Attention is currently required from: Maulik V Vaghela, Tim Wawrzynczak, Patrick Rudolph. Hello build bot (Jenkins), Tim Wawrzynczak, Subrata Banik, Patrick Rudolph,
https://review.coreboot.org/c/coreboot/+/56853
Change subject: mb/*/{brya,adlrvp}: move cpu_cluster static configuration to chipset.cb ......................................................................
For mainboard devicetree, it always have definition for enabling cpu_cluster 0 which is required for all the variants. Since it is SoC related settings, it's better to keep in chipset.cb as a common setting for all the mainboards using the same SoC.
BUG=None BRANCH=None TEST=Change has no functional impact on the brya board.
Change-Id: I8f7c3184b62f8d84ca4605fb9f2a1cc569f1f964 Signed-off-by: MAULIK V VAGHELA maulik.v.vaghela@intel.com --- M src/mainboard/google/brya/variants/baseboard/brask/devicetree.cb M src/mainboard/google/brya/variants/baseboard/brya/devicetree.cb M src/mainboard/intel/adlrvp/devicetree.cb M src/mainboard/intel/adlrvp/devicetree_m.cb M src/soc/intel/alderlake/chipset.cb 5 files changed, 2 insertions(+), 8 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/53/56853/2
