Kyösti Mälkki has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/38188 )
Change subject: drivers/pc80/rtc: Clean up some POST_CODE_EXTRA use ......................................................................
Change-Id: I5ecfa0860a28547f76a72592a8d07bca67822217 Signed-off-by: Kyösti Mälkki kyosti.malkki@gmail.com --- M src/drivers/pc80/rtc/post.c M src/include/console/console.h 2 files changed, 43 insertions(+), 51 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/88/38188/1
diff --git a/src/drivers/pc80/rtc/post.c b/src/drivers/pc80/rtc/post.c index e559edf..0d5d0e1 100644 --- a/src/drivers/pc80/rtc/post.c +++ b/src/drivers/pc80/rtc/post.c @@ -24,9 +24,7 @@ void cmos_post_log(void) { u8 code = 0; -#if CONFIG(CMOS_POST_EXTRA) u32 extra = 0; -#endif
spin_lock(&cmos_post_lock);
@@ -34,15 +32,13 @@ switch (cmos_read(CMOS_POST_BANK_OFFSET)) { case CMOS_POST_BANK_0_MAGIC: code = cmos_read(CMOS_POST_BANK_1_OFFSET); -#if CONFIG(CMOS_POST_EXTRA) - extra = cmos_read32(CMOS_POST_BANK_1_EXTRA); -#endif + if (CONFIG(CMOS_POST_EXTRA)) + extra = cmos_read32(CMOS_POST_BANK_1_EXTRA); break; case CMOS_POST_BANK_1_MAGIC: code = cmos_read(CMOS_POST_BANK_0_OFFSET); -#if CONFIG(CMOS_POST_EXTRA) - extra = cmos_read32(CMOS_POST_BANK_0_EXTRA); -#endif + if (CONFIG(CMOS_POST_EXTRA)) + extra = cmos_read32(CMOS_POST_BANK_0_EXTRA); break; }
@@ -60,11 +56,9 @@ "in previous boot: 0x%02x\n", code); #if CONFIG(ELOG) && (ENV_RAMSTAGE || CONFIG(ELOG_PRERAM)) elog_add_event_word(ELOG_TYPE_LAST_POST_CODE, code); -#if CONFIG(CMOS_POST_EXTRA) - if (extra) + if (CONFIG(CMOS_POST_EXTRA) && extra) elog_add_event_dword(ELOG_TYPE_POST_EXTRA, extra); #endif -#endif } }
@@ -83,49 +77,15 @@ /* Initialize to zero */ cmos_write(0, CMOS_POST_BANK_0_OFFSET); cmos_write(0, CMOS_POST_BANK_1_OFFSET); -#if CONFIG(CMOS_POST_EXTRA) - cmos_write32(0, CMOS_POST_BANK_0_EXTRA); - cmos_write32(0, CMOS_POST_BANK_1_EXTRA); -#endif + if (CONFIG(CMOS_POST_EXTRA)) { + cmos_write32(0, CMOS_POST_BANK_0_EXTRA); + cmos_write32(0, CMOS_POST_BANK_1_EXTRA); + } }
cmos_write(magic, CMOS_POST_BANK_OFFSET); }
-#if CONFIG(CMOS_POST_EXTRA) -void post_log_extra(u32 value) -{ - spin_lock(&cmos_post_lock); - - switch (cmos_read(CMOS_POST_BANK_OFFSET)) { - case CMOS_POST_BANK_0_MAGIC: - cmos_write32(value, CMOS_POST_BANK_0_EXTRA); - break; - case CMOS_POST_BANK_1_MAGIC: - cmos_write32(value, CMOS_POST_BANK_1_EXTRA); - break; - } - - spin_unlock(&cmos_post_lock); -} - -void post_log_path(const struct device *dev) -{ - if (dev) { - /* Encode path into lower 3 bytes */ - u32 path = dev_path_encode(dev); - /* Upper byte contains the log type */ - path |= CMOS_POST_EXTRA_DEV_PATH << 24; - post_log_extra(path); - } -} - -void post_log_clear(void) -{ - post_log_extra(0); -} -#endif /* CONFIG_CMOS_POST_EXTRA */ - void cmos_post_code(u8 value) { spin_lock(&cmos_post_lock); @@ -141,3 +101,37 @@
spin_unlock(&cmos_post_lock); } + +static void __unused cmos_post_extra(u32 value) +{ + spin_lock(&cmos_post_lock); + + switch (cmos_read(CMOS_POST_BANK_OFFSET)) { + case CMOS_POST_BANK_0_MAGIC: + cmos_write32(value, CMOS_POST_BANK_0_EXTRA); + break; + case CMOS_POST_BANK_1_MAGIC: + cmos_write32(value, CMOS_POST_BANK_1_EXTRA); + break; + } + + spin_unlock(&cmos_post_lock); +} + +#if CONFIG(CMOS_POST_EXTRA) +void post_log_path(const struct device *dev) +{ + if (dev) { + /* Encode path into lower 3 bytes */ + u32 path = dev_path_encode(dev); + /* Upper byte contains the log type */ + path |= CMOS_POST_EXTRA_DEV_PATH << 24; + cmos_post_extra(path); + } +} + +void post_log_clear(void) +{ + cmos_post_extra(0); +} +#endif /* CONFIG_CMOS_POST_EXTRA */ diff --git a/src/include/console/console.h b/src/include/console/console.h index c573123..9983cef 100644 --- a/src/include/console/console.h +++ b/src/include/console/console.h @@ -32,12 +32,10 @@ void arch_post_code(u8 value); void cmos_post_code(u8 value); #if CONFIG(CMOS_POST_EXTRA) -void post_log_extra(u32 value); struct device; void post_log_path(const struct device *dev); void post_log_clear(void); #else -#define post_log_extra(x) do {} while (0) #define post_log_path(x) do {} while (0) #define post_log_clear() do {} while (0) #endif
Angel Pons has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/38188 )
Patch Set 4: Code-Review+2
Patrick Georgi has submitted this change. ( https://review.coreboot.org/c/coreboot/+/38188 )
Change-Id: I5ecfa0860a28547f76a72592a8d07bca67822217 Signed-off-by: Kyösti Mälkki kyosti.malkki@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/38188 Reviewed-by: Angel Pons th3fanbus@gmail.com Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/drivers/pc80/rtc/post.c M src/include/console/console.h 2 files changed, 43 insertions(+), 51 deletions(-)
