Duncan Laurie (dlaurie@chromium.org) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/16394
commit 44e9e4c580ecc1b9d8f365ed5c3ef01839e412b1 Author: Duncan Laurie dlaurie@chromium.org Date: Wed Aug 31 13:51:14 2016 -0700
drivers/i2c/tpm: Make driver safe for use in x86 pre-ram
Use CAR accessors where needed for accessing static data. In some cases this required some minor restructuring to pass in a variable instead of use a global one.
For the tpm_vendor_init the structure no longer has useful defaults, which nobody was depending on anyway. This now requires the caller to provide a non-zero address.
Tested by enabling I2C TPM on reef and compiling successfully.
Change-Id: I8e02fbcebf5fe10c4122632eda1c48b247478289 Signed-off-by: Duncan Laurie dlaurie@chromium.org --- src/drivers/i2c/tpm/tis.c | 24 ++++++------ src/drivers/i2c/tpm/tpm.c | 94 ++++++++++++++++++++++------------------------- src/drivers/i2c/tpm/tpm.h | 8 ++-- 3 files changed, 61 insertions(+), 65 deletions(-)
diff --git a/src/drivers/i2c/tpm/tis.c b/src/drivers/i2c/tpm/tis.c index 0404109..c6173b4 100644 --- a/src/drivers/i2c/tpm/tis.c +++ b/src/drivers/i2c/tpm/tis.c @@ -13,6 +13,7 @@ * GNU General Public License for more details. */
+#include <arch/early_variables.h> #include <stdint.h> #include <string.h> #include <assert.h> @@ -26,7 +27,7 @@ #include <console/console.h>
/* global structure for tpm chip data */ -struct tpm_chip g_chip; +static struct tpm_chip g_chip CAR_GLOBAL;
#define TPM_CMD_COUNT_BYTE 2 #define TPM_CMD_ORDINAL_BYTE 6 @@ -34,18 +35,18 @@ struct tpm_chip g_chip;
int tis_open(void) { + struct tpm_chip *chip = car_get_var_ptr(&g_chip); int rc;
- if (g_chip.is_open) { + if (chip->is_open) { printk(BIOS_DEBUG, "tis_open() called twice.\n"); return -1; }
- rc = tpm_vendor_init(CONFIG_DRIVER_TPM_I2C_BUS, - CONFIG_DRIVER_TPM_I2C_ADDR); - + rc = tpm_vendor_init(chip, CONFIG_DRIVER_TPM_I2C_BUS, + CONFIG_DRIVER_TPM_I2C_ADDR); if (rc < 0) - g_chip.is_open = 0; + chip->is_open = 0;
if (rc) { return -1; @@ -56,9 +57,11 @@ int tis_open(void)
int tis_close(void) { - if (g_chip.is_open) { - tpm_vendor_cleanup(&g_chip); - g_chip.is_open = 0; + struct tpm_chip *chip = car_get_var_ptr(&g_chip); + + if (chip->is_open) { + tpm_vendor_cleanup(chip); + chip->is_open = 0; }
return 0; @@ -104,8 +107,7 @@ static ssize_t tpm_transmit(const uint8_t *buf, size_t bufsiz) { int rc; uint32_t count, ordinal; - - struct tpm_chip *chip = &g_chip; + struct tpm_chip *chip = car_get_var_ptr(&g_chip);
memcpy(&count, buf + TPM_CMD_COUNT_BYTE, sizeof(count)); count = be32_to_cpu(count); diff --git a/src/drivers/i2c/tpm/tpm.c b/src/drivers/i2c/tpm/tpm.c index 306005f..727feb6 100644 --- a/src/drivers/i2c/tpm/tpm.c +++ b/src/drivers/i2c/tpm/tpm.c @@ -28,6 +28,7 @@ * GNU General Public License for more details. */
+#include <arch/early_variables.h> #include <stdint.h> #include <string.h> #include <types.h> @@ -37,9 +38,6 @@ #include <endian.h> #include "tpm.h"
-/* Address of the TPM on the I2C bus */ -#define TPM_I2C_ADDR 0x20 - /* max. number of iterations after I2C NAK */ #define MAX_COUNT 3
@@ -78,10 +76,7 @@ struct tpm_inf_dev { enum i2c_chip_type chip_type; };
-static struct tpm_inf_dev tpm_dev = { - .bus = -1, - .addr = TPM_I2C_ADDR -}; +static struct tpm_inf_dev g_tpm_dev CAR_GLOBAL;
/* * iic_tpm_read() - read from TPM register @@ -99,15 +94,18 @@ static struct tpm_inf_dev tpm_dev = { */ static int iic_tpm_read(uint8_t addr, uint8_t *buffer, size_t len) { + struct tpm_inf_dev *tpm_dev = car_get_var_ptr(&g_tpm_dev); int rc; int count;
- if (tpm_dev.bus < 0) + if (tpm_dev->addr == 0) return -1; - if ((tpm_dev.chip_type == SLB9635) || (tpm_dev.chip_type == UNKNOWN)) { + if ((tpm_dev->chip_type == SLB9635) || + (tpm_dev->chip_type == UNKNOWN)) { /* slb9635 protocol should work in both cases */ for (count = 0; count < MAX_COUNT; count++) { - rc = i2c_write_raw(tpm_dev.bus, tpm_dev.addr, &addr, 1); + rc = i2c_write_raw(tpm_dev->bus, tpm_dev->addr, + &addr, 1); if (rc == 0) break; /* success, break to skip sleep */
@@ -123,7 +121,7 @@ static int iic_tpm_read(uint8_t addr, uint8_t *buffer, size_t len) */ for (count = 0; count < MAX_COUNT; count++) { udelay(SLEEP_DURATION); - rc = i2c_read_raw(tpm_dev.bus, tpm_dev.addr, + rc = i2c_read_raw(tpm_dev->bus, tpm_dev->addr, buffer, len); if (rc == 0) break; /* success, break to skip sleep */ @@ -136,13 +134,13 @@ static int iic_tpm_read(uint8_t addr, uint8_t *buffer, size_t len) * retries should usually not be needed, but are kept just to * be safe on the safe side. */ - struct i2c_seg aseg = { .read = 0, .chip = tpm_dev.addr, + struct i2c_seg aseg = { .read = 0, .chip = tpm_dev->addr, .buf = &addr, .len = 1 }; - struct i2c_seg dseg = { .read = 1, .chip = tpm_dev.addr, + struct i2c_seg dseg = { .read = 1, .chip = tpm_dev->addr, .buf = buffer, .len = len }; for (count = 0; count < MAX_COUNT; count++) { - rc = i2c_transfer(tpm_dev.bus, &aseg, 1) || - i2c_transfer(tpm_dev.bus, &dseg, 1); + rc = i2c_transfer(tpm_dev->bus, &aseg, 1) || + i2c_transfer(tpm_dev->bus, &dseg, 1); if (rc == 0) break; /* break here to skip sleep */ udelay(SLEEP_DURATION); @@ -161,6 +159,7 @@ static int iic_tpm_write_generic(uint8_t addr, uint8_t *buffer, size_t len, unsigned int sleep_time, uint8_t max_count) { + struct tpm_inf_dev *tpm_dev = car_get_var_ptr(&g_tpm_dev); int rc = 0; int count;
@@ -170,14 +169,14 @@ static int iic_tpm_write_generic(uint8_t addr, uint8_t *buffer, size_t len, }
/* prepare send buffer */ - tpm_dev.buf[0] = addr; - memcpy(&(tpm_dev.buf[1]), buffer, len); + tpm_dev->buf[0] = addr; + memcpy(&(tpm_dev->buf[1]), buffer, len);
- if (tpm_dev.bus < 0) + if (tpm_dev->addr == 0) return -1; for (count = 0; count < max_count; count++) { - rc = i2c_write_raw(tpm_dev.bus, tpm_dev.addr, - tpm_dev.buf, len + 1); + rc = i2c_write_raw(tpm_dev->bus, tpm_dev->addr, + tpm_dev->buf, len + 1); if (rc == 0) break; /* success, break to skip sleep */
@@ -480,55 +479,53 @@ out_err: return -1; }
-static struct tpm_vendor_specific tpm_tis_i2c = { - .status = tpm_tis_i2c_status, - .recv = tpm_tis_i2c_recv, - .send = tpm_tis_i2c_send, - .cancel = tpm_tis_i2c_ready, - .req_complete_mask = TPM_STS_DATA_AVAIL | TPM_STS_VALID, - .req_complete_val = TPM_STS_DATA_AVAIL | TPM_STS_VALID, - .req_canceled = TPM_STS_COMMAND_READY, -}; - /* Initialization of I2C TPM */
-int tpm_vendor_init(unsigned bus, uint32_t dev_addr) +int tpm_vendor_init(struct tpm_chip *chip, unsigned bus, uint32_t dev_addr) { + struct tpm_inf_dev *tpm_dev = car_get_var_ptr(&g_tpm_dev); uint32_t vendor; - unsigned int old_addr; - struct tpm_chip *chip; - extern struct tpm_chip g_chip;
- old_addr = tpm_dev.addr; - if (dev_addr != 0) - tpm_dev.addr = dev_addr; - tpm_dev.bus = bus; + if (dev_addr == 0) { + printk(BIOS_ERR, "%s: missing device address\n", __func__); + return -1; + }
- chip = &g_chip; - memcpy(&chip->vendor, &tpm_tis_i2c, sizeof(struct tpm_vendor_specific)); + tpm_dev->bus = bus; + tpm_dev->addr = dev_addr; + + memset(&chip->vendor, 0, sizeof(struct tpm_vendor_specific)); chip->is_open = 1;
+ chip->vendor.status = &tpm_tis_i2c_status; + chip->vendor.recv = &tpm_tis_i2c_recv; + chip->vendor.send = &tpm_tis_i2c_send; + chip->vendor.cancel = &tpm_tis_i2c_ready; + chip->vendor.req_complete_mask = TPM_STS_DATA_AVAIL | TPM_STS_VALID; + chip->vendor.req_complete_val = TPM_STS_DATA_AVAIL | TPM_STS_VALID; + chip->vendor.req_canceled = TPM_STS_COMMAND_READY; + /* Disable interrupts (not supported) */ chip->vendor.irq = 0;
if (request_locality(chip, 0) != 0) - goto out_err; + return -1;
/* Read four bytes from DID_VID register */ if (iic_tpm_read(TPM_DID_VID(0), (uint8_t *)&vendor, 4) < 0) - goto out_release; + goto out_err;
if (vendor == TPM_TIS_I2C_DID_VID_9645) { - tpm_dev.chip_type = SLB9645; + tpm_dev->chip_type = SLB9645; } else if (be32_to_cpu(vendor) == TPM_TIS_I2C_DID_VID_9635) { - tpm_dev.chip_type = SLB9635; + tpm_dev->chip_type = SLB9635; } else { printk(BIOS_DEBUG, "Vendor ID 0x%08x not recognized.\n", vendor); - goto out_release; + goto out_err; }
printk(BIOS_DEBUG, "1.2 TPM (chip type %s device-id 0x%X)\n", - chip_name[tpm_dev.chip_type], vendor >> 16); + chip_name[tpm_dev->chip_type], vendor >> 16);
/* * A timeout query to TPM can be placed here. @@ -537,11 +534,8 @@ int tpm_vendor_init(unsigned bus, uint32_t dev_addr)
return 0;
-out_release: - release_locality(chip, 0, 1); - out_err: - tpm_dev.addr = old_addr; + release_locality(chip, 0, 1); return -1; }
diff --git a/src/drivers/i2c/tpm/tpm.h b/src/drivers/i2c/tpm/tpm.h index 625679d..7dfd594 100644 --- a/src/drivers/i2c/tpm/tpm.h +++ b/src/drivers/i2c/tpm/tpm.h @@ -47,9 +47,9 @@ enum tpm_timeout { struct tpm_chip;
struct tpm_vendor_specific { - const uint8_t req_complete_mask; - const uint8_t req_complete_val; - const uint8_t req_canceled; + uint8_t req_complete_mask; + uint8_t req_complete_val; + uint8_t req_canceled; int irq; int (*recv)(struct tpm_chip *, uint8_t *, size_t); int (*send)(struct tpm_chip *, uint8_t *, size_t); @@ -121,7 +121,7 @@ struct tpm_cmd_t {
/* ---------- Interface for TPM vendor ------------ */
-int tpm_vendor_init(unsigned bus, uint32_t dev_addr); +int tpm_vendor_init(struct tpm_chip *chip, unsigned bus, uint32_t dev_addr);
void tpm_vendor_cleanup(struct tpm_chip *chip);
