Alexander Couzens has uploaded this change for review. ( https://review.coreboot.org/21236
Change subject: src/mainboard/Kconfig: split out options into own file ......................................................................
Having includes in one file and option in another file is cleaner. Also prepare to move mainboard vendor and board selection upwards.
Change-Id: I732dad9758817b0c5a4ade314489bf4d5662e60b Signed-off-by: Alexander Couzens lynxis@fe80.eu --- M src/mainboard/Kconfig A src/mainboard/Kconfig.mainboard 2 files changed, 158 insertions(+), 157 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/36/21236/1
diff --git a/src/mainboard/Kconfig b/src/mainboard/Kconfig index bdaa9e7..7367367 100644 --- a/src/mainboard/Kconfig +++ b/src/mainboard/Kconfig @@ -10,160 +10,4 @@
source "src/mainboard/*/Kconfig"
-config BOARD_ROMSIZE_KB_64 - bool -config BOARD_ROMSIZE_KB_128 - bool -config BOARD_ROMSIZE_KB_256 - bool -config BOARD_ROMSIZE_KB_512 - bool -config BOARD_ROMSIZE_KB_1024 - bool -config BOARD_ROMSIZE_KB_2048 - bool -config BOARD_ROMSIZE_KB_4096 - bool -config BOARD_ROMSIZE_KB_8192 - bool -config BOARD_ROMSIZE_KB_12288 - bool -config BOARD_ROMSIZE_KB_16384 - bool -config BOARD_ROMSIZE_KB_32768 - bool -config BOARD_ROMSIZE_KB_65536 - bool - -# TODO: No help text possible for choice fields? -choice - prompt "ROM chip size" - default COREBOOT_ROMSIZE_KB_64 if BOARD_ROMSIZE_KB_64 - default COREBOOT_ROMSIZE_KB_128 if BOARD_ROMSIZE_KB_128 - default COREBOOT_ROMSIZE_KB_256 if BOARD_ROMSIZE_KB_256 - default COREBOOT_ROMSIZE_KB_512 if BOARD_ROMSIZE_KB_512 - default COREBOOT_ROMSIZE_KB_1024 if BOARD_ROMSIZE_KB_1024 - default COREBOOT_ROMSIZE_KB_2048 if BOARD_ROMSIZE_KB_2048 - default COREBOOT_ROMSIZE_KB_4096 if BOARD_ROMSIZE_KB_4096 - default COREBOOT_ROMSIZE_KB_8192 if BOARD_ROMSIZE_KB_8192 - default COREBOOT_ROMSIZE_KB_12288 if BOARD_ROMSIZE_KB_12288 - default COREBOOT_ROMSIZE_KB_16384 if BOARD_ROMSIZE_KB_16384 - default COREBOOT_ROMSIZE_KB_32768 if BOARD_ROMSIZE_KB_32768 - default COREBOOT_ROMSIZE_KB_65536 if BOARD_ROMSIZE_KB_65536 - help - Select the size of the ROM chip you intend to flash coreboot on. - - The build system will take care of creating a coreboot.rom file - of the matching size. - -config COREBOOT_ROMSIZE_KB_64 - bool "64 KB" - help - Choose this option if you have a 64 KB ROM chip. - -config COREBOOT_ROMSIZE_KB_128 - bool "128 KB" - help - Choose this option if you have a 128 KB ROM chip. - -config COREBOOT_ROMSIZE_KB_256 - bool "256 KB" - help - Choose this option if you have a 256 KB ROM chip. - -config COREBOOT_ROMSIZE_KB_512 - bool "512 KB" - help - Choose this option if you have a 512 KB ROM chip. - -config COREBOOT_ROMSIZE_KB_1024 - bool "1024 KB (1 MB)" - help - Choose this option if you have a 1024 KB (1 MB) ROM chip. - -config COREBOOT_ROMSIZE_KB_2048 - bool "2048 KB (2 MB)" - help - Choose this option if you have a 2048 KB (2 MB) ROM chip. - -config COREBOOT_ROMSIZE_KB_4096 - bool "4096 KB (4 MB)" - help - Choose this option if you have a 4096 KB (4 MB) ROM chip. - -config COREBOOT_ROMSIZE_KB_8192 - bool "8192 KB (8 MB)" - help - Choose this option if you have a 8192 KB (8 MB) ROM chip. - -config COREBOOT_ROMSIZE_KB_12288 - bool "12288 KB (12 MB)" - help - Choose this option if you have a 12288 KB (12 MB) ROM chip. - -config COREBOOT_ROMSIZE_KB_16384 - bool "16384 KB (16 MB)" - help - Choose this option if you have a 16384 KB (16 MB) ROM chip. - -config COREBOOT_ROMSIZE_KB_32768 - bool "32768 KB (32 MB)" - help - Choose this option if you have a 32768 KB (32 MB) ROM chip. - -config COREBOOT_ROMSIZE_KB_65536 - bool "65536 KB (64 MB)" - help - Choose this option if you have a 65536 KB (64 MB) ROM chip. - -endchoice - -# Map the config names to an integer (KB). -config COREBOOT_ROMSIZE_KB - int - default 64 if COREBOOT_ROMSIZE_KB_64 - default 128 if COREBOOT_ROMSIZE_KB_128 - default 256 if COREBOOT_ROMSIZE_KB_256 - default 512 if COREBOOT_ROMSIZE_KB_512 - default 1024 if COREBOOT_ROMSIZE_KB_1024 - default 2048 if COREBOOT_ROMSIZE_KB_2048 - default 4096 if COREBOOT_ROMSIZE_KB_4096 - default 8192 if COREBOOT_ROMSIZE_KB_8192 - default 12288 if COREBOOT_ROMSIZE_KB_12288 - default 16384 if COREBOOT_ROMSIZE_KB_16384 - default 32768 if COREBOOT_ROMSIZE_KB_32768 - default 65536 if COREBOOT_ROMSIZE_KB_65536 - -# Map the config names to a hex value (bytes). -config ROM_SIZE - hex - default 0x10000 if COREBOOT_ROMSIZE_KB_64 - default 0x20000 if COREBOOT_ROMSIZE_KB_128 - default 0x40000 if COREBOOT_ROMSIZE_KB_256 - default 0x80000 if COREBOOT_ROMSIZE_KB_512 - default 0x100000 if COREBOOT_ROMSIZE_KB_1024 - default 0x200000 if COREBOOT_ROMSIZE_KB_2048 - default 0x400000 if COREBOOT_ROMSIZE_KB_4096 - default 0x800000 if COREBOOT_ROMSIZE_KB_8192 - default 0xc00000 if COREBOOT_ROMSIZE_KB_12288 - default 0x1000000 if COREBOOT_ROMSIZE_KB_16384 - default 0x2000000 if COREBOOT_ROMSIZE_KB_32768 - default 0x4000000 if COREBOOT_ROMSIZE_KB_65536 - -config ENABLE_POWER_BUTTON - bool "Enable the power button" if POWER_BUTTON_IS_OPTIONAL - default y if POWER_BUTTON_DEFAULT_ENABLE - default n if POWER_BUTTON_DEFAULT_DISABLE - help - The selected mainboard can optionally have the power button tied - to ground with a jumper so that the button appears to be - constantly depressed. If this option is enabled and the jumper is - installed then the board will turn on, but turn off again after a - short timeout, usually 4 seconds. - - Select Y here if you have removed the jumper and want to use an - actual power button. Select N if you have the jumper installed. - -config ENABLE_POWER_BUTTON - def_bool y if !POWER_BUTTON_IS_OPTIONAL && POWER_BUTTON_FORCE_ENABLE - def_bool n if !POWER_BUTTON_IS_OPTIONAL && POWER_BUTTON_FORCE_DISABLE +source "src/mainboard/Kconfig.mainboard" diff --git a/src/mainboard/Kconfig.mainboard b/src/mainboard/Kconfig.mainboard new file mode 100644 index 0000000..babbb95 --- /dev/null +++ b/src/mainboard/Kconfig.mainboard @@ -0,0 +1,157 @@ +config BOARD_ROMSIZE_KB_64 + bool +config BOARD_ROMSIZE_KB_128 + bool +config BOARD_ROMSIZE_KB_256 + bool +config BOARD_ROMSIZE_KB_512 + bool +config BOARD_ROMSIZE_KB_1024 + bool +config BOARD_ROMSIZE_KB_2048 + bool +config BOARD_ROMSIZE_KB_4096 + bool +config BOARD_ROMSIZE_KB_8192 + bool +config BOARD_ROMSIZE_KB_12288 + bool +config BOARD_ROMSIZE_KB_16384 + bool +config BOARD_ROMSIZE_KB_32768 + bool +config BOARD_ROMSIZE_KB_65536 + bool + +# TODO: No help text possible for choice fields? +choice + prompt "ROM chip size" + default COREBOOT_ROMSIZE_KB_64 if BOARD_ROMSIZE_KB_64 + default COREBOOT_ROMSIZE_KB_128 if BOARD_ROMSIZE_KB_128 + default COREBOOT_ROMSIZE_KB_256 if BOARD_ROMSIZE_KB_256 + default COREBOOT_ROMSIZE_KB_512 if BOARD_ROMSIZE_KB_512 + default COREBOOT_ROMSIZE_KB_1024 if BOARD_ROMSIZE_KB_1024 + default COREBOOT_ROMSIZE_KB_2048 if BOARD_ROMSIZE_KB_2048 + default COREBOOT_ROMSIZE_KB_4096 if BOARD_ROMSIZE_KB_4096 + default COREBOOT_ROMSIZE_KB_8192 if BOARD_ROMSIZE_KB_8192 + default COREBOOT_ROMSIZE_KB_12288 if BOARD_ROMSIZE_KB_12288 + default COREBOOT_ROMSIZE_KB_16384 if BOARD_ROMSIZE_KB_16384 + default COREBOOT_ROMSIZE_KB_32768 if BOARD_ROMSIZE_KB_32768 + default COREBOOT_ROMSIZE_KB_65536 if BOARD_ROMSIZE_KB_65536 + help + Select the size of the ROM chip you intend to flash coreboot on. + + The build system will take care of creating a coreboot.rom file + of the matching size. + +config COREBOOT_ROMSIZE_KB_64 + bool "64 KB" + help + Choose this option if you have a 64 KB ROM chip. + +config COREBOOT_ROMSIZE_KB_128 + bool "128 KB" + help + Choose this option if you have a 128 KB ROM chip. + +config COREBOOT_ROMSIZE_KB_256 + bool "256 KB" + help + Choose this option if you have a 256 KB ROM chip. + +config COREBOOT_ROMSIZE_KB_512 + bool "512 KB" + help + Choose this option if you have a 512 KB ROM chip. + +config COREBOOT_ROMSIZE_KB_1024 + bool "1024 KB (1 MB)" + help + Choose this option if you have a 1024 KB (1 MB) ROM chip. + +config COREBOOT_ROMSIZE_KB_2048 + bool "2048 KB (2 MB)" + help + Choose this option if you have a 2048 KB (2 MB) ROM chip. + +config COREBOOT_ROMSIZE_KB_4096 + bool "4096 KB (4 MB)" + help + Choose this option if you have a 4096 KB (4 MB) ROM chip. + +config COREBOOT_ROMSIZE_KB_8192 + bool "8192 KB (8 MB)" + help + Choose this option if you have a 8192 KB (8 MB) ROM chip. + +config COREBOOT_ROMSIZE_KB_12288 + bool "12288 KB (12 MB)" + help + Choose this option if you have a 12288 KB (12 MB) ROM chip. + +config COREBOOT_ROMSIZE_KB_16384 + bool "16384 KB (16 MB)" + help + Choose this option if you have a 16384 KB (16 MB) ROM chip. + +config COREBOOT_ROMSIZE_KB_32768 + bool "32768 KB (32 MB)" + help + Choose this option if you have a 32768 KB (32 MB) ROM chip. + +config COREBOOT_ROMSIZE_KB_65536 + bool "65536 KB (64 MB)" + help + Choose this option if you have a 65536 KB (64 MB) ROM chip. + +endchoice + +# Map the config names to an integer (KB). +config COREBOOT_ROMSIZE_KB + int + default 64 if COREBOOT_ROMSIZE_KB_64 + default 128 if COREBOOT_ROMSIZE_KB_128 + default 256 if COREBOOT_ROMSIZE_KB_256 + default 512 if COREBOOT_ROMSIZE_KB_512 + default 1024 if COREBOOT_ROMSIZE_KB_1024 + default 2048 if COREBOOT_ROMSIZE_KB_2048 + default 4096 if COREBOOT_ROMSIZE_KB_4096 + default 8192 if COREBOOT_ROMSIZE_KB_8192 + default 12288 if COREBOOT_ROMSIZE_KB_12288 + default 16384 if COREBOOT_ROMSIZE_KB_16384 + default 32768 if COREBOOT_ROMSIZE_KB_32768 + default 65536 if COREBOOT_ROMSIZE_KB_65536 + +# Map the config names to a hex value (bytes). +config ROM_SIZE + hex + default 0x10000 if COREBOOT_ROMSIZE_KB_64 + default 0x20000 if COREBOOT_ROMSIZE_KB_128 + default 0x40000 if COREBOOT_ROMSIZE_KB_256 + default 0x80000 if COREBOOT_ROMSIZE_KB_512 + default 0x100000 if COREBOOT_ROMSIZE_KB_1024 + default 0x200000 if COREBOOT_ROMSIZE_KB_2048 + default 0x400000 if COREBOOT_ROMSIZE_KB_4096 + default 0x800000 if COREBOOT_ROMSIZE_KB_8192 + default 0xc00000 if COREBOOT_ROMSIZE_KB_12288 + default 0x1000000 if COREBOOT_ROMSIZE_KB_16384 + default 0x2000000 if COREBOOT_ROMSIZE_KB_32768 + default 0x4000000 if COREBOOT_ROMSIZE_KB_65536 + +config ENABLE_POWER_BUTTON + bool "Enable the power button" if POWER_BUTTON_IS_OPTIONAL + default y if POWER_BUTTON_DEFAULT_ENABLE + default n if POWER_BUTTON_DEFAULT_DISABLE + help + The selected mainboard can optionally have the power button tied + to ground with a jumper so that the button appears to be + constantly depressed. If this option is enabled and the jumper is + installed then the board will turn on, but turn off again after a + short timeout, usually 4 seconds. + + Select Y here if you have removed the jumper and want to use an + actual power button. Select N if you have the jumper installed. + +config ENABLE_POWER_BUTTON + def_bool y if !POWER_BUTTON_IS_OPTIONAL && POWER_BUTTON_FORCE_ENABLE + def_bool n if !POWER_BUTTON_IS_OPTIONAL && POWER_BUTTON_FORCE_DISABLE
