Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/83703?usp=email )
Change subject: soc/mediatek/common: Refactor EINT driver ......................................................................
Refactor EINT driver by - Move `pos_bit_calc_for_eint` to `common/gpio_eint_v1.c` and rename to `gpio_calc_eint_pos_bit`. - Implement `gpio_get_eint_reg` to obtain EINT base address.
This change is prepared for the driver change in MT8196.
BUG=b:334723688 TEST=EINT works on Geralt
Change-Id: Ie53abc23971bfa39250ebd7dd48e28d6b91c5973 Signed-off-by: Yidi Lin yidilin@chromium.org Reviewed-on: https://review.coreboot.org/c/coreboot/+/83703 Reviewed-by: Yu-Ping Wu yupingso@google.com Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/soc/mediatek/common/gpio.c A src/soc/mediatek/common/gpio_eint_v1.c M src/soc/mediatek/common/include/soc/gpio_common.h M src/soc/mediatek/mt8183/Makefile.mk M src/soc/mediatek/mt8186/Makefile.mk M src/soc/mediatek/mt8188/Makefile.mk M src/soc/mediatek/mt8192/Makefile.mk M src/soc/mediatek/mt8195/Makefile.mk 8 files changed, 40 insertions(+), 22 deletions(-)
Approvals: Yu-Ping Wu: Looks good to me, approved build bot (Jenkins): Verified
diff --git a/src/soc/mediatek/common/gpio.c b/src/soc/mediatek/common/gpio.c index e8a50b2..bbfbb3d 100644 --- a/src/soc/mediatek/common/gpio.c +++ b/src/soc/mediatek/common/gpio.c @@ -1,5 +1,6 @@ /* SPDX-License-Identifier: GPL-2.0-only */
+#include <assert.h> #include <device/mmio.h> #include <gpio.h>
@@ -113,23 +114,16 @@ gpio_set_mode(gpio, GPIO_MODE); }
-enum { - MAX_EINT_REG_BITS = 32, -}; - -static void pos_bit_calc_for_eint(gpio_t gpio, u32 *pos, u32 *bit) -{ - *pos = gpio.id / MAX_EINT_REG_BITS; - *bit = gpio.id % MAX_EINT_REG_BITS; -} - int gpio_eint_poll(gpio_t gpio) { u32 pos; u32 bit; u32 status; + struct eint_regs *mtk_eint;
- pos_bit_calc_for_eint(gpio, &pos, &bit); + gpio_calc_eint_pos_bit(gpio, &pos, &bit); + mtk_eint = gpio_get_eint_reg(gpio); + assert(mtk_eint);
status = (read32(&mtk_eint->sta.regs[pos]) >> bit) & 0x1;
@@ -143,8 +137,12 @@ { u32 pos; u32 bit, mask; + struct eint_regs *mtk_eint;
- pos_bit_calc_for_eint(gpio, &pos, &bit); + gpio_calc_eint_pos_bit(gpio, &pos, &bit); + mtk_eint = gpio_get_eint_reg(gpio); + assert(mtk_eint); + mask = 1 << bit;
/* Make it an input first. */ diff --git a/src/soc/mediatek/common/gpio_eint_v1.c b/src/soc/mediatek/common/gpio_eint_v1.c new file mode 100644 index 0000000..194dff4 --- /dev/null +++ b/src/soc/mediatek/common/gpio_eint_v1.c @@ -0,0 +1,15 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#include <soc/addressmap.h> +#include <gpio.h> + +void gpio_calc_eint_pos_bit(gpio_t gpio, u32 *pos, u32 *bit) +{ + *pos = gpio.id / MAX_EINT_REG_BITS; + *bit = gpio.id % MAX_EINT_REG_BITS; +} + +struct eint_regs *gpio_get_eint_reg(gpio_t gpio) +{ + return (struct eint_regs *)(EINT_BASE); +} diff --git a/src/soc/mediatek/common/include/soc/gpio_common.h b/src/soc/mediatek/common/include/soc/gpio_common.h index b12d9c9..870dac5 100644 --- a/src/soc/mediatek/common/include/soc/gpio_common.h +++ b/src/soc/mediatek/common/include/soc/gpio_common.h @@ -102,8 +102,6 @@
check_member(eint_regs, d1en, 0x420);
-static struct eint_regs *const mtk_eint = (void *)(EINT_BASE); - /* * Firmware never enables interrupts on this platform. This function * reads current EINT status and clears the pending interrupt. @@ -117,4 +115,11 @@ */ void gpio_eint_configure(gpio_t gpio, enum gpio_irq_type type);
+enum { + MAX_EINT_REG_BITS = 32, +}; + +void gpio_calc_eint_pos_bit(gpio_t gpio, u32 *pos, u32 *bit); +struct eint_regs *gpio_get_eint_reg(gpio_t gpio); + #endif diff --git a/src/soc/mediatek/mt8183/Makefile.mk b/src/soc/mediatek/mt8183/Makefile.mk index 3b4a1e8..775cdea 100644 --- a/src/soc/mediatek/mt8183/Makefile.mk +++ b/src/soc/mediatek/mt8183/Makefile.mk @@ -3,7 +3,7 @@
bootblock-y += bootblock.c bootblock-y += ../common/auxadc.c -bootblock-y += ../common/gpio.c gpio.c +bootblock-y += ../common/gpio_eint_v1.c ../common/gpio.c gpio.c bootblock-y += ../common/pll.c pll.c bootblock-$(CONFIG_SPI_FLASH) += ../common/spi.c spi.c bootblock-y += mt8183.c @@ -17,7 +17,7 @@ decompressor-y += ../common/timer.c
verstage-y += ../common/auxadc.c -verstage-y += ../common/gpio.c gpio.c +verstage-y += ../common/gpio_eint_v1.c ../common/gpio.c gpio.c verstage-$(CONFIG_SPI_FLASH) += ../common/spi.c spi.c verstage-y += mt8183.c verstage-y += ../common/i2c.c i2c.c @@ -34,7 +34,7 @@ romstage-y += memory.c romstage-$(CONFIG_MEMORY_TEST) += ../common/memory_test.c romstage-y += mt8183.c -romstage-y += ../common/gpio.c gpio.c +romstage-y += ../common/gpio_eint_v1.c ../common/gpio.c gpio.c romstage-y += ../common/mmu_operations.c mmu_operations.c romstage-y += ../common/pll.c pll.c romstage-y += ../common/pmic_wrap.c pmic_wrap.c mt6358.c @@ -50,7 +50,7 @@ ramstage-y += ../common/auxadc.c ramstage-y += ../common/ddp.c ddp.c ramstage-y += ../common/dsi.c ../common/mtk_mipi_dphy.c -ramstage-y += ../common/gpio.c gpio.c +ramstage-y += ../common/gpio_eint_v1.c ../common/gpio.c gpio.c ramstage-y += ../common/i2c.c i2c.c ramstage-y += ../common/mcu.c ramstage-y += ../common/mmu_operations.c mmu_operations.c diff --git a/src/soc/mediatek/mt8186/Makefile.mk b/src/soc/mediatek/mt8186/Makefile.mk index 8e116f8..f637dcf 100644 --- a/src/soc/mediatek/mt8186/Makefile.mk +++ b/src/soc/mediatek/mt8186/Makefile.mk @@ -4,7 +4,7 @@ # for bootblock, verstage, romstage, ramstage all-y += ../common/cpu_id.c all-y += ../common/flash_controller.c -all-y += ../common/gpio.c ../common/gpio_op.c gpio.c +all-y += ../common/gpio_eint_v1.c ../common/gpio.c ../common/gpio_op.c gpio.c all-y += ../common/i2c.c i2c.c all-y += ../common/pll.c pll.c all-$(CONFIG_SPI_FLASH) += ../common/spi.c spi.c diff --git a/src/soc/mediatek/mt8188/Makefile.mk b/src/soc/mediatek/mt8188/Makefile.mk index f67c827..6a57da4 100644 --- a/src/soc/mediatek/mt8188/Makefile.mk +++ b/src/soc/mediatek/mt8188/Makefile.mk @@ -2,7 +2,7 @@ ifeq ($(CONFIG_SOC_MEDIATEK_MT8188),y)
all-y += ../common/flash_controller.c -all-y += ../common/gpio.c ../common/gpio_op.c gpio.c +all-y += ../common/gpio_eint_v1.c ../common/gpio.c ../common/gpio_op.c gpio.c all-y += ../common/i2c.c i2c.c all-y += ../common/pll.c pll.c all-$(CONFIG_SPI_FLASH) += ../common/spi.c spi.c diff --git a/src/soc/mediatek/mt8192/Makefile.mk b/src/soc/mediatek/mt8192/Makefile.mk index 5d4b87b..4e35fe1 100644 --- a/src/soc/mediatek/mt8192/Makefile.mk +++ b/src/soc/mediatek/mt8192/Makefile.mk @@ -3,7 +3,7 @@
# for bootblock, verstage, romstage, ramstage all-y += ../common/flash_controller.c -all-y += ../common/gpio.c ../common/gpio_op.c gpio.c +all-y += ../common/gpio_eint_v1.c ../common/gpio.c ../common/gpio_op.c gpio.c all-y += ../common/i2c.c i2c.c all-$(CONFIG_SPI_FLASH) += ../common/spi.c spi.c all-y += ../common/timer.c diff --git a/src/soc/mediatek/mt8195/Makefile.mk b/src/soc/mediatek/mt8195/Makefile.mk index 56a10bc..d1c1920 100644 --- a/src/soc/mediatek/mt8195/Makefile.mk +++ b/src/soc/mediatek/mt8195/Makefile.mk @@ -3,7 +3,7 @@
# for bootblock, verstage, romstage, ramstage all-y += ../common/flash_controller.c -all-y += ../common/gpio.c ../common/gpio_op.c gpio.c +all-y += ../common/gpio_eint_v1.c ../common/gpio.c ../common/gpio_op.c gpio.c all-y += ../common/i2c.c i2c.c all-$(CONFIG_SPI_FLASH) += ../common/spi.c spi.c all-y += ../common/timer.c ../common/timer_prepare.c
