Hello Felix Singer, build bot (Jenkins), Patrick Georgi, Furquan Shaikh, Frans Hendriks, Jeremy Soller, Stefan Reinauer, Angel Pons, Patrick Rudolph, Piotr Król, Nico Huber, Martin Roth, Michał Żygowski, David Guckian, Tim Wawrzynczak, Vanessa Eusebio, Alexander Couzens, Wim Vervoorn,
https://review.coreboot.org/c/coreboot/+/44775
to look at the new patch set (#27).
Change subject: treewide: stop using hexdumps for SPD files ......................................................................
SPD files normally don't get edited. Keeping the files as hexdump does not have any advantage and conversion from hex to bin adds complexity with a high chance for bugs and other sorts of problems.
One example for such problem is an issue that only appeared on one of my systems, where conversion of '01 02 03' to binary resulted in \x01\x32\x03 instead of \x01\x02\x03:
for c in 01 02 03; do printf $(printf '%o' 0x$c); done | xxd -g 1 00000000: 01 32 03 .2.
The reason for this was that the syntax in lib/Makefile.inc is wrong, because the backslash must be escaped due to chaining two printf commands.
To avoid future problems, we should remove some of the aforementioned complexity to lower the probability of future encoding problems. Thus, convert all SPD hexdumps to binaries and adapt the Makefiles to just concatenate them to `spd.bin`.
The SPDs, manifests and Makefiles for soc/intel/{tiger,jasper}lake and mainboard/google/{dedede,volteer,zork} have been regenerated using the following commands:
go run util/spd_tools/ddr4/gen_spd.go src/soc/intel/tigerlake/spd/ \ util/spd_tools/ddr4/global_ddr4_mem_parts.json.txt TGL
go run util/spd_tools/lp4x/gen_spd.go src/soc/intel/tigerlake/spd/ \ util/spd_tools/lp4x/global_lp4x_mem_parts.json.txt TGL
go run util/spd_tools/lp4x/gen_spd.go src/soc/intel/jasperlake/spd/ \ util/spd_tools/lp4x/global_lp4x_mem_parts.json.txt JSL
for v in src/mainboard/google/zork/variants/*; do [ -f ${v}/spd/mem_parts_used.txt ] || continue go run util/spd_tools/ddr4/gen_part_id.go \ src/mainboard/google/zork/spd \ ${v}/spd ${v}/spd/mem_parts_used.txt done
for v in src/mainboard/google/{dedede,volteer}/variants/*; do [ -f ${v}/memory/mem_list_variant.txt ] || continue for m in ddr4 lp4x; do go run ./util/spd_tools/${m}/gen_part_id.go \ src/soc/intel/tigerlake/spd ${v}/memory \ ${v}/memory/mem_list_variant.txt done done
All other SPD files have been converted with `grep -v "^#" | xxd -ps -r` or `xxd -rg1`, depending on the format.
Documentation has been updated where needed.
For all affected boards the output binary has been verified to remain identical, using timeless abuild.
Exception: google/volteer/variants/lindar will have an empty spd.bin until CB:44848 gets merged.
Signed-off-by: Michael Niewöhner foss@mniewoehner.de Change-Id: I0f24183a872924cddcfdf7587cc0c126da900f91 --- M .gitignore M Documentation/Intel/Board/board.html M Documentation/soc/amd/family17h.md M src/lib/Kconfig M src/lib/Makefile.inc A src/mainboard/bap/ode_e20XX/spd/BAP_Q7_1066.spd.bin D src/mainboard/bap/ode_e20XX/spd/BAP_Q7_1066.spd.hex A src/mainboard/bap/ode_e20XX/spd/BAP_Q7_800.spd.bin D src/mainboard/bap/ode_e20XX/spd/BAP_Q7_800.spd.hex A src/mainboard/facebook/fbg1701/spd/KINGSTON_B5116ECMDXGGB.spd.bin D src/mainboard/facebook/fbg1701/spd/KINGSTON_B5116ECMDXGGB.spd.hex A src/mainboard/facebook/fbg1701/spd/MICRON_MT41K512M16HA-125A.spd.bin D src/mainboard/facebook/fbg1701/spd/MICRON_MT41K512M16HA-125A.spd.hex A src/mainboard/facebook/fbg1701/spd/SAMSUNG_K4B8G1646D-MYKO.spd.bin D src/mainboard/facebook/fbg1701/spd/SAMSUNG_K4B8G1646D-MYKO.spd.hex A src/mainboard/gizmosphere/gizmo/spd/Elpida_EDJ2116DEBG.spd.bin D src/mainboard/gizmosphere/gizmo/spd/Elpida_EDJ2116DEBG.spd.hex A src/mainboard/gizmosphere/gizmo2/spd/Micron_MT41J128M16JT.spd.bin D src/mainboard/gizmosphere/gizmo2/spd/Micron_MT41J128M16JT.spd.hex A src/mainboard/google/auron/variants/auron_paine/spd/Hynix_HMT425S6AFR6A.spd.bin D src/mainboard/google/auron/variants/auron_paine/spd/Hynix_HMT425S6AFR6A.spd.hex A src/mainboard/google/auron/variants/auron_paine/spd/Hynix_HMT425S6CFR6A_H5TC4G63CFR.spd.bin D src/mainboard/google/auron/variants/auron_paine/spd/Hynix_HMT425S6CFR6A_H5TC4G63CFR.spd.hex M src/mainboard/google/auron/variants/auron_paine/spd/Makefile.inc A src/mainboard/google/auron/variants/auron_paine/spd/Micron_4KTF25664HZ.spd.bin D src/mainboard/google/auron/variants/auron_paine/spd/Micron_4KTF25664HZ.spd.hex A src/mainboard/google/auron/variants/auron_paine/spd/empty.spd.bin D src/mainboard/google/auron/variants/auron_paine/spd/empty.spd.hex A src/mainboard/google/auron/variants/auron_yuna/spd/Hynix_HMT425S6AFR6A.spd.bin D src/mainboard/google/auron/variants/auron_yuna/spd/Hynix_HMT425S6AFR6A.spd.hex A src/mainboard/google/auron/variants/auron_yuna/spd/Hynix_HMT425S6CFR6A_H5TC4G63CFR.spd.bin D src/mainboard/google/auron/variants/auron_yuna/spd/Hynix_HMT425S6CFR6A_H5TC4G63CFR.spd.hex M src/mainboard/google/auron/variants/auron_yuna/spd/Makefile.inc A src/mainboard/google/auron/variants/auron_yuna/spd/Micron_4KTF25664HZ.spd.bin D src/mainboard/google/auron/variants/auron_yuna/spd/Micron_4KTF25664HZ.spd.hex A src/mainboard/google/auron/variants/auron_yuna/spd/empty.spd.bin D src/mainboard/google/auron/variants/auron_yuna/spd/empty.spd.hex A src/mainboard/google/auron/variants/gandof/spd/Hynix_HMT425S6AFR6A.spd.bin D src/mainboard/google/auron/variants/gandof/spd/Hynix_HMT425S6AFR6A.spd.hex A src/mainboard/google/auron/variants/gandof/spd/Hynix_HMT425S6CFR6A_H5TC4G63CFR.spd.bin D src/mainboard/google/auron/variants/gandof/spd/Hynix_HMT425S6CFR6A_H5TC4G63CFR.spd.hex M src/mainboard/google/auron/variants/gandof/spd/Makefile.inc A src/mainboard/google/auron/variants/gandof/spd/Micron_4KTF25664HZ.spd.bin D src/mainboard/google/auron/variants/gandof/spd/Micron_4KTF25664HZ.spd.hex A src/mainboard/google/auron/variants/gandof/spd/Samsung_M471B5674EB0-YK0.spd.bin D src/mainboard/google/auron/variants/gandof/spd/Samsung_M471B5674EB0-YK0.spd.hex A src/mainboard/google/auron/variants/gandof/spd/empty.spd.bin D src/mainboard/google/auron/variants/gandof/spd/empty.spd.hex M src/mainboard/google/auron/variants/lulu/spd/Makefile.inc A src/mainboard/google/auron/variants/lulu/spd/empty.spd.bin D src/mainboard/google/auron/variants/lulu/spd/empty.spd.hex A src/mainboard/google/auron/variants/lulu/spd/hynix_2GiB_dimm_H5TC4G63AFR-PBA.spd.bin D src/mainboard/google/auron/variants/lulu/spd/hynix_2GiB_dimm_H5TC4G63AFR-PBA.spd.hex A src/mainboard/google/auron/variants/lulu/spd/hynix_4GiB_dimm_H5TC8G63CMR-PBA.spd.bin D src/mainboard/google/auron/variants/lulu/spd/hynix_4GiB_dimm_H5TC8G63CMR-PBA.spd.hex A src/mainboard/google/auron/variants/lulu/spd/micron_2GiB_dimm_MT41K256M16HA-125.spd.bin D src/mainboard/google/auron/variants/lulu/spd/micron_2GiB_dimm_MT41K256M16HA-125.spd.hex A src/mainboard/google/auron/variants/lulu/spd/micron_4GiB_dimm_MT41K512M16TNA-125.spd.bin D src/mainboard/google/auron/variants/lulu/spd/micron_4GiB_dimm_MT41K512M16TNA-125.spd.hex A src/mainboard/google/auron/variants/lulu/spd/samsung_2GiB_dimm_K4B4G1646E-BYK0.spd.bin D src/mainboard/google/auron/variants/lulu/spd/samsung_2GiB_dimm_K4B4G1646E-BYK0.spd.hex A src/mainboard/google/auron/variants/lulu/spd/samsung_2GiB_dimm_K4B4G1646Q-HYK0.spd.bin D src/mainboard/google/auron/variants/lulu/spd/samsung_2GiB_dimm_K4B4G1646Q-HYK0.spd.hex A src/mainboard/google/auron/variants/lulu/spd/samsung_4GiB_dimm_K4B8G1646Q-MYK0.spd.bin D src/mainboard/google/auron/variants/lulu/spd/samsung_4GiB_dimm_K4B8G1646Q-MYK0.spd.hex M src/mainboard/google/auron/variants/samus/spd/Makefile.inc A src/mainboard/google/auron/variants/samus/spd/elpida_16.spd.bin D src/mainboard/google/auron/variants/samus/spd/elpida_16.spd.hex A src/mainboard/google/auron/variants/samus/spd/elpida_4.spd.bin D src/mainboard/google/auron/variants/samus/spd/elpida_4.spd.hex A src/mainboard/google/auron/variants/samus/spd/elpida_8.spd.bin D src/mainboard/google/auron/variants/samus/spd/elpida_8.spd.hex A src/mainboard/google/auron/variants/samus/spd/empty.spd.bin D src/mainboard/google/auron/variants/samus/spd/empty.spd.hex A src/mainboard/google/auron/variants/samus/spd/hynix_16.spd.bin D src/mainboard/google/auron/variants/samus/spd/hynix_16.spd.hex A src/mainboard/google/auron/variants/samus/spd/hynix_4.spd.bin D src/mainboard/google/auron/variants/samus/spd/hynix_4.spd.hex A src/mainboard/google/auron/variants/samus/spd/hynix_8.spd.bin D src/mainboard/google/auron/variants/samus/spd/hynix_8.spd.hex A src/mainboard/google/auron/variants/samus/spd/samsung_4.spd.bin D src/mainboard/google/auron/variants/samus/spd/samsung_4.spd.hex A src/mainboard/google/auron/variants/samus/spd/samsung_8.spd.bin D src/mainboard/google/auron/variants/samus/spd/samsung_8.spd.hex A src/mainboard/google/cyan/spd/empty.spd.bin D src/mainboard/google/cyan/spd/empty.spd.hex A src/mainboard/google/cyan/spd/hynix_2GiB_dimm_H5TC4G63AFR-PBA.spd.bin D src/mainboard/google/cyan/spd/hynix_2GiB_dimm_H5TC4G63AFR-PBA.spd.hex A src/mainboard/google/cyan/spd/hynix_2GiB_dimm_H9CCNNN8GTMLAR-NUD.spd.bin D src/mainboard/google/cyan/spd/hynix_2GiB_dimm_H9CCNNN8GTMLAR-NUD.spd.hex A src/mainboard/google/cyan/spd/hynix_2GiB_dimm_HMT425S6CFR6A_H5TC4G63CFR.spd.bin D src/mainboard/google/cyan/spd/hynix_2GiB_dimm_HMT425S6CFR6A_H5TC4G63CFR.spd.hex A src/mainboard/google/cyan/spd/hynix_dimm_H9CCNNN8GTALAR-NUD.spd.bin D src/mainboard/google/cyan/spd/hynix_dimm_H9CCNNN8GTALAR-NUD.spd.hex A src/mainboard/google/cyan/spd/hynix_dimm_H9CCNNN8GTMLAR-NUD.spd.bin D src/mainboard/google/cyan/spd/hynix_dimm_H9CCNNN8GTMLAR-NUD.spd.hex A src/mainboard/google/cyan/spd/hynix_dimm_H9CCNNN8JTBLAR-NUD-1G-1866.spd.bin D src/mainboard/google/cyan/spd/hynix_dimm_H9CCNNN8JTBLAR-NUD-1G-1866.spd.hex A src/mainboard/google/cyan/spd/hynix_dimm_H9CCNNN8JTBLAR-NUD.spd.bin D src/mainboard/google/cyan/spd/hynix_dimm_H9CCNNN8JTBLAR-NUD.spd.hex A src/mainboard/google/cyan/spd/micron_2GiB_dimm_EDF8132A3MA-GD-F-R.spd.bin D src/mainboard/google/cyan/spd/micron_2GiB_dimm_EDF8132A3MA-GD-F-R.spd.hex A src/mainboard/google/cyan/spd/micron_2GiB_dimm_EDF8132A3MA-JD-F.spd.bin D src/mainboard/google/cyan/spd/micron_2GiB_dimm_EDF8132A3MA-JD-F.spd.hex A src/mainboard/google/cyan/spd/micron_2GiB_dimm_MT41K256M16TW-107.spd.bin D src/mainboard/google/cyan/spd/micron_2GiB_dimm_MT41K256M16TW-107.spd.hex A src/mainboard/google/cyan/spd/micron_2GiB_dimm_MT52L256M32D1PF-107WT.spd.bin D src/mainboard/google/cyan/spd/micron_2GiB_dimm_MT52L256M32D1PF-107WT.spd.hex A src/mainboard/google/cyan/spd/micron_2GiB_dimm_MT52L256M32D1PF.spd.bin D src/mainboard/google/cyan/spd/micron_2GiB_dimm_MT52L256M32D1PF.spd.hex A src/mainboard/google/cyan/spd/micron_dimm_MT52L256M32D1PF-107.spd.bin D src/mainboard/google/cyan/spd/micron_dimm_MT52L256M32D1PF-107.spd.hex A src/mainboard/google/cyan/spd/nanya_dimm_NT6CL256T32CM-H1.spd.bin D src/mainboard/google/cyan/spd/nanya_dimm_NT6CL256T32CM-H1.spd.hex A src/mainboard/google/cyan/spd/samsung_2GiB_dimm_K4B4G1646E-BYK0.spd.bin D src/mainboard/google/cyan/spd/samsung_2GiB_dimm_K4B4G1646E-BYK0.spd.hex A src/mainboard/google/cyan/spd/samsung_2GiB_dimm_K4B4G1646Q-HYK0.spd.bin D src/mainboard/google/cyan/spd/samsung_2GiB_dimm_K4B4G1646Q-HYK0.spd.hex A src/mainboard/google/cyan/spd/samsung_2GiB_dimm_K4E8E304EE-EGCE.spd.bin D src/mainboard/google/cyan/spd/samsung_2GiB_dimm_K4E8E304EE-EGCE.spd.hex A src/mainboard/google/cyan/spd/samsung_2GiB_dimm_K4E8E304EE-EGCF.spd.bin D src/mainboard/google/cyan/spd/samsung_2GiB_dimm_K4E8E304EE-EGCF.spd.hex A src/mainboard/google/cyan/spd/samsung_2GiB_dimm_K4E8E324EB-EGCF.spd.bin D src/mainboard/google/cyan/spd/samsung_2GiB_dimm_K4E8E324EB-EGCF.spd.hex A src/mainboard/google/cyan/spd/samsung_dimm_K4E8E304EE-EGCE.spd.bin D src/mainboard/google/cyan/spd/samsung_dimm_K4E8E304EE-EGCE.spd.hex A src/mainboard/google/cyan/spd/samsung_dimm_K4E8E304EE-EGCF.spd.bin D src/mainboard/google/cyan/spd/samsung_dimm_K4E8E304EE-EGCF.spd.hex A src/mainboard/google/cyan/spd/samsung_dimm_K4E8E324EB-EGCF.spd.bin D src/mainboard/google/cyan/spd/samsung_dimm_K4E8E324EB-EGCF.spd.hex M src/mainboard/google/dedede/variants/boten/memory/Makefile.inc M src/mainboard/google/dedede/variants/drawcia/memory/Makefile.inc M src/mainboard/google/dedede/variants/madoo/memory/Makefile.inc M src/mainboard/google/dedede/variants/magolor/memory/Makefile.inc M src/mainboard/google/dedede/variants/waddledee/memory/Makefile.inc M src/mainboard/google/dedede/variants/waddledoo/memory/Makefile.inc M src/mainboard/google/dedede/variants/wheelie/memory/Makefile.inc M src/mainboard/google/drallion/spd/Makefile.inc A src/mainboard/google/drallion/spd/empty_ddr4.spd.bin D src/mainboard/google/drallion/spd/empty_ddr4.spd.hex A src/mainboard/google/drallion/spd/hynix_dimm_H5AN8G6NCJR-VKC.spd.bin D src/mainboard/google/drallion/spd/hynix_dimm_H5AN8G6NCJR-VKC.spd.hex A src/mainboard/google/drallion/spd/hynix_dimm_H5AN8G6NDJR-XNC.spd.bin D src/mainboard/google/drallion/spd/hynix_dimm_H5AN8G6NDJR-XNC.spd.hex A src/mainboard/google/drallion/spd/hynix_dimm_H5ANAG6NCMR-VKC.spd.bin D src/mainboard/google/drallion/spd/hynix_dimm_H5ANAG6NCMR-VKC.spd.hex A src/mainboard/google/drallion/spd/micron_dimm_MT40A1G16KD-062EE.spd.bin D src/mainboard/google/drallion/spd/micron_dimm_MT40A1G16KD-062EE.spd.hex A src/mainboard/google/drallion/spd/micron_dimm_MT40A1G16KNR-075E.spd.bin D src/mainboard/google/drallion/spd/micron_dimm_MT40A1G16KNR-075E.spd.hex A src/mainboard/google/drallion/spd/micron_dimm_MT40A512M16LY-075E.spd.bin D src/mainboard/google/drallion/spd/micron_dimm_MT40A512M16LY-075E.spd.hex A src/mainboard/google/drallion/spd/micron_dimm_MT40A512M16TB-062EJ.spd.bin D src/mainboard/google/drallion/spd/micron_dimm_MT40A512M16TB-062EJ.spd.hex A src/mainboard/google/drallion/spd/samsung_dimm_K4A8G165WC-BCTD.spd.bin D src/mainboard/google/drallion/spd/samsung_dimm_K4A8G165WC-BCTD.spd.hex A src/mainboard/google/drallion/spd/samsung_dimm_K4A8G165WC-BCWE.spd.bin D src/mainboard/google/drallion/spd/samsung_dimm_K4A8G165WC-BCWE.spd.hex A src/mainboard/google/drallion/spd/samsung_dimm_K4AAG165WA-BCWE.spd.bin D src/mainboard/google/drallion/spd/samsung_dimm_K4AAG165WA-BCWE.spd.hex A src/mainboard/google/drallion/spd/samsung_dimm_K4AAG165WB-MCTD.spd.bin D src/mainboard/google/drallion/spd/samsung_dimm_K4AAG165WB-MCTD.spd.hex A src/mainboard/google/eve/spd/empty.spd.bin D src/mainboard/google/eve/spd/empty.spd.hex A src/mainboard/google/eve/spd/hynix_dimm_H9CCNNN8GTALAR.spd.bin D src/mainboard/google/eve/spd/hynix_dimm_H9CCNNN8GTALAR.spd.hex A src/mainboard/google/eve/spd/hynix_dimm_H9CCNNNBJTALAR.spd.bin D src/mainboard/google/eve/spd/hynix_dimm_H9CCNNNBJTALAR.spd.hex A src/mainboard/google/eve/spd/hynix_dimm_H9CCNNNCLTMLAR.spd.bin D src/mainboard/google/eve/spd/hynix_dimm_H9CCNNNCLTMLAR.spd.hex A src/mainboard/google/eve/spd/samsung_dimm_K4E6E304EB.spd.bin D src/mainboard/google/eve/spd/samsung_dimm_K4E6E304EB.spd.hex A src/mainboard/google/eve/spd/samsung_dimm_K4E8E324EB.spd.bin D src/mainboard/google/eve/spd/samsung_dimm_K4E8E324EB.spd.hex A src/mainboard/google/eve/spd/samsung_dimm_K4EBE304EB.spd.bin D src/mainboard/google/eve/spd/samsung_dimm_K4EBE304EB.spd.hex A src/mainboard/google/glados/spd/empty.spd.bin D src/mainboard/google/glados/spd/empty.spd.hex A src/mainboard/google/glados/spd/hynix_dimm_H9CCNNN8GTALAR.spd.bin D src/mainboard/google/glados/spd/hynix_dimm_H9CCNNN8GTALAR.spd.hex A src/mainboard/google/glados/spd/hynix_dimm_H9CCNNN8GTMLAR-NUD.spd.bin D src/mainboard/google/glados/spd/hynix_dimm_H9CCNNN8GTMLAR-NUD.spd.hex A src/mainboard/google/glados/spd/hynix_dimm_H9CCNNN8GTMLAR.spd.bin D src/mainboard/google/glados/spd/hynix_dimm_H9CCNNN8GTMLAR.spd.hex A src/mainboard/google/glados/spd/hynix_dimm_H9CCNNN8JTBLAR-NUD-1G-1866.spd.bin D src/mainboard/google/glados/spd/hynix_dimm_H9CCNNN8JTBLAR-NUD-1G-1866.spd.hex A src/mainboard/google/glados/spd/hynix_dimm_H9CCNNN8JTBLAR.spd.bin D src/mainboard/google/glados/spd/hynix_dimm_H9CCNNN8JTBLAR.spd.hex A src/mainboard/google/glados/spd/hynix_dimm_H9CCNNNBJTALAR.spd.bin D src/mainboard/google/glados/spd/hynix_dimm_H9CCNNNBJTALAR.spd.hex A src/mainboard/google/glados/spd/hynix_dimm_H9CCNNNBJTMLAR-NUD.spd.bin D src/mainboard/google/glados/spd/hynix_dimm_H9CCNNNBJTMLAR-NUD.spd.hex A src/mainboard/google/glados/spd/hynix_dimm_H9CCNNNBJTMLAR.spd.bin D src/mainboard/google/glados/spd/hynix_dimm_H9CCNNNBJTMLAR.spd.hex A src/mainboard/google/glados/spd/hynix_dimm_H9CCNNNBLTALAR.spd.bin D src/mainboard/google/glados/spd/hynix_dimm_H9CCNNNBLTALAR.spd.hex A src/mainboard/google/glados/spd/hynix_dimm_H9CCNNNBLTBLAR-NUD-2G-1866.spd.bin D src/mainboard/google/glados/spd/hynix_dimm_H9CCNNNBLTBLAR-NUD-2G-1866.spd.hex A src/mainboard/google/glados/spd/hynix_dimm_H9CCNNNCLGALAR.spd.bin D src/mainboard/google/glados/spd/hynix_dimm_H9CCNNNCLGALAR.spd.hex A src/mainboard/google/glados/spd/hynix_dimm_H9CCNNNCLTMLAR.spd.bin D src/mainboard/google/glados/spd/hynix_dimm_H9CCNNNCLTMLAR.spd.hex A src/mainboard/google/glados/spd/micron_16GiB_dimm_MT52L1G32D4PG.spd.bin D src/mainboard/google/glados/spd/micron_16GiB_dimm_MT52L1G32D4PG.spd.hex A src/mainboard/google/glados/spd/micron_4GiB_dimm_MT52L256M32D1PF.spd.bin D src/mainboard/google/glados/spd/micron_4GiB_dimm_MT52L256M32D1PF.spd.hex A src/mainboard/google/glados/spd/micron_8GiB_dimm_MT52L512M32D2PF.spd.bin D src/mainboard/google/glados/spd/micron_8GiB_dimm_MT52L512M32D2PF.spd.hex A src/mainboard/google/glados/spd/micron_dimm_MT52L256M32D1PF-107-1G-1866.spd.bin D src/mainboard/google/glados/spd/micron_dimm_MT52L256M32D1PF-107-1G-1866.spd.hex A src/mainboard/google/glados/spd/micron_dimm_MT52L512M32D2PF-107-2G-1866.spd.bin D src/mainboard/google/glados/spd/micron_dimm_MT52L512M32D2PF-107-2G-1866.spd.hex A src/mainboard/google/glados/spd/samsung_dimm_K4E6E304EB-EGCF-2G-1866.spd.bin D src/mainboard/google/glados/spd/samsung_dimm_K4E6E304EB-EGCF-2G-1866.spd.hex A src/mainboard/google/glados/spd/samsung_dimm_K4E6E304EB-EGCF.spd.bin D src/mainboard/google/glados/spd/samsung_dimm_K4E6E304EB-EGCF.spd.hex A src/mainboard/google/glados/spd/samsung_dimm_K4E6E304EE-EGCF.spd.bin D src/mainboard/google/glados/spd/samsung_dimm_K4E6E304EE-EGCF.spd.hex A src/mainboard/google/glados/spd/samsung_dimm_K4E8E304EE-EGCE.spd.bin D src/mainboard/google/glados/spd/samsung_dimm_K4E8E304EE-EGCE.spd.hex A src/mainboard/google/glados/spd/samsung_dimm_K4E8E304EE-EGCF.spd.bin D src/mainboard/google/glados/spd/samsung_dimm_K4E8E304EE-EGCF.spd.hex A src/mainboard/google/glados/spd/samsung_dimm_K4E8E324EB-EGCF-1G-1866.spd.bin D src/mainboard/google/glados/spd/samsung_dimm_K4E8E324EB-EGCF-1G-1866.spd.hex A src/mainboard/google/glados/spd/samsung_dimm_K4E8E324EB-EGCF.spd.bin D src/mainboard/google/glados/spd/samsung_dimm_K4E8E324EB-EGCF.spd.hex A src/mainboard/google/glados/spd/samsung_dimm_K4EBE304EB-EGCF.spd.bin D src/mainboard/google/glados/spd/samsung_dimm_K4EBE304EB-EGCF.spd.hex A src/mainboard/google/glados/spd/samsung_dimm_K4EBE304EB-EGCG.spd.bin D src/mainboard/google/glados/spd/samsung_dimm_K4EBE304EB-EGCG.spd.hex A src/mainboard/google/hatch/spd/16G_2400.spd.bin D src/mainboard/google/hatch/spd/16G_2400.spd.hex A src/mainboard/google/hatch/spd/16G_2666.spd.bin D src/mainboard/google/hatch/spd/16G_2666.spd.hex A src/mainboard/google/hatch/spd/16G_2666_2bg.spd.bin D src/mainboard/google/hatch/spd/16G_2666_2bg.spd.hex A src/mainboard/google/hatch/spd/16G_3200.spd.bin D src/mainboard/google/hatch/spd/16G_3200.spd.hex A src/mainboard/google/hatch/spd/16G_3200_4bg.spd.bin D src/mainboard/google/hatch/spd/16G_3200_4bg.spd.hex A src/mainboard/google/hatch/spd/4G_2400.spd.bin D src/mainboard/google/hatch/spd/4G_2400.spd.hex A src/mainboard/google/hatch/spd/8G_2400.spd.bin D src/mainboard/google/hatch/spd/8G_2400.spd.hex A src/mainboard/google/hatch/spd/8G_2666.spd.bin D src/mainboard/google/hatch/spd/8G_2666.spd.hex A src/mainboard/google/hatch/spd/8G_3200.spd.bin D src/mainboard/google/hatch/spd/8G_3200.spd.hex A src/mainboard/google/hatch/spd/LP_16G_2133.spd.bin D src/mainboard/google/hatch/spd/LP_16G_2133.spd.hex A src/mainboard/google/hatch/spd/LP_4G_2133.spd.bin D src/mainboard/google/hatch/spd/LP_4G_2133.spd.hex A src/mainboard/google/hatch/spd/LP_8G_2133.spd.bin D src/mainboard/google/hatch/spd/LP_8G_2133.spd.hex A src/mainboard/google/hatch/spd/empty_ddr4.spd.bin D src/mainboard/google/hatch/spd/empty_ddr4.spd.hex A src/mainboard/google/kahlee/spd/empty.spd.bin D src/mainboard/google/kahlee/spd/empty.spd.hex A src/mainboard/google/kahlee/spd/hynix-H5AN8G6NAFR-UH.spd.bin D src/mainboard/google/kahlee/spd/hynix-H5AN8G6NAFR-UH.spd.hex A src/mainboard/google/kahlee/spd/hynix-H5AN8G6NCJR-VKC.spd.bin D src/mainboard/google/kahlee/spd/hynix-H5AN8G6NCJR-VKC.spd.hex A src/mainboard/google/kahlee/spd/hynix-H5AN8G6NCJR-XNC.spd.bin D src/mainboard/google/kahlee/spd/hynix-H5AN8G6NCJR-XNC.spd.hex A src/mainboard/google/kahlee/spd/hynix-H5ANAG6NAMR-UH.spd.bin D src/mainboard/google/kahlee/spd/hynix-H5ANAG6NAMR-UH.spd.hex A src/mainboard/google/kahlee/spd/hynix-H5ANAG6NCMR-VKC.spd.bin D src/mainboard/google/kahlee/spd/hynix-H5ANAG6NCMR-VKC.spd.hex A src/mainboard/google/kahlee/spd/hynix-H5ANAG6NCMR-XNC.spd.bin D src/mainboard/google/kahlee/spd/hynix-H5ANAG6NCMR-XNC.spd.hex A src/mainboard/google/kahlee/spd/micron-MT40A1G16KNR-075-E.spd.bin D src/mainboard/google/kahlee/spd/micron-MT40A1G16KNR-075-E.spd.hex A src/mainboard/google/kahlee/spd/micron-MT40A1G16RC-062E-B.spd.bin D src/mainboard/google/kahlee/spd/micron-MT40A1G16RC-062E-B.spd.hex A src/mainboard/google/kahlee/spd/micron-MT40A512M16JY-083E-B.spd.bin D src/mainboard/google/kahlee/spd/micron-MT40A512M16JY-083E-B.spd.hex A src/mainboard/google/kahlee/spd/micron-MT40A512M16LY-075-E.spd.bin D src/mainboard/google/kahlee/spd/micron-MT40A512M16LY-075-E.spd.hex A src/mainboard/google/kahlee/spd/micron-MT40A512M16TB-062E-J.spd.bin D src/mainboard/google/kahlee/spd/micron-MT40A512M16TB-062E-J.spd.hex A src/mainboard/google/kahlee/spd/samsung-K4A8G165WB-BCRC.spd.bin D src/mainboard/google/kahlee/spd/samsung-K4A8G165WB-BCRC.spd.hex A src/mainboard/google/kahlee/spd/samsung-K4A8G165WC-BCTD.spd.bin D src/mainboard/google/kahlee/spd/samsung-K4A8G165WC-BCTD.spd.hex A src/mainboard/google/kahlee/spd/samsung-K4A8G165WC-BCWE.spd.bin D src/mainboard/google/kahlee/spd/samsung-K4A8G165WC-BCWE.spd.hex A src/mainboard/google/kahlee/spd/samsung-K4AAG165WA-BCTD.spd.bin D src/mainboard/google/kahlee/spd/samsung-K4AAG165WA-BCTD.spd.hex A src/mainboard/google/kahlee/spd/samsung-K4AAG165WA-BCWE.spd.bin D src/mainboard/google/kahlee/spd/samsung-K4AAG165WA-BCWE.spd.hex A src/mainboard/google/kahlee/spd/samsung-K4AAG165WB-MCRC.spd.bin D src/mainboard/google/kahlee/spd/samsung-K4AAG165WB-MCRC.spd.hex A src/mainboard/google/kahlee/spd/samsung-K4AAG165WB-MCTD.spd.bin D src/mainboard/google/kahlee/spd/samsung-K4AAG165WB-MCTD.spd.hex A src/mainboard/google/link/spd/elpida_4Gb_1600_x16.spd.bin D src/mainboard/google/link/spd/elpida_4Gb_1600_x16.spd.hex A src/mainboard/google/link/spd/micron_4Gb_1600_1.35v_x16.spd.bin D src/mainboard/google/link/spd/micron_4Gb_1600_1.35v_x16.spd.hex A src/mainboard/google/link/spd/samsung_4Gb_1600_1.35v_x16.spd.bin D src/mainboard/google/link/spd/samsung_4Gb_1600_1.35v_x16.spd.hex M src/mainboard/google/poppy/spd/Makefile.inc A src/mainboard/google/poppy/spd/empty.spd.bin D src/mainboard/google/poppy/spd/empty.spd.hex A src/mainboard/google/poppy/spd/empty_ddr4.spd.bin D src/mainboard/google/poppy/spd/empty_ddr4.spd.hex A src/mainboard/google/poppy/spd/hynix_dimm_H5AN4G6NAFR-UHC.spd.bin D src/mainboard/google/poppy/spd/hynix_dimm_H5AN4G6NAFR-UHC.spd.hex A src/mainboard/google/poppy/spd/hynix_dimm_H5AN4G6NBJR-UHC.spd.bin D src/mainboard/google/poppy/spd/hynix_dimm_H5AN4G6NBJR-UHC.spd.hex A src/mainboard/google/poppy/spd/hynix_dimm_H5AN8G6NAFR-UHC.spd.bin D src/mainboard/google/poppy/spd/hynix_dimm_H5AN8G6NAFR-UHC.spd.hex A src/mainboard/google/poppy/spd/hynix_dimm_H5AN8G6NCJR-VKC.spd.bin D src/mainboard/google/poppy/spd/hynix_dimm_H5AN8G6NCJR-VKC.spd.hex A src/mainboard/google/poppy/spd/hynix_dimm_H5ANAG6NAMR-UHC.spd.bin D src/mainboard/google/poppy/spd/hynix_dimm_H5ANAG6NAMR-UHC.spd.hex A src/mainboard/google/poppy/spd/hynix_dimm_H5ANAG6NCMR-VKC.spd.bin D src/mainboard/google/poppy/spd/hynix_dimm_H5ANAG6NCMR-VKC.spd.hex A src/mainboard/google/poppy/spd/hynix_dimm_H9CCNNN8GTALAR-NUD.spd.bin D src/mainboard/google/poppy/spd/hynix_dimm_H9CCNNN8GTALAR-NUD.spd.hex A src/mainboard/google/poppy/spd/hynix_dimm_H9CCNNNBJTALAR-NUD.spd.bin D src/mainboard/google/poppy/spd/hynix_dimm_H9CCNNNBJTALAR-NUD.spd.hex A src/mainboard/google/poppy/spd/hynix_dimm_H9CCNNNBKTALBR-NUD.spd.bin D src/mainboard/google/poppy/spd/hynix_dimm_H9CCNNNBKTALBR-NUD.spd.hex A src/mainboard/google/poppy/spd/hynix_dimm_H9CCNNNCLGALAR-NUD.spd.bin D src/mainboard/google/poppy/spd/hynix_dimm_H9CCNNNCLGALAR-NUD.spd.hex A src/mainboard/google/poppy/spd/hynix_dimm_H9CCNNNCLGALAR-NVD.spd.bin D src/mainboard/google/poppy/spd/hynix_dimm_H9CCNNNCLGALAR-NVD.spd.hex A src/mainboard/google/poppy/spd/hynix_dimm_H9CCNNNCPTALBR-NUD.spd.bin D src/mainboard/google/poppy/spd/hynix_dimm_H9CCNNNCPTALBR-NUD.spd.hex A src/mainboard/google/poppy/spd/hynix_dimm_H9CCNNNFAGMLLR-NUD.spd.bin D src/mainboard/google/poppy/spd/hynix_dimm_H9CCNNNFAGMLLR-NUD.spd.hex A src/mainboard/google/poppy/spd/micron_dimm_MT40A1G16KNR-075E.spd.bin D src/mainboard/google/poppy/spd/micron_dimm_MT40A1G16KNR-075E.spd.hex A src/mainboard/google/poppy/spd/micron_dimm_MT40A256M16GE-083E.spd.bin D src/mainboard/google/poppy/spd/micron_dimm_MT40A256M16GE-083E.spd.hex A src/mainboard/google/poppy/spd/micron_dimm_MT40A256M16LY-075F.spd.bin D src/mainboard/google/poppy/spd/micron_dimm_MT40A256M16LY-075F.spd.hex A src/mainboard/google/poppy/spd/micron_dimm_MT40A512M16LY-075E.spd.bin D src/mainboard/google/poppy/spd/micron_dimm_MT40A512M16LY-075E.spd.hex A src/mainboard/google/poppy/spd/micron_dimm_MT40A512M16TB-062EJ.spd.bin D src/mainboard/google/poppy/spd/micron_dimm_MT40A512M16TB-062EJ.spd.hex A src/mainboard/google/poppy/spd/micron_dimm_MT52L1G32D4PG-107.spd.bin D src/mainboard/google/poppy/spd/micron_dimm_MT52L1G32D4PG-107.spd.hex A src/mainboard/google/poppy/spd/micron_dimm_MT52L1G64D8QC-107.spd.bin D src/mainboard/google/poppy/spd/micron_dimm_MT52L1G64D8QC-107.spd.hex A src/mainboard/google/poppy/spd/micron_dimm_MT52L256M32D1PF-093.spd.bin D src/mainboard/google/poppy/spd/micron_dimm_MT52L256M32D1PF-093.spd.hex A src/mainboard/google/poppy/spd/micron_dimm_MT52L256M32D1PF-107.spd.bin D src/mainboard/google/poppy/spd/micron_dimm_MT52L256M32D1PF-107.spd.hex A src/mainboard/google/poppy/spd/micron_dimm_MT52L256M64D2PP-107.spd.bin D src/mainboard/google/poppy/spd/micron_dimm_MT52L256M64D2PP-107.spd.hex A src/mainboard/google/poppy/spd/micron_dimm_MT52L512M32D2PF-093.spd.bin D src/mainboard/google/poppy/spd/micron_dimm_MT52L512M32D2PF-093.spd.hex A src/mainboard/google/poppy/spd/micron_dimm_MT52L512M32D2PF-107.spd.bin D src/mainboard/google/poppy/spd/micron_dimm_MT52L512M32D2PF-107.spd.hex A src/mainboard/google/poppy/spd/micron_dimm_MT52L512M64D4PQ-107.spd.bin D src/mainboard/google/poppy/spd/micron_dimm_MT52L512M64D4PQ-107.spd.hex A src/mainboard/google/poppy/spd/nayna_dimm_NT6CL256T32CM-H1.spd.bin D src/mainboard/google/poppy/spd/nayna_dimm_NT6CL256T32CM-H1.spd.hex A src/mainboard/google/poppy/spd/samsung_dimm_K3QF3F30BM-AGCF.spd.bin D src/mainboard/google/poppy/spd/samsung_dimm_K3QF3F30BM-AGCF.spd.hex A src/mainboard/google/poppy/spd/samsung_dimm_K3QF4F40BM-AGCF.spd.bin D src/mainboard/google/poppy/spd/samsung_dimm_K3QF4F40BM-AGCF.spd.hex A src/mainboard/google/poppy/spd/samsung_dimm_K3QFAFA0CM-AGCF.spd.bin D src/mainboard/google/poppy/spd/samsung_dimm_K3QFAFA0CM-AGCF.spd.hex A src/mainboard/google/poppy/spd/samsung_dimm_K4A4G165WE-BCRC.spd.bin D src/mainboard/google/poppy/spd/samsung_dimm_K4A4G165WE-BCRC.spd.hex A src/mainboard/google/poppy/spd/samsung_dimm_K4A8G165WB-BCRC.spd.bin D src/mainboard/google/poppy/spd/samsung_dimm_K4A8G165WB-BCRC.spd.hex A src/mainboard/google/poppy/spd/samsung_dimm_K4A8G165WC-BCTD.spd.bin D src/mainboard/google/poppy/spd/samsung_dimm_K4A8G165WC-BCTD.spd.hex A src/mainboard/google/poppy/spd/samsung_dimm_K4AAG165WB-MCRC.spd.bin D src/mainboard/google/poppy/spd/samsung_dimm_K4AAG165WB-MCRC.spd.hex A src/mainboard/google/poppy/spd/samsung_dimm_K4E6E304EB-EGCF.spd.bin D src/mainboard/google/poppy/spd/samsung_dimm_K4E6E304EB-EGCF.spd.hex A src/mainboard/google/poppy/spd/samsung_dimm_K4E6E304EC-EGCF.spd.bin D src/mainboard/google/poppy/spd/samsung_dimm_K4E6E304EC-EGCF.spd.hex A src/mainboard/google/poppy/spd/samsung_dimm_K4E6E304ED-EGCG.spd.bin D src/mainboard/google/poppy/spd/samsung_dimm_K4E6E304ED-EGCG.spd.hex A src/mainboard/google/poppy/spd/samsung_dimm_K4E8E324EB-EGCF.spd.bin D src/mainboard/google/poppy/spd/samsung_dimm_K4E8E324EB-EGCF.spd.hex A src/mainboard/google/poppy/spd/samsung_dimm_K4E8E324ED-EGCG.spd.bin D src/mainboard/google/poppy/spd/samsung_dimm_K4E8E324ED-EGCG.spd.hex A src/mainboard/google/poppy/spd/samsung_dimm_K4EBE304EB-EGCG.spd.bin D src/mainboard/google/poppy/spd/samsung_dimm_K4EBE304EB-EGCG.spd.hex A src/mainboard/google/poppy/spd/samsung_dimm_K4EBE304EC-EGCF.spd.bin D src/mainboard/google/poppy/spd/samsung_dimm_K4EBE304EC-EGCF.spd.hex A src/mainboard/google/poppy/spd/samsung_dimm_K4EBE304EC-EGCG.spd.bin D src/mainboard/google/poppy/spd/samsung_dimm_K4EBE304EC-EGCG.spd.hex A src/mainboard/google/poppy/spd/samsung_dimm_K4EBE304ED-EGCG.spd.bin D src/mainboard/google/poppy/spd/samsung_dimm_K4EBE304ED-EGCG.spd.hex A src/mainboard/google/rambi/spd/HT_micron_HTTC4G63CFR-PBA_x16_4Gb.spd.bin D src/mainboard/google/rambi/spd/HT_micron_HTTC4G63CFR-PBA_x16_4Gb.spd.hex A src/mainboard/google/rambi/spd/Hynix_HMT425S6CFR6A_H5TC4G63CFR.spd.bin D src/mainboard/google/rambi/spd/Hynix_HMT425S6CFR6A_H5TC4G63CFR.spd.hex A src/mainboard/google/rambi/spd/Samsung_2Gib_K4B4G1646Q-HYK0.spd.bin D src/mainboard/google/rambi/spd/Samsung_2Gib_K4B4G1646Q-HYK0.spd.hex A src/mainboard/google/rambi/spd/Samsung_2Gib_M471B5674QH0.spd.bin D src/mainboard/google/rambi/spd/Samsung_2Gib_M471B5674QH0.spd.hex A src/mainboard/google/rambi/spd/elpida_2GiB_dimm_EDJ4216EFBG-GNL-F.spd.bin D src/mainboard/google/rambi/spd/elpida_2GiB_dimm_EDJ4216EFBG-GNL-F.spd.hex A src/mainboard/google/rambi/spd/empty.spd.bin D src/mainboard/google/rambi/spd/empty.spd.hex A src/mainboard/google/rambi/spd/hynix_1GiB_dimm_H5TC2G63FFR-PBA.spd.bin D src/mainboard/google/rambi/spd/hynix_1GiB_dimm_H5TC2G63FFR-PBA.spd.hex A src/mainboard/google/rambi/spd/hynix_2GiB_dimm_H5TC4G63AFR-PBA.spd.bin D src/mainboard/google/rambi/spd/hynix_2GiB_dimm_H5TC4G63AFR-PBA.spd.hex A src/mainboard/google/rambi/spd/hynix_2GiB_dimm_H5TC4G63CFR-PBA.spd.bin D src/mainboard/google/rambi/spd/hynix_2GiB_dimm_H5TC4G63CFR-PBA.spd.hex A src/mainboard/google/rambi/spd/hynix_2GiB_dimm_H5TC4G63MFR-PBA.spd.bin D src/mainboard/google/rambi/spd/hynix_2GiB_dimm_H5TC4G63MFR-PBA.spd.hex A src/mainboard/google/rambi/spd/micron_1GiB_dimm_MT41K128M16JT-125.spd.bin D src/mainboard/google/rambi/spd/micron_1GiB_dimm_MT41K128M16JT-125.spd.hex A src/mainboard/google/rambi/spd/micron_2GiB_dimm_MT41K256M16HA-125.spd.bin D src/mainboard/google/rambi/spd/micron_2GiB_dimm_MT41K256M16HA-125.spd.hex A src/mainboard/google/rambi/spd/micron_2GiB_dimm_MT41K256M16HA-125a.spd.bin D src/mainboard/google/rambi/spd/micron_2GiB_dimm_MT41K256M16HA-125a.spd.hex A src/mainboard/google/rambi/spd/micron_2GiB_dimm_MT41K256M16TW-107.spd.bin D src/mainboard/google/rambi/spd/micron_2GiB_dimm_MT41K256M16TW-107.spd.hex A src/mainboard/google/rambi/spd/samsung_1GiB_dimm_K4B2G1646Q-BYK0.spd.bin D src/mainboard/google/rambi/spd/samsung_1GiB_dimm_K4B2G1646Q-BYK0.spd.hex A src/mainboard/google/rambi/spd/samsung_2GiB_dimm_K4B4G1646E-BYK0.spd.bin D src/mainboard/google/rambi/spd/samsung_2GiB_dimm_K4B4G1646E-BYK0.spd.hex A src/mainboard/google/rambi/spd/samsung_2GiB_dimm_K4B4G1646Q-HYK0.spd.bin D src/mainboard/google/rambi/spd/samsung_2GiB_dimm_K4B4G1646Q-HYK0.spd.hex M src/mainboard/google/slippy/variants/falco/Makefile.inc A src/mainboard/google/slippy/variants/falco/spd/Elpida_EDJ4216EFBG.spd.bin D src/mainboard/google/slippy/variants/falco/spd/Elpida_EDJ4216EFBG.spd.hex A src/mainboard/google/slippy/variants/falco/spd/Hynix_HMT425S6AFR6A.spd.bin D src/mainboard/google/slippy/variants/falco/spd/Hynix_HMT425S6AFR6A.spd.hex A src/mainboard/google/slippy/variants/falco/spd/Micron_4KTF25664HZ.spd.bin D src/mainboard/google/slippy/variants/falco/spd/Micron_4KTF25664HZ.spd.hex A src/mainboard/google/slippy/variants/falco/spd/Samsung_M471B5674QH0.spd.bin D src/mainboard/google/slippy/variants/falco/spd/Samsung_M471B5674QH0.spd.hex M src/mainboard/google/slippy/variants/leon/Makefile.inc A src/mainboard/google/slippy/variants/leon/spd/Hynix_HMT425S6AFR6A.spd.bin D src/mainboard/google/slippy/variants/leon/spd/Hynix_HMT425S6AFR6A.spd.hex A src/mainboard/google/slippy/variants/leon/spd/Micron_4KTF25664HZ.spd.bin D src/mainboard/google/slippy/variants/leon/spd/Micron_4KTF25664HZ.spd.hex A src/mainboard/google/slippy/variants/leon/spd/Samsung_K4B4G1646Q.spd.bin D src/mainboard/google/slippy/variants/leon/spd/Samsung_K4B4G1646Q.spd.hex M src/mainboard/google/slippy/variants/peppy/Makefile.inc A src/mainboard/google/slippy/variants/peppy/spd/Elpida_EDJ4216EFBG.spd.bin D src/mainboard/google/slippy/variants/peppy/spd/Elpida_EDJ4216EFBG.spd.hex A src/mainboard/google/slippy/variants/peppy/spd/Hynix_HMT425S6AFR6A.spd.bin D src/mainboard/google/slippy/variants/peppy/spd/Hynix_HMT425S6AFR6A.spd.hex A src/mainboard/google/slippy/variants/peppy/spd/Hynix_HMT425S6CFR6A.spd.bin D src/mainboard/google/slippy/variants/peppy/spd/Hynix_HMT425S6CFR6A.spd.hex A src/mainboard/google/slippy/variants/peppy/spd/Micron_4KTF25664HZ.spd.bin D src/mainboard/google/slippy/variants/peppy/spd/Micron_4KTF25664HZ.spd.hex M src/mainboard/google/slippy/variants/wolf/Makefile.inc A src/mainboard/google/slippy/variants/wolf/spd/Hynix_HMT425S6AFR6A.spd.bin D src/mainboard/google/slippy/variants/wolf/spd/Hynix_HMT425S6AFR6A.spd.hex A src/mainboard/google/slippy/variants/wolf/spd/Micron_4KTF25664HZ.spd.bin D src/mainboard/google/slippy/variants/wolf/spd/Micron_4KTF25664HZ.spd.hex A src/mainboard/google/slippy/variants/wolf/spd/Samsung_K4B4G1646B.spd.bin D src/mainboard/google/slippy/variants/wolf/spd/Samsung_K4B4G1646B.spd.hex M src/mainboard/google/volteer/variants/delbin/memory/Makefile.inc M src/mainboard/google/volteer/variants/eldrid/memory/Makefile.inc M src/mainboard/google/volteer/variants/elemi/memory/Makefile.inc M src/mainboard/google/volteer/variants/halvor/memory/Makefile.inc M src/mainboard/google/volteer/variants/lindar/memory/Makefile.inc M src/mainboard/google/volteer/variants/malefor/memory/Makefile.inc M src/mainboard/google/volteer/variants/terrador/memory/Makefile.inc M src/mainboard/google/volteer/variants/todor/memory/Makefile.inc M src/mainboard/google/volteer/variants/trondo/memory/Makefile.inc M src/mainboard/google/volteer/variants/volteer/memory/Makefile.inc M src/mainboard/google/volteer/variants/volteer2/memory/Makefile.inc M src/mainboard/google/volteer/variants/voxel/memory/Makefile.inc A src/mainboard/google/zork/spd/ddr4-spd-1.bin D src/mainboard/google/zork/spd/ddr4-spd-1.hex A src/mainboard/google/zork/spd/ddr4-spd-2.bin D src/mainboard/google/zork/spd/ddr4-spd-2.hex A src/mainboard/google/zork/spd/ddr4-spd-3.bin D src/mainboard/google/zork/spd/ddr4-spd-3.hex A src/mainboard/google/zork/spd/ddr4-spd-4.bin D src/mainboard/google/zork/spd/ddr4-spd-4.hex A src/mainboard/google/zork/spd/ddr4-spd-5.bin D src/mainboard/google/zork/spd/ddr4-spd-5.hex A src/mainboard/google/zork/spd/ddr4-spd-6.bin D src/mainboard/google/zork/spd/ddr4-spd-6.hex A src/mainboard/google/zork/spd/ddr4-spd-7.bin D src/mainboard/google/zork/spd/ddr4-spd-7.hex A src/mainboard/google/zork/spd/ddr4-spd-8.bin D src/mainboard/google/zork/spd/ddr4-spd-8.hex A src/mainboard/google/zork/spd/ddr4-spd-empty.bin D src/mainboard/google/zork/spd/ddr4-spd-empty.hex M src/mainboard/google/zork/spd/ddr4_spd_manifest.generated.txt M src/mainboard/google/zork/variants/berknip/spd/Makefile.inc M src/mainboard/google/zork/variants/dalboz/spd/Makefile.inc M src/mainboard/google/zork/variants/dirinboz/spd/Makefile.inc M src/mainboard/google/zork/variants/ezkinil/spd/Makefile.inc M src/mainboard/google/zork/variants/morphius/spd/Makefile.inc M src/mainboard/google/zork/variants/trembyle/spd/Makefile.inc M src/mainboard/google/zork/variants/vilboz/spd/Makefile.inc M src/mainboard/google/zork/variants/woomax/spd/Makefile.inc A src/mainboard/hp/snb_ivb_laptops/spd/hynix_4g.spd.bin D src/mainboard/hp/snb_ivb_laptops/spd/hynix_4g.spd.hex A src/mainboard/intel/cannonlake_rvp/spd/empty.spd.bin D src/mainboard/intel/cannonlake_rvp/spd/empty.spd.hex A src/mainboard/intel/cannonlake_rvp/spd/samsung_ddr4_4GB.spd.bin D src/mainboard/intel/cannonlake_rvp/spd/samsung_ddr4_4GB.spd.hex A src/mainboard/intel/cannonlake_rvp/spd/samsung_lpddr4_8GB.spd.bin D src/mainboard/intel/cannonlake_rvp/spd/samsung_lpddr4_8GB.spd.hex A src/mainboard/intel/harcuvar/spd/micron_4GiB_dimm_MTA9ASF51272PZ-2G1A2.spd.bin D src/mainboard/intel/harcuvar/spd/micron_4GiB_dimm_MTA9ASF51272PZ-2G1A2.spd.hex A src/mainboard/intel/icelake_rvp/spd/empty.spd.bin D src/mainboard/intel/icelake_rvp/spd/empty.spd.hex A src/mainboard/intel/icelake_rvp/spd/samsung_K4F6E304HBMGCJ.spd.bin D src/mainboard/intel/icelake_rvp/spd/samsung_K4F6E304HBMGCJ.spd.hex A src/mainboard/intel/jasperlake_rvp/spd/empty.spd.bin D src/mainboard/intel/jasperlake_rvp/spd/empty.spd.hex A src/mainboard/intel/jasperlake_rvp/spd/jslrvp.spd.bin D src/mainboard/intel/jasperlake_rvp/spd/jslrvp.spd.hex A src/mainboard/intel/kblrvp/spd/empty.spd.bin D src/mainboard/intel/kblrvp/spd/empty.spd.hex A src/mainboard/intel/kblrvp/spd/hynix_dimm_H9CCNNNBJTMLAR.spd.bin D src/mainboard/intel/kblrvp/spd/hynix_dimm_H9CCNNNBJTMLAR.spd.hex A src/mainboard/intel/kblrvp/spd/rvp3.spd.bin D src/mainboard/intel/kblrvp/spd/rvp3.spd.hex A src/mainboard/intel/kunimitsu/spd/empty.spd.bin D src/mainboard/intel/kunimitsu/spd/empty.spd.hex A src/mainboard/intel/kunimitsu/spd/hynix_dimm_H9CCNNN8JTALAR-NUD-1G-1866.spd.bin D src/mainboard/intel/kunimitsu/spd/hynix_dimm_H9CCNNN8JTALAR-NUD-1G-1866.spd.hex A src/mainboard/intel/kunimitsu/spd/hynix_dimm_H9CCNNN8JTBLAR-NUD-1G-1866.spd.bin D src/mainboard/intel/kunimitsu/spd/hynix_dimm_H9CCNNN8JTBLAR-NUD-1G-1866.spd.hex A src/mainboard/intel/kunimitsu/spd/hynix_dimm_H9CCNNNBLTALAR-NUD-2G-1866.spd.bin D src/mainboard/intel/kunimitsu/spd/hynix_dimm_H9CCNNNBLTALAR-NUD-2G-1866.spd.hex A src/mainboard/intel/kunimitsu/spd/hynix_dimm_H9CCNNNBLTBLAR-NUD-2G-1866.spd.bin D src/mainboard/intel/kunimitsu/spd/hynix_dimm_H9CCNNNBLTBLAR-NUD-2G-1866.spd.hex A src/mainboard/intel/kunimitsu/spd/mic_dimm_EDF8132A3MA-JD-F-1G-1866.spd.bin D src/mainboard/intel/kunimitsu/spd/mic_dimm_EDF8132A3MA-JD-F-1G-1866.spd.hex A src/mainboard/intel/kunimitsu/spd/samsung_dimm_K4E6E304EE-EGCF-2G-1866.spd.bin D src/mainboard/intel/kunimitsu/spd/samsung_dimm_K4E6E304EE-EGCF-2G-1866.spd.hex A src/mainboard/intel/kunimitsu/spd/samsung_dimm_K4E8E304EE-EGCE.spd.bin D src/mainboard/intel/kunimitsu/spd/samsung_dimm_K4E8E304EE-EGCE.spd.hex A src/mainboard/intel/kunimitsu/spd/samsung_dimm_K4E8E304EE-EGCF-1G-1866.spd.bin D src/mainboard/intel/kunimitsu/spd/samsung_dimm_K4E8E304EE-EGCF-1G-1866.spd.hex A src/mainboard/intel/tglrvp/spd/Hynix-H9HKNNNEBMAV-4267.spd.bin D src/mainboard/intel/tglrvp/spd/Hynix-H9HKNNNEBMAV-4267.spd.hex A src/mainboard/intel/tglrvp/spd/Micron-MT53D1G64D8SQ-046.spd.bin D src/mainboard/intel/tglrvp/spd/Micron-MT53D1G64D8SQ-046.spd.hex A src/mainboard/intel/tglrvp/spd/Samsung-K4UBE3D4AA-MGCL.spd.bin D src/mainboard/intel/tglrvp/spd/Samsung-K4UBE3D4AA-MGCL.spd.hex A src/mainboard/intel/tglrvp/spd/empty.spd.bin D src/mainboard/intel/tglrvp/spd/empty.spd.hex A src/mainboard/lenovo/s230u/spd/elpida_2gb.spd.bin D src/mainboard/lenovo/s230u/spd/elpida_2gb.spd.hex A src/mainboard/lenovo/s230u/spd/elpida_4gb.spd.bin D src/mainboard/lenovo/s230u/spd/elpida_4gb.spd.hex A src/mainboard/lenovo/s230u/spd/elpida_8gb.spd.bin D src/mainboard/lenovo/s230u/spd/elpida_8gb.spd.hex A src/mainboard/lenovo/s230u/spd/hynix_2gb.spd.bin D src/mainboard/lenovo/s230u/spd/hynix_2gb.spd.hex A src/mainboard/lenovo/s230u/spd/hynix_4gb.spd.bin D src/mainboard/lenovo/s230u/spd/hynix_4gb.spd.hex A src/mainboard/lenovo/s230u/spd/samsung_2gb.spd.bin D src/mainboard/lenovo/s230u/spd/samsung_2gb.spd.hex A src/mainboard/lenovo/s230u/spd/samsung_4gb.spd.bin D src/mainboard/lenovo/s230u/spd/samsung_4gb.spd.hex M src/mainboard/lenovo/t430s/variants/t431s/spd/Makefile.inc A src/mainboard/lenovo/t430s/variants/t431s/spd/samsung_4gb.spd.bin D src/mainboard/lenovo/t430s/variants/t431s/spd/samsung_4gb.spd.hex A src/mainboard/lenovo/x1_carbon_gen1/spd/elpida.spd.bin D src/mainboard/lenovo/x1_carbon_gen1/spd/elpida.spd.hex A src/mainboard/lenovo/x1_carbon_gen1/spd/hynix.spd.bin D src/mainboard/lenovo/x1_carbon_gen1/spd/hynix.spd.hex A src/mainboard/lenovo/x1_carbon_gen1/spd/samsung.spd.bin D src/mainboard/lenovo/x1_carbon_gen1/spd/samsung.spd.hex A src/mainboard/pcengines/apu1/spd/HYNIX-H5TQ2G83CFR.spd.bin D src/mainboard/pcengines/apu1/spd/HYNIX-H5TQ2G83CFR.spd.hex A src/mainboard/pcengines/apu1/spd/HYNIX-H5TQ4G83MFR.spd.bin D src/mainboard/pcengines/apu1/spd/HYNIX-H5TQ4G83MFR.spd.hex A src/mainboard/pcengines/apu2/spd/HYNIX-2G-1333.spd.bin D src/mainboard/pcengines/apu2/spd/HYNIX-2G-1333.spd.hex A src/mainboard/pcengines/apu2/spd/HYNIX-4G-1333-ECC.spd.bin D src/mainboard/pcengines/apu2/spd/HYNIX-4G-1333-ECC.spd.hex A src/mainboard/portwell/m107/spd/KINGSTON_B5116ECMDXGGB.spd.bin D src/mainboard/portwell/m107/spd/KINGSTON_B5116ECMDXGGB.spd.hex A src/mainboard/portwell/m107/spd/MICRON_MT41K512M16HA-125A.spd.bin D src/mainboard/portwell/m107/spd/MICRON_MT41K512M16HA-125A.spd.hex A src/mainboard/portwell/m107/spd/SAMSUNG_K4B8G1646D-MYKO.spd.bin D src/mainboard/portwell/m107/spd/SAMSUNG_K4B8G1646D-MYKO.spd.hex A src/mainboard/razer/blade_stealth_kbl/spd/micron_dimm_MT52L1G32D4PG-107.spd.bin D src/mainboard/razer/blade_stealth_kbl/spd/micron_dimm_MT52L1G32D4PG-107.spd.hex A src/mainboard/razer/blade_stealth_kbl/spd/micron_dimm_MT52L512M32D2PF-107.spd.bin D src/mainboard/razer/blade_stealth_kbl/spd/micron_dimm_MT52L512M32D2PF-107.spd.hex A src/mainboard/samsung/lumpy/spd/lumpy.spd.bin D src/mainboard/samsung/lumpy/spd/lumpy.spd.hex A src/mainboard/system76/lemp9/spd/samsung-K4AAG165WA-BCTD.spd.bin D src/mainboard/system76/lemp9/spd/samsung-K4AAG165WA-BCTD.spd.hex M src/soc/amd/picasso/Makefile.inc A src/soc/intel/jasperlake/spd/lp4x-spd-1.bin D src/soc/intel/jasperlake/spd/lp4x-spd-1.hex A src/soc/intel/jasperlake/spd/lp4x-spd-2.bin D src/soc/intel/jasperlake/spd/lp4x-spd-2.hex A src/soc/intel/jasperlake/spd/lp4x-spd-3.bin D src/soc/intel/jasperlake/spd/lp4x-spd-3.hex A src/soc/intel/jasperlake/spd/lp4x-spd-4.bin D src/soc/intel/jasperlake/spd/lp4x-spd-4.hex A src/soc/intel/jasperlake/spd/lp4x-spd-5.bin D src/soc/intel/jasperlake/spd/lp4x-spd-5.hex A src/soc/intel/jasperlake/spd/lp4x-spd-6.bin D src/soc/intel/jasperlake/spd/lp4x-spd-6.hex A src/soc/intel/jasperlake/spd/lp4x-spd-7.bin D src/soc/intel/jasperlake/spd/lp4x-spd-7.hex M src/soc/intel/jasperlake/spd/lp4x_spd_manifest.generated.txt A src/soc/intel/tigerlake/spd/ddr4-spd-1.bin D src/soc/intel/tigerlake/spd/ddr4-spd-1.hex A src/soc/intel/tigerlake/spd/ddr4-spd-2.bin D src/soc/intel/tigerlake/spd/ddr4-spd-2.hex A src/soc/intel/tigerlake/spd/ddr4-spd-3.bin D src/soc/intel/tigerlake/spd/ddr4-spd-3.hex A src/soc/intel/tigerlake/spd/ddr4-spd-4.bin D src/soc/intel/tigerlake/spd/ddr4-spd-4.hex A src/soc/intel/tigerlake/spd/ddr4-spd-5.bin D src/soc/intel/tigerlake/spd/ddr4-spd-5.hex A src/soc/intel/tigerlake/spd/ddr4-spd-6.bin D src/soc/intel/tigerlake/spd/ddr4-spd-6.hex A src/soc/intel/tigerlake/spd/ddr4-spd-7.bin D src/soc/intel/tigerlake/spd/ddr4-spd-7.hex A src/soc/intel/tigerlake/spd/ddr4-spd-8.bin D src/soc/intel/tigerlake/spd/ddr4-spd-8.hex A src/soc/intel/tigerlake/spd/ddr4-spd-empty.bin D src/soc/intel/tigerlake/spd/ddr4-spd-empty.hex M src/soc/intel/tigerlake/spd/ddr4_spd_manifest.generated.txt A src/soc/intel/tigerlake/spd/lp4x-spd-1.bin D src/soc/intel/tigerlake/spd/lp4x-spd-1.hex A src/soc/intel/tigerlake/spd/lp4x-spd-2.bin D src/soc/intel/tigerlake/spd/lp4x-spd-2.hex A src/soc/intel/tigerlake/spd/lp4x-spd-3.bin D src/soc/intel/tigerlake/spd/lp4x-spd-3.hex A src/soc/intel/tigerlake/spd/lp4x-spd-4.bin D src/soc/intel/tigerlake/spd/lp4x-spd-4.hex A src/soc/intel/tigerlake/spd/lp4x-spd-5.bin D src/soc/intel/tigerlake/spd/lp4x-spd-5.hex M src/soc/intel/tigerlake/spd/lp4x_spd_manifest.generated.txt 637 files changed, 185 insertions(+), 10,844 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/75/44775/27
