULL_NONE), };
-static const struct soc_amd_gpio trembyle_v3_gpio_set_stage_ram[] = { +static const struct soc_amd_gpio trembyle_bid3_gpio_set_stage_ram[] = { + /* DMIC_SEL */ + PAD_GPO(GPIO_13, LOW), // Select Camera 1 Dmic /* USB_OC4_L - USB_A1 */ PAD_NF(GPIO_14, USB_OC4_L, PULL_UP), /* USB_OC2_L - USB A0 */ PAD_NF(GPIO_18, USB_OC2_L, PULL_UP), + /* EN_PWR_TOUCHPAD_PS2 */ + PAD_GPO(GPIO_67, HIGH), + /* MST_GPIO_2 (Fw Update HDMI hub) */ + PAD_GPI(GPIO_86, PULL_NONE), + /* MST_GPIO_3 (Fw Update HDMI hub) */ + PAD_GPI(GPIO_90, PULL_NONE), };
if (board_version <= 2) { - *size = ARRAY_SIZE(trembyle_v1_v2_gpio_set_stage_ram); - return trembyle_v1_v2_gpio_set_stage_ram; + *size = ARRAY_SIZE(trembyle_bid1_bid2_gpio_set_stage_ram); + return trembyle_bid1_bid2_gpio_set_stage_ram; } else if (board_version <= 3) { - *size = ARRAY_SIZE(trembyle_v3_gpio_set_stage_ram); - return trembyle_v3_gpio_set_stage_ram; + *size = ARRAY_SIZE(trembyle_bid3_gpio_set_stage_ram); + return trembyle_bid3_gpio_set_stage_ram; }
*size = 0;
Hello build bot (Jenkins), Aaron Durbin,
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/24/42724/2
Aaron Durbin has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/42724 )
Patch Set 2: Code-Review+2
Furquan Shaikh has submitted this change. ( https://review.coreboot.org/c/coreboot/+/42724 )
Signed-off-by: Martin Roth martinroth@chromium.org Signed-off-by: Furquan Shaikh furquan@google.com Change-Id: Ib1d6ee2e995c1fca229c20ea63da9a45fb89f64a Reviewed-on: https://chromium-review.googlesource.com/c/chromiumos/third_party/coreboot/+... Reviewed-by: Aaron Durbin adurbin@google.com Commit-Queue: Furquan Shaikh furquan@chromium.org Tested-by: Furquan Shaikh furquan@chromium.org Reviewed-on: https://review.coreboot.org/c/coreboot/+/42724 Reviewed-by: Aaron Durbin adurbin@chromium.org Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/mainboard/google/zork/variants/baseboard/gpio_baseboard_trembyle.c M src/mainboard/google/zork/variants/berknip/gpio.c M src/mainboard/google/zork/variants/ezkinil/gpio.c M src/mainboard/google/zork/variants/morphius/gpio.c M src/mainboard/google/zork/variants/trembyle/gpio.c 5 files changed, 105 insertions(+), 30 deletions(-)
Approvals: build bot (Jenkins): Verified Aaron Durbin: Looks good to me, approved
*size = 0;
