Maxim Polyakov has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/41034 )
Change subject: soc/intel/gpio: convert PAD_CFG0_ROUTE_* to PAD_IRQ_ROUTE() ......................................................................
As with other macros, convert PAD_CFG0_ROUTE_* to PAD_IRQ_ROUTE() to make the code in gpio_defs.h cleaner.
Change-Id: Iadc9c4b3c96ae04c56d060cb060737a8eba7f165 Signed-off-by: Maxim Polyakov max.senia.poliak@gmail.com --- M src/soc/intel/common/block/include/intelblocks/gpio_defs.h 1 file changed, 4 insertions(+), 3 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/34/41034/1
diff --git a/src/soc/intel/common/block/include/intelblocks/gpio_defs.h b/src/soc/intel/common/block/include/intelblocks/gpio_defs.h index ecc9489..713c808 100644 --- a/src/soc/intel/common/block/include/intelblocks/gpio_defs.h +++ b/src/soc/intel/common/block/include/intelblocks/gpio_defs.h @@ -138,6 +138,7 @@ #define PAD_FUNC(value) PAD_CFG0_MODE_##value #define PAD_RESET(value) PAD_CFG0_LOGICAL_RESET_##value #define PAD_RX_POL(value) PAD_CFG0_RX_POL_##value +#define PAD_IRQ_ROUTE(value) PAD_CFG0_ROUTE_##value #define PAD_TRIG(value) PAD_CFG0_TRIG_##value #define PAD_PULL(value) PAD_CFG1_PULL_##value
@@ -159,14 +160,14 @@ #endif
#define PAD_IRQ_CFG(route, trig, inv) \ - (PAD_CFG0_ROUTE_##route | \ + (PAD_IRQ_ROUTE(route) | \ PAD_TRIG(trig) | \ PAD_RX_POL(inv))
#if CONFIG(SOC_INTEL_COMMON_BLOCK_GPIO_DUAL_ROUTE_SUPPORT) #define PAD_IRQ_CFG_DUAL_ROUTE(route1, route2, trig, inv) \ - (PAD_CFG0_ROUTE_##route1 | \ - PAD_CFG0_ROUTE_##route2 | \ + (PAD_IRQ_ROUTE(route1) | \ + PAD_IRQ_ROUTE(route2) | \ PAD_TRIG(trig) | \ PAD_RX_POL(inv)) #endif /* CONFIG_SOC_INTEL_COMMON_BLOCK_GPIO_DUAL_ROUTE_SUPPORT */
Paul Menzel has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/41034 )
Patch Set 1: Code-Review+1
Hello build bot (Jenkins), Paul Menzel, Patrick Rudolph,
Tested with BUILD_TIMELESS=1, Kontron COMe-mAL10 on T10-TNI carrierboard does not change.
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/34/41034/5
Change subject: soc/intel/gpio: Convert PAD_CFG0_ROUTE_* to PAD_IRQ_ROUTE() ......................................................................
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/34/41034/7
Michael Niewöhner has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/41034 )
Patch Set 11: Code-Review+2
Patrick Georgi has submitted this change. ( https://review.coreboot.org/c/coreboot/+/41034 )
Change-Id: Iadc9c4b3c96ae04c56d060cb060737a8eba7f165 Signed-off-by: Maxim Polyakov max.senia.poliak@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/41034 Reviewed-by: Michael Niewöhner Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/soc/intel/common/block/include/intelblocks/gpio_defs.h 1 file changed, 4 insertions(+), 3 deletions(-)
Approvals: build bot (Jenkins): Verified Michael Niewöhner: Looks good to me, approved
diff --git a/src/soc/intel/common/block/include/intelblocks/gpio_defs.h b/src/soc/intel/common/block/include/intelblocks/gpio_defs.h index e257f07..1ff0b2c 100644 --- a/src/soc/intel/common/block/include/intelblocks/gpio_defs.h +++ b/src/soc/intel/common/block/include/intelblocks/gpio_defs.h @@ -125,6 +125,7 @@ #define PAD_FUNC(value) PAD_CFG0_MODE_##value #define PAD_RESET(value) PAD_CFG0_LOGICAL_RESET_##value #define PAD_RX_POL(value) PAD_CFG0_RX_POL_##value +#define PAD_IRQ_ROUTE(value) PAD_CFG0_ROUTE_##value #define PAD_TRIG(value) PAD_CFG0_TRIG_##value #define PAD_PULL(value) PAD_CFG1_PULL_##value
@@ -146,14 +147,14 @@ #endif
