Paul Menzel (paulepanter@users.sourceforge.net) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/3544
commit 4d0334704bb3ba1f7f8b63967efd9ce7c0ec97a2 Author: Bruce Griffith Bruce.Griffith@se-eng.com Date: Tue Jun 25 14:01:21 2013 -0600
AMD SB700 boards: Set Azalia configuration flags
The existing code for setting Azalia configuration assumes that the configuration bits are contiguous within a single byte and can be set using a byte copy addressed into the lowest 2-bit subfield.
The fix in Family 14 defines a union that can be addressed as a byte to overlay the bit fields. Since the offset of the four subfields is not necessarily fixed, change the code to initialize each of the four subfields individually.
Change-Id: I1dff20bb8bd3e1bcd8b4e6b0537e20779d2a3521 Signed-off-by: Bruce Griffith Bruce.Griffith@se-eng.com --- src/mainboard/amd/dinar/sb700_cfg.c | 5 ++++- src/mainboard/amd/dinar/sb700_cfg.h | 6 +++++- src/mainboard/supermicro/h8qgi/sb700_cfg.c | 5 ++++- src/mainboard/supermicro/h8qgi/sb700_cfg.h | 6 +++++- src/mainboard/supermicro/h8scm/sb700_cfg.c | 5 ++++- src/mainboard/supermicro/h8scm/sb700_cfg.h | 6 +++++- 6 files changed, 27 insertions(+), 6 deletions(-)
diff --git a/src/mainboard/amd/dinar/sb700_cfg.c b/src/mainboard/amd/dinar/sb700_cfg.c index 94e4b40..c9a0949 100644 --- a/src/mainboard/amd/dinar/sb700_cfg.c +++ b/src/mainboard/amd/dinar/sb700_cfg.c @@ -126,7 +126,10 @@ void sb700_cimx_config(AMDSBCFG *sb_config) /* Azalia HDA */ sb_config->AzaliaController = AZALIA_CONTROLLER; sb_config->AzaliaPinCfg = AZALIA_PIN_CONFIG; - sb_config->AzaliaSdin0 = AZALIA_SDIN_PIN; + sb_config->AzaliaSdin0 = AZALIA_SDIN_PIN_0; + sb_config->AzaliaSdin1 = AZALIA_SDIN_PIN_1; + sb_config->AzaliaSdin2 = AZALIA_SDIN_PIN_2; + sb_config->AzaliaSdin3 = AZALIA_SDIN_PIN_3; sb_config->pAzaliaOemCodecTablePtr = NULL;
#ifndef __PRE_RAM__ diff --git a/src/mainboard/amd/dinar/sb700_cfg.h b/src/mainboard/amd/dinar/sb700_cfg.h index 371c7ce..216c264 100644 --- a/src/mainboard/amd/dinar/sb700_cfg.h +++ b/src/mainboard/amd/dinar/sb700_cfg.h @@ -192,7 +192,11 @@ */ #ifndef AZALIA_SDIN_PIN //#define AZALIA_SDIN_PIN 0xAA -#define AZALIA_SDIN_PIN 0x2A +#define AZALIA_SDIN_PIN +#define AZALIA_SDIN_PIN_0 0x2 +#define AZALIA_SDIN_PIN_1 0x2 +#define AZALIA_SDIN_PIN_2 0x2 +#define AZALIA_SDIN_PIN_3 0x0 #endif
/** diff --git a/src/mainboard/supermicro/h8qgi/sb700_cfg.c b/src/mainboard/supermicro/h8qgi/sb700_cfg.c index 54c139a..ff2334f 100644 --- a/src/mainboard/supermicro/h8qgi/sb700_cfg.c +++ b/src/mainboard/supermicro/h8qgi/sb700_cfg.c @@ -126,7 +126,10 @@ void sb700_cimx_config(AMDSBCFG *sb_config) /* Azalia HDA */ sb_config->AzaliaController = AZALIA_CONTROLLER; sb_config->AzaliaPinCfg = AZALIA_PIN_CONFIG; - sb_config->AzaliaSdin0 = AZALIA_SDIN_PIN; + sb_config->AzaliaSdin0 = AZALIA_SDIN_PIN_0; + sb_config->AzaliaSdin1 = AZALIA_SDIN_PIN_1; + sb_config->AzaliaSdin2 = AZALIA_SDIN_PIN_2; + sb_config->AzaliaSdin3 = AZALIA_SDIN_PIN_3; sb_config->pAzaliaOemCodecTablePtr = NULL;
#ifndef __PRE_RAM__ diff --git a/src/mainboard/supermicro/h8qgi/sb700_cfg.h b/src/mainboard/supermicro/h8qgi/sb700_cfg.h index a3e5a38..1df3fc5 100644 --- a/src/mainboard/supermicro/h8qgi/sb700_cfg.h +++ b/src/mainboard/supermicro/h8qgi/sb700_cfg.h @@ -192,7 +192,11 @@ */ #ifndef AZALIA_SDIN_PIN //#define AZALIA_SDIN_PIN 0xAA -#define AZALIA_SDIN_PIN 0x2A +#define AZALIA_SDIN_PIN +#define AZALIA_SDIN_PIN_0 0x2 +#define AZALIA_SDIN_PIN_1 0x2 +#define AZALIA_SDIN_PIN_2 0x2 +#define AZALIA_SDIN_PIN_3 0x0 #endif
/** diff --git a/src/mainboard/supermicro/h8scm/sb700_cfg.c b/src/mainboard/supermicro/h8scm/sb700_cfg.c index 12169e6..c03a501 100644 --- a/src/mainboard/supermicro/h8scm/sb700_cfg.c +++ b/src/mainboard/supermicro/h8scm/sb700_cfg.c @@ -126,7 +126,10 @@ void sb700_cimx_config(AMDSBCFG *sb_config) /* Azalia HDA */ sb_config->AzaliaController = AZALIA_CONTROLLER; sb_config->AzaliaPinCfg = AZALIA_PIN_CONFIG; - sb_config->AzaliaSdin0 = AZALIA_SDIN_PIN; + sb_config->AzaliaSdin0 = AZALIA_SDIN_PIN_0; + sb_config->AzaliaSdin1 = AZALIA_SDIN_PIN_1; + sb_config->AzaliaSdin2 = AZALIA_SDIN_PIN_2; + sb_config->AzaliaSdin3 = AZALIA_SDIN_PIN_3; sb_config->pAzaliaOemCodecTablePtr = NULL;
#ifndef __PRE_RAM__ diff --git a/src/mainboard/supermicro/h8scm/sb700_cfg.h b/src/mainboard/supermicro/h8scm/sb700_cfg.h index eca355f..40c89fa 100644 --- a/src/mainboard/supermicro/h8scm/sb700_cfg.h +++ b/src/mainboard/supermicro/h8scm/sb700_cfg.h @@ -192,7 +192,11 @@ */ #ifndef AZALIA_SDIN_PIN //#define AZALIA_SDIN_PIN 0xAA -#define AZALIA_SDIN_PIN 0x2A +#define AZALIA_SDIN_PIN +#define AZALIA_SDIN_PIN_0 0x2 +#define AZALIA_SDIN_PIN_1 0x2 +#define AZALIA_SDIN_PIN_2 0x2 +#define AZALIA_SDIN_PIN_3 0x0 #endif
