Kyösti Mälkki (kyosti.malkki@gmail.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/6132
commit 7095eb51fac0d080f0d1c813b7d6b45b48cc4871 Author: Kyösti Mälkki kyosti.malkki@gmail.com Date: Thu Jun 19 23:12:15 2014 +0300
AGESA: Add agesawrapper_post_device()
Change-Id: I0f082e7af1769c8d7d03cdd51fdb5dacbf3402b4 Signed-off-by: Kyösti Mälkki kyosti.malkki@gmail.com --- src/cpu/amd/agesa/amd_late_init.c | 48 ++++++++++++++++++++++ src/mainboard/amd/dinar/agesawrapper.h | 1 + src/mainboard/amd/dinar/get_bus_conf.c | 22 ---------- src/mainboard/amd/inagua/agesawrapper.h | 1 + src/mainboard/amd/inagua/get_bus_conf.c | 21 ---------- src/mainboard/amd/olivehill/get_bus_conf.c | 35 ---------------- src/mainboard/amd/parmer/get_bus_conf.c | 35 ---------------- src/mainboard/amd/persimmon/get_bus_conf.c | 34 --------------- src/mainboard/amd/south_station/agesawrapper.h | 1 + src/mainboard/amd/south_station/get_bus_conf.c | 21 ---------- src/mainboard/amd/thatcher/get_bus_conf.c | 35 ---------------- src/mainboard/amd/torpedo/agesawrapper.h | 1 + src/mainboard/amd/torpedo/get_bus_conf.c | 23 ----------- src/mainboard/amd/union_station/agesawrapper.h | 1 + src/mainboard/amd/union_station/get_bus_conf.c | 21 ---------- src/mainboard/asrock/e350m1/agesawrapper.h | 1 + src/mainboard/asrock/e350m1/get_bus_conf.c | 21 ---------- src/mainboard/asrock/imb-a180/get_bus_conf.c | 35 ---------------- src/mainboard/asus/f2a85-m/get_bus_conf.c | 35 ---------------- src/mainboard/gizmosphere/gizmo/get_bus_conf.c | 34 --------------- src/mainboard/hp/pavilion_m6_1035dx/get_bus_conf.c | 35 ---------------- src/mainboard/jetway/nf81-t56n-lf/get_bus_conf.c | 37 ----------------- .../lippert/frontrunner-af/get_bus_conf.c | 34 --------------- src/mainboard/lippert/toucan-af/get_bus_conf.c | 34 --------------- src/mainboard/supermicro/h8qgi/agesawrapper.h | 1 + src/mainboard/supermicro/h8qgi/get_bus_conf.c | 22 ---------- src/mainboard/supermicro/h8scm/agesawrapper.h | 1 + src/mainboard/supermicro/h8scm/get_bus_conf.c | 22 ---------- src/mainboard/tyan/s8226/agesawrapper.h | 1 + src/mainboard/tyan/s8226/get_bus_conf.c | 22 ---------- 30 files changed, 57 insertions(+), 578 deletions(-)
diff --git a/src/cpu/amd/agesa/amd_late_init.c b/src/cpu/amd/agesa/amd_late_init.c new file mode 100644 index 0000000..3f359e0 --- /dev/null +++ b/src/cpu/amd/agesa/amd_late_init.c @@ -0,0 +1,48 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2012 Advanced Micro Devices, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#include <bootstate.h> +#include <arch/acpi.h> +#include <console/console.h> +#include "agesawrapper.h" + +static void agesawrapper_post_device(void *unused) +{ + u32 status; + if (acpi_is_wakeup_s3()) + return; + + status = agesawrapper_amdinitlate(); + if (status) { + printk(BIOS_DEBUG, "agesawrapper_amdinitlate failed: %x \n", status); + } + + if (!acpi_s3_resume_allowed()) + return; + + status = agesawrapper_amdS3Save(); + if (status) { + printk(BIOS_DEBUG, "agesawrapper_amds3save failed: %x \n", status); + } +} + +BOOT_STATE_INIT_ENTRIES(agesa_bscb) = { + BOOT_STATE_INIT_ENTRY(BS_POST_DEVICE, BS_ON_EXIT, + agesawrapper_post_device, NULL), +}; diff --git a/src/mainboard/amd/dinar/agesawrapper.h b/src/mainboard/amd/dinar/agesawrapper.h index c42b2b0..7917e6c 100644 --- a/src/mainboard/amd/dinar/agesawrapper.h +++ b/src/mainboard/amd/dinar/agesawrapper.h @@ -95,4 +95,5 @@ UINT32 agesawrapper_amdinitmmio (void); void *agesawrapper_getlateinitptr (int pick); UINT32 agesawrapper_amdlaterunaptask (UINT32 Func, UINT32 Data, VOID *ConfigPtr);
+static inline UINT32 agesawrapper_amdS3Save(void) { } #endif diff --git a/src/mainboard/amd/dinar/get_bus_conf.c b/src/mainboard/amd/dinar/get_bus_conf.c index a59bc43..a4d627b 100644 --- a/src/mainboard/amd/dinar/get_bus_conf.c +++ b/src/mainboard/amd/dinar/get_bus_conf.c @@ -66,8 +66,6 @@ static u32 get_bus_conf_done = 0;
void get_bus_conf(void) { - u32 status; - device_t dev; int i, j;
@@ -77,26 +75,6 @@ void get_bus_conf(void) get_bus_conf_done = 1;
printk(BIOS_DEBUG, "Mainboard - Get_bus_conf.c - get_bus_conf - Start.\n"); - /* - * This is the call to AmdInitLate. It is really in the wrong place, conceptually, - * but functionally within the coreboot model, this is the best place to make the - * call. The logically correct place to call AmdInitLate is after PCI scan is done, - * after the decision about S3 resume is made, and before the system tables are - * written into RAM. The routine that is responsible for writing the tables is - * "write_tables", called near the end of "main". There is no platform - * specific entry point between the S3 resume decision point and the call to - * "write_tables", and the next platform specific entry points are the calls to - * the ACPI table write functions. The first of ose would seem to be the right - * place, but other table write functions, e.g. the PIRQ table write function, are - * called before the ACPI tables are written. This routine is called at the beginning - * of each of the write functions called prior to the ACPI write functions, so this - * becomes the best place for this call. - */ - status = agesawrapper_amdinitlate(); - if(status) { - printk(BIOS_DEBUG, "agesawrapper_amdinitlate failed: %x \n", status); - } - printk(BIOS_DEBUG, "Got past agesawrapper_amdinitlate\n");
sbdn_sb700 = 0;
diff --git a/src/mainboard/amd/inagua/agesawrapper.h b/src/mainboard/amd/inagua/agesawrapper.h index 50b6a30..4ad2a45 100644 --- a/src/mainboard/amd/inagua/agesawrapper.h +++ b/src/mainboard/amd/inagua/agesawrapper.h @@ -53,4 +53,5 @@ UINT32 agesawrapper_amdinitmmio (void); UINT32 agesawrapper_amdlaterunaptask (UINT32 Func, UINT32 Data, VOID *ConfigPtr); void *agesawrapper_getlateinitptr (int pick);
+static inline UINT32 agesawrapper_amdS3Save(void) { } #endif diff --git a/src/mainboard/amd/inagua/get_bus_conf.c b/src/mainboard/amd/inagua/get_bus_conf.c index be281055..8ab41d1 100644 --- a/src/mainboard/amd/inagua/get_bus_conf.c +++ b/src/mainboard/amd/inagua/get_bus_conf.c @@ -55,7 +55,6 @@ static u32 get_bus_conf_done = 0; void get_bus_conf(void) { u32 apicid_base; - u32 status;
device_t dev; int i, j; @@ -65,26 +64,6 @@ void get_bus_conf(void)
- /* - * This is the call to AmdInitLate. It is really in the wrong place, conceptually, - * but functionally within the coreboot model, this is the best place to make the - * call. The logically correct place to call AmdInitLate is after PCI scan is done, - * after the decision about S3 resume is made, and before the system tables are - * written into RAM. The routine that is responsible for writing the tables is - * "write_tables", called near the end of "main". There is no platform - * specific entry point between the S3 resume decision point and the call to - * "write_tables", and the next platform specific entry points are the calls to - * the ACPI table write functions. The first of ose would seem to be the right - * place, but other table write functions, e.g. the PIRQ table write function, are - * called before the ACPI tables are written. This routine is called at the beginning - * of each of the write functions called prior to the ACPI write functions, so this - * becomes the best place for this call. - */ - status = agesawrapper_amdinitlate(); - if(status) { - printk(BIOS_DEBUG, "agesawrapper_amdinitlate failed: %x \n", status); - } - sbdn_sb800 = 0;
memset(bus_sb800, 0, sizeof(bus_sb800)); diff --git a/src/mainboard/amd/olivehill/get_bus_conf.c b/src/mainboard/amd/olivehill/get_bus_conf.c index df6ebb7..3addc97 100644 --- a/src/mainboard/amd/olivehill/get_bus_conf.c +++ b/src/mainboard/amd/olivehill/get_bus_conf.c @@ -50,13 +50,9 @@ u32 sbdn_yangtze;
-#if CONFIG_HAVE_ACPI_RESUME -extern u8 acpi_slp_type; -#endif void get_bus_conf(void) { u32 apicid_base; - u32 status; u32 value;
device_t dev; @@ -67,37 +63,6 @@ void get_bus_conf(void)
- /* - * This is the call to AmdInitLate. It is really in the wrong place, conceptually, - * but functionally within the coreboot model, this is the best place to make the - * call. The logically correct place to call AmdInitLate is after PCI scan is done, - * after the decision about S3 resume is made, and before the system tables are - * written into RAM. The routine that is responsible for writing the tables is - * "write_tables", called near the end of "hardwaremain". There is no platform - * specific entry point between the S3 resume decision point and the call to - * "write_tables", and the next platform specific entry points are the calls to - * the ACPI table write functions. The first of ose would seem to be the right - * place, but other table write functions, e.g. the PIRQ table write function, are - * called before the ACPI tables are written. This routine is called at the beginning - * of each of the write functions called prior to the ACPI write functions, so this - * becomes the best place for this call. - */ -#if CONFIG_HAVE_ACPI_RESUME - if (acpi_slp_type != 3) { - status = agesawrapper_amdinitlate(); - if(status) { - printk(BIOS_DEBUG, "agesawrapper_amdinitlate failed: %x \n", status); - } - status = agesawrapper_amdS3Save(); - if (status) { - printk(BIOS_DEBUG, "agesawrapper_amds3save failed: %x \n", status); - } - } -#else - status = agesawrapper_amdinitlate(); - if (status) - printk(BIOS_DEBUG, "agesawrapper_amdinitlate failed: %x \n", status); -#endif dev = dev_find_slot(0, PCI_DEVFN(0, 0)); /* clear IoapicSbFeatureEn */ pci_write_config32(dev, 0xF8, 0); pci_write_config32(dev, 0xFC, 5); /* TODO: move it to dsdt.asl */ diff --git a/src/mainboard/amd/parmer/get_bus_conf.c b/src/mainboard/amd/parmer/get_bus_conf.c index bf76fe2..ce5276f 100644 --- a/src/mainboard/amd/parmer/get_bus_conf.c +++ b/src/mainboard/amd/parmer/get_bus_conf.c @@ -50,13 +50,9 @@ u32 sbdn_hudson;
device_t dev; int i, j; @@ -66,37 +62,6 @@ void get_bus_conf(void)
- /* - * This is the call to AmdInitLate. It is really in the wrong place, conceptually, - * but functionally within the coreboot model, this is the best place to make the - * call. The logically correct place to call AmdInitLate is after PCI scan is done, - * after the decision about S3 resume is made, and before the system tables are - * written into RAM. The routine that is responsible for writing the tables is - * "write_tables", called near the end of "main". There is no platform - * specific entry point between the S3 resume decision point and the call to - * "write_tables", and the next platform specific entry points are the calls to - * the ACPI table write functions. The first of ose would seem to be the right - * place, but other table write functions, e.g. the PIRQ table write function, are - * called before the ACPI tables are written. This routine is called at the beginning - * of each of the write functions called prior to the ACPI write functions, so this - * becomes the best place for this call. - */ -#if CONFIG_HAVE_ACPI_RESUME - if (acpi_slp_type != 3) { - status = agesawrapper_amdinitlate(); - if(status) { - printk(BIOS_DEBUG, "agesawrapper_amdinitlate failed: %x \n", status); - } - status = agesawrapper_amdS3Save(); - if (status) { - printk(BIOS_DEBUG, "agesawrapper_amds3save failed: %x \n", status); - } - } -#else - status = agesawrapper_amdinitlate(); - if (status) - printk(BIOS_DEBUG, "agesawrapper_amdinitlate failed: %x \n", status); -#endif
sbdn_hudson = 0;
diff --git a/src/mainboard/amd/persimmon/get_bus_conf.c b/src/mainboard/amd/persimmon/get_bus_conf.c index ac65a1d..15b1989 100644 --- a/src/mainboard/amd/persimmon/get_bus_conf.c +++ b/src/mainboard/amd/persimmon/get_bus_conf.c @@ -53,14 +53,9 @@ u32 sbdn_sb800;
-#if CONFIG_HAVE_ACPI_RESUME -extern u8 acpi_slp_type; -#endif - void get_bus_conf(void) { u32 apicid_base; - u32 status;
device_t dev; int i, j; @@ -70,35 +65,6 @@ void get_bus_conf(void)
-/* - * This is the call to AmdInitLate. It is really in the wrong place, conceptually, - * but functionally within the coreboot model, this is the best place to make the - * call. The logically correct place to call AmdInitLate is after PCI scan is done, - * after the decision about S3 resume is made, and before the system tables are - * written into RAM. The routine that is responsible for writing the tables is - * "write_tables", called near the end of "main". There is no platform - * specific entry point between the S3 resume decision point and the call to - * "write_tables", and the next platform specific entry points are the calls to - * the ACPI table write functions. The first of ose would seem to be the right - * place, but other table write functions, e.g. the PIRQ table write function, are - * called before the ACPI tables are written. This routine is called at the beginning - * of each of the write functions called prior to the ACPI write functions, so this - * becomes the best place for this call. - */ -#if CONFIG_HAVE_ACPI_RESUME - if (acpi_slp_type != 3) { - status = agesawrapper_amdinitlate(); - if(status) - printk(BIOS_DEBUG, "agesawrapper_amdinitlate failed: %x \n", status); - status = agesawrapper_amdS3Save(); - if(status) - printk(BIOS_DEBUG, "agesawrapper_amds3save failed: %x \n", status); - } -#else - status = agesawrapper_amdinitlate(); - if(status) - printk(BIOS_DEBUG, "agesawrapper_amdinitlate failed: %x \n", status); -#endif sbdn_sb800 = 0;
memset(bus_sb800, 0, sizeof(bus_sb800)); diff --git a/src/mainboard/amd/south_station/agesawrapper.h b/src/mainboard/amd/south_station/agesawrapper.h index 48ed2f1..a4b1693 100644 --- a/src/mainboard/amd/south_station/agesawrapper.h +++ b/src/mainboard/amd/south_station/agesawrapper.h @@ -53,4 +53,5 @@ UINT32 agesawrapper_amdinitmmio (void); UINT32 agesawrapper_amdlaterunaptask (UINT32 Func, UINT32 Data, VOID *ConfigPtr); void *agesawrapper_getlateinitptr (int pick);
+static inline UINT32 agesawrapper_amdS3Save(void) { } #endif /* _AGESAWRAPPER_H_ */ diff --git a/src/mainboard/amd/south_station/get_bus_conf.c b/src/mainboard/amd/south_station/get_bus_conf.c index df8ce6e..6a3d232 100644 --- a/src/mainboard/amd/south_station/get_bus_conf.c +++ b/src/mainboard/amd/south_station/get_bus_conf.c @@ -55,7 +55,6 @@ static u32 get_bus_conf_done = 0; void get_bus_conf(void) { u32 apicid_base; - u32 status;
-/* - * This is the call to AmdInitLate. It is really in the wrong place, conceptually, - * but functionally within the coreboot model, this is the best place to make the - * call. The logically correct place to call AmdInitLate is after PCI scan is done, - * after the decision about S3 resume is made, and before the system tables are - * written into RAM. The routine that is responsible for writing the tables is - * "write_tables", called near the end of "main". There is no platform - * specific entry point between the S3 resume decision point and the call to - * "write_tables", and the next platform specific entry points are the calls to - * the ACPI table write functions. The first of ose would seem to be the right - * place, but other table write functions, e.g. the PIRQ table write function, are - * called before the ACPI tables are written. This routine is called at the beginning - * of each of the write functions called prior to the ACPI write functions, so this - * becomes the best place for this call. - */ - status = agesawrapper_amdinitlate(); - if(status) { - printk(BIOS_DEBUG, "agesawrapper_amdinitlate failed: %x \n", status); - } - sbdn_sb800 = 0;
memset(bus_sb800, 0, sizeof(bus_sb800)); diff --git a/src/mainboard/amd/thatcher/get_bus_conf.c b/src/mainboard/amd/thatcher/get_bus_conf.c index bf76fe2..ce5276f 100644 --- a/src/mainboard/amd/thatcher/get_bus_conf.c +++ b/src/mainboard/amd/thatcher/get_bus_conf.c @@ -50,13 +50,9 @@ u32 sbdn_hudson;
sbdn_hudson = 0;
diff --git a/src/mainboard/amd/torpedo/agesawrapper.h b/src/mainboard/amd/torpedo/agesawrapper.h index 9883bd1..0754e91 100644 --- a/src/mainboard/amd/torpedo/agesawrapper.h +++ b/src/mainboard/amd/torpedo/agesawrapper.h @@ -95,4 +95,5 @@ UINT32 agesawrapper_amdinitmmio (void); UINT32 agesawrapper_amdlaterunaptask (UINT32 Func, UINT32 Data, VOID *ConfigPtr); void *agesawrapper_getlateinitptr (int pick);
+static inline UINT32 agesawrapper_amdS3Save(void) { } #endif diff --git a/src/mainboard/amd/torpedo/get_bus_conf.c b/src/mainboard/amd/torpedo/get_bus_conf.c index 2b4e9fa..5404941 100644 --- a/src/mainboard/amd/torpedo/get_bus_conf.c +++ b/src/mainboard/amd/torpedo/get_bus_conf.c @@ -59,8 +59,6 @@ static u32 get_bus_conf_done = 0;
@@ -70,27 +68,6 @@ void get_bus_conf(void) get_bus_conf_done = 1;
printk(BIOS_DEBUG, "Mainboard - %s - %s - Start.\n", __FILE__, __func__); -/* - * This is the call to AmdInitLate. It is really in the wrong place, conceptually, - * but functionally within the coreboot model, this is the best place to make the - * call. The logically correct place to call AmdInitLate is after PCI scan is done, - * after the decision about S3 resume is made, and before the system tables are - * written into RAM. The routine that is responsible for writing the tables is - * "write_tables", called near the end of "main". There is no platform - * specific entry point between the S3 resume decision point and the call to - * "write_tables", and the next platform specific entry points are the calls to - * the ACPI table write functions. The first of ose would seem to be the right - * place, but other table write functions, e.g. the PIRQ table write function, are - * called before the ACPI tables are written. This routine is called at the beginning - * of each of the write functions called prior to the ACPI write functions, so this - * becomes the best place for this call. - */ - printk(BIOS_DEBUG, "agesawrapper_amdinitlate "); - status = agesawrapper_amdinitlate(); - if (status) - printk(BIOS_DEBUG, "error level: %x \n", status); - else - printk(BIOS_DEBUG, "passed.\n");
sbdn_sb900 = 0;
diff --git a/src/mainboard/amd/union_station/agesawrapper.h b/src/mainboard/amd/union_station/agesawrapper.h index 48ed2f1..a4b1693 100644 --- a/src/mainboard/amd/union_station/agesawrapper.h +++ b/src/mainboard/amd/union_station/agesawrapper.h @@ -53,4 +53,5 @@ UINT32 agesawrapper_amdinitmmio (void); UINT32 agesawrapper_amdlaterunaptask (UINT32 Func, UINT32 Data, VOID *ConfigPtr); void *agesawrapper_getlateinitptr (int pick);
+static inline UINT32 agesawrapper_amdS3Save(void) { } #endif /* _AGESAWRAPPER_H_ */ diff --git a/src/mainboard/amd/union_station/get_bus_conf.c b/src/mainboard/amd/union_station/get_bus_conf.c index df8ce6e..6a3d232 100644 --- a/src/mainboard/amd/union_station/get_bus_conf.c +++ b/src/mainboard/amd/union_station/get_bus_conf.c @@ -55,7 +55,6 @@ static u32 get_bus_conf_done = 0; void get_bus_conf(void) { u32 apicid_base; - u32 status;
memset(bus_sb800, 0, sizeof(bus_sb800)); diff --git a/src/mainboard/asrock/e350m1/agesawrapper.h b/src/mainboard/asrock/e350m1/agesawrapper.h index 10158f6..77319a1 100644 --- a/src/mainboard/asrock/e350m1/agesawrapper.h +++ b/src/mainboard/asrock/e350m1/agesawrapper.h @@ -84,4 +84,5 @@ UINT32 agesawrapper_amdinitcpuio (void); UINT32 agesawrapper_amdlaterunaptask (UINT32 Func, UINT32 Data, VOID *ConfigPtr); void *agesawrapper_getlateinitptr (int pick);
+static inline UINT32 agesawrapper_amdS3Save(void) { } #endif diff --git a/src/mainboard/asrock/e350m1/get_bus_conf.c b/src/mainboard/asrock/e350m1/get_bus_conf.c index df8ce6e..6a3d232 100644 --- a/src/mainboard/asrock/e350m1/get_bus_conf.c +++ b/src/mainboard/asrock/e350m1/get_bus_conf.c @@ -55,7 +55,6 @@ static u32 get_bus_conf_done = 0; void get_bus_conf(void) { u32 apicid_base; - u32 status;
memset(bus_sb800, 0, sizeof(bus_sb800)); diff --git a/src/mainboard/asrock/imb-a180/get_bus_conf.c b/src/mainboard/asrock/imb-a180/get_bus_conf.c index a380872..226d57d 100644 --- a/src/mainboard/asrock/imb-a180/get_bus_conf.c +++ b/src/mainboard/asrock/imb-a180/get_bus_conf.c @@ -47,13 +47,9 @@ u32 sbdn_yangtze;
device_t dev; @@ -64,37 +60,6 @@ void get_bus_conf(void)
- /* - * This is the call to AmdInitLate. It is really in the wrong place, conceptually, - * but functionally within the coreboot model, this is the best place to make the - * call. The logically correct place to call AmdInitLate is after PCI scan is done, - * after the decision about S3 resume is made, and before the system tables are - * written into RAM. The routine that is responsible for writing the tables is - * "write_tables", called near the end of "hardwaremain". There is no platform - * specific entry point between the S3 resume decision point and the call to - * "write_tables", and the next platform specific entry points are the calls to - * the ACPI table write functions. The first of ose would seem to be the right - * place, but other table write functions, e.g. the PIRQ table write function, are - * called before the ACPI tables are written. This routine is called at the beginning - * of each of the write functions called prior to the ACPI write functions, so this - * becomes the best place for this call. - */ -#if CONFIG_HAVE_ACPI_RESUME - if (acpi_slp_type != 3) { - status = agesawrapper_amdinitlate(); - if(status) { - printk(BIOS_DEBUG, "agesawrapper_amdinitlate failed: %x \n", status); - } - status = agesawrapper_amdS3Save(); - if (status) { - printk(BIOS_DEBUG, "agesawrapper_amds3save failed: %x \n", status); - } - } -#else - status = agesawrapper_amdinitlate(); - if (status) - printk(BIOS_DEBUG, "agesawrapper_amdinitlate failed: %x \n", status); -#endif dev = dev_find_slot(0, PCI_DEVFN(0, 0)); /* clear IoapicSbFeatureEn */ pci_write_config32(dev, 0xF8, 0); pci_write_config32(dev, 0xFC, 5); /* TODO: move it to dsdt.asl */ diff --git a/src/mainboard/asus/f2a85-m/get_bus_conf.c b/src/mainboard/asus/f2a85-m/get_bus_conf.c index b915d76..5d5922b 100644 --- a/src/mainboard/asus/f2a85-m/get_bus_conf.c +++ b/src/mainboard/asus/f2a85-m/get_bus_conf.c @@ -48,13 +48,9 @@ u32 sbdn_hudson;
device_t dev; int i, j; @@ -64,37 +60,6 @@ void get_bus_conf(void)
sbdn_hudson = 0;
diff --git a/src/mainboard/gizmosphere/gizmo/get_bus_conf.c b/src/mainboard/gizmosphere/gizmo/get_bus_conf.c index 89118aa..3b43d9d 100755 --- a/src/mainboard/gizmosphere/gizmo/get_bus_conf.c +++ b/src/mainboard/gizmosphere/gizmo/get_bus_conf.c @@ -52,14 +52,9 @@ u32 sbdn_sb800;
device_t dev; int i, j; @@ -69,35 +64,6 @@ void get_bus_conf(void)
-/* - * This is the call to AmdInitLate. It is really in the wrong place, conceptually, - * but functionally within the coreboot model, this is the best place to make the - * call. The logically correct place to call AmdInitLate is after PCI scan is done, - * after the decision about S3 resume is made, and before the system tables are - * written into RAM. The routine that is responsible for writing the tables is - * "write_tables", called near the end of "hardwaremain". There is no platform - * specific entry point between the S3 resume decision point and the call to - * "write_tables", and the next platform specific entry points are the calls to - * the ACPI table write functions. The first of ose would seem to be the right - * place, but other table write functions, e.g. the PIRQ table write function, are - * called before the ACPI tables are written. This routine is called at the beginning - * of each of the write functions called prior to the ACPI write functions, so this - * becomes the best place for this call. - */ -#if CONFIG_HAVE_ACPI_RESUME - if (acpi_slp_type != 3) { - status = agesawrapper_amdinitlate(); - if(status) - printk(BIOS_DEBUG, "agesawrapper_amdinitlate failed: %x \n", status); - status = agesawrapper_amdS3Save(); - if(status) - printk(BIOS_DEBUG, "agesawrapper_amds3save failed: %x \n", status); - } -#else - status = agesawrapper_amdinitlate(); - if(status) - printk(BIOS_DEBUG, "agesawrapper_amdinitlate failed: %x \n", status); -#endif sbdn_sb800 = 0;
memset(bus_sb800, 0, sizeof(bus_sb800)); diff --git a/src/mainboard/hp/pavilion_m6_1035dx/get_bus_conf.c b/src/mainboard/hp/pavilion_m6_1035dx/get_bus_conf.c index 79a5380..34afc17 100644 --- a/src/mainboard/hp/pavilion_m6_1035dx/get_bus_conf.c +++ b/src/mainboard/hp/pavilion_m6_1035dx/get_bus_conf.c @@ -49,13 +49,9 @@ u32 sbdn_hudson;
device_t dev; int i, j; @@ -65,37 +61,6 @@ void get_bus_conf(void)
sbdn_hudson = 0;
diff --git a/src/mainboard/jetway/nf81-t56n-lf/get_bus_conf.c b/src/mainboard/jetway/nf81-t56n-lf/get_bus_conf.c index 688f9dd..69a86ab 100644 --- a/src/mainboard/jetway/nf81-t56n-lf/get_bus_conf.c +++ b/src/mainboard/jetway/nf81-t56n-lf/get_bus_conf.c @@ -54,14 +54,9 @@ u32 sbdn_sb800;
-#if CONFIG_HAVE_ACPI_RESUME -extern u8 acpi_slp_type; -#endif /* CONFIG_HAVE_ACPI_RESUME */ - void get_bus_conf(void) { u32 apicid_base; - u32 status;
device_t dev; int i, j; @@ -72,39 +67,7 @@ void get_bus_conf(void)
- /* - * This is the call to AmdInitLate. It is really in the wrong place, - * conceptually, but functionally within the coreboot model, this is the - * best place to make the call. The logically correct place to call - * AmdInitLate is after PCI scan is done, after the decision about S3 - * resume is made, and before the system tables are written into RAM. The - * routine that is - * responsible for writing the tables is "write_tables", called near the - * end of "main". There is no platform specific entry point between the S3 - * resume decision point and the call to "write_tables", and the next - * platform specific entry points are the calls to the ACPI table write - * functions. The first of ose would seem to be the right place, but other - * table write - * functions, e.g. the PIRQ table write function, are called before the - * ACPI tables are written. This routine is called at the beginning of each - * of the write functions called prior to the ACPI write functions, so this - * becomes the best place for this call. - */
-#if CONFIG_HAVE_ACPI_RESUME - if (acpi_slp_type != 3) { - status = agesawrapper_amdinitlate(); - if(status) - printk(BIOS_DEBUG, "agesawrapper_amdinitlate failed: %x \n", status); - status = agesawrapper_amdS3Save(); - if(status) - printk(BIOS_DEBUG, "agesawrapper_amds3save failed: %x \n", status); - } -#else - status = agesawrapper_amdinitlate(); - if(status) - printk(BIOS_DEBUG, "agesawrapper_amdinitlate failed: %x \n", status); -#endif /* CONFIG_HAVE_ACPI_RESUME */
sbdn_sb800 = 0;
diff --git a/src/mainboard/lippert/frontrunner-af/get_bus_conf.c b/src/mainboard/lippert/frontrunner-af/get_bus_conf.c index 258d895..1e7fca4 100644 --- a/src/mainboard/lippert/frontrunner-af/get_bus_conf.c +++ b/src/mainboard/lippert/frontrunner-af/get_bus_conf.c @@ -51,14 +51,9 @@ u32 sbdn_sb800;
device_t dev; int i, j; @@ -68,35 +63,6 @@ void get_bus_conf(void)
memset(bus_sb800, 0, sizeof(bus_sb800)); diff --git a/src/mainboard/lippert/toucan-af/get_bus_conf.c b/src/mainboard/lippert/toucan-af/get_bus_conf.c index 258d895..1e7fca4 100644 --- a/src/mainboard/lippert/toucan-af/get_bus_conf.c +++ b/src/mainboard/lippert/toucan-af/get_bus_conf.c @@ -51,14 +51,9 @@ u32 sbdn_sb800;
memset(bus_sb800, 0, sizeof(bus_sb800)); diff --git a/src/mainboard/supermicro/h8qgi/agesawrapper.h b/src/mainboard/supermicro/h8qgi/agesawrapper.h index 4f5a693..8ff9c18 100644 --- a/src/mainboard/supermicro/h8qgi/agesawrapper.h +++ b/src/mainboard/supermicro/h8qgi/agesawrapper.h @@ -79,4 +79,5 @@ UINT32 agesawrapper_amdinitmmio (void); void *agesawrapper_getlateinitptr (int pick); UINT32 agesawrapper_amdlaterunaptask (UINT32 Func, UINT32 Data, VOID *ConfigPtr);
+static inline UINT32 agesawrapper_amdS3Save(void) { } #endif diff --git a/src/mainboard/supermicro/h8qgi/get_bus_conf.c b/src/mainboard/supermicro/h8qgi/get_bus_conf.c index 25dc2a2..345c75d 100644 --- a/src/mainboard/supermicro/h8qgi/get_bus_conf.c +++ b/src/mainboard/supermicro/h8qgi/get_bus_conf.c @@ -48,8 +48,6 @@ static u32 get_bus_conf_done = 0;
@@ -58,26 +56,6 @@ void get_bus_conf(void)
- /* - * This is the call to AmdInitLate. It is really in the wrong place, conceptually, - * but functionally within the coreboot model, this is the best place to make the - * call. The logically correct place to call AmdInitLate is after PCI scan is done, - * after the decision about S3 resume is made, and before the system tables are - * written into RAM. The routine that is responsible for writing the tables is - * "write_tables", called near the end of "main". There is no platform - * specific entry point between the S3 resume decision point and the call to - * "write_tables", and the next platform specific entry points are the calls to - * the ACPI table write functions. The first of ose would seem to be the right - * place, but other table write functions, e.g. the PIRQ table write function, are - * called before the ACPI tables are written. This routine is called at the beginning - * of each of the write functions called prior to the ACPI write functions, so this - * becomes the best place for this call. - */ - status = agesawrapper_amdinitlate(); - if(status) { - printk(BIOS_DEBUG, "agesawrapper_amdinitlate failed: %x \n", status); - } - sbdn_sp5100 = 0;
for (i = 0; i < ARRAY_SIZE(bus_sp5100); i++) { diff --git a/src/mainboard/supermicro/h8scm/agesawrapper.h b/src/mainboard/supermicro/h8scm/agesawrapper.h index 4f5a693..8ff9c18 100644 --- a/src/mainboard/supermicro/h8scm/agesawrapper.h +++ b/src/mainboard/supermicro/h8scm/agesawrapper.h @@ -79,4 +79,5 @@ UINT32 agesawrapper_amdinitmmio (void); void *agesawrapper_getlateinitptr (int pick); UINT32 agesawrapper_amdlaterunaptask (UINT32 Func, UINT32 Data, VOID *ConfigPtr);
+static inline UINT32 agesawrapper_amdS3Save(void) { } #endif diff --git a/src/mainboard/supermicro/h8scm/get_bus_conf.c b/src/mainboard/supermicro/h8scm/get_bus_conf.c index 4b2cb32..4b51f2a 100644 --- a/src/mainboard/supermicro/h8scm/get_bus_conf.c +++ b/src/mainboard/supermicro/h8scm/get_bus_conf.c @@ -48,8 +48,6 @@ static u32 get_bus_conf_done = 0;
for (i = 0; i < 0; i++) { diff --git a/src/mainboard/tyan/s8226/agesawrapper.h b/src/mainboard/tyan/s8226/agesawrapper.h index 4f5a693..8ff9c18 100644 --- a/src/mainboard/tyan/s8226/agesawrapper.h +++ b/src/mainboard/tyan/s8226/agesawrapper.h @@ -79,4 +79,5 @@ UINT32 agesawrapper_amdinitmmio (void); void *agesawrapper_getlateinitptr (int pick); UINT32 agesawrapper_amdlaterunaptask (UINT32 Func, UINT32 Data, VOID *ConfigPtr);
+static inline UINT32 agesawrapper_amdS3Save(void) { } #endif diff --git a/src/mainboard/tyan/s8226/get_bus_conf.c b/src/mainboard/tyan/s8226/get_bus_conf.c index d45e1ad..5c416c5 100644 --- a/src/mainboard/tyan/s8226/get_bus_conf.c +++ b/src/mainboard/tyan/s8226/get_bus_conf.c @@ -47,8 +47,6 @@ static u32 get_bus_conf_done = 0;
@@ -57,26 +55,6 @@ void get_bus_conf(void)
