Attention is currently required from: Raul Rangel, Marshall Dawson, Felix Held. Hello Jason Glenesk, build bot (Jenkins), Raul Rangel, Marshall Dawson, Paul Menzel, Karthik Ramasubramanian,
https://review.coreboot.org/c/coreboot/+/56814
Change subject: soc/amd/common/block/spi: introduce SOC_AMD_COMMON_BLOCK_SPI_4DW_BURST ......................................................................
Add a new Kconfig option to enable or disable the 4 DWORD burst support of the SPI controller and use this setting to determine if the corresponding feature bit in SPI100_HOST_PREF_CONFIG will be set or cleared. Since fch_spi_disable_4dw_burst can now enable or disable the feature, rename it to fch_spi_configure_4dw_burst. On Stoneyridge the SPI_RD4DW_EN_HOST bit needs to be cleared (see the Rd4dw_en_host bit definition in the SPIx2C SPI100 Host Prefetch Config register in the public BKDG #55072 Rev 3.09), so add a SoC dependency to the Kconfig option.
Signed-off-by: Karthikeyan Ramasubramanian kramasub@google.com Signed-off-by: Felix Held felix-coreboot@felixheld.de Change-Id: Id754fa8d5f9554ed25cf9f3341bfdd1968693788 --- M src/soc/amd/common/block/spi/Kconfig M src/soc/amd/common/block/spi/fch_spi.c 2 files changed, 14 insertions(+), 3 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/14/56814/2
