Attention is currently required from: Dtrain Hsu, Paul Menzel, Tim Wawrzynczak, Felix Held. Hello build bot (Jenkins), Tim Wawrzynczak, Zhuohao Lee, Felix Held,
https://review.coreboot.org/c/coreboot/+/63645
Change subject: mb/google/brya/variants/baseboard/brask: fix boot beep ......................................................................
Fix the issue that can't hear the boot beep at dev screen. GPP_B14 is used for PWM_PP3300_BUZZER and it should set to GPO. Modify GPP_B4 from PAD_CFG_NF_LOCK to PAD_CFG_GPO_LOCK.
BUG=b:229345416 BRANCH=firmware-brya-14505.B TEST=emerge-brask coreboot and verify if the buzzer beeps.
Signed-off-by: Dtrain Hsu dtrain_hsu@compal.corp-partner.google.com Change-Id: I601735ab20974cd992ca5dd6dbaca1517a395aa2 --- M src/mainboard/google/brya/variants/baseboard/brask/gpio.c 1 file changed, 1 insertion(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/45/63645/3
