Attention is currently required from: Dinesh Gehlot, Dtrain Hsu, Eric Lai, Jayvik Desai, Kapil Porwal, Nick Vaccaro, Paul Menzel, Subrata Banik.
Hello Dinesh Gehlot, Dtrain Hsu, Eric Lai, Jayvik Desai, Kapil Porwal, Nick Vaccaro, Subrata Banik, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/85537?usp=email
The following approvals got outdated and were removed: Code-Review+2 by Dtrain Hsu, Code-Review+2 by Eric Lai, Code-Review+2 by Subrata Banik, Verified+1 by build bot (Jenkins)
The change is no longer submittable: Code-Review and Verified are unsatisfied now.
Change subject: mb/google/brya/uldrenite: Add WWAN RW350R-GL power on sequence ......................................................................
Uldrenite supports the WWAN 5G device and uses variant.c to handle the power-on sequence according to the Rolling Wireless_RW350R-GL_Hardware Guide_Generic_V1.1. Due to no hardware access, the boot time is estimated to increase by 50 ms.
At this stage, we do not yet have the board or key parts for verification. However, I still need to merge the CL to ensure that the WWAN functionality works. Once the motherboard is available, I will make adjustments to optimize and reduce the boot time.
BUG=b:381393809, b:383212261 BRANCH=None TEST=emerge-nissa coreboot
Change-Id: If8695920c2b3d2a27da62afcbe75e70d1ea09792 Signed-off-by: John Su john_su@compal.corp-partner.google.com --- M src/mainboard/google/brya/variants/uldrenite/Makefile.mk A src/mainboard/google/brya/variants/uldrenite/variant.c 2 files changed, 37 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/37/85537/8
