Christian Gmeiner (christian.gmeiner@gmail.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/3271
commit c3a5c16b1bcc0915581393e8f7dd7aa50335e2b9 Author: Christian Gmeiner christian.gmeiner@gmail.com Date: Thu May 23 13:26:37 2013 +0200
OT200: bring LEDs into a defined state
Keep in mind that we can _NOT_ read back the current state of the LEDS as some crazy FPGA designer wanted it that way.
Change-Id: I5cd1ac598072318b3234d1ec35a79271655b46ac Signed-off-by: Christian Gmeiner christian.gmeiner@gmail.com --- src/mainboard/bachmann/ot200/mainboard.c | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/src/mainboard/bachmann/ot200/mainboard.c b/src/mainboard/bachmann/ot200/mainboard.c index 0ea053a..d4b0b2d 100644 --- a/src/mainboard/bachmann/ot200/mainboard.c +++ b/src/mainboard/bachmann/ot200/mainboard.c @@ -22,6 +22,7 @@ #include <smbios.h> #include <console/console.h> #include <cpu/x86/msr.h> +#include <arch/io.h>
/* overwrite a weak function to fill SMBIOS table with a custom value */ static u8 hw_rev = 0; @@ -52,6 +53,14 @@ static void init(struct device *dev) return; }
+ /* turn off all leds except led_ini */ + outb(0x02, 0x5a); /* bit0 - led_run */ + /* bit1 - led_ini */ + /* bit2 - led_err */ + /* bit3-bit7 - write has no effect */ + outb(0x00, 0x49); /* bit0-bit6 - led_7-led_1 */ + /* bit7 - write has no effect */ + /* read the whole block and check if checksum is okay */ for (i = 0; i < 20; i++) { block[i] = smbus_read_byte(eeprom_dev, i);
