Hello build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/70310
Change subject: intelp2m: Update cli options ......................................................................
Use the new options format:
basic functions: -file <path> path to the inteltool log file -out <path> path to the generated file -platform <type> set the PCH platform type <sunrise> enter ? to show details
generation of long composite macros with bit field definitions: -fields <type> generate a long macro consisting of bitfield macros enter ? to show details
control flags: -exclude exclude fields that should be ignored to gen macro -unchecked disable automatic checking of macro fields before gen
generate additional information: -i add function to the comments -ii add DW0/DW1 register value to the comments -iii add ignored bitfields to the comments -iiii add target PAD_CFG() macro to the comments
Use the following bash command: $ complete `-C `pwd`/intelp2m ./intelp2m to allow automatic completion of arguments
Change-Id: I08ff379b99b018b1099aa5d70fea47026bc84045 Signed-off-by: Maxim Polyakov max.senia.poliak@gmail.com --- A util/intelp2m/cli/completion.go A util/intelp2m/cli/options.go M util/intelp2m/config/p2m/config.go M util/intelp2m/main.go 4 files changed, 202 insertions(+), 68 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/10/70310/2
