Aaron Durbin (adurbin@google.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/3234
commit 4ee4f5e8fbd614efc4c495f7d454a1d2c5d6f2e3 Author: Aaron Durbin adurbin@chromium.org Date: Fri May 10 00:42:14 2013 -0500
chromeos: use cache-as-ram migration API for vbnv
It's possible that the vbnv global variables may be accessed in romstage after cache-as-ram is torn down. Therefore use the cache-as-ram migration API. Wrappers were written to wrap the API to keep the existing code as close as possible.
Change-Id: Ia1d8932f98e00def0a44444a1ead0018a59d3d98 Signed-off-by: Aaron Durbin adurbin@chromium.org --- src/vendorcode/google/chromeos/vbnv.c | 32 +++++++++++++++++++++++++------- 1 file changed, 25 insertions(+), 7 deletions(-)
diff --git a/src/vendorcode/google/chromeos/vbnv.c b/src/vendorcode/google/chromeos/vbnv.c index 2a2faf9..d94203a 100644 --- a/src/vendorcode/google/chromeos/vbnv.c +++ b/src/vendorcode/google/chromeos/vbnv.c @@ -53,7 +53,25 @@ #define CRC_OFFSET 15
static int vbnv_initialized CAR_GLOBAL; -uint8_t vbnv[CONFIG_VBNV_SIZE] CAR_GLOBAL; +static uint8_t vbnv[CONFIG_VBNV_SIZE] CAR_GLOBAL; + +/* Wrappers for accessing the variables marked as CAR_GLOBAL. */ +static inline int is_vbnv_initialized(void) +{ + return car_get_var(vbnv_initialized); +} + +static inline uint8_t *vbnv_data_addr(int index) +{ + uint8_t *vbnv_arr = car_get_var_ptr(vbnv); + + return &vbnv_arr[index]; +} + +static inline uint8_t vbnv_data(int index) +{ + return *vbnv_data_addr(index); +}
/* Return CRC-8 of the data, using x^8 + x^2 + x + 1 polynomial. A * table-based algorithm would be faster, but for only 15 bytes isn't @@ -109,20 +127,20 @@ void save_vbnv(const uint8_t *vbnv_copy)
static void vbnv_setup(void) { - read_vbnv(vbnv); - vbnv_initialized = 1; + read_vbnv(vbnv_data_addr(0)); + car_set_var(vbnv_initialized, 1); }
int get_recovery_mode_from_vbnv(void) { - if (!vbnv_initialized) + if (!is_vbnv_initialized()) vbnv_setup(); - return vbnv[RECOVERY_OFFSET]; + return vbnv_data(RECOVERY_OFFSET); }
int vboot_wants_oprom(void) { - if (!vbnv_initialized) + if (!is_vbnv_initialized()) vbnv_setup();
/* FIXME(crosbug.com/p/8789). The following commented-out line does the @@ -130,6 +148,6 @@ int vboot_wants_oprom(void) * rebooted if it finds that it's needed but not loaded. At the moment, * it doesn't yet do that, so we must always say we want it. */
- /* return (vbnv[BOOT_OFFSET] & BOOT_OPROM_NEEDED) ? 1 : 0; */ + /* return (vbnv_data(BOOT_OFFSET) & BOOT_OPROM_NEEDED) ? 1 : 0; */ return 1; }
